> CX-7 > Turbo Induction & ECU Tuning
CX-7 > Turbo Induction & ECU Tuning Have an ECU tuning issue? Do you want to discuss Mazdaspeed 3 tuning solutions? Up to date info on the latest! Piasini Reflash, Cobb Access Port, Xede, Procede, Standback, Superchips & others supported here!
Welcome to Mazdaspeed Forums
Search Forum
Like Tree14Likes
  • 2 Post By Zdraveca
  • 1 Post By Haltech
  • 2 Post By Raider
  • 1 Post By Raider
  • 2 Post By speedcig
  • 1 Post By Koke382
  • 1 Post By Zdraveca
  • 1 Post By qtrmile beast
  • 1 Post By theschrum
 Old 03-22-2013, 11:02 AM   #1
speedcig's Avatar
Posts: 8   (View Stats)
speedcig is a jewel in the roughspeedcig is a jewel in the roughspeedcig is a jewel in the roughspeedcig is a jewel in the rough
Default Bigger Turbo on CX-7
Hi
I am looking for the best bigger TURBO for my Mazda CX-7 AWD 2009 ... ATP? GT3071R, GT3076R
Help Me !!!
Thank you everybody for your answer
speedcig is offline   Reply With Quote
The Following 2 Users Say Thank You to speedcig For This Useful Post:
Payne Racing 67 (03-22-2013), Raider (03-22-2013)
The Following 3 Users Say NO Thank You to speedcig For This Un-useful Post:
captain slow (03-22-2013), faeker (03-22-2013), Vansquish (03-22-2013)
 Old 03-22-2013, 11:14 AM   #2
Zdraveca's Avatar
Posts: 3,888   (View Stats)
Groans: 145
Bnrs3 at most. The auto tranny is so weak in the cx that it simply can not support the higher hp and torque that comes with the big turbo. If you want to do it the right way do a transmission swap and get a gt 3071 and make a cayenne killer
Sent while putting train lengths on @Redline143 ;
What other mods you have?
speedcig and Redline143 like this.
2011 MS3"Princess GRU"
GT2876r
E85 FREEKTUNE
Last edited by Zdraveca; 03-22-2013 at 11:14 AM. Reason: MSF Database - Automerged Doublepost
The Following 2 Users Say Thank You to Zdraveca For This Useful Post:
speedcig (03-23-2013), Vansquish (03-22-2013)
 Old 03-22-2013, 11:28 AM   #3
Police - Grammarhead
Vansquish's Avatar
The Euro-market CX-7 was available with the MZR-DISI and a manual transmission. This is the only combination that will hold up to a 3071/3076, and even then, with the car being so much heavier than an MS6, you're asking for trouble.
Fail_6 (03-23-2013), speedcig (03-23-2013)
 Old 03-22-2013, 12:00 PM   #4
Well he could remove the valve body and have a trans shop build him a proper shift kit and modify the line pressure. That will help quite a bit.
speedcig likes this.
The Following 5 Users Say Thank You to Haltech For This Useful Post:
Bolted6 (12-18-2013), Fail_6 (03-23-2013), RhoadBlock (12-18-2013), speedcig (03-23-2013), Tenchix (03-22-2013)
 Old 03-22-2013, 12:38 PM   #5
speedcig's Avatar
SUGGEST ME WHAT YOU DO WITH THE TURBO
Thank
GT2871R or may be the same problem???
Last edited by speedcig; 03-22-2013 at 12:38 PM. Reason: MSF Database - Automerged Doublepost
 Old 03-22-2013, 12:40 PM   #6
I have seen a BT done. It is possible. Hell. CPE makes the intake, intercooler, manifold and turboback.
You will need FP internals and snag a discounted Versatune (on sale now, check their section).
Having had a CX-7 from their arrival in the USA, it is possible, the trans can indeed handle it. I would look to an external trans cooler for sure.
CX-7's are not to be downplayed for mods. When my wife had the TMIC and CAI alone, it gave it so much more power, little ricer Civics had trouble off the line.
Hawksfinebyme and speedcig like this.
speedcig (03-23-2013), Tomas (12-17-2013)
 Old 03-22-2013, 12:51 PM   #7
OLD thread
BUILT MOTOR CX7 with a 2871 turbo | MCX7 Community Forums
@qtrmile beast; here made that.
qtrmile beast (03-22-2013), speedcig (03-23-2013)
 Old 03-22-2013, 01:02 PM   #8
speedcig's Avatar
Default MY MOD
yep
i all ready have versatuner
and all this mod
Tuned with Versatuner And Tatrix cable
CORKSPORT CAI Stage II Power Series
CORKSPORT Mazdaspeed Top Mount Intercooler
CORKSPORT Boost Tubes
CORKSPORT 'Power Series' Downpipe
CORKSPORT catch can
CORKSPORT TMIC
MZR 2.3 DISI SAFEseal™ Injector Seals
Autotech High Pressure Fuel Pump Internals: MAZDASPEED 3 & Mazdaspeed 6
StreetUnit Edition Red/Silver Compact Dual Port Blow Off Valve Kit: 2.3L MZR DISI
JBR EGR Block Off Kit
JBR Balance Shaft Delete & Oil Pan Baffle Kit
SURE Torq R7 Engine Mount for CX-7: Stealth Black & Street Urethane
Defi Red Racer 52mm Boost Gauge
Raider and Zdraveca like this.
The Following 4 Users Say Thank You to speedcig For This Useful Post:
dthomas.llewellyn (11-16-2013), mazdaspeeding (03-23-2013), Raider (03-22-2013), Zdraveca (03-22-2013)
 Old 03-22-2013, 01:06 PM   #9
Koke382's Avatar
Posts: 4,361   (View Stats)
Groans: 32
id go bnrs3, good for more than 350 hp and pretty much no lagg compared to stock k04.
Sent from your Anus
2007 Mazdaspeed 3 GT
18x8.75 XXR 527 225/40/18r
New fucken miata build:
1993 Red Na6
Some suspension modz yo
Coilovers// Other shit
 Old 03-22-2013, 01:07 PM   #10
NICE work!
JBR has a new passenger mount that should fit the CX-7 too, since they share the MS6 platform. Wonder about trans mount tho.
 Old 03-22-2013, 07:36 PM   #11
Zdraveca's Avatar
Groans: 145
thats a pretty nice mod list
GT2876r
E85 FREEKTUNE
The Following User Says Thank You to Zdraveca For This Useful Post:
 Old 03-22-2013, 07:58 PM   #12
qtrmile beast's Avatar
Posts: 2,423   (View Stats)
I was going to post that i did this!!! I was also working on doing a tranny swap for it but the guy pulled out after we found out what it would cost.
track weight 3220
street weight 3370
The Following User Says Thank You to qtrmile beast For This Useful Post:
 Old 03-22-2013, 08:57 PM   #13
Zdraveca's Avatar
Groans: 145
just interested if you remember what it would cost and if it will be direct swap
GT2876r
E85 FREEKTUNE
 Old 03-22-2013, 10:28 PM   #14
no it is not a direct swap not completely. The tranny should bolt up to the engine and the mount should line up. I believe the axle (driverside may need to be custom as it is too short) There is no hole in the firewall for the shift cables i dont believe. You will have to move the E brake also. So the cost will first off be for what a tranny would cost( in the area of about 11-1500, The axle may cost you about 3-500. I can't remember the other details that needed to be changed. Shifter cables, what ever they cost, clutch about 800 you would also need to to do a custom center console for the shift cables.
track weight 3220
street weight 3370
The Following 2 Users Say Thank You to qtrmile beast For This Useful Post:
speedcig (03-23-2013), Zdraveca (03-22-2013)
 Old 03-23-2013, 10:36 AM   #15
speedcig's Avatar
No tranny for me I think I'll order the GT2871R Bolt On Turbo Kit from ATP and I'll start the test quietly without exceeding 16-18 psi I'm sure would have more LAGG
 Old 03-23-2013, 11:44 AM   #16
Zdraveca's Avatar
Groans: 145
Im sure you will like the bnr s3 better for the cx7
GT2876r
E85 FREEKTUNE
 Old 03-23-2013, 11:55 AM   #17
speedcig's Avatar
Where i can buy an find the best price ??? And see the spec ???
Thank
 Old 03-23-2013, 12:05 PM   #18
Zdraveca's Avatar
Groans: 145
Thank
Bnrsupercars.com also start fuckung searching the forums.
GT2876r
E85 FREEKTUNE
 Old 03-23-2013, 01:37 PM   #19
Redline143's Avatar
Posts: 930   (View Stats)
Redline143 is the leader of the worldRedline143 is the leader of the worldRedline143 is the leader of the worldRedline143 is the leader of the worldRedline143 is the leader of the worldRedline143 is the leader of the worldRedline143 is the leader of the worldRedline143 is the leader of the worldRedline143 is the leader of the worldRedline143 is the leader of the worldRedline143 is the leader of the world
Do they offer an S3 that works with the CX-7? Apparently the turbos are slightly different (even though they're both K04s). They won't even accept a CX-7 core for exchange, IIRC.
Redline143 is offline   Reply With Quote
 Old 03-23-2013, 02:26 PM   #20
Zdraveca's Avatar
Groans: 145
why wouldn't it work
GT2876r
E85 FREEKTUNE
 Old 03-23-2013, 02:57 PM   #21
Redline143's Avatar
As I think more about it, it very well may work. In fact, I'll bet it would, with nothing more than minor modifications (if any at all). It's just that he'd have to find a different core, otherwise he'd be charged extra because of no core exchange.
You can get a good turbo on here for cheap, though. The smokey ones are usually very cheap. I got a really good turbo for $150. It has virtually no shaft play, doesn't smoke and only has about 25k miles on it.
 Old 03-23-2013, 04:35 PM   #22
theschrum's Avatar
Posts: 1,031   (View Stats)
theschrum is the leader of the worldtheschrum is the leader of the worldtheschrum is the leader of the worldtheschrum is the leader of the worldtheschrum is the leader of the worldtheschrum is the leader of the worldtheschrum is the leader of the worldtheschrum is the leader of the worldtheschrum is the leader of the worldtheschrum is the leader of the worldtheschrum is the leader of the world
Thank
Ask EdgeAutosport or MAPerformance. Both can get it at a great price. Instead of a GT2871, go GTX2867.
for specs: http://www.atpturbo.com/root/release...e110101-1.html
06 Speed 6 GT: True twin scroll T4 PTE Billet 6262, dual MVS, SP 10.6:1 pistons, K1 rods, sleeved block...
08 Speed 3|SOLD
theschrum is offline   Reply With Quote
The Following 2 Users Say Thank You to theschrum For This Useful Post:
Jh8909 (03-23-2013), speedcig (03-23-2013)
 Old 03-23-2013, 08:56 PM   #23
torquemaniac's Avatar
Posts: 733   (View Stats)
yep
and all this mod
CORKSPORT catch can
CORKSPORT TMIC
Wow...very nice mods list
Glad to see a fellow ''Quebecois'' that does some crazy shit on a CX-7
Did you tune with Veratuner yourself...or did you go with Stratified tuning?
I got a used MS6 K04 from Darkthunder to put on my CX-7 (that shit needed a solid rebuilt...enough shaft play to rub the side of the compressor housing)...but im thinking about something bigger...BNR S3 looks appealing
How is it going with Corksport catch can...mine froze a couple of time this winter...had to empty it every 5-7 days...lots of condenastion buildup...I also got some fuel/oil odor in the car when idling with the Corksport connection setup (crank and cam breather connected to the TIP vaccum line)
2011 CX-7 AWD 2.3 turbo
 Old 03-24-2013, 08:28 PM   #24
speedcig's Avatar
I do it me and myself for versatuner and for my catch can my CX-7 sleep in the garage at 20°C empty it 3 time at this time
For the Turbo i go with GTX2867X from ATP
Sorry GTX2867R
Last edited by speedcig; 03-24-2013 at 08:28 PM. Reason: MSF Database - Automerged Doublepost
 Old 07-17-2013, 08:00 PM   #25
bklyncx7's Avatar
bklyncx7 has a little shameless behaviour in the past
Sorry GTX2867R
the versatune is it something that a Noob could try with out distroying ones car
Don From BROOKLYN N.Y.
Mazda Cx-7 2009 sure SRI. CP-E TMIC & Down pipe & test pipe and cat back, Auto tech internals SURE RMM, Forge bpv
bklyncx7 is offline   Reply With Quote
The Following User Says NO Thank You to bklyncx7 For This Un-useful Post:
faeker (07-17-2013)
 Old 07-17-2013, 08:10 PM   #26
faeker's Avatar
Posts: 5,091   (View Stats)
Groans: 731
destroying*
don't rez retarded threads
Mods: stock
 Old 12-18-2013, 03:52 AM   #27
Project_dog's Avatar
Posts: 333   (View Stats)
Project_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond repute
Groaned at 7 Times in 5 Posts
glad to see a big turbo build in a cx7.
Project_dog is offline   Reply With Quote
The Following 2 Users Say NO Thank You to Project_dog For This Un-useful Post:
faeker (12-18-2013), jk_ms3 (12-18-2013)
 Old 12-18-2013, 04:44 AM   #28
faeker's Avatar
Groans: 731
See the post above yours. Ignore the thanks. Stupid phone thought in actually enjoyed seeing your dumbass rez of a post
now with three times the hate
Mods: stock
 Old 12-18-2013, 08:23 AM   #29
jk_ms3's Avatar
Posts: 1,390   (View Stats)
Groans: 40
(I picked up the groan for you there, @faeker
Dude, what you posted is the sort of thing that you say in your head, not the sort of thing that's useful to post.
On deck: VG Sharkfin Antenna
The Following User Says Thank You to jk_ms3 For This Useful Post:
faeker (12-18-2013)
 Old 12-18-2013, 08:32 PM   #30
So just like the post you just did.
Sent from my SAMSUNG-SGH-I337 using tapatalkreplace 4
2007 Mazda CX-7: Custom FMIC, Forge V1 BPV, Grimmspeed 3 port EBC, BNR S3 turbo, 3 inch Catless DP, Muffler Delete, JBR 3.5 intake, Autotech HPFP Internals, JBR OCC, Vogland Springs. Stereo: Two Memphis 10" Subs, 2 Memphis 1.500 Amps. Memphis 4.50 Amp, Image Dynamics Components and Coaxials.
The Following User Says NO Thank You to Project_dog For This Un-useful Post:
faeker (12-18-2013)
 Old 12-18-2013, 09:16 PM   #31
faeker's Avatar
Groans: 731
no. his post was a reply to your dumb ass. don't rez threads if all you have to say is..oh gee thanks.
Mods: stock
jk_ms3 (12-18-2013), mxlplx71 (12-25-2013)
 Old 12-18-2013, 09:18 PM   #32
I really dont care.
 Old 12-25-2013, 12:21 PM   #33
JDMCRX's Avatar
Posts: 128   (View Stats)
JDMCRX has a reputation beyond reputeJDMCRX has a reputation beyond reputeJDMCRX has a reputation beyond reputeJDMCRX has a reputation beyond reputeJDMCRX has a reputation beyond reputeJDMCRX has a reputation beyond reputeJDMCRX has a reputation beyond reputeJDMCRX has a reputation beyond reputeJDMCRX has a reputation beyond reputeJDMCRX has a reputation beyond reputeJDMCRX has a reputation beyond repute
Groaned at 18 Times in 6 Posts
Anymore updates on this merry Christmas everyone !
JDMCRX is offline   Reply With Quote
 Old 12-25-2013, 12:36 PM   #34
faeker's Avatar
Groans: 731
No
Mods: stock
 Old 12-04-2017, 02:04 PM   #35
cokerduke1's Avatar
Posts: 1   (View Stats)
cokerduke1 is an unknown quantity at this point
Default Turbo replacement
Thank-you for the welcome. I have a 2010 CX-7 with turbo going bad. $2500.00 for dealership to replace. Looking for info. on better after market turbo. I'm sure there is info. in this forum, I just started looking.
cokerduke1 is offline   Reply With Quote
 Old 12-05-2017, 07:48 AM   #36
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
Any turbo option for the 3/6MPS Mazdaspeed 3/6 will also work on the CX7.
You need pretty much the same power mods, and I'm not sure if the exhaust mods will require in-house fabrication or if you find any already done. But the idea is the same:
- larger turbo (up to your choice and taste);
- hpfp internals;
- upgraded intake;
- upgraded downpipe and test pipe;
- a tuning software (Versatuner);
- ideally but not necessarily WMI.
At this stage depending on the turbo option you will be between 330 and 400 crank HP (depending on the supporting mods and software settings). I recommend not aiming for too high torque with the CX7 but for rather flattening the torque curve. 420-450Nm/310-330lb*ft below 4000rpm is where you want to be at. No problem upping the torque to 350lb*ft/475Nm in the 4000-5000rpm range.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
BIGGER TURBO MBC OR EBC ? speed6pilot MazdaSpeed 3/6 - Turbo Induction 24 02-09-2012 06:54 AM
Video: Fórmula Truck - The bigger they race, the bigger they crash Haltech Automotive News 0 08-02-2010 09:50 AM
Bigger turbo on stock internals.... SPDZRCR6 MazdaSpeed 3/6 - Turbo Induction 77 09-25-2009 01:41 PM
tuning for a bigger turbo 18psiWhiteMS3
Cobb ATR Support
7 08-27-2009 04:17 PM
New Porsche 911 Turbo gets a bigger 500 hp engine Haltech Automotive News 0 08-07-2009 09:10 AM
Page generated in 0.54538 seconds with 36 queries
