![]() Join Date: Aug 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,995
Groans: 88
Groaned at 186 Times in 83 Posts
(Thread Starter) | Not Ranked : 0 score what AP are u using specifically for Rouge Detection for Wireless Security? i have 1300's Aironets and i'm wondering if i can use them. i ahve about 200 that i would like to spread out throughout the property of 22,000 acres. |
![]() Join Date: Nov 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 39
| Not Ranked : 0 score I am assuming you're looking for rogue not rouge detection? Should work for you... Cisco IOS Software Configuration Guide for Cisco Aironet 1300 Series Outdoor Access Point/Bridge 12.3(7)JA - Configuring WDS, Fast Secure Roaming, Radio Management, and Wireless Intrusion Detection Services— [Cisco Aironet 1300 Series] - Cisco System Also wondering what you're using for a controller? You won't have rogue detection without a controller
__________________ 2006 Mazdaspeed 6 GT w/ Nav - Black Cherry Mica Cobb SRI / Cobb TIP / Cobb AP / PTP FP internals /IVT 22 / Turbosmart BPV / ETS TMIC / SURE TP / Flex-Innovations grounding kit / Stage 2 TWM SS / Corksport strut tower brace / Corksport SS Brake lines / SU Rear interior brace / SU Stiff Diff / TT Top Diff Mount / Morimoto projectors / 3000k HID Fogs |
Groans: 88
(Thread Starter) | Not Ranked : 0 score yea, i figured that much a longtime ago. i opted to go with a meru system and controller. works like a charm! |
| Not Ranked : 0 score how did you decide on Meru?
Groans: 88
(Thread Starter) | Not Ranked : 0 score we had one device laying around after we parted ways with our wireless ISP. we had this equipment left over. it is awesome because it will do rouge detections and kill unauthorized AP's |
| Not Ranked : 0 score Cisco does the same They will send de-auth messages on the same frequency and spoof the unwanted SSID to punt users off the rogue wireless. Optionally you could tie that in to your wired network (if also Cisco) to block that port completely and keep that unwanted wireless off your network. Best of luck on your deployment!
Groans: 88
(Thread Starter) | Not Ranked : 0 score we don't use Cisco. we use Avaya. but i see what you are talking about. |
| question | 06speed | MazdaSpeed 6 - Engine, Transmission & Driveline | 20 | 12-09-2011 06:11 AM |
| question about what map to use w/ ap | 11mazdaspeed3 | 2010 MS3 - ECU Computer Tuning | 6 | 05-30-2011 09:02 AM |
| Question about Used AP | Special--k | 2010 MS3 - ECU Computer Tuning | 11 | 05-20-2011 03:29 PM |
| MS6: Just did my first mod...now for a question | egbertnr | MazdaSpeed 3/6 - Car Audio & Electronics | 8 | 05-06-2009 12:05 PM |
| Hey I've Got a question | I_like_Boost | Mazdaspeed3/6 General Discussion | 11 | 04-10-2009 08:11 AM |
