Search Forum |
| ![]() | LinkBack | Thread Tools | Search this Thread | Display Modes |
![]() | ![]() | #1 | ![]() |
![]() Join Date: Aug 2018
Rep Power: 0 ![]() Thanks: 0
(Thread Starter) | ![]() ![]() ![]() Basically all steering wheel controls are inoperable/unresponsive. Occured after getting a new clutch in my 2013 speed. Is there a particular fuse or wiring harness that powers the steering controls that I cant seem to find? Any help would be appreciated. I have a 5 hour drive ahead of me and I would love some cruise lol being a bit of a noob, I cant seem to find the info I'm looking for. Thanks guys. |
![]() | ![]() | #2 | ![]() |
(Thread Starter) | ![]() ![]() ![]() I guess it will remain a mystery... |
![]() | ![]() | #3 | ![]() |
![]() Join Date: Feb 2012 Location: Li ny
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,290
Groans: 74
| ![]() ![]() ![]() Did you unplug anything by the glove box where the module is? or the radio where some of the wires go? Or the column where the wires plug into the clock spring? The controls are resistance based to ground. There is 1 wire that goes to the Bluetooth module above the glove box that attaches to the controls. If you want a responce to a thread try bumping it by saying BUMP.
__________________ MECP 2012 BM PTE 5858 Vband .82ar // Tial EWG // CPE Mani // 3" Turboback // JBR Under route hot pipe // MD ST mani+spacer with PI // Siemens 60lb Injectors // Splitsecond inj controller // JBR 88 duro RMM/TMM // MD PMM // TWM Full replacement shifter // JBR CC // Autotech FP Internals // SP63 SB/Manley rods SP63 pro pistons // Treadstone FMIC TR824 // FoMoCo Tranny Jizz // South Bend Clutch Stage 3 enduro// GFB Respons // FJ 4" intake // WMI 100% VPM1 // Air Lift 1000 in rear // N2MB WOT BOX Rfinkle tune in progress The Brooklyn beater: 2005 1.8 Auto Sentra |
![]() | ![]() | #4 | ![]() |
![]() Join Date: Apr 2016 Location: Richmond, VA
| ![]() ![]() ![]() When my battery died completely and I had to push start my car to get it to the store to buy a new battery, my steering was cutting in and out on the way. There is definitely an electrical issue there. There are two grounds on a bracket on the transmission casing which need to be disconnected to pull the transmission for a clutch swap. I'm pretty sure that one of those grounds is the ground for the hydraulic power assisted steering system. They may have forgotten to connect it or it came loose. |
![]() | ![]() | #5 | ![]() |
(Thread Starter) | ![]() ![]() ![]() I'm thinking that ground will likely be the issue. Appreciate the insight guys. |
![]() | ![]() | #6 | ![]() |
(Thread Starter) | ![]() ![]() ![]() So all the grounds are in tact. I cant seem to locate any loose wires or plugs. Pulled every fuse. Anyone know what wires go into the main harness related to this? |
Steering Wheel controls problem | chock | CX-7 > Car Audio & Electronics | 12 | 06-05-2018 03:16 AM |
how to install Double DIN and keep steering wheel controls | mlamp89 | CX-7 > Car Audio & Electronics | 8 | 06-15-2015 04:33 PM |
Steering wheel controls | Pseudonym | MazdaSpeed 3/6 - Car Audio & Electronics | 4 | 05-31-2013 11:40 PM |
Steering wheel controls pinout | nmhforlife | MazdaSpeed 3/6 - Car Audio & Electronics | 1 | 07-17-2011 11:09 PM |
can't stop, ABS/Traction Control lights, no cruise control...vacuum leak? | btstarcher | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 13 | 06-17-2011 11:06 PM |
