| EdgeAutosport.com EdgeAutosport.com is committed to being the best at what we do. High performance aftermarket parts is what we do but not who we are. We operate at the highest level of integrity and honesty, all while bringing you superior products and unmatched customer service and support. We hold ourselves to the highest standards, just like we do for our cars! Let us know how we can help! |
| Approved MSF Vendor ![]() Join Date: Sep 2011 Location: Denver Colorado
Rep Power: 5796 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,830
First of all, turbo seals may let some oil out, but that doesn't mean they are blown. There are a lot of different pressures that are involved as well as other places for oil to come from. Turbo seals are usually a piston ring style seal and they are designed to keep pressure out of the oil passages and therefore the crank case but they are not exactly designed to keep oil from getting out of the the oil passages when there is no pressure on the compressor or turbine side of the seal. When oil goes into the bearing housing, it is under pressure and mixes with air due to turbulence as it passes between the bearing and journal surfaces. Oil is brought in under pressure but it leaves via gravity. That is why the oil drain is so much bigger than the oil feed. As it drains out, it is frothy and light and anything that impedes this gravity flow will cause the frothy oil/air mixture to stay in the bearing housing. Once it rises above the level of the turbo seals it has the ability to leak into the compressor and turbine housings. However, there are other issues that can cause this besides a malfunctioning drain. Most people, when upgrading turbos, will already have a catch can but some people keep the valve cover vented into the intake. In a lot of cases that we have seen, the oil in the hot charge pipe and in the compressor come from this. As blow by gas and vapor escape the valve cover, they have no where to go but back through the turbo. A good idea if you do not already have a vented catch can is to grab one of these from the local hardware store. This breather filter will save you from venting gross blow by gasses back into your intake and turbo system. Don't forget to block off the port on the intake where the tube connects from the valve cover though because then you end up with a massive influx of un-metered air which could cause you to run lean. Walking back from there, another cause for oil to be present in your compressor housing can also be as simple as a dirty air filter. As the intake filter becomes increasingly restricted, it will cause a pressure drop. This will cause a partial vacuum at the compressor inlet during idle or low load situations. This can cause oil to be sucked from the bearing housing through the seal an into the compressor outlet. The same problem exist when your intake or filter are too small. This doesn't occur at WOT when there is ample pressure in the compressor, but only when a vacuum can be created by lack of flow to the turbo. Also, you will only see oil in the compressor outlet area if this is the root of your issue. The solution to this is simple. Just clean your air filter regularly. Also, it is a good idea to have a properly sized intake, though this is not a common problem as most people pick up a 3" or 3.5" intake before upgrading the turbo. If you are seeing oil on your turbine outlet, the cause for this is most likely an inability for the oil to drain properly from your turbo. You will need to make sure that the drain port on your turbo is pointed straight down. Also, make sure that there is no "grease trap" sag in your oil drain line and that it is as straight a shot as possible from the turbo to the port on the block. Another issue is that sometimes on steel braided lines, the line can become pinched on the the inside while the outside cover remains normal. Check and make sure there are no internal blockages. I hope this helps clear some of the blown turbo seal questions up for you guys experiencing the problem! Let me know if you have any questions or if you have anything to add, please post it up!
__________________ ![]() Click here to check out some clearance items were getting out of here! There are some great deals in here! Last edited by EdgeAutosport.com; 12-03-2014 at 11:10 AM. | |
| The Following 12 Users Say Thank You to EdgeAutosport.com For This Useful Post: | 09TrueRedGTX (12-03-2014), ASHMS3 (12-03-2014), chaser27 (12-03-2014), Hammology (12-03-2014), Hush (12-03-2014), jack_hammer (12-03-2014), mr_mazda329 (12-03-2014), Ryguy (12-03-2014), ShadowHunter117 (12-03-2014), taf0422 (12-03-2014), turboKart (12-03-2014), WetzMS3 (12-03-2014) |
![]() Join Date: Mar 2011 Location: Ramstein, Germany
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 24
| Not Ranked : 0 score Thanks for this post. I have been having these exact issues with my GTX2867r turbo kit I bought from you guys about 9 months ago. I have checked to see if oil could be coming through from my valve cover, but there is no oil in the valve cover breather hose, or the intake where the hose goes into it. One issue I read about and you also mention is the oil drain line being too long. It does seem like the drain line you supplied is a tad too long and does have a slight sag or uphill part before connecting to the drain fitting on the engine. Have you guys since offered, or is it possible for me to get a drain line that is just an inch shorter to see if this helps resolve the issue?
__________________ 2011 Black Mica MS3 Engine: HTP 3.5" Intake, HTP Small Battery Box, GTX2867R Turbo, TR6 Intercooler w/CX Racing Pipe, PNP Stock Intake Mani w/ VTC Delete, Steadspeed Exhaust Mani, CNT Catted DP, 3" Magnaflow Exhaust, Autotech HPFP Internals, JBR OCC, JBR EGR Delete, 3-bar MAP Sensor, Grimmspeed EBCS, Forge BPV V2, Stratified Tuned Handling: CS Lowering Springs, JBR Rear Swaybar, JBR PMM/TMM(70 duro) RMM(88 duro), GTSPEC Chassis Braces(Except trunk), Front Strut Tower Bar, 17x9 TRMotorsports C3 Wheels w/ 245/40ZR17 Michelin Pilot Sport A/S 3 Waiting to Install: Stratified Guardian Angel, Snow Performance Stage 2 Meth Kit w/Failsafe and Trunk Mount Tank |
| The Following User Says Thank You to ShadowHunter117 For This Useful Post: | EdgeAutosport.com (12-03-2014) |
![]() Join Date: Aug 2014
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 251
| Not Ranked : 0 score Great post Edge!
When doing my gtx3071 install, I did not even use the hose supplied and made my own from jegs parts. I was surprised at how little braided line I actually needed. | |
| The Following 3 Users Say Thank You to 09TrueRedGTX For This Useful Post: |
__________________ 2011 Black Mica MS3 Engine: HTP 3.5" Intake, HTP Small Battery Box, GTX2867R Turbo, TR6 Intercooler w/CX Racing Pipe, PNP Stock Intake Mani w/ VTC Delete, Steadspeed Exhaust Mani, CNT Catted DP, 3" Magnaflow Exhaust, Autotech HPFP Internals, JBR OCC, JBR EGR Delete, 3-bar MAP Sensor, Grimmspeed EBCS, Forge BPV V2, Stratified Tuned Handling: CS Lowering Springs, JBR Rear Swaybar, JBR PMM/TMM(70 duro) RMM(88 duro), GTSPEC Chassis Braces(Except trunk), Front Strut Tower Bar, 17x9 TRMotorsports C3 Wheels w/ 245/40ZR17 Michelin Pilot Sport A/S 3 Waiting to Install: Stratified Guardian Angel, Snow Performance Stage 2 Meth Kit w/Failsafe and Trunk Mount Tank | |
| The Following User Says Thank You to ShadowHunter117 For This Useful Post: | 09TrueRedGTX (12-03-2014) |
![]() Join Date: Feb 2011 Location: Chicago
Rep Power: 365 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 183
Groans: 74
| Not Ranked : 0 score I have a question, kind of I guess. I smell oil inside the cabin at idle. No oil in boost tubes. No blue smoke and I'm catless. I recently put this motor in and then added a k04 with a new CHRA. I would appreciate suggestions where this smell might be coming from. No oil leaks at the valve cover. I'm suspecting it might be the copper washer on the oil feed line. Does that sound reasonable? If you carry those copper washers I will probably order some, I bought a big set online and quality is terrible, a lot of burr.
__________________ 2007 TR MazdaSpeed3:Autotech FP inernals, CorkSport Turbo, TR8 Front Mount w/CX piping, JBR 3" intake, COBB EBCS, Cobb AP, Toyota Injector Seals, FR stud mod, Fidanza flywheel/LUK clutch, Forge BPV v2, cp-e xFlex stage 2 RMM, Wiseco .20 Pistons/Manley Rods/BSD, Dual DM catch cans, Koni Yellows/H&R springs, FD wheels, eBay downpipe, stock CBE 2005 Mazda 3 SP23: mods include rusty quarter panels and grinding 3rd gear. It does have a fusion motor, so I guess that's a mod too. |
![]() Join Date: Jan 2011 Location: Jacksonville, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 311
If you have already been warned of this then my apologies
__________________ 08 MazdaSpeed3 | Cobb AP | MS Intake | CS TIP | CP-E FMIC | CNT Catless TBE | ITV22 | | AutoTech Internals | TurboSmart BOV | BC Racing Coilovers | CS RMM | CS TMM | | Black Powdercoated Stockers | Built Motor | | Mahle 88mm Pistons | Manley H-Beam Rods | | |
| The Following User Says Thank You to Jtaylor For This Useful Post: | EdgeAutosport.com (12-03-2014) |
Groans: 74
| Not Ranked : 0 score Was a fresh engine oil smell?
| Not Ranked : 0 score Yeah, although it is tranny fluid it was still very strong. Burned my nostrils
| The Following 2 Users Say Thank You to Jtaylor For This Useful Post: | EdgeAutosport.com (12-03-2014), stockms3 (12-03-2014) |
The Kozmic Motorsports Oil Drain would be a good option to try as it is a bit shorter than the ATP line and more easily modified for length.
| The Following 2 Users Say Thank You to EdgeAutosport.com For This Useful Post: | ShadowHunter117 (12-03-2014), stockms3 (12-03-2014) |
Groans: 74
| Not Ranked : 0 score I had a leak on the oil pan. I pulled it and resealed it. It appears to be good so far. I didn't see or feel any oil by the flywheel. Looked at the bottom of turbo and oil drain looked dry. I will need to investigate further once the finals are over.
| The Following 2 Users Say Thank You to stockms3 For This Useful Post: | EdgeAutosport.com (12-04-2014), Jtaylor (12-04-2014) |
| Not Ranked : 0 score I would like to add that by putting a filter on the valvecover does decrease the ability of the engine to evacuate the PCV gases from the crankcase. The reason it is plumbed to the intake is so there is a vacuum pulling out these oil vapors all the time. This is how I view PCV gas evacuation in order from most preferred to least preferred: - Route valve cover line to slashcut in downpipe w/CC inline - Route valve cover line to intake w/CC inline - Put filter on valve cover The slashcut is the most effective IMO because it always pulls a vacuum on the crankcase like the intake would, but no oil gets into the intake tract. I'm not saying that a filter is harmful but if you're going to step up to a bigger turbo and run lots of boost (30+ psi) then the amount of PCV gases will increase and the need to effectively vent these gases becomes greater. There are other options too, such as running a second port off of the PCV plate like the Perm one, or using a vented oil fill cap like the SP63 one. Both allow more PCV gases to escape.
| The Following 2 Users Say Thank You to Mazdazilla6 For This Useful Post: | EdgeAutosport.com (12-04-2014), Tyhackman15 (12-04-2014) |
![]() Join Date: Sep 2012 Location: Milwaukee, WI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 644
__________________ SOLD 2008 MS3 17x8 Evo 9's, 235 v12 1995 Miata 1.8L w/ FMII GT2560R @11psi, FM stage 2 clutch/flywheel, FM Frame rail braces, FM high capacity radiator/fans, RB Sway bars, Racing beat exhaust, Fat cat Coilovers, Jongbloed 15x9, Wilwood 4 wheel BBK, Rollbar, Hardtop, TDR Racing seat 2001 Saab 9-3 Viggen 2.3T Stage 3+ bro, SRI, 3" DP, ETS FMIC, 17x8 BBS RK2's, Full chassis bracing / sway bars, Forge BPV, Winter/DD | |
(Thread Starter) | Not Ranked : 0 score This is where running a perm plate in conjunction with a vented can and a non vented can comes in. |
| Possible bad turbo seals or no? | coopsspeed | MazdaSpeed 3/6 - Turbo Induction | 5 | 11-25-2014 02:43 PM |
| Blown Injector Seals on K04? | bean59 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 10 | 10-28-2013 09:38 PM |
| Turbo seals went | joey | MazdaSpeed 3/6 - Turbo Induction | 6 | 08-31-2012 01:52 AM |
| Blown injector seals | Voltwings | 2010 MS3 - ECU Computer Tuning | 20 | 08-16-2012 01:39 PM |
| Blow by or Seals blown? | Zai_MS3 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 3 | 10-08-2011 02:05 AM |
