| MazdaSpeed 3 - Engine, Transmission & Driveline Discussion of engine, tranny and drivelines. |
| The Following User Says Thank You to For This Useful Post: | SpeedSixxx (12-10-2009) |
![]() Join Date: Aug 2008 Location: Puyallup, WA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 127
Groaned at 6 Times in 2 Posts
| Not Ranked : 0 score PTperformance they are working great for me. |
![]() Join Date: Mar 2008 Location: Navarre, FL
Rep Power: 4956 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,585
Groans: 370
| Not Ranked : 0 score i have all 3 streetunit ones....awesome |
| Lurkers
Posts: n/a
![]() Join Date: Aug 2009 Location: Albany, OR
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 867
Groans: 39
| Not Ranked : 0 score The tranny mount is under the battery box bolts right up like factory. I have the trz tranny and rear mount. Some strong vibes but you get used to em |
| ILL3ST ![]() Join Date: Jun 2008 Location: Ann Arbor, MI
Rep Power: 1317 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,292
Groans: 105
| Not Ranked : 0 score waiting waiting waiting for cp-e's |
![]() Join Date: Nov 2008 Location: Merrimack, New Hampshire
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 134
| Not Ranked : 0 score i have the 75 duro cp-e rear motor mount and still get a lot of wheel hop going into 2nd gear
__________________ cp-e Cold Air Intake cp-e Rear Motor Mount Turbosmart bypass valve SU shifter bushings |
![]() Join Date: Aug 2008 Location: Red Deer, AB
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,362
| Not Ranked : 0 score i haz the SU mounts. rear mount always, side mounts to go to the track. OEM fitment, i can change both side mounts in just over an hour with a socket set and a torque wrench. the battery box bolts to a plate that sits on top of the tranny mount. fits fine with the SU mount
__________________ |
Groans: 356
| Not Ranked : 0 score i hear medieval has some pretty beefy ones
| The Following 3 Users Say Thank You to rodrigo For This Useful Post: |
![]() Join Date: May 2009 Location: Tallmadge, OH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 208
Groaned at 8 Times in 5 Posts
| Not Ranked : 0 score I've noticed you're going to have wheelhop regardless of the mounts. Some will make it seem gone for a little bit, but as soon as the mount breaks in, wheelhop will come back. What CP-e RMM did for me (60 duro) was made those 5500-6000rpm shift much more smoother and quicker. It made the gear really click as you rush it in third or fourth and so on. I recommend cp-e, but I doubt that any mm's alone will completely eliminate wheelhop.
__________________ ::: Cobb AP ::: HTP 3" Full Intake ::: Ebay DP ::: CNT CBE ::: JBR Triology ::: JBR SSP ::: JBR RSB ::: CS TMIC ::: MSD Dashhawk ::: White PC RX-8 Wheels wrapped in Continental DWS 225-40-18 ::: ::: DIZZY TUNED by Boost_creep ::: |
Groans: 78
| Not Ranked : 0 score save yourself the money and just get the TRZ tranny mount. im a huge fanboi of it. the initial vibes are a bit rough, but they soften up. the performance benefit is huge, you really will feel a substantial difference. the fitment is just like stock, you dont have to re-arrange anything to make it fit, bolts right up. the SU mounts are awesome and all, but thats too much money for me when the trz is simple and effective for much less.
| Banned ![]() Join Date: Jun 2008 Location: northern nj
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 350
| Not Ranked : 0 score I have the trz passenger side mount it works really well but makes the tranny sound loud, and vibes r pretty strong,im thinking about changing to the street unit mounte just the sides and leave the trz rear mount |
| patrick failman ![]() Join Date: Mar 2009
Rep Power: 2905 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,275
Groans: 74
| Not Ranked : 0 score trz tranny ftw.
__________________ 2012 ingot silver mustang gt w/ 6 speed, 3.73 rear end, bama 93 tune, cat deletes, boss 302 oil cooler, roush cai, dynotech aluminum driveshaft, ford racing strut tower brace, dampers & springs, boss 302 sway bars, gt500 strut mounts, lower control arms & axle backs, j&m adjustable panhard bar, steeda upper control arm & 3 point braces, jlt catch can, barton short shifter & shift bracket |
![]() Join Date: Aug 2008 Location: jersey
Rep Power: 609 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 388
| Not Ranked : 0 score i would wait for cpe nothing out right now is all that impressive |
| Alittle Faster ![]() ![]() Join Date: May 2008 Location: Cape Coral, FL
Rep Power: 6078 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,006
| Not Ranked : 0 score Been waiting on CP-E for like what feels like 1 year, probably has been a year already lol. And one of their main guys has left them and no updates on their mounts have been heard for a long while now. My statement along time ago still stands "that CP-E' TMM will be turned 90*, like the PTP TMM". ![]() So anyone got any news on them?!?!?!?! |
![]() Join Date: May 2009 Location: Browns Mills/NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 739
| Not Ranked : 0 score I would recommend the ptp kicker to compliment whichever other mounts you do decide to get. Ive never heard anything negative about the trz combo, which is what ill be getting soon. If your worried about vibs go with the topspeed mounts they are as close to stock as you can get.
__________________ A Kabar is just a paper weight until it's in the hand of a Marine. If a Marine can't fight it, f@#k it, or eat it, he's going to destroy it and burn it to the ground. COBB SRI | COBB TURBO INLET | TURBOSMART BPV | APEXI TT | SAIKOU MICHI STAGE II OCC | DENSO ITV22 PLUGS | MSD DASHHAWK | SU SHIFTER BUSHINGS | JBARONE SSP | SPEEDLINE HEATED CONVEX MIRRORS | CLEAR SIDEMARKERS | 5000K 35W D2S BULBS | 3000K 35W HID FOG LIGHTS | 6000K REVERSE LIGHT HID KIT | RALLY ARMOR URETHANE MUD FLAPS | PROGRESS TECHNOLOGY RSB | TRZ RMM | GRIMMSPEED EBCS NATOR PA |
Groans: 370
| Not Ranked : 0 score i dunno, doesnt seem like many have the SU ones but i think they are great... I have not gotten wheelhop once since I put them in. Vibes are there, but its not bad w/ 900 rpm idle. |
![]() Join Date: Sep 2009 Location: Austin, Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 289
Groans: 40
| Not Ranked : 0 score I got AWR's Rear MM and Trans , looking to get the rest soon. |
| Lurkers
Posts: n/a
| whatsthe link for AWR?> |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 145
| Not Ranked : 0 score They make a PMM, RMM and TMM for the speed 6 but only the RMM for a speed 3. Your best bet is the TRZ trans mount in addition to your rear with an engine torque damper. The vibrations arent all that bad, and if youre going to bolt it up to be a racer, support the motor.
__________________ All wagon, No traction |
| Engine mounts? | Mcopping | MazdaSpeed 3 - How-To's | 45 | 06-10-2010 06:03 PM |
| TRZ TM and SU engine mounts | ms3boost | MazdaSpeed 6 - Engine, Transmission & Driveline | 2 | 03-27-2009 07:56 PM |
| SU Side Engine Mounts Completed & Installed | Grim | MazdaSpeed 3 - Engine, Transmission & Driveline | 22 | 10-30-2008 02:29 PM |
