| MazdaSpeed 3 - Engine, Transmission & Driveline Discussion of engine, tranny and drivelines. |
![]() Join Date: Mar 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 16
(Thread Starter) | Not Ranked : 0 score i was wondering what is all need to do a built motor? -pistons -rods -arp head studs? what gaskets are needed and is there any bearings needed?
__________________ 2008 TR MS3 Sport[/B]:Cobb Sri,AP/Corksport Dp/Vibrant Dp Back/Pg HF CDFP/SU Boost Tubes/TRZ Poly MM/TWM STS, Shifter bushings/DashHawk/Turbosmart DualPort BOV/15,35% Tints/AutoExe Shift Knob/ Redline Shifter,E-brake Boot Future Mods[/B] auter Rods/CP pistons/PTP SST K04/PG Tubular Manifold EWG/Turbo XS Dp/Cobb TIP/HKS Plugs/Perrin OCC/Devils Own WM Injection/BC Racing Coilovers/Hotchkis H&R Sway Bars/Rotora F&R slotted Rotors/EBC Red stuff Pads/Goodridge Stainless Brake Lines/ACT Street clutch and flywheel/Cobb FMIC/Tial 38mm v-band and screamer pipe/SU Side Mounts/8000k HIDs/PTP BS delete,WT/rx8 wheels/samco silicone hoses/235-40-18 Falken Azenis RT-615/P&L Motorsports ATP or ATR tune we will see though although 350whp is the goal! |
![]() Join Date: Mar 2008 Location: Victoria TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 405
Groans: 70
| Not Ranked : 0 score yes you will need main and rod bearings.you might as well get a full gasket set.
__________________ Black 2003 Evo VIII-3in TBE,HKS 280's,ETS Intake,Halman pro MBC,Forge BOV,Precision 6262,4" Intercooler,AEM Meth injection,Manely S&R's.4G63 FTW! |
![]() Join Date: Mar 2008 Location: west palm beach, fl
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 70
| Not Ranked : 0 score ill sell you my whole kit brand new |
| NEC ![]() Join Date: Mar 2008
Rep Power: 472 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 129
| Not Ranked : 0 score Clutch. Do the clutch while the engine is out of the car. With a built motor you're gonna want a clutch and its a 45 minute job with the engine removed vs. an 8 hour job with the engine still in.
__________________ 2006 Lotus Elise: Toy car 1999 B4000: DD / Parts hauler / SC Project 2007 Mazdaspeed 3: *sold* 2005 Corolla XRS: *sold* |
(Thread Starter) | Not Ranked : 0 score dont worry i had another thread about that made and would be doing it at the same time
![]() Join Date: Jul 2008
Rep Power: 1790 ![]() Thanks: 2,239
Groans: 62
Groaned at 156 Times in 148 Posts
| Not Ranked : 0 score Rods Pistons Rod/Main bearings & thrust washer ARP main and head studs Clutch/Flywheel Flywheel Bolts Crank pulley bolt Full gasket set I stock all of these on a regular basis. |
| The Following User Says Thank You to MarkyMark For This Useful Post: | phillyb (05-26-2009) |
![]() Join Date: Mar 2008 Location: STL, MO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,984
| Not Ranked : 0 score Don't forget machine work. |
| Not Ranked : 0 score FWIW I don't think shon did any machinework on his motor, but when I asked him what he would have done differently he said he would have done it instead of skipping it.
![]() Join Date: Jun 2008 Location: NW Indiana
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 361
| Not Ranked : 0 score Do the machine work...If your not going to do it right then dont do it at all.Your going to want to bore it .020 over also just to get rid of mazda crappy machine work they done to the car.
__________________ Pauter rods,Cp pistons 9.5:1 @ .020 over,ARP head & main studs,DNP ceramic coated exhaust mani.,TXS Dp,TXS Tp with high flow cat,PG reworked turbo,Cobb sri,Cobb fmic,Cobb Ap,Cobb inlet,HPFP,BSD,ACT street disk with light flywheel,TWM shifter bushing,rear MM,Oil CC and 1 step colder plugs and more http://videos.streetfire.net/profile/SharkDiver.htm http://www.youtube.com/user/sharkdiverjohn |
| Banned ![]() Join Date: Mar 2008 Location: On this planet (Washington)
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 436
| Not Ranked : 0 score Better yet, get a built motor with the proper parts in it all ready. Simple. Sure it will cost more, but in the long run and after the assembly time and machine shop work, your going to be just as far into it as if you would have bought one from a vendor. We will have motors for your cars here very soon, that are properly built. |
| Banned ![]() Join Date: Mar 2008 Location: Gaithersburg, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 335
| Not Ranked : 0 score I'd also consider doing any and all modifications to the engine at that time as well. For example, getting the ring gear cut off the crank prior to being balanced. Installing a windage tray, or a baffle tray. Installing a lightweight pulley prior to timing anything...clutch/flywheel. Whatever manifold you choose for the car. If you're doing cam's, now's the time! Valve jobs, etc. If your car has a lot of miles on it, I'd consider replacing the water pump, thermostat. (Heck if the car has a real lot of miles, might inspect the oil pump) Of course replace all seals, gaskets. If you have the money, I'd get a silicon radiator hose kit...why bother putting the rubber junk back on there if you don't have to....far easier to install those hoses while the engine is being put back in, then afterwords. On that point, I'd also replace all the pcv valves, and replace all vacuum lines with silicon instead of rubber. To really do it right, you want pretty much every single wear item replaced...that way you'll be good for another 100k+ miles after the rebuild. It always sucks to spend all that time, all that money replacing and rebuilding an engine, and then have some cheap ass wear item part break and have to take all this crap apart to replace it...when you could have done it at the same time in a few minutes. |
__________________ 2008 TR MS3 Sport[/B]:Cobb Sri,AP/Corksport Dp/Vibrant Dp Back/Pg HF CDFP/SU Boost Tubes/TRZ Poly MM/TWM STS, Shifter bushings/DashHawk/Turbosmart DualPort BOV/15,35% Tints/AutoExe Shift Knob/ Redline Shifter,E-brake Boot Future Mods[/B] auter Rods/CP pistons/PTP SST K04/PG Tubular Manifold EWG/Turbo XS Dp/Cobb TIP/HKS Plugs/Perrin OCC/Devils Own WM Injection/BC Racing Coilovers/Hotchkis H&R Sway Bars/Rotora F&R slotted Rotors/EBC Red stuff Pads/Goodridge Stainless Brake Lines/ACT Street clutch and flywheel/Cobb FMIC/Tial 38mm v-band and screamer pipe/SU Side Mounts/8000k HIDs/PTP BS delete,WT/rx8 wheels/samco silicone hoses/235-40-18 Falken Azenis RT-615/P&L Motorsports ATP or ATR tune we will see though although 350whp is the goal! | |
![]() ![]() Join Date: Jun 2008 Location: Greenville, SC
Rep Power: 2562 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,586
Groans: 125
i did "minimal" machine work. did not do balancing. if i were to do it again, i would do things alot different. id go all out. i would have left the compression stock.
__________________ 1994 Mazda RX7 - 20b-rew - S480sx - Injector Dynamics - Xcessive Manufacturing - Full Function Engineering - Haltech Elite 2500 | |
![]() Join Date: Apr 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
| Not Ranked : 0 score sleeves balanceshaft removal |
![]() Join Date: Jun 2008 Location: Dallas, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10
| Not Ranked : 0 score |
![]() Join Date: Mar 2008 Location: orange county
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,807
Groans: 137
| Not Ranked : 0 score damn... with me being in the shop 5 hours a day for 16 days this summer with tools and a bitchin` new engine building room, with nothing to do but "keep occupied", its kinda tempting to buy a beater and go big with the help of the instructor and a group of students. fuck me. (Danems6 currently looking on autotrader for cheap truck)
__________________ 2008 STi Intake Turboback AP |
| Catch CAn 101, this is how you build them. | ptperformance | Mazdaspeed3/6 General Discussion | 13 | 04-07-2009 11:57 PM |
| Theory: Build before Build | demonspeed | MazdaSpeed 6 - Engine, Transmission & Driveline | 5 | 02-10-2009 06:52 PM |
| Sq build | Strytnyne | MazdaSpeed 3/6 - Car Audio & Electronics | 10 | 12-18-2008 03:19 PM |
| Build-a-Bull: Automobile mag helps build the first production Lambo LP560-4 | Haltech | Automotive News | 0 | 04-01-2008 05:20 PM |
