| MazdaSpeed 3 - Engine, Transmission & Driveline Discussion of engine, tranny and drivelines. |
![]() Join Date: Mar 2014 Location: madison/LAX, WI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 96
| Not Ranked : 0 score Just put in my jbr rmm 88a today and it took me about 30min.. Stock one was shitty.lol vibes are pretty nasty right now but I'm guessing they'll get better.
__________________ SOLD 2009 CWP Speed3 Cobb Ap/AT Internals/Cobb Downpipe/Cobb SRI,TIP/TS BPV/sure shortcut/JBR 88a RMM/JBR TMM/JBR solid shifter bushings/Freektune OTS+ |
![]() Join Date: Oct 2015 Location: Hibbing, MN
Rep Power: 66 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 264
| Not Ranked : 0 score Im looking at the JBR trilogy kit, and I seen that its recommended for the 80 rmm and tmm but only a 70 pmm. Would this not cause excessive wear on the mounts because two of them are vibrating more (or something)? Also I seen that JBR posted a 10% off code a while back, is there another sale coming up for Columbus day or an actual holiday lol. |
![]() Join Date: Jun 2014 Location: Austin Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 33
| Not Ranked : 0 score Installing JBR motor mounts, the torque specs in the directions from JBR differ from the shop manual torque specs for the bolts attaching the to the motor and the frame. Should the shop manual torque specs (higher) or the JBR torque specs (lower) be followed? |
| Approved MSF Vendor ![]() Join Date: Sep 2009
Rep Power: 7118 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,203
| Not Ranked : 0 score Use the lower spec. |
| The Following User Says Thank You to JBR For This Useful Post: | HBspeed (08-11-2014) |
| Not Ranked : 0 score What about for the transmission motor mount? No torque specs are listed in the JBR directions for that one |
| Not Ranked : 0 score For ms6? Can't hardly get a torque wrench on any of the bolts. Just get them tight. |
![]() Join Date: Sep 2013
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 205
| Not Ranked : 0 score Strange, didn't have any issue getting a 14" HF 1/2" drive torque wrench on mine with a shallow 6pt craftsman socket. Car was on ramps, but would have probably been higher on a set of stands. |
![]() Join Date: Oct 2013 Location: Tallahassee, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 218
Groaned at 7 Times in 5 Posts
| Not Ranked : 0 score I thought they were when I installed mine. Could be wrong... Maybe I used the oem spec.
__________________ JP |
| The Following User Says Thank You to Jap11g For This Useful Post: | HBspeed (08-11-2014) |
| Not Ranked : 0 score Thank y'all, installed, running great! |
![]() Join Date: Feb 2009 Location: Tampa, Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 503
| Not Ranked : 0 score Sooooooo, I have been driving the car with a TRZ TMM, JBR PMM, and The RMM I put on years ago, can't remember the brand its a one piece proly the medieval. I checked it once awhile ago when I felt clunks shifting hard and it was tight and intact (shoulda checked PMM,haha) so, with the current setup, feels great from a perfomance aspect, and the vibes are there, for sure, but I am ok with the tactile vibes, not a driving issue The NOISE, however is a deal breaker. Its horrendous intrudes on conversation, the stereo, masks other car sounds which are important to be aware of. Its gotta go. I'm going to try leaving the JBR in and putting the OEM TMM back in place as a test since my oem PMM is blown and the TMM appears intact. if that largely corrects the noise (which is the engine vibes inducing something to vibrate in the midbass range, dashparts, firewall???) then I guess I leave it , or find another TMM, or mod the TRZ ( TMM fairly simple, PMM fairly techy. has anyone else tried to chase down the source of the noise, and muffled it ?? added Dynamat etc?
__________________ A democracy, in its purest form, is well represented by a group consisting of 2 wolves and 1 rabbit. Voting on what to have for lunch |
| Not Ranked : 0 score I had mad vibes. TRZ trans mount bushing after 40-50k was wore. JBR went in, vibes and sound settled. I would pull the rear. Swap anything midevil. |
| Not Ranked : 0 score right on dunno for sure the RMM brand, its the one that had the rep for bad welds back in the day. mine was a wednesday unit Duno how many miles on the TMM, looks newish, but with a small, hard bushing
![]() Join Date: Sep 2011 Location: Cape Town, South Africa
Rep Power: 237 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 90
| Not Ranked : 0 score Genpu MMs: • JBR RMM 88 & unknown durometer • CP-E RMM Stage 2 • JBR TMM unknown • CorkSport RMM • JBR PMM unknown • JBR RMM 80 • Sure RMM TorqR3 WARNING: read http://www.mazdaspeedforum.org/forum/foru...3/#post1927730 • JBR PMM 80 • JBR RMM 70 • Cobb RMM • CorkSport TMM • Damond Motorsports RMM • JBR PMM 70 & 88 • CP-E TMM • TRZ RMM • CorkSport PMM • Street Unit RMM WARNING: read http://www.mazdaspeedforum.org/forum/foru...3/#post1927730 • Ford Electric Focus RMM (RMM part number CM5Z-6068-A; bolt W500545S900) • Minerva PMM & TMM (probably best to avoid, see Minerva Motorwerkz? ) • Sure PMM & TMM WARNING: read http://www.mazdaspeedforum.org/forum/foru...3/#post1927730 • AWR RMM 88 • Torque Solution RMM • Turbine Tech Front Engine Mount • Turbine Tech Differential Mount Update using 2015 prices: JBR RMM Urethane MS6 MS3 Available from: MS6 JBR RMM Urethane MS6 MS3 JBR RMM Urethane MS3 MS6 (Yes: 80a $105), MS3 1st Gen (Yes: 88a $100, 80a $125, 70a $125), MS3 2nd Gen (Yes: 88a $100, 80a $125, 70a $125) CP-E RMM Stage 2 Rubber MS6 MS3 Available from: MS6 CP-E RMM Stage 2 Rubber MS6 MS3 CP-E RMM Stage 2 Rubber MS3 MS6 (Yes: 70a xFlex) $139, MS3 1st Gen (Not found), MS3 2nd Gen (Yes) $198 JBR TMM Urethane MS6 MS3 Available from: MS6 JBR TMM Urethane MS6 MS3 JBR TMM Urethane MS3 MS6 (Yes: 80a, 70a) $175, MS3 1st Gen (Yes: 88a, 80a, 70a) $185, MS3 2nd Gen (Yes: 88a, 80a, 70a) $185 CorkSport RMM Urethane MS6's Insert MS6's Full Replacement MS3's Insert MS3's Full Replacement MS3's Race Available from: MS6 CorkSport RMM Urethane MS6 MS3 CorkSport RMM Urethane MS3 Gen1 CorkSport RMM Urethane MS3 Gen2 MS6 (Yes, Standard 70a) $115.99, MS3 1st Gen (Yes: Insert 70a $39.99, Standard 80a $99.99, Race 80a $125.99), MS3 2nd Gen (Yes: Insert 70a $39.99, Standard 80a $99.99, Race 80a $125.99) JBR PMM Urethane MS6 MS3 Available from: MS6 JBR PMM Urethane MS6 MS3 JBR PMM Urethane MS3 MS6 (Yes: 80a, 70a) $175, MS3 1st Gen (Yes: 80a, 70a) $185, MS3 2nd Gen (Yes: 80a, 70a) $185 Cobb RMM Available from: Cobb RMM MS3 MS6 (Not found), MS3 1st Gen (Yes) $159, MS3 2nd Gen (Yes) $159 CorkSport TMM Insert Polyurethane MS6 MS3 Available from: MS6 CorkSport TMM Insert Polyurethane MS6 MS3 CorkSport TMM Insert Polyurethane MS3 MS6 (Yes) $54.99, MS3 1st Gen (Yes), MS3 2nd Gen (Yes) $39.99 Damond Motorsports RMM Available from: Damond Motorsports RMM MS3 MS6 (Not found), MS3 1st Gen (Yes), MS3 2nd Gen (Yes) $145 in black or gold mount and black or red bushing CP-E TMM Available from: CP-E TMM MS3 MS6 (Not found), MS3 1st Gen (Yes, 75a) $271.30, MS3 2nd Gen (Yes, 75a) $271.30 TRZ RMM Available from: TRZ RMM MS3 MS6 (Not found), MS3 1st Gen (Yes), MS3 2nd Gen (Yes) $100 CorkSport PMM Available from: CorkSport PMM MS3 MS6 (Not found), MS3 1st Gen (Yes), MS3 2nd Gen (Yes) $229.99 Ford Electric Focus RMM (RMM part number CM5Z-6068-A; bolt W500545S900) Available from: local Ford dealership MS6 (Not confirmed), MS3 1st Gen (Yes), MS3 2nd Gen (Yes) $43.92 + $1.10 AWR RMM Urethane MS6 MS3 Available from: MS6 AWR RMM Urethane MS6 MS3 AWR RMM Urethane MS3 MS6 (Yes: 95a, 80a, 70a) $82, MS3 1st Gen (Yes: 95a, 80a, 70a) $95, MS3 2nd Gen (Yes: 95a, 80a, 70a) $95 AWR PMM Urethane MS6 MS3 Available from: MS6 AWR PMM Urethane MS6 MS3 AWR PMM Urethane MS3 MS6 (Yes: 95a, 80a, 70a) $172, MS3 1st Gen (Yes: 95a, 80a, 70a) $172, MS3 2nd Gen (Yes: 95a, 80a, 70a) $172 AWR TMM Urethane MS6 MS3 Available from: MS6 AWR TMM Urethane MS6 MS3 AWR TMM Urethane MS3 MS6 (Yes: 95a, 80a, 70a) $140, MS3 1st Gen (Yes: 95a, 80a, 70a) $225, MS3 2nd Gen (Yes: 95a, 80a, 70a) $225 Torque Solution RMM Polyurethane Available from: Torque Solution RMM Polyurethane MS3 MS6 (Not found), MS3 1st Gen (Yes, 75a) $134.99, MS3 2nd Gen (Yes, 75a) $134.99 TRZ TMM Available from: TRZ TMM MS3 MS6 (Not found), MS3 1st Gen (Yes), MS3 2nd Gen (Yes) $100 Damond Motorsports PMM Available from: Damond Motorsports PMM MS3 MS6 (Not found), MS3 1st Gen (Yes), MS3 2nd Gen (Yes) $225 in black or gold mount and black or red bushing Turbine Tech Front Engine Mount MS6 MS3 Gen 1 MS3 Gen 2 Available from: MS6 Turbine Tech Front Engine Mount MS6 MS3 Gen 1 Turbine Tech Front Engine Mount MS3 Gen 1 MS3 Gen 2 Turbine Tech Front Engine Mount MS3 Gen 2 MS6 (Yes) $359, MS3 1st Gen (Yes) $399, MS3 2nd Gen (Yes) $379 Turbine Tech Differential Mount Available from: Turbine Tech Differential Mount MS6 MS6 (Yes) $289, MS3 1st Gen (Not found), MS3 2nd Gen (Not found)
__________________ MS3 Gen2: AT: HPFP Int; Cobb: AP V3/ATR; CS: SRI/TIP, Catless DP; DIY: Air-box; GS: EBCS; Hankook: V12; NGK: 1 step cooler; OTC: EGR Del, OCC with VTA, PCV Plate, TP Coolant Bypass Last edited by Inquisitive; 02-10-2015 at 04:38 AM. Reason: Fixed broken JBR TMM MS3 image, separated DM PMM |
| The Following 2 Users Say Thank You to Inquisitive For This Useful Post: | Gorky_Park (08-03-2015), tegxsi (02-02-2015) |
I like this a lot! Does anyone else have info to add? Last edited by Raider; 01-29-2015 at 06:36 AM. | |
| Not Ranked : 0 score This is GREAT! The biggest thing I can ask of you, is to update the whole OP, so I can copy and paste it all in. One thing I am seeing, is missing images. For theones missing, I am asking you go to their site and fined and link the newer image. Feel free to save and upload in your post here for permanent hosting. Protege Garage is now FJ Motorsports, but there is no PMM from PG. |
| Not Ranked : 0 score To prevent confusion, this is the Speed3 mount thread after all, you may wish to remove the bit that says "MS6 (Not found)," since most of the listed companies make mounts for the 6
| The Following User Says Thank You to TiGraySpeed6 For This Useful Post: | Raider (01-27-2015) |
Wanna split it up, all I need is 2 posts. 1 MS6. 1 MS3. | |
| Not Ranked : 0 score Just wanted to update these more accurate information... MS3: • JBR RMM 70, 80, 88 • JBR TMM 70, 80, 88 • JBR PMM 70, 80 MS6: • JBR RMM 80 • JBR TMM 70, 80 • JBR PMM 70, 80 |
| Not Ranked : 0 score I'm fine with the content being the same in both, certainly easier to copy/paste! This being the case then, let's just change my earlier comments to reflect that most of those companies make mounts or inserts for the 6, the following are easily found- CPE Speed6 Mounts- RMM - 70a Rubber - http://cp-e.com/webstore/product/maz...r-motor-mount/ Corksport Speed6 Mount & Inserts- RMM - Urethane - http://corksport.com/corksport-mazda...tor-mount.html TMM Insert - Polyurethane - http://corksport.com/corksport-2006-...nt-insert.html JBR Speed6 Mounts- http://www.jamesbaroneracing.com/sho...ath=42_213_245 RMM - 80 Urethane PMM - 80 & 70 Urethane TMM - 80 & 70 Urethane AWR Speed6 Mounts- RMM - 70, 88, 95 Urethane - http://store.awrracing.com/engine-mo...07-rear-lower/ PMM - 70, 88, 95 Urethane - http://store.awrracing.com/engine-mo...assenger-side/ TMM - 70, 88, 95 Urethane - http://store.awrracing.com/transmiss...t-mazdaspeed6/ SURE Speed6 Mounts- RMM - Urethane - http://www.suremotorsports.com/product-p/sure0547-1.htm PMM - Urethane - http://www.suremotorsports.com/product-p/sure0551-1.htm TMM - Urethane - http://www.suremotorsports.com/product-p/sure0550-1.htm Urethane listed as Street, Aggressive or Track, duro not provided
__________________ Was a Mazdaspeed6 GT #3476 TiGray slicktop Now in a BMW 135i - double the turbos, double the fun! E82.N54 2009 / BSM / A/T / Drop-in / PR CP / Berk Street / MHD / xHP 340hp / 371tq Last edited by TiGraySpeed6; 01-27-2015 at 08:00 AM. |
![]() Join Date: Oct 2011 Location: San Leandro, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 460
Groans: 87
| Not Ranked : 0 score I saw that @Inquisitive; listed the Ford Focus RMM. I'd like to contribute by adding the Ford part numbers. Electric Focus RMM: CM5Z-6068-A Bolt: W500545S900
__________________ 2018 Audi RS3 2013 CWP Mazdaspeed3 - CS Turbo 2007 Acura TSX 6MT |
| The Following User Says Thank You to tegxsi For This Useful Post: | Raider (01-28-2015) |
| Not Ranked : 0 score @Raider; I cannot update the OP, but you should be able to quote, copy and paste mine into the OP with your super-user privileges. @jbarone; Thanks for the durometer numbers. Just for clarity, it wasn’t that I didn’t know your numbers, it was that the MSF member didn’t put the numbers in their signature or personal profile. Like many vendors, you will find that I have visited many members already to get my descending ranking order. With threads like this it is often asked, “Which is the best?” This is difficult to answer as some consider best quality at any price, personal preference / bragging rights / street cred (popular brand), best value (quality at a good price), popularity (local Nator), cheapest price, etc. Like the Wiki and my other threads, this is just a list in descending Genpu purchased popularity order and not meant to be a slight upon JBR's good name. I have placed the durometer numbers in the images section. @TiGraySpeed6; Thanks for the links. Uploaded. @tegxsi; Thanks for the Ford part numbers and images.
__________________ MS3 Gen2: AT: HPFP Int; Cobb: AP V3/ATR; CS: SRI/TIP, Catless DP; DIY: Air-box; GS: EBCS; Hankook: V12; NGK: 1 step cooler; OTC: EGR Del, OCC with VTA, PCV Plate, TP Coolant Bypass Last edited by Inquisitive; 01-31-2015 at 06:48 PM. |
| The Following User Says Thank You to Inquisitive For This Useful Post: | prosper0 (12-10-2015) |
| Not Ranked : 0 score I can easily edit the post 1, no problemo. But for some reason, the new update looks to be missing a lot. TO get the details from the OP, you can choose to quote it. It will give you the details of the OP, and then you can edit as needed, then post it up all with everything from images to product links. |
| Not Ranked : 0 score @Raider; Many of the OP’s images are URL links, which are broken as that is the nature of the Internet over time. My images are embedded jpgs and should have more permanency. If by “missing a lot” you meant images and "available from" URLs in my post, that exercise is now complete. Juggling 25 images was interesting. Please let me know if I inserted any incorrectly or if anything is missing. If you meant the OP’s words, I have RhoadBlock’s quote and can add his words to my post The Motor Mount Thread as appropriate.
__________________ MS3 Gen2: AT: HPFP Int; Cobb: AP V3/ATR; CS: SRI/TIP, Catless DP; DIY: Air-box; GS: EBCS; Hankook: V12; NGK: 1 step cooler; OTC: EGR Del, OCC with VTA, PCV Plate, TP Coolant Bypass |
![]() | | #24 | ![]() |
![]() Join Date: Oct 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,795
Groans: 89
| Not Ranked : 0 score There is no TRZ PMM, only the rear motor mount and TMM. May want to update the P to a T in the description and link. Perhaps it was a simple typo after looking at all these damn mounts. |
| The Following User Says Thank You to 08.5MS3 For This Useful Post: | Inquisitive (01-29-2015) |
![]() | | #25 | ![]() |
| Not Ranked : 0 score TMM, not PMM. Fixed. |
| The Following 2 Users Say Thank You to Raider For This Useful Post: | 08.5MS3 (01-29-2015), Inquisitive (01-29-2015) |
![]() | | #26 | ![]() |
![]() Join Date: Jun 2012 Location: Wichita, KS
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 155
| Not Ranked : 0 score Was in scoping out the refresh and found Damond's PMM missing and figured I'd post up the info to add. Available from: Damond Motorsports PMM MS6 (Not found), MS3 1st Gen (Yes), MS3 2nd Gen (Yes) $225 in black or gold
__________________ '10 VRM MS3 3" JBR WP, ETS TMIC, KMD/Aviva HPFP, NGK LTR7IX, M2 TP, Grimmspeed, JBR & MD EGR delete, MD OCC, MD PMM, CPe Stg2 RMM, CS TMM insert Mazda Motorsports C/O, JBR RSB, SPC camber arms, Konig Hypergram 17x9 +40 & 200 UTQG rubber or Drag DR-49 18x8 +45, Michelin Pilot Sport A/S 3 Strive for perfection in everything. Take the best that exists and make it better. If it doesn't exist, create it. Accept nothing nearly right or good enough. Sir Henry Royce |
![]() | | #27 | ![]() |
| Not Ranked : 0 score Updated • Added JBR RMM MS3 image • JBR TMM: the unnamed image was the MS6, now named and added MS3’s image • Fixed broken JBR PMM MS6 image • Removed orphaned “$” in Cobb RMM MS6 • Added DM RMM MS6 image and price (Thanks @ibcrusn; ) • Fixed broken AWR RMM MS6 image We are now up to 30 images.
| The Following User Says Thank You to Inquisitive For This Useful Post: | TiGraySpeed6 (01-31-2015) |
![]() | | #28 | ![]() |
![]() Join Date: Feb 2015 Location: Calgary,ab
Rep Power: 0 ![]() Thanks: 1
| Not Ranked : 0 score thanks for this, very useful! I am going to have to look further into this! Last edited by Raider; 02-02-2015 at 01:23 PM. |
![]() | | #29 | ![]() |
| Not Ranked : 0 score Please, in the future limit or trim quotes- there was no need to completely repeat the original post in order to express your appreciation! Thanks, and glad you found it helpful. There @Raider; I'm being nice....
| The Following User Says Thank You to TiGraySpeed6 For This Useful Post: | Raider (02-02-2015) |
![]() | | #30 | ![]() |
| Not Ranked : 0 score Oh god I'm sorry! I don't know how that happened |
| The Following User Says Thank You to genpu007 For This Useful Post: | Raider (02-02-2015) |
![]() | | #31 | ![]() |
| Not Ranked : 0 score OP updated! Thanks, @Inquisitive;! |
![]() | | #32 | ![]() |
| Not Ranked : 0 score Uh, i just saw the Damond Motorsports RMM pic is the PMM, and no PMM in your post, @Inquisitive;. Can you update it and I can copy it up to the OP and Knowledgebase? |
| The Following User Says Thank You to Raider For This Useful Post: | Inquisitive (02-04-2015) |
![]() | | #33 | ![]() |
![]() Join Date: Feb 2014 Location: Pittsburgh, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() Thanks: 8
| Not Ranked : 0 score Ok, so for the MS6 I wanna do the 80 JBR Trilogy, the Turbine Tech FMM, Turbine Tech Front dif mount and CP-e rear dif mount. Would this be the best complete mount solution I could do for my 10 year old car to get eall the mounts up to spec?
__________________ 2006 Mazdaspeed6 GT: Autotech Fuel pump, GT3071R, Cobb AP FreakTune, 3" Custom Magnaflow Turboback Dual Exhaust, Mazdaspeeed intake/turbo inlet tube, NGK XI 1 step colder plugs, Fidanza Flywheel, EGR/VTCS Delete, Cobb EBC, Cross drilled rotors, Corksport BPV, TSW Nurburgrings, Techna-Fit SS Clutch Line |
![]() | | #34 | ![]() |
| Not Ranked : 0 score That sounds like a plan to me. Will keep it all in check! |
| The Following User Says Thank You to Raider For This Useful Post: | Douggievee (06-16-2015) |
![]() | | #35 | ![]() |
Groans: 111
| Not Ranked : 0 score Did anyone have the chance to ride either the same car or similarly modified cars with the CS Race mount with the 80DURO bushings and the Cobb RMM? I guess both do a similar job at holding the motor in place but I'm interested in the added NVH comparison. CS doesn't have the 70DURO bushings any more for their race mount and so far this was the perfect mount for me (I don't mind changing the bushings every 15-20k miles, but I mind the added NVH), so now because I'm at the last set of 70DURO I'm searching for the quietest replacement which is still on the market. Or is there a quieter option than these two (of course, also suitable for holding nearly 450 pounds of torque away from the firewall)?
![]() | | #36 | ![]() |
| The Following User Says Thank You to JBR For This Useful Post: | mituc (07-02-2015) |
![]() | | #37 | ![]() |
Groans: 111
| Not Ranked : 0 score Thank you! Everybody talks about your 80 and 88 DURO mounts so I wasn't even aware you offer a mount with better comfort even if I'm pretty familiar with your product line. Can you tell what is the diameter of the center bushings of the 70DURO mount? It looks like I really need to add the JBR 70DURO to my comparison list.
![]() | | #38 | ![]() |
| The Following User Says Thank You to JBR For This Useful Post: | mituc (07-23-2015) |
![]() | | #39 | ![]() |
Groans: 111
| Not Ranked : 0 score Ok, I decided to give the JBR 70DURO RMM a try and also purchased a set of 80DURO bushings plus another spare 70DURO. Since I had all the soft mounts in history this was the only one that was missing from my drawer. The CS race mount I have is on its last set of 70DURO bushings which are almost fresh, they have like 2k miles on them, so in case things will not go well with the JBR (which I doubt, but always possible since all comes down to a matter of taste and personal preference) I will still have a backup for a while (20k kms/12k miles or so).
![]() | | #40 | ![]() |
![]() Join Date: Jun 2015 Location: Lake in the Hills IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 69
| Not Ranked : 0 score Got a cs race mount and it's awesome. Can't beat it since it was free! Vibs are not bad at all. Actually was pretty surprised as I thought they would be more. No more missing third hopefully. The stock one had 60k and was wasted. |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f10/motor-mount-thread-100696/ | ||||
| Mazda3 Forums : The #1 Mazda 3 Forum - View Single Post - Rmm | This thread | Refback | 12-18-2015 12:05 PM | |
| Rmm - Mazda3 Forums : The #1 Mazda 3 Forum | This thread | Refback | 10-06-2015 06:35 AM | |
| Motor mount discussion - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum | This thread | Refback | 04-06-2015 07:23 PM | |
| How to: Left Side Trans Mount | This thread | Refback | 06-05-2014 09:30 AM | |
| Motor Mount Inserts vs. Rear Motor Mount Pro's n Con's | Dre | 2010 MS3 - Engine, Transmission & Driveline | 23 | 05-21-2016 08:47 AM |
| another blowing motor thread | campbell | MazdaSpeed 3 - Engine, Transmission & Driveline | 40 | 04-16-2010 08:19 PM |
| is transmission mount the same as motor mount? | spoonher | MazdaSpeed 3 - Engine, Transmission & Driveline | 10 | 08-26-2009 02:21 PM |
| weakest motor mount..? what mount takes a dump first? | Lvis | MazdaSpeed 3 - Engine, Transmission & Driveline | 29 | 03-02-2009 11:39 PM |
