| MazdaSpeed 3 - Engine, Transmission & Driveline Discussion of engine, tranny and drivelines. |
![]() Join Date: Mar 2010
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 895
(Thread Starter) | Not Ranked : 0 score edit: ok found it... http://www.napaonline.com/Search/Det...+50042+2042001 50 bucks... =/.... however...looks like you can just buy the bearing http://shop.advanceautoparts.com/web...CGRPACPTAMS___ and press out the bearin and replace it....however you cannot do this with the tensioner pulley....it is a plastic wheel and the bearing is captive in the wheel and trying to press it out will destroy it.... now....i have a quesiton about the tensioner pulley...on this forum ive seen this one http://www.usallparts.com/catalog/pr...9fd9b202165c89 being cited as the correct pulley....however on some of the other mazda forums im seeing http://www.ryderfleetproducts.com/cg...uct_detail.jsp as being the correct one......now the only difference between the two is the width between the inside flanges.....the dayco pulley is cited as being 23 mm and the duralast is 25 mm....i already have bough and installed te duralast....so i have the oem pulley...i will measure it at work and let you know.....2mm a big difference? the grooves matched up ok... Last edited by TRex; 11-14-2010 at 07:43 PM. |
![]() Join Date: Jul 2009 Location: Vancouver, BC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3
Groaned at 9 Times in 9 Posts
| Not Ranked : 0 score How's about this crazy thought: Pull the belt and see if the noise goes away. That should isolate the problem to one of the spinny bits on the outside of the engine, as opposed to the ones inside. The car will still move and drive around allright for a short while, sans PS, etc. |
(Thread Starter) | Not Ranked : 0 score wont pulling the belt and running the car fuck with timing and be kinda dangeous...it is just one belt connecting everything.... |
| Banned ![]() Join Date: Feb 2010 Location: Waste Milford North JerZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,140
Groans: 444
Groaned at 154 Times in 97 Posts
| Not Ranked : 0 score timing is done w/ a chain -- not the belt i actually did my tensioner/idler w/e the fuck it is friday night at philly's house i was about three threads away from pulling the whole assembly off when i saw a tiny little pebbly stuck in the grooves of the pulley itself take off your belt and check to see if any debris has gotten up in there and in any grooves on the pulleys as soon as i removed that, the sound magically disappeared and i saved myself $65 |
(Thread Starter) | Not Ranked : 0 score well i had the belt off since i did replace the pulley (i didnt buy the whole assembly just the wheel) so any debris caught there should have come loose if nothing can be harmed by running without the belt then i will just try that and see if it is indeed the idler or VVT |
Groans: 444
| Not Ranked : 0 score no no no -- there was a little rock that was actually STUCK inside the groove of the pulley -- check your other pulley wheels to see if there are any rocks in there this thing was a BITCH to try and get out of the groove |
(Thread Starter) | Not Ranked : 0 score ah, ic...yea no rocks in the old pulley (sitting on my desk)..so i dont know...there was noticeable side play in the pulley before i took it off...the new one has 0...i think im going to pull the belt...see if there is any side play in the idler...and then run it and see if it is VVT |
Groans: 444
| Not Ranked : 0 score yeah -- when you have the belt off, check the other pulleys as well for rocks or anyhting odd post back and let us know whats up |
(Thread Starter) | Not Ranked : 0 score mini update...ran out to grab a pizza tonight and rattle come on and was quite loud just sitting at idle...when i gave it some gas i went away....left off...no rattle...blip the throttle rattle for a second then gone....no rattle while driving...minor while idling...not thinking it is VVt since it seems that noise changes with RPM...still planning on pulling belts...will update on saturday |
| Not Ranked : 0 score Does it come and go with any dependency of the clutch pedal (depressed vs engaged)? |
(Thread Starter) | Not Ranked : 0 score nope its not the throw out bearing...i threw that one out first...only comes at the initial application of gas (gone once rpms rise) or when i apply minor load to the engine (steer while sitting still or have the AC on)...all of this points to something with the belts |
(Thread Starter) | Not Ranked : 0 score look what i found Duralast/Idler Pulley (231144) | Idler Pulley | 2009 Mazda Mazdaspeed3 4 Cylinders L 2.3L DI Turbo DOHC | AutoZone.com cheap alternative to the 50 dollar napa one....going to pull mine and measure them both up...looking at the two websites though the dimensions are the same....however...the napa and oem idler pulley are metal...where as this one is plastic...worth a shot though... i am also going to verify whether or not the duralast or dayco tensioner pulley should be used as they have slightly different dimensions (per website duralast 25mm wide dayco 23 mm wide...per measurement oem 23 mm wide) |
| [MSF STIG] ![]() Join Date: Apr 2008 Location: Gloucester, VA
Rep Power: 2121 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,476
Also, if you pull off the serp belt, the water pump isn't turning so you can't just "drive it around".
__________________ `07 Speed6 Sport Tit Gray Sleeper Express... SOLD `11 Ducati 1198SP SBK Duc Red w/Termi exh; Redline flash-tune + PC-5; Sargent; Shift-tech, CDT, & EVR Carbon; 14F/39R gear w/FBF QC; Speedymoto; R&G; ProGrip; Custom LED; Antigravity; Ducabike; Duc Perf, etc... a 182whp/105wtq The BIG DOG `12 Ducati 1100SP EVO Hyper Duc CORSE w/Termi exh; Redline flash-tune + PC-5; Ducshop Hyperstacks; 14F/41R gear w/FBF QC; Shift-tech, CDT, & BST(wheels) Carbon; R&G; ProGrip; Antigravity; Ducabike; Duc Perf, etc... a 95whp/75wtq The Hooligan `12 Aprilia RSV4 "Factory" SBK w/Akra Tit exh & race map; 15/42 gear; R&G; ProGrip; Gilles; CompWerkes; LightWerkes; Lightech; LSL Pegs; Antigravity; Zero Gravity; AF1 Flat Carbon, etc... the 181whp/83wtq The Land Rocket `17 Ford Focus RS Nitrous Blue w/Cobb V3/AT; OZ Ultraleggera; Schroth harness The Super Fun Toy | |
(Thread Starter) | Not Ranked : 0 score hpfp? that is a new one...per dashhawk my fuel delievery looks ok...any other symptoms that may be about?..it isnt a ticking....it is a rattle....huh...guess ill just pull the belt and rev a bit and see if it is there... also it isnt constant...this morning i didnt hear it at all...last night i heard it very clearly |
(Thread Starter) | Not Ranked : 0 score rattle kind of cured... ok replaced my idler.....stock pulley had TONS of sideplay...replaced it with this Duralast/Idler Pulley (231144)...it is a plasic pulley however...oem is metal...but the only one that sells a metal replacement is napa...for 50 bucks...fuck that...the plastic one was 15.....so yea...put it on...no more side play...fired that bitch up.....and........................very very very minor rattle....not nearly as loud as before.......and now...it doesnt go up with intial rpms like the old rattle.....so now im not sure...i looked at the VVT...chain is tight...no wear marks inside the case.....maybe i have a heat shield loose....regardless i confirmed a cheaper alternative to the napa part....which is a good thing... so in conclusion if you want to replace your pulleys on the cheap duralast 231015 (ribbed) tensioner duralast 231144 (smooth) idler will work |
| The Following 3 Users Say Thank You to TRex For This Useful Post: |
![]() Join Date: Jun 2008 Location: lancaster, ca
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,297
Groans: 91
| Not Ranked : 0 score good to see theres a cheaper alternative i got the 50 assembly and damn bolt on the tensioner is a 15mm not 14mm like stock this was from gates purchased at kragen
__________________ "Go find your own enterprise, and get the fuck off my bridge!" 2008 Speed 3 GT- Cobb SRI, Cobb TIP, AQ Motorsports DP (Turboxs Adapter Plate), TurboXS FMIC, GReddy CBE, GReddy BPV, 3P Flange, GReddy TT, GReddy Boost Gauge, Vent Pod, GReddy Shift Knob, SU Shifter Bushings, AWR RMM, Cobb RSB, Cobb AP, Cobb Shifter Weight, Autotech FP Internals, Corksport Exhaust Hangers. "parked hard" 1996 200sx SE-R- Injen CAI, GReddy SP CBE, Tein Basic Coilovers, Progress FSB, Clutch Masters Flywheel, Progress RSB, Cusco FSTB, Progress LCAB, Prothane MM, JWT POP Program, JWT S4 Cams, Mishimoto Radiator, GoodRidge SS Brake Lines, Powerslot Rotors, Nismo CF Shift Knob. "back in action" |
(Thread Starter) | Not Ranked : 0 score yea...im considering getting the bolt on tensioner next....i drove a round a bit...the rattle is still there...but not nearly as bad...it is pissig me off that i cant pin it down...i am trying my hardest not to believe it is teh VVt.... |
| Banned ![]() Join Date: Apr 2009 Location: Misery
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 19,148
Groans: 546
Groaned at 125 Times in 71 Posts
| Not Ranked : 0 score Welcome to the speed! |
(Thread Starter) | Not Ranked : 0 score did you have vvt issues sellers? |
| Not Ranked : 0 score Why don't you record a good video/sound clip and we can tell you what it is????
Groans: 546
| Not Ranked : 0 score Yeah, I think I hear what you're talking about. Sounds like the timing chain tensioner to me. The tensioner is a known problem area. The dealers are changing them out if under warranty. The tensioner is spring loaded and the spring gets weak and will let the chain go slack. Sometimes they fail completely and you get the chain hitting the cover, etc. Sounds like yours is just getting a bit weaker and allowing the chain to go slack when the revs stsrt up, then it catches up.
![]() | | #24 | ![]() |
(Thread Starter) | Not Ranked : 0 score yea..thats what im afraid of...i think im going to go ahead an put the old pullies back on and stock out and head to the dealership |
![]() | | #25 | ![]() |
![]() Join Date: Aug 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 194
| Not Ranked : 0 score how difficult of a job is it to replace the chain tensioner?
__________________ 2008 MS3 Forge BPV, COBB SRI, AP ATR Stg 2+SF v107 FMIC, RPMC turbo inlet, Exhaust Depot DP, CP-E CBE, KMD internals, TT, DH, OF conversion, TRZ Poly mount, Exhaust Depot FMIC,TWM ss w/bushings, ITV22, AIS meth injection |
![]() | | #26 | ![]() |
(Thread Starter) | Not Ranked : 0 score not sure...but i sure as hell am not going to pull off the cover while im still under warranty...the pulleys took like 20 min (after getting the car in the air) |
![]() | | #27 | ![]() |
(Thread Starter) | Not Ranked : 0 score Rattle cured dealership replaced the tensioner assembly (they said the spring was weak and it was bouncing tight loose tight loose causing the rattle) what does this mean? it seems the pulleys may not be to blame for the rattle issue... |
| The Following 5 Users Say Thank You to TRex For This Useful Post: | Broxer (10-02-2011), FORZDA 1 (12-08-2010), jwilkins88 (12-08-2010), kgb (12-09-2010), MPSdriver (12-10-2010) |
![]() | | #28 | ![]() |
| Banned ![]() Join Date: Nov 2010 Location: Valley Park, Missouri
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 26,461
Groans: 126
| Not Ranked : 0 score Dude... If you need any help putting your mods back on, hit me up. NATOR MO is always open for business |
![]() | | #29 | ![]() |
(Thread Starter) | Not Ranked : 0 score got em on last night as soon as i pulled in the drive way (simple shit...SRI and TP)...but thanks for the offer...ill hit you up when i go FMIC and what not o and just to be clear as i was rereading the comments...it wasn't the chain tensioner...it was the belt tensioner assembly |
| The Following User Says Thank You to TRex For This Useful Post: | FORZDA 1 (12-09-2010) |
![]() | | #30 | ![]() |
Rep Power: 0 ![]() Thanks: 0
What do you mean by belt tensioner assembly, what belt? What parts does this assembly include? | |
![]() | | #31 | ![]() |
![]() Join Date: Oct 2008 Location: Greenbackville, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,927
| Not Ranked : 0 score So for clarity it was BELT tensioner not timing chain related? I had my pulley tensioner go out at 25k when i was only mildly modified (intake,rmm,cbe) dealer replaced mine no problems..
__________________ CP-E HPFpump™ CP-E 3" SS Cat Back Exhaust System CP-E 3" SS Downpipe System CP-E Rear Engine Mount CP-E XcelNANO™ Air Intake CP-E Nviscid™ Pipe CP-E Triple Gauge Pod Cobb AccessPORTv2 Cobb Anti Sway Bar(rear) Corksport TMIC PERM TUNED Forge bpv Eibach ProKit Prosport Wideband AFR Boost Oil Temp Oil Pressure JBR Shift Knob SunTek CarbonXP 30% around 2002 Mazda Protege5:AEM sri KYB gr2's DDM hid RIP |
![]() | | #32 | ![]() |
(Thread Starter) | Not Ranked : 0 score correct it was BELT tensioner that was replaced...nothing to do with chain unfortunately it seems the rattle is NOT coming from the play in the pulley wheel (as i replaced those myself and still had the rattle) it was coming from the assembly itself |
![]() | | #33 | ![]() |
![]() Join Date: May 2009 Location: N Las Vegas, NV
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 523
Groans: 77
| Not Ranked : 0 score sorry for the bump but any alternatives besides going to the dealer? anything i can buy from the auto parts store?
__________________ 2008.5 MAZDASPEED3 GT TRUE RED ***GONE*** ![]() 2012 FORD MUSTANG GT >>> 400A Premium _ Performance White _ 6MT _ 3.73 _ HID & Security Pkg Koni Yellows _ Whiteline FSB & RSB _ FRPP K-Springs w/ Bump Stops, Boss 302 Strut Tower Brace, GT500 Strut Mounts, GT500 RCA, GT500-style AB J&M PHB _ Eibach Camber Bolts _ Avant Garde M510 Satin Silver 19x9.5 40ET _ Hankook Ventus S1 noble2 275/40/19 |
![]() | | #34 | ![]() |
Groans: 77
https://www.dmauto.com/web/dmauto/Ca...mfg/NBH/38408/
__________________ 2008.5 MAZDASPEED3 GT TRUE RED ***GONE*** ![]() 2012 FORD MUSTANG GT >>> 400A Premium _ Performance White _ 6MT _ 3.73 _ HID & Security Pkg Koni Yellows _ Whiteline FSB & RSB _ FRPP K-Springs w/ Bump Stops, Boss 302 Strut Tower Brace, GT500 Strut Mounts, GT500 RCA, GT500-style AB J&M PHB _ Eibach Camber Bolts _ Avant Garde M510 Satin Silver 19x9.5 40ET _ Hankook Ventus S1 noble2 275/40/19 | |
![]() | | #35 | ![]() |
(Thread Starter) | Not Ranked : 0 score ^haha yea that is the only alternative for the entire assembly also look in my original post there is a NAPA part # but the link no worky any more...but yea that part looks to be the same |
![]() | | #36 | ![]() |
![]() Join Date: Oct 2009 Location: Denver, CO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 47
| Not Ranked : 0 score I changed my belt tensioner assembly and still have the rattle. So my next step was to open the oil cap (When the engine was cold) to see if my chain had tension on it. Since I was able to basically lift the chain off of the sprocket, I now know the source of the rattle.
__________________ 2007 Cosmic Blue Mazdaspeed 3 GT |
| Transmission Cured | FreeFlyFreak | MazdaSpeed 3 - Engine, Transmission & Driveline | 305 | 11-08-2017 08:36 AM |
| Dash rattle | turd burglar | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 12 | 03-27-2011 03:21 AM |
| Engine rattle | Speedee3 | MazdaSpeed 3 - Engine, Transmission & Driveline | 2 | 04-07-2010 04:59 PM |
| HKS exhaust rattle | himynameisevan | MazdaSpeed 3 - Engine, Transmission & Driveline | 2 | 04-05-2010 09:59 PM |
| rattle trap | Baseballpler | Mazdaspeed3/6 General Discussion | 9 | 02-01-2009 04:44 PM |
