| MazdaSpeed 3 - Engine, Transmission & Driveline Discussion of engine, tranny and drivelines. |
![]() | | #81 | ![]() |
![]() Join Date: Oct 2008 Location: Las Vegas, NV
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 23,548
Groans: 30
| Not Ranked : 0 score
__________________ 2008 GT MS3 - 307 WHP/338 WTQ ATP GTX2867R - HTP 3" Intake - Cobb FMIC pipes + Treadstone TR8L - Cobb Catted Turboback - Cobb XLE BPV - Denso ITV22 plugs - Corksport Injector Seals - KMD HPFP - Cobb AP - CP-E RMM - Southbend Stage 3 Enduro Clutch/Flywheel - Bilstein B8s + Swift Springs - SPC Rear Camber Arms - Hotchkis RSB - MD OCC Kit - Enkei RPF1 - Bridgestone Potenza S-04 235/40/18 1995 Miata Dunlop Direzza Star Specs 185/60/14 - Koyo 37mm radiator - NAPA blank rotors - StopTech Street Performance pads - 949 Racing XIDA CS Coilovers - IL Motorsports suspension bushings - Racing Beat FSB - 949 Endlinks |
![]() | | #82 | ![]() |
![]() Join Date: Jul 2008 Location: Virginia
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 563
| Not Ranked : 0 score Mine hasn't got better yet.. I have other issues though. Amsoil and mt90 was smoother than this. IMHO
__________________ ![]() 2006 MAZDASPEED6 ![]() FREEKTUNED @ 20PSI // COBB AP V3 // CPE TMIC // COBB SF // PG TIH // DENSO ITV22s // AUTOTECH INTERNALS // SURE TP // MAGNAFLOW CATBACK // JBR OCC // JBR IM SPACER // JBR PASSENGER & TRANNY MOUNT // SURE RMM // H&R SPRINGS // XXR 530 18X8.75 +35 // CAR LED TAILS // CPE REAR DIF MOUNT // TURBINE TECH FRONT DIF MOUNT // CPE TOW HOOK // 35% TINT // 3M DINOC WRAPPED ROOF // AUTOEXE CARBON FIBER BADGELESS GRILL |
| The Following User Says Thank You to Qwik6 For This Useful Post: | dizzin9 (02-22-2010) |
![]() | | #83 | ![]() |
![]() Join Date: Dec 2009 Location: Fontucky, California
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,096
Groans: 1,364
Groaned at 589 Times in 386 Posts
| Not Ranked : 0 score Theres always THAT ONE. |
![]() | | #84 | ![]() |
![]() Join Date: Aug 2008 Location: Medford, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 625
| Not Ranked : 0 score After a day or so driving with this stuff in the tranny, I'd have to say it's noticably better than MT-90 as far as the knotchy, hard to get into gear problem when it's cold. As far as normal shifting goes, there doesn't seem to be too much better tha MT-90. Ironically enough, the "wah wah wah" noise when turning the wheel hard left or right at slow speeds is gone with this fluid, which is nice.
__________________ 08.5 CWP MS3 - Cobb AP *Stage 2* ATR with a street tune - JBR Power Path Stage II Short Ram Intake - Corksport TMIC - Corksport Downpipe (w/OE midpipe) - PTP HPFP - Stock BPV - TWM SS w/bushings - CP-e RMM - Bilstein Sports w/OE springs - TSW Nurburgring Machined 18x8.5 Wheels - FIREHAWK INDY 500 - SIZE: 235/40R18 - Cobb RSB - Motorcraft XT-M5-QS in the tranny! |
![]() | | #85 | ![]() |
![]() Join Date: Aug 2009 Location: Kingwood, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,102
Groans: 50
| Not Ranked : 0 score Really!?!? I didn't even HAVE that noise until I put this shit in! WTF FAIL! |
![]() | | #86 | ![]() |
![]() Join Date: Sep 2008 Location: Tallahassee, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 61
I've been fine with the stock fluid for the first 30K. No grinding and shifts smooth for me. Gonna pick up three qts. of 75W-90 GL-4 dino oil from Napa next week - $13.86 total. Hopefully it'll work well. If not, then I'll try the Ford juice. Just don't see the need for it if the stock fluid works well enough for me. But we shall see | |
![]() | | #87 | ![]() |
![]() Join Date: Apr 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 303
Groans: 113
Groaned at 91 Times in 89 Posts
__________________ '07 MS3 GT - CS SRI - CS TIP - TP - CP-E RMM - JBR SSP - E4 Knob - Amsoil MTG | |
| The Following User Says NO Thank You to BolvangaR For This Un-useful Post: |
![]() | | #88 | ![]() |
![]() Join Date: Feb 2010 Location: Gahanna OH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
| Not Ranked : 0 score definite improvement over the OEM fluid, make sure you add the LSD additive to supplement the stock LSD.
__________________ |
![]() | | #89 | ![]() |
![]() Join Date: May 2009 Location: Browns Mills/NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 739
| Not Ranked : 0 score you have a part number on the lsd additive?
__________________ A Kabar is just a paper weight until it's in the hand of a Marine. If a Marine can't fight it, f@#k it, or eat it, he's going to destroy it and burn it to the ground. COBB SRI | COBB TURBO INLET | TURBOSMART BPV | APEXI TT | SAIKOU MICHI STAGE II OCC | DENSO ITV22 PLUGS | MSD DASHHAWK | SU SHIFTER BUSHINGS | JBARONE SSP | SPEEDLINE HEATED CONVEX MIRRORS | CLEAR SIDEMARKERS | 5000K 35W D2S BULBS | 3000K 35W HID FOG LIGHTS | 6000K REVERSE LIGHT HID KIT | RALLY ARMOR URETHANE MUD FLAPS | PROGRESS TECHNOLOGY RSB | TRZ RMM | GRIMMSPEED EBCS NATOR PA |
![]() | | #90 | ![]() |
![]() Join Date: May 2009 Location: N Las Vegas, NV
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 523
Groans: 77
| Not Ranked : 0 score this crap feels the same as stock. amsoil mtg is better.
__________________ 2008.5 MAZDASPEED3 GT TRUE RED ***GONE*** ![]() 2012 FORD MUSTANG GT >>> 400A Premium _ Performance White _ 6MT _ 3.73 _ HID & Security Pkg Koni Yellows _ Whiteline FSB & RSB _ FRPP K-Springs w/ Bump Stops, Boss 302 Strut Tower Brace, GT500 Strut Mounts, GT500 RCA, GT500-style AB J&M PHB _ Eibach Camber Bolts _ Avant Garde M510 Satin Silver 19x9.5 40ET _ Hankook Ventus S1 noble2 275/40/19 |
| The Following User Says Thank You to dizzin9 For This Useful Post: | Qwik6 (02-24-2010) |
![]() | | #91 | ![]() |
Groans: 113
| Not Ranked : 0 score So who actually used the friction modifier and who didn't?
![]() | | #92 | ![]() |
| Banned ![]() Join Date: Jun 2008 Location: northern nj
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 350
| Not Ranked : 0 score my 2 gear pops out when driving this really sucks and im trying to sell the car,i really dont wana get a new trans |
![]() | | #93 | ![]() |
| Not Ranked : 0 score what fluid you using? do you have a short shifter?
![]() | | #94 | ![]() |
| Not Ranked : 0 score I did not use friction modifier with this fluid and it works just fine. Gear noise is down and shifting is noticeably smoother.
![]() | | #95 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 546
| Not Ranked : 0 score So after having this fluid for almost a month, im still getting a 2nd gear clunk. its not as buttery as when i first put it in. I also have a AWR RMM. All the other gears are smooth, but going into 2nd still has a slight grind to it.
__________________ 2008 Cosmic Blue Mazdaspeed3 1986 Mazda RX7 2002.5 Sunlightsilver Protege5 (sold 12/26/09) Hey you should read this: http://www.mazdaspeedforum.org/forum/foru...ler-you-58361/ |
![]() | | #96 | ![]() |
Groans: 77
| Not Ranked : 0 score throw it away and get amsoil mtg. regardless, 2nd gear is really a bitch. just be careful with it.
![]() | | #97 | ![]() |
![]() Join Date: Dec 2009 Location: camas valley
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,720
Groans: 40
| Not Ranked : 0 score i added the lsd additive to oil that already had some in it and made it shift a lot better but lost my lsd so i dumped and went back to Mobil synthetic with the additive in it. hope it starts working. to much additive is bad my Mazda tech said heed rebuild it if needed warantee ya!! reason for adding the additive was the lsd was grabby after he rebuilt my trans, live with grabby
__________________ BT T3 .5557 @25 psi 10. 6:1 peformance3 pistons, manley rods arp 625+ rod bolts, arp L19 head studs, Ap, 4'' inlet rr mani 4'' custom inlet, ,2.5'' ic piping, treadstone intercooler tr10 , turbosmart bov , tail 44mm wg, cobb electronic boost control 1 3/4 screamer p, odyssey batt, cs racepipe, custom 3'' dp 80mm cat back 80mm, egr del, vcts del, and port matched,sure tig's, running 100% meth 2000 cc, ATC 6 puck sl fw 472 hp 461tq virtual dyno and ran out of fuel! nishan said theirs a easy 550 in the setup if i had the fuel but meh... 54,000 miles big turbo! stock block at 104000 2 bent rods current miles 113000 and runs perfect! no hiccups! tuned by nishan |
![]() | | #98 | ![]() |
![]() Join Date: Sep 2009 Location: CREVE COUER, MO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 263
Groans: 75
| Not Ranked : 0 score ive got about 200 miles on this stuff now and boy does it work great...the shit i drained out was a pretty good amount thicker than it, im very happy with the change. |
![]() | | #99 | ![]() |
Groans: 113
Sometimes when I shift gears, it's a perfect "click" but most of the times it feels like I'm pushing through mush... like 2-4 little "clicks" before it goes into gear. Not grinding, there is not harsh noise, but it's not a nice in and out feeling. I have the aluminum shifter bushing and that is all, but I'm not talking about "racing" style shifts, just good ol' regular, soft shifting. WTF? I seriously hate this tranny. Will a better fluid help with this?
| The Following User Says Thank You to BolvangaR For This Useful Post: | revin-it02 (01-09-2014) |
![]() | | #100 | ![]() |
Groans: 113
| The Following User Says Thank You to BolvangaR For This Useful Post: | the_caruch (03-26-2010) |
![]() | | #101 | ![]() |
![]() Join Date: Dec 2008 Location: Kannapolis NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 77
| Not Ranked : 0 score You guys using Amsoil, are you using MTF or MTG? |
![]() | | #102 | ![]() |
Groans: 77
| Not Ranked : 0 score MTG, get it i swear by this!
![]() | | #103 | ![]() |
Groans: 50
| Not Ranked : 0 score Where can one buy the Amsoil mtg??? |
![]() | | #104 | ![]() |
| Not Ranked : 0 score |
![]() | | #105 | ![]() |
Groans: 77
| Not Ranked : 0 score i've used mtg and that other stuff (motorcraft) and without a doubt amsoil is better.
![]() | | #106 | ![]() |
Groans: 50
| Not Ranked : 0 score Yeah, I've had this motorcraft stuff in for almost 3000 miles...it's not living up to my expectations. It feels about the same as stock (maybe mildly improved) but it causes my trans and lsd to WHINE like crazy. It's getting annoying, and I'm thinking about switching to the Amsoil. Edit: anyone know the exact part number for this stuff?? |
![]() | | #107 | ![]() |
Groans: 77
| Not Ranked : 0 score look into the transmission fluid section of amsoil's website. it's the piss colored one.
![]() | | #108 | ![]() |
![]() Join Date: Mar 2010 Location: New Eagle, PA
Rep Power: 2281 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,142
Groans: 324
| Not Ranked : 0 score Just to chime in on all the complaints about LSD noise, you have to add the Ford friction modifier when doing the change. This fluid doesn't have any and the stock fluid did. :edit: Found this on BITOG that could be of concern: http://www.bobistheoilguy.com/forums...47#Post1278047 "That fluid, XT-M5-QS, is not GL4. It says it is suitable where GL4 is specified. It is made by Castrol and is not available in the US under the Castrol label. Ford specifies it for use in the Contour / Mystique / Cougar / Focus MTX75 5 speed manual transaxle. It is very nearly a 10W40 synthetic motor oil but with a very high TBN. Last I knew, Royal Purple cataloged their 10W40 synthetic motor oil as their recommended replacement although many Contour owners use Royal Purple's manual transmission oil instead. XT-M5-QS works especially well in the MTX75 transaxle, but I would be reluctant to use it in other transmissions. It's additive package falls way short of that of other gear oils." |
![]() | | #109 | ![]() |
| Not Ranked : 0 score Interesting... You would think there would be some sort of warning on the bottle, maybe being more specific to its intended application then. But hell, we used to use a concocktion of GM Syncromesh, Redline, and 75w90 dino in our early WRX's. To make them shift smooth. |
![]() | | #110 | ![]() |
| The Kamikaze King! ![]() Join Date: Jun 2008
Rep Power: 1829 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,794
Groans: 754
http://www.opieoils.co.uk/p-739-cast...productDetails "Castrol SMX-S can be recommended for most manual transmissions where API GL1-4 lubricants are required. It has been used successfully as a problem solver in the manual transmissions of a number of manufacturers. SAE 75W-85 API GL1-4"
__________________ BB code url is no longer allowed.........so..... http://www.fuelly.com/driver/FreeFlyFreak/speed-3 http://www.fuelly.com/driver/FreeFlyFreak/speed-3 Suspension: OEM --> FSD 4040 --> FSD 4040 with cut stops --> MS Coils --> FSD 4045's --> FSD4045 with cut stops --> Bilstein Sports Yes, that is me in the avatar. Last edited by FreeFlyFreak; 03-20-2010 at 07:07 PM. | ||
![]() | | #111 | ![]() |
| Not Ranked : 0 score I'm not trying to poke holes in anybodys theory. But how can we be sure the Castrol SMX-S is actually whats in the Motorcraft XT-M5-QS. Because all I am seeing is hear say on those forums. In either direction with the stuff. |
![]() | | #112 | ![]() |
Groans: 754
(Thread Starter) | Neutral : -1 score
Mazda Forums - View Single Post 35 - For those that have LSD noise after switching to MT90 Mazda Forums - View Single Post 40 - For those that have LSD noise after switching to MT90
__________________ BB code url is no longer allowed.........so..... http://www.fuelly.com/driver/FreeFlyFreak/speed-3 http://www.fuelly.com/driver/FreeFlyFreak/speed-3 Suspension: OEM --> FSD 4040 --> FSD 4040 with cut stops --> MS Coils --> FSD 4045's --> FSD4045 with cut stops --> Bilstein Sports Yes, that is me in the avatar. | |
| The Following 2 Users Say Thank You to FreeFlyFreak For This Useful Post: | cld12pk2go (03-21-2010), HutcHJC (06-24-2010) |
![]() | | #113 | ![]() |
Groans: 754
But it is reported that that Motorcraft oil is made by Castrol. The motorcraft oil was made for trannies that have shifting problems. The Castrol SMX-S "has been used successfully as a problem solver in the manual transmissions of a number of manufacturers." So the theory is that the Motorcraft stuff is repackaged Castrol SMX-S. The only way to prove it would be an oil analysis of both. Is it the same?.......Personally...... I dont care either way. It solved my problem, which was caused by the Mazda/Subie dealer putting some crap in there that made the shifting get worse and worse and worse when they replaced one of my drive shafts. My guess they put some Subie GL-5 stuff in there that was screwing up the syncros. EDIT: after a little more searching it is definitely not exactly the same, because the viscosity is different. The Motorcraft is 75/90 and the Castrol is 75/85
__________________ BB code url is no longer allowed.........so..... http://www.fuelly.com/driver/FreeFlyFreak/speed-3 http://www.fuelly.com/driver/FreeFlyFreak/speed-3 Suspension: OEM --> FSD 4040 --> FSD 4040 with cut stops --> MS Coils --> FSD 4045's --> FSD4045 with cut stops --> Bilstein Sports Yes, that is me in the avatar. Last edited by FreeFlyFreak; 03-20-2010 at 07:10 PM. | |
![]() | | #114 | ![]() |
Groans: 324
| Not Ranked : 0 score My main concern is whether or not it's good long-term. Also, if the trans is identical between Gen1 and Gen2 beyond ratios, then it would stand to reason that any lower-viscosity fluid would do the trick and this just happened to be the first someone tried. I've emailed Mazda asking them about all this to see what input, if any, they'll have. |
![]() | | #115 | ![]() |
Seriously good luck getting a legitimate response back. They are probably going to tell you theres nothing wrong with the car, just the driver.
__________________ A Kabar is just a paper weight until it's in the hand of a Marine. If a Marine can't fight it, f@#k it, or eat it, he's going to destroy it and burn it to the ground. COBB SRI | COBB TURBO INLET | TURBOSMART BPV | APEXI TT | SAIKOU MICHI STAGE II OCC | DENSO ITV22 PLUGS | MSD DASHHAWK | SU SHIFTER BUSHINGS | JBARONE SSP | SPEEDLINE HEATED CONVEX MIRRORS | CLEAR SIDEMARKERS | 5000K 35W D2S BULBS | 3000K 35W HID FOG LIGHTS | 6000K REVERSE LIGHT HID KIT | RALLY ARMOR URETHANE MUD FLAPS | PROGRESS TECHNOLOGY RSB | TRZ RMM | GRIMMSPEED EBCS NATOR PA | |
![]() | | #116 | ![]() |
| Banned ![]() Join Date: Mar 2008 Location: Winter springs
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,251
Groans: 974
Groaned at 738 Times in 373 Posts
| Not Ranked : 0 score Shit I bought this Ford motorcraft stuff but now I'm not so sure I even want to use it. It seems like people are getting better results with Amsoil which is that I used to begin with (it’s good but I think it’s time for another change because I’m at around 47k miles). I guess I’ll try to sell the Ford motorcraft fluid and buy some more Amsoil. |
![]() | | #117 | ![]() |
![]() Join Date: Feb 2010 Location: Ft lauderdale FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 373
| Not Ranked : 0 score i dont have any problems getting into gears but i have 60k miles and im hearing the diff noise (wah wah wah).what would you guys recommend i use to quiet it down? id like to pick it up on my lunch break tomorrow the amsoil mtg? |
![]() | | #118 | ![]() |
Groans: 324
| Not Ranked : 0 score Until further evidence supports the Motorcraft stuff is any better, I'd definitely go Amsoil. |
![]() | | #119 | ![]() |
Groans: 113
EDIT: Finally replaced whatever was in my tranny and now the "wah wah" is much louder. Before, I could barely hear it and not very often. Now, it's very noticeable. Transmission seems to be more notchy, but not in a bad way. I haven't had more than a couple minutes driving with it, but so far I don't really see an improvement... it's just different.
__________________ '07 MS3 GT - CS SRI - CS TIP - TP - CP-E RMM - JBR SSP - E4 Knob - Amsoil MTG Last edited by BolvangaR; 03-25-2010 at 03:03 PM. | |
![]() | | #120 | ![]() |
Groans: 324
They also informed me that Mazda makes the transmission themselves. After calling them out, they told me to ask the dealership. (hah.) They then sent me to MazdaTechInfo.com. They said to use what's in the manual. *facepalm* | |
| Transmission Oil Change - How Often? | cheez | 2010 MS3 - Engine, Transmission & Driveline | 18 | 10-14-2009 01:12 AM |
| transmission | AK-speeder | MazdaSpeed 3 - Engine, Transmission & Driveline | 6 | 08-24-2009 09:44 PM |
