 Old 05-25-2012, 09:47 AM   #1
soulefx's Avatar
Posts: 30   (View Stats)
soulefx will become famous soon enoughsoulefx will become famous soon enough
Default Clutch master and slave cylinder repacement questions
Ok, so the time has come to replace my clutch master and slave cylinders. I've been having problems with my clutch, and after reading through the forums, it seems that its either the master or slave cylinder thats starting to fail, so since its been suggested that both get replaced at the same time, thats my next project. But one thing i couldnt find much info on is which brand to go with. is ther a brand thats better than the rest, or are they all about the same?
These are some of the options that i'm looking at:
Pep Boys: LuK Original Master cylinder, Dorman slave cylinder
Autozone: Duralast Master cylinder
AdvanceAutoparts: Perfection Clutch Technovation Master and Slave cylinders
Rock Auto: Exedy, Rhinopac, Beck/Arnley, Wagner Master cylinder, (didnt see the slave cylinder in their catalog)
Is ther any one brand thats better than the rest or are they all about the same?
is there any brands that i should avoid?
Are there any other brands i didnt list that are better than these?
Also, is there any special procedure for bleeding the master cylinder? I found a howto for bleeding the the slave cylinder and it seems pretty straightforward. Once i install both master and slave cylinder, will following the procedure for bleeding the slave cylinder bleed the master cylinder as well, or are there additional steps i need to take to bleed the master?
soulefx is offline   Reply With Quote
 Old 05-25-2012, 09:53 AM   #2
trf5000's Avatar
Posts: 2,290   (View Stats)
Online Mazda Parts
Don't mess around and go OEM. This place is the best place for OEM mazda parts.
2010 MS3 - Sold
2015 CX-5 GT AWD - Current
 Old 05-25-2012, 10:05 AM   #3
We can also get you an act clutch.
trf5000 (05-25-2012)
 Old 05-25-2012, 10:45 AM   #4
soulefx's Avatar
thx, but I got the act street clutch installed last year after my clutch failed on me.
The Following User Says Thank You to soulefx For This Useful Post:
EdgeAutosport.com (05-25-2012)
 Old 05-25-2012, 10:54 AM   #5
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
The pepboys luk/dorman combo is likely the oem manufacturers but I doubt its a oem quality part, generally parts sold to oems are higher quality than those sold to pepboys etc.
Ide stay far away from the rest.
Napa brand parts are generally fairly high quality as well.
2006 Mazdaspeed 6
 Old 05-25-2012, 11:27 AM   #6
soulefx's Avatar
if you have a speed3 then most likely its your slave cylinder. buy the newest rev from the dealer and you should be good. ive never heard of a master blowing out on this car in the last 5 years
Its a speed6. Were there revisions for the speed6 slave cylinder as well? If so, do you know what the latest revision is?
I guess i should just suck it up and pay the extra for an OEM replacement?
 Old 05-25-2012, 10:46 AM   #7
We also carry spec if you want one of those. We do have OEM stuff also if you want to go that route
Eric
 Old 05-25-2012, 02:33 PM   #8
soulefx's Avatar
Eric
Hey Eric, How much are you selling the OEM clutch master and slave cylinder for?
 Old 05-25-2012, 10:56 AM   #9
06Speed6 (05-25-2012), Boosted Beluga (05-25-2012), helmetface (09-21-2012), mtnrunner (09-20-2012)
 Old 05-25-2012, 11:43 AM   #10
Boosted Beluga's Avatar
Posts: 4,859   (View Stats)
Groans: 50
The og slave cylinder was made of plastic and with the heavy duty clutch it will brake after awhile. This happened to me. The new upgraded slave cylinder is made of metal.
The master cylinder I would say yes spend the extra money.
08 Mazdaspeed 3
Fucking FREEK TUNED and shit
 Old 05-25-2012, 02:54 PM   #11
I<3Groceries's Avatar
Posts: 1,990   (View Stats)
I have replaced both and swapped in a braided hose as well, just recently. I agree the issue is more than likely the slave. But don't overlook the master. They may not "blow", but its seal can wear out after so long, just like anything else. Might as well do it, just for good measure. Honestly, I don't see why you don't just rebuild them both. Mazda sells rebuild kits. And they are cheap. You can pull the master, rebuild it and reinstall in 30 minutes. Slave is even easier.
 Old 09-03-2012, 03:41 PM   #12
I had no idea the new clutch cylinder is made of metal. Do the GenPu's have a metal one too?
 Old 09-19-2012, 11:14 PM   #13
Mfinlay04's Avatar
Posts: 827   (View Stats)
total noob showing on this one, anyone have a diy or know where i can find instructions on how to rebuild these bitches. I think mine are bad, as my clutch pedal is "dynamic". If I drive out of boost the clutch engagement point is roughly the same. As soon as I go WOT the next shift the clutch engagement is totally different, and is at the top of the pedal, vs middle or bottom on every other shift. Not to mention the grinding has been getting worse as of late.
 Old 09-20-2012, 05:57 AM   #14
jm211's Avatar
Posts: 943   (View Stats)
Whats wrong with a rebuild kit?
Its a 1/5 of the price and you maintain the OEM casing. You are just replacing the springs and o-rings.
TiGrayspeed6 did his a little while ago and so far it has been strong. He may..may have posted a how-to on 6forums but not sure.
 Old 09-20-2012, 06:06 AM   #15
v8 convert
p057's Avatar
Posts: 1,782   (View Stats)
p057 has disabled reputation
Groans: 220
I dont think anyone is poo-pooing rebuild kit..
however, just like @Mfinlay04 , I'd like to know where a DIY is.
p057 is offline   Reply With Quote
 Old 09-20-2012, 11:00 AM   #16
Mfinlay04's Avatar
I'm just confused on the master cylinder as I know our brake and clutch share the same reservoir. So is the clutch master cylinder connected to the brake master cylinder? I know where the slave cylinder is as that is where i bled my clutch fluid at and easily accessable
 Old 09-20-2012, 12:10 PM   #17
No, they are housed separately. I guess you know where the brake master is. Well, the clutch master is nearby, attached to the firewall, just in front on the clutch pedal. When you press the clutch, a little rod protrudes forward, and into a little piston on the clutch master. Anyway, it is easy as balls to rebuild. Both the master cylinders really don't need a walk through. It is more difficult getting them off of the car than it is to rebuild them.
 Old 09-21-2012, 02:28 PM   #18
Mfinlay04's Avatar
Thanks I need to install my ebcs soon so when I'm installing that I'll locate the master cylinder.
2006 MS6 Titanium Grey
Tuned with
 Old 01-30-2014, 05:05 PM   #19
ROLANDO's Avatar
Posts: 7   (View Stats)
ROLANDO can only hope to improve
Groaned at 7 Times in 1 Post
Okay I have a problem. Replaced my slave cylinder last week with a brand new OEM cylinder. Car drove fine for a week, no leaks, no mushy pedal, then I had sudden clutch failure in a drive thru line. All of a sudden cylinder is hemorrhaging fluid from where the hydraulic line goes in, and my clutch won't even attempt to engage. Weird thing is there's still full pressure on the pedal. And before you ask, yes I put the gasket back in when I replaced it. Lost it and took forever finding it when I replaced it, so I'm positive it's in. Any ideas?
No matter where you go, there you are.
__________________________________
'08 MS3 Cosmic Blue Mica, Fujita F5 CAI, SURE RMM, JBR SSB, Bilstein Sport shocks and struts
ROLANDO is offline   Reply With Quote
 Old 02-25-2014, 02:09 PM   #20
Esteban123toro's Avatar
Posts: 245   (View Stats)
Esteban123toro is the leader of the worldEsteban123toro is the leader of the worldEsteban123toro is the leader of the worldEsteban123toro is the leader of the worldEsteban123toro is the leader of the worldEsteban123toro is the leader of the worldEsteban123toro is the leader of the worldEsteban123toro is the leader of the worldEsteban123toro is the leader of the worldEsteban123toro is the leader of the worldEsteban123toro is the leader of the world
Groaned at 6 Times in 4 Posts
So today on my way home i was driving normally when i was about to shift something swallowed my clutch lol.. I haven't see a slave cylinder how to on the forums if anyone can sent me a link please i need to do this ASAP thanks
Esteban123toro is offline   Reply With Quote
 Old 02-25-2014, 02:36 PM   #21
mtosofsky's Avatar
Posts: 543   (View Stats)
mtosofsky is the leader of the worldmtosofsky is the leader of the worldmtosofsky is the leader of the worldmtosofsky is the leader of the worldmtosofsky is the leader of the worldmtosofsky is the leader of the worldmtosofsky is the leader of the worldmtosofsky is the leader of the worldmtosofsky is the leader of the worldmtosofsky is the leader of the worldmtosofsky is the leader of the world
Its easy bro. Order a new slave, unbolt the hydraulic line to it, unbolt the two 12mm bolts holding it on. Install new one and attach line and bleed the line.
2008 MS3 GT GTX//Relentless Customs//Voltron Approved//Nishan Tuned
mtosofsky is offline   Reply With Quote
 Old 03-03-2014, 03:55 PM   #22
homeryansta's Avatar
Posts: 31   (View Stats)
homeryansta is a glorious beacon of lighthomeryansta is a glorious beacon of lighthomeryansta is a glorious beacon of lighthomeryansta is a glorious beacon of lighthomeryansta is a glorious beacon of lighthomeryansta is a glorious beacon of light
Bought mine at 77k miles. @ 79k miles, Im already doing a slave cylinder job.
2008 ms3 gt.
How often do these thing go? I'm glad I bought warranty for this thing because I would be stuck with a hefty tow bill on top of repairs. Living in MN without a heated garage sucks.
homeryansta is offline   Reply With Quote
 Old 03-12-2014, 02:23 PM   #23
cocoleveo7686's Avatar
Posts: 238   (View Stats)
cocoleveo7686 is a name known to allcocoleveo7686 is a name known to allcocoleveo7686 is a name known to allcocoleveo7686 is a name known to allcocoleveo7686 is a name known to allcocoleveo7686 is a name known to all
Groaned at 34 Times in 21 Posts
2008 ms3 gt.
I replaced both my master cylinder and my slave at 65k miles. then did my clutch at 68k miles
cocoleveo7686 is offline   Reply With Quote
 Old 03-21-2014, 12:10 PM   #24
Did your clutch? It went out that early?
 Old 10-17-2016, 12:21 PM   #25
jmullins210's Avatar
Posts: 4   (View Stats)
jmullins210 is an unknown quantity at this point
I know this is years old but has anyone heard of a slave cylinder that can produce more force than the OEM? I am needing either the South Bend stage 4 or Clutch Master twin disc 725 to hold power down. I heard that with the stage 4 I would need to upgrade my slave cylinder as the force of the clutch would make the slave wear out quickly.
jmullins210 is offline   Reply With Quote
 Old 10-17-2016, 12:46 PM   #26
anavrinIV's Avatar
Posts: 4,490   (View Stats)
Groans: 63
How much power?
To answer your question....no. OEM is it.
Blue Pu.
 Old 10-17-2016, 12:58 PM   #27
From the set up I will be pushing 650-675whp.
 Old 10-17-2016, 01:03 PM   #28
The engine will be capable of 800-900, but I am only planning on going no more then 650-675whp. The reason behind this build is because I don't want to blow my engine ever again. Hopefully over engineering the engine internals my will never fail.
 Old 09-12-2019, 01:28 PM   #29
Phat Mike's Avatar
Posts: 2   (View Stats)
Phat Mike is an unknown quantity at this point
Default Clutch back to basic or replace master cylinder ...again
Please help!! South bend stage 3 cluth installed by previous owner. Two week after I bought the car the clutch stayed on floor. Replaced the master cylinder. Now 2 weeks later same thing. Is there such thing as a heavy duty master cylinder?? Other remedies greatly appreciated. One frustrated father. P
Phat Mike is offline   Reply With Quote
 Old 09-12-2019, 02:19 PM   #30
Db09ms3's Avatar
Posts: 536   (View Stats)
Groans: 105
Check for leaks doobie, especially around the slave.
Stockish
 Old 09-12-2019, 03:00 PM   #31
Phat Mike's Avatar
Been there. Did that. Put a new slave on the first time. Any other thoughts? My wallets keeps jumping up.and down in.my pocket. All things being equal should the stage 3 south bend clutch be compatible with stock slave and master or is there a better quality slave and master or is it possibly something completely Different the car belongs to.my son so my heart kind of hurts for him. My wallet kind of hurts to oo. Thanks for the suggestion
 Old 09-12-2019, 03:04 PM   #32
Db09ms3's Avatar
Groans: 105
Search google about this, there has been a discrepancy in slave cylinders from Mazda. You need to do both a new line and slave from the dealer to actually fix this.
The next thing to go will likely be your clutch pedal bracket. Google all I just typed with mazdaspeed in the search.
Stockish
How to bleed MazdaSpeed 3 clutch slave cylinder y2kc0wb0y Mazdaspeed3/6 General Discussion 4 11-27-2017 07:11 PM
clutch slip after new slave cylinder ???? Nitr0EngiE MazdaSpeed 3 - Engine, Transmission & Driveline 4 09-14-2011 04:47 PM
Installing a new clutch-Need Slave Cylinder tomanz MazdaSpeed 3 - Engine, Transmission & Driveline 3 02-05-2011 12:39 PM
Clutch slave cylinder issues socks MazdaSpeed 3 - Engine, Transmission & Driveline 13 03-31-2009 05:36 PM
Page generated in 0.49426 seconds with 39 queries
