![]() Join Date: May 2010 Location: Los Angeles, CA
Rep Power: 195 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 26
| Not Ranked : 0 score Cool man looks like a good solution. What are the symptoms going to be when the seals are starting to go bad?
__________________ 2010 MS3 5% REAR 30% FRONT DDM 5K HID RMM CS TIP/SRI Dizzy Tuned Autotech Internals Swift Springs JBR Rear Sway Stoptech 309's First Turbo Car and I love it! |
![]() Join Date: Nov 2010 Location: Moscow, Russia
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 208
(Thread Starter) | Not Ranked : 0 score They either are OK, or get blown. If they are blown, you'll notice the knocking/chattering sound and jerking under boost.
__________________ Mazda 6 MPS Velocity Red, cp-e nano, cp-e TIP, BNR Stg3, Custom FMIC, cp-e HPFP, HKS Twin Power DLI2 ignition, HKS M35LF spark plugs, EGR block-off, catless 3" dp with welded in resonator, AutoExe Grounding Earth System, Grimmspeed BCS, AWR competition radiator, JBR SSP, 355mm 4-piston JBT Big Brake Kit, Rays RE30 wheels, Advan v103 tires, etc.. |
![]() Join Date: Aug 2011
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 284
| Not Ranked : 0 score im gonna order these next week. its cheap enough to gamble. thanks i love oem style fixes.
__________________ 2006 MAZDASPEED6 // SURE R6 // SURE AEROS & TIH // COBB AP // JBR TIG // SURE ANCHORS & SHORTCUT // SURE DREADNAUGHT // WHITELINE RSB // RACING BEAT E.L. // ULTRA GAUGE // AMSOIL FLUIDS [SIGPIC][/SIGPIC] formerly pursuit_special |
| The Following User Says Thank You to 671 grains of reason For This Useful Post: | rfinkle2 (02-10-2012) |
| Injector seals solution. | paveltol | 2010 MS3 - Fuel, Nitrous & Water Injection | 404 | 11-22-2016 03:39 AM |
| Injector seals solution. Version B | paveltol | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 463 | 11-12-2016 09:30 AM |
| Injector seals solution. | paveltol | 2010 MS3 - Engine, Transmission & Driveline | 397 | 07-25-2014 08:34 PM |
| Injector seals solution - Gen 2 | paveltol | MSF KB - Mazdaspeed 3/6 - Engine, Transmission & Driveline | 397 | 09-19-2012 02:50 PM |
| Injector seals solution. | paveltol | MSF KB - Mazdaspeed 3/6 - Fuel | 401 | 09-19-2012 01:49 PM |
