 Old 09-26-2011, 01:01 PM   #1
oh_yeams6's Avatar
Posts: 104   (View Stats)
oh_yeams6 has a reputation beyond reputeoh_yeams6 has a reputation beyond reputeoh_yeams6 has a reputation beyond reputeoh_yeams6 has a reputation beyond reputeoh_yeams6 has a reputation beyond reputeoh_yeams6 has a reputation beyond reputeoh_yeams6 has a reputation beyond reputeoh_yeams6 has a reputation beyond reputeoh_yeams6 has a reputation beyond reputeoh_yeams6 has a reputation beyond reputeoh_yeams6 has a reputation beyond repute
Groaned at 9 Times in 7 Posts
Default rear diff options
I would like to upgrade the rear diff to support some launches. There are so many options now, that I am overwhelmed.
On street unit there is a brace (no mount upgrades?)
Front mount, rear mount
Rear bushings (reuse the stock mount?) from TT
CPE rear diff mount
So....is it enough to just upgrade the bushings? Would that be the same as say, the CPE mount?
Thanks!
oh_yeams6 is offline   Reply With Quote
The Following User Says NO Thank You to oh_yeams6 For This Un-useful Post:
manelscout4life (09-26-2011)
 Old 09-26-2011, 02:48 PM   #2
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
Search is your friend. This dead horse has been beaten to a pulp.
Dont get just bushings, they are nearly worthless.
The street unit rear mount and the AWR front mount is a good upgrade.
2006 Mazdaspeed 6
 Old 09-26-2011, 02:58 PM   #3
MS6 Alan's Avatar
Posts: 453   (View Stats)
MS6 Alan is the leader of the worldMS6 Alan is the leader of the worldMS6 Alan is the leader of the worldMS6 Alan is the leader of the worldMS6 Alan is the leader of the worldMS6 Alan is the leader of the worldMS6 Alan is the leader of the worldMS6 Alan is the leader of the worldMS6 Alan is the leader of the worldMS6 Alan is the leader of the worldMS6 Alan is the leader of the world
I'm running a cpe upper rear and a turbinetech forward mount. It is pretty solid back there.
Bushings alone aren't worth it by any means.
'06 Mazdaspeed6 GT - Titanium Gray
- ATP 3076r - CP-e XCel Intake - CP-e FMIC - CP-e 4" TIP - COBB AccessPORT - Medieval EWG Manifold - Tial 44mm EWG - ATP Downpipe - Custom 3" Dual Magnaflow CBE - JBR EGR Block Off - HKS SSQV BPV - mrlilguyCDFP (KMDv1) - Denso ITV-22 Plugs - F2 BSD & Baffle - CP-e Upper Rear Diff Mount - TurbineTech Forward Rear Diff Mount - TurbineTech Front Motor Mount - AWR Rear Motor Mount - Tanabe Strut Tower Brace - Technafit SS Clutch Line - RPM Sport Springs .75/1.1 - TWM Stage 2 SS w/bushings - COBB Shift Weight - Défi-Link BF Boost Gauge - Innovate LC-1 Wideband - Hardwired Passport 8500 X50 - AuxMod Basic for CarPC -
MS6 Alan is offline   Reply With Quote
 Old 09-26-2011, 03:03 PM   #4
2zz mr-s
dooderek's Avatar
Posts: 5,119   (View Stats)
Groans: 239
some advice, if you decide to do the rear diff mount, you might as well buy a rsb too, since they both require about the same type of work to install
The Following User Says Thank You to dooderek For This Useful Post:
xfeejayx (09-27-2011)
The Following User Says NO Thank You to dooderek For This Un-useful Post:
 Old 09-26-2011, 04:20 PM   #5
oh_yeams6's Avatar
What does a rear mount offer that the bushings won't? So, a front mount would be needed in addition to the rear then...interesting
 Old 09-26-2011, 06:06 PM   #6
Speeeeeed
06Speed6's Avatar
The metal of the rear mount stress cracks and they is how they fail.
2006 Mazdaspeed 6
 Old 09-26-2011, 08:01 PM   #7
jroc's Avatar
Posts: 1,482   (View Stats)
who said this?
lots of us run just the top mount and it works fine.
JDMFresh.com 1990 Mazda Miata
The Following 3 Users Say Thank You to jroc For This Useful Post:
Delphie (09-27-2011), manelscout4life (09-26-2011), xfeejayx (09-27-2011)
 Old 09-26-2011, 08:08 PM   #8
oh_yeams6's Avatar
Is the CPE mount the "top" mount? I really don't want to drop 500 on two mounts if I don't have to. If the one mount is enough, such as the CPE or sure Dreadnaught or SU StiffDiff...it would be nice
 Old 09-27-2011, 12:10 AM   #9
amggilly305's Avatar
Posts: 899   (View Stats)
amggilly305 is the leader of the worldamggilly305 is the leader of the worldamggilly305 is the leader of the worldamggilly305 is the leader of the worldamggilly305 is the leader of the worldamggilly305 is the leader of the worldamggilly305 is the leader of the worldamggilly305 is the leader of the worldamggilly305 is the leader of the worldamggilly305 is the leader of the worldamggilly305 is the leader of the world
Groans: 92
sure motorsports has upgraded diff mounts
KILLAH BUILT
PTE 5862 @29psi
JMF MANI
METH
TUNED BY NISHAN
11.54@123
What does your new map trap
amggilly305 is offline   Reply With Quote
 Old 09-27-2011, 12:15 AM   #10
ColonR's Avatar
Posts: 1,453   (View Stats)
ColonR is the leader of the worldColonR is the leader of the worldColonR is the leader of the worldColonR is the leader of the worldColonR is the leader of the worldColonR is the leader of the worldColonR is the leader of the worldColonR is the leader of the worldColonR is the leader of the worldColonR is the leader of the worldColonR is the leader of the world
just buy both SURE juggernaught and SURE dreadnaught whoever tells you that you only need the lower rear dif brace also called the dreadnaught is an idiot! do both and you wont have to worry about ever needing to replace them again and your launches will be cherry!
1992 miata, track beast here I come with 2 bride seats!! (current)
3076r speed6 owner (traded)
2000 camaro 415rwhp thru midwest chassis fab (sold)
ColonR is offline   Reply With Quote
The Following User Says NO Thank You to ColonR For This Un-useful Post:
 Old 09-27-2011, 08:45 AM   #11
xfeejayx's Avatar
Posts: 1,729   (View Stats)
Groans: 78
I'm running the dread only. I was amazed how much more solid the setup felt with just the top mount upgrade. have launched as high as 6k no problems.
get the top mount first. if you can swing it, get both.
-Wetz
QFT
 Old 09-27-2011, 11:30 AM   #12
oh_yeams6's Avatar
Would you think that a "thunk" noise upon shifting (most of time) from the rear (sounds like that area), could be failed mounts on the diff? I know the epic "thump launch" is a diff issue...
 Old 09-27-2011, 12:42 PM   #13
Speeeeeed
06Speed6's Avatar
On my car it was the trans mount, but I think the rear diff was on its way out as well because I replaced the diff mounts first and it reduced the chunk sound.
2006 Mazdaspeed 6
Rear diff locks while turning after SURE diff mount and brace install wettoast MazdaSpeed 6 - Engine, Transmission & Driveline 47 11-04-2018 04:50 PM
Rear diff mount and rear sway bar bcmps MazdaSpeed 6 - Engine, Transmission & Driveline 16 03-25-2014 06:33 PM
Rear or Front rear diff mount? Its2realj Mazdaspeed3/6 General Discussion 0 06-05-2011 08:45 PM
rear diff "stiff diff" brace vs. rear diff front mount giordanos4 MazdaSpeed 6 - Engine, Transmission & Driveline 18 03-03-2011 08:38 AM
Page generated in 0.31620 seconds with 27 queries
