![]() Join Date: Feb 2010 Location: Austin, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
__________________ K&N Drop in, Cobb AP Stage 1 - 93, CP-e rear motor mount, AWR tranny mount, Koni Yellows, Whiteline rear sway bar, SPC adjustable ball joints, Turbine Tech Diff mount. SU rear Diff mount, Labonte Methanol injection |
![]() Join Date: Nov 2010
Rep Power: 0 ![]() ![]() Thanks: 2
| Not Ranked : 0 score possibly diff overheating? Was it the little car emblem light or the 4x4 light? |
![]() Join Date: Mar 2009 Location: Portlandia, Oregano
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,295
Groans: 196
| Not Ranked : 0 score Can you pull the code?
__________________ |
![]() Join Date: Jun 2010 Location: Santa Fe NM
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,637
Groans: 371
| Not Ranked : 0 score +1 on diff overheating |
| [MSF STIG] ![]() Join Date: Apr 2008 Location: Gloucester, VA
Rep Power: 2121 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,476
| Not Ranked : 0 score Nah, the slide triggered the light because the wheels were turning at different speeds and the sensors reported it to the ECU. No problem as the light will go out after a few feet of rolling all together. All is normal, even with DSC OFF, the TCS is still "ON", but "disengaged". The light will flash if the TCS is "engaged" and the wheels slip.
__________________ `07 Speed6 Sport Tit Gray Sleeper Express... SOLD `11 Ducati 1198SP SBK Duc Red w/Termi exh; Redline flash-tune + PC-5; Sargent; Shift-tech, CDT, & EVR Carbon; 14F/39R gear w/FBF QC; Speedymoto; R&G; ProGrip; Custom LED; Antigravity; Ducabike; Duc Perf, etc... a 182whp/105wtq The BIG DOG `12 Ducati 1100SP EVO Hyper Duc CORSE w/Termi exh; Redline flash-tune + PC-5; Ducshop Hyperstacks; 14F/41R gear w/FBF QC; Shift-tech, CDT, & BST(wheels) Carbon; R&G; ProGrip; Antigravity; Ducabike; Duc Perf, etc... a 95whp/75wtq The Hooligan `12 Aprilia RSV4 "Factory" SBK w/Akra Tit exh & race map; 15/42 gear; R&G; ProGrip; Gilles; CompWerkes; LightWerkes; Lightech; LSL Pegs; Antigravity; Zero Gravity; AF1 Flat Carbon, etc... the 181whp/83wtq The Land Rocket `17 Ford Focus RS Nitrous Blue w/Cobb V3/AT; OZ Ultraleggera; Schroth harness The Super Fun Toy |
| The Following 3 Users Say Thank You to FORZDA 1 For This Useful Post: |
(Thread Starter) | Not Ranked : 0 score It was the car with squiggly lines that lit up. I think Forzda post answered it. Just one more question- When the light is illuminated is anything effected? Does it cut engine power or effect the AWD in anyway or maybe even ABS?
| traction control light on.... | countrymanjeff | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 17 | 04-01-2016 07:08 PM |
| Traction control & brake light coming on | dutchbuffalo | MazdaSpeed 6 - Engine, Transmission & Driveline | 21 | 01-21-2011 07:14 AM |
| HELP! Traction control light and Weird idle after motor mount install? | xcoldricex | MazdaSpeed 3 - Engine, Transmission & Driveline | 15 | 05-20-2010 04:16 AM |
| e-brake and traction light coming on | baja2700 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 13 | 05-03-2010 08:49 AM |
| Traction control light | tuners | MazdaSpeed 3/6 - Suspension & Brakes | 1 | 07-20-2009 06:14 PM |
