  • 1 Post By Fstrnyou
 Old 11-30-2018, 05:23 PM   #1
ian209's Avatar
Posts: 17   (View Stats)
ian209 will become famous soon enoughian209 will become famous soon enough
Default 08 MS3 EBCS P0245 issue
Hey All,
Anyone have a picture of their EBCS or know if the factory connector is suppose to be 2 wire or 1 wire? I have the Corksport EBCS installed in my speed3 and it comes with a 2 wire connector, but my factory harness is only 1 wire. I'm also getting a P0245 when I scan for codes, but the CEL isn't on. My tuner just recently turned up the WGDC to 25% to supposedly yield 20PSI of boost, but I'm only getting around 16-17 PSI on my Corksport Turbo, which is around wastegate spring pressure. Any help would be appreciated! I don't have pictures quite yet, but I'll try to get some soon.
Also, if it suppose to be 2 wire on the factory harness, does someone have a wiring diagram/pinout for it?
Thanks,
Ian
ian209 is offline   Reply With Quote
 Old 11-30-2018, 05:36 PM   #2
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
ian209 (12-07-2018)
 Old 12-05-2018, 06:26 PM   #3
ian209's Avatar
Just checking if I'm tripping balls or not. The EBCS has a switched +12V going to one pin from the main relay with a fuse "ENG BB 5A." The other pin is from the PCM to the solenoid with presumably an active low PWM signal. Am I correct?
 Old 12-06-2018, 07:47 AM   #4
Posts: 2,233   (View Stats)
you mixed 2 connectors if the 1 remain for the ebcs has just 1 wire. In that car, i figured out Mazda made all connectors différents in the engine bay to avoid mixing them except these 2 and unfortunately both are at the same location to make it easy to be mixed...
You probably put the wrong one to the capacitor bolted on top plate above the EGR valve.
EBCS connector needs 2 wires. one is a constant +12v and the other one is the pulsed negative signal from the ECU.
ian209 (12-07-2018)
 Old 12-07-2018, 02:49 AM   #5
ian209's Avatar
Yep, you were right lol. The guys that installed my new Corksport Dankai 1 motor mixed up the connection for the EBCS and capacitor. What does that capacitor do btw?
 Old 12-07-2018, 06:12 AM   #6
i bet it is a filtering cap to reduce some signal noise but idk
 Old 12-09-2018, 03:35 PM   #7
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
Be careful with your new tune now that the connector is fixed.
Jeff23spl likes this.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
P0245 CEL Flameninja00 2010 MS3 - Troubleshoot/Diagnostics 10 01-26-2017 07:07 PM
p0401 and p0245 cocoleveo7686 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 15 12-10-2013 01:55 PM
P0245 CEL Zbrit00x Gen2 MS3 General Discussion 2 08-09-2012 09:46 PM
CLE P0245 ms6ms6 MazdaSpeed 6 - Engine, Transmission & Driveline 1 09-20-2011 11:26 PM
P0245, with MBC? 11cruzito11 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 3 12-20-2009 08:29 PM
Page generated in 0.28256 seconds with 24 queries
