 Old 02-01-2017, 07:45 PM   #1
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
Default 3" intake with 3.5" MAF housing
I don't think my plans will leave enough room for a 3.5" intake, so I was thinking a 3" intake pipe can transition to the 3.5 MAF, so long as the distance from the MAF to the transition is adequate enough to not disturb the flow distribution.
Curious to hear if this has been done before.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
 Old 02-02-2017, 06:46 AM   #2
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
Are you intending to go BT?
Rich Tuned
330WHP and 363TQ
10-19-13 Moore Automotive
 Old 02-02-2017, 07:28 AM   #3
Fstrnyou's Avatar
My first step is pointing me to the puppy power corksport turbo. Plans may change down the road and a 3071 could go in.
Other rides:
History:
 Old 02-02-2017, 07:32 AM   #4
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
If you don't have an intake now, I don't understand the issue of getting a full 3.5 inch now... If its about space, I know some guys were just using full 3.5 inch silicone intakes, but I'm sure that still gets pretty damn close to the ECU. Or just relocate the ECU and keep the same battery.
I would recommend either buying 1 or the other. If you get a 3 inch now, and need to go bigger, then sell the 3 inch and buy the correct one later.
Rich Tuned
330WHP and 363TQ
 Old 02-02-2017, 07:37 AM   #5
Fstrnyou's Avatar
MS6. ECU in the cabin where it belongs. Much to my dismay, the battery will be moving to the trunk, but I'm filling that space with something equally large. I've read the 3" intakes fit with the stock size battery. But my concern is that I'll be on the edge of maxing out a 3" MAF. Even though the JBR is 3" ID vs OD like others.
Other rides:
History:
 Old 02-02-2017, 07:47 AM   #6
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
Maybe on a CS, I don't honestly know though. But definitely not on stock turbo.
Rich Tuned
330WHP and 363TQ
 Old 02-02-2017, 07:49 AM   #7
Fstrnyou's Avatar
Oh ya. I know I won't max it on a K04. I don't want to do things twice, so trying to plan ahead.
Other rides:
History:
 Old 02-02-2017, 07:51 AM   #8
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
So what is going where the battery belongs?
Rich Tuned
330WHP and 363TQ
 Old 02-02-2017, 07:57 AM   #9
Fstrnyou's Avatar
In spite of numerous suggestions otherwise, I'll be putting a W2A intercooler there.
Other rides:
History:
 Old 02-02-2017, 06:35 PM   #10
sheston's Avatar
Posts: 1,847   (View Stats)
I'm having a hard time picturing how you would put a 3.5 MAF on a 3 in intake? I would think that it would cause the air to not flow well and read accurately, much like not having an air straightener.
For all the stock turbo haters - My K04 loves it's 4 in intake :-)
 Old 02-02-2017, 08:15 PM   #11
Fstrnyou's Avatar
Stock size Group 35 battery is about 6.9" wide. The intercooler I plan on making is only 6" wide. Napkin math tells me a 3.5" intake "should" fit. I was just hoping to use a 3" intake for more wiggle room, but without the MAF limit of the 3".
Other rides:
History:
 Old 02-02-2017, 08:23 PM   #12
Fstrnyou's Avatar
The below reducer coupler should attach a 3" pipe to a JBR 3.5" MAF. But if a 3.5" intake might fit, this thread and the below link are moot.
HPS High Temp 3" > 3.75" ID x 3" Long 4-ply Reinforced Silicone Reducer Coupler Hose Black 76mm 95mm
Other rides:
History:
 Old 02-02-2017, 08:33 PM   #13
sharksinspace's Avatar
Posts: 766   (View Stats)
Groans: 126
But how much more does it love it than it would a 3" or 3.5"?
Genpoo stuff
 Old 02-04-2017, 10:03 PM   #14
Fstrnyou's Avatar
Mocked up my W2A intercooler with foam board. Looks like there is room for a 3.5" intake after all. Used a roll of paper gasket maker as a stunt double for the intake pipe.
Other rides:
History:
Page generated in 0.32129 seconds with 24 queries
