  • 1 Post By Gr8Speed
 Old 08-28-2014, 01:55 AM   #1
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
Default 3" intake improvisation
So far I have a CP-e inlet paired with a tiny Cobb SRI intake which I didn't want to change because of the CAI box which I found useful both at fighting IATs and for smog/MOT inspections (the regular ones as well as the random police inspections in traffic).
However, with this large turbo (GTX3071R) I'd really like to have a larger intake to reduce the differential pressure on the sides of the compressor wheel.
But:
- I don't want to replace the CP-e inlet because it's really close to 3" and the larger options require hacking of the battery tray and/or ECU relocation;
- I still want to keep the CorkSport CAI box for the two above mentioned reasons.
So this is what I have in mind, I hope that someone did this already or was at least close to what I want to try. I want to get either a Kozmic/SSP big MAF intake kit or the XcelXL and adapt them to the CS air box. I can eventually try a different filter option if the ones supplied with these two will not fit, I'm pretty sure K&N will have something to fit my needs in therms of length, outside diameter and coupler diameter.
The silicone coupler these two have should help with the positioning of the filter inside the box, and eventually can be cut if necessary.
I'm a bit concerned using a breather filter instead of the breather line going back to the intake which gets a bit more vacuum (to make a bit more mess in the intake, but this is the ventilation system we have and we have to live with it), while the breather filter will only see barometric pressure all the time.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
 Old 09-02-2014, 03:33 PM   #2
Gr8Speed's Avatar
Posts: 5,702   (View Stats)
I have some polycarbonate MAF housings that are 3". I made one for my car. If you want to piece a filter/couplers together to make it work I would send it to you for shipping cost. Just let me know and I'll get a pic with signage and tag you in a FS thread on here. I think that's what I'd need to do @Raider; correct me if I'm wrong. Weird situation since I'm not really selling it.
Raider likes this.
 Old 09-02-2014, 05:39 PM   #3
NATOR does not really apply, but prove you have it, scammer boy. Lol
Gr8Speed (09-02-2014)
 Old 09-02-2014, 05:45 PM   #4
Gr8Speed's Avatar
Will do if he responds and is interested. Gotta go dig it out of the garage and I'm pretty sure it's in my stock parts box so not worth digging if he doesn't want it lol
Raider likes this.
Questions before ordering a "Path Stage II Power Intake" levon.mark JAMES BARONE RACING 37 03-26-2013 05:01 PM
Anyones 2010 "BOGGING" with intake? Mine is... DarkSpeed3 2010 MS3 - Troubleshoot/Diagnostics 21 07-10-2010 04:39 PM
Page generated in 0.25110 seconds with 22 queries
