 Old 10-30-2012, 06:09 AM   #1
v8 convert
p057's Avatar
Posts: 1,782   (View Stats)
p057 has disabled reputation
Groans: 220
Default Adjusting WG spring preload on turbo?
Is it possible to adjust the wastegate spring preload while still in the car? i dont feel like taking my turbo out again to adjust the preload.
Reason why is that I'm thinking it may be the root cause of not being able to stay at 23PSI. Currently, I hit that target and by redline it tapers off to about 20.5PSI
WG spring is 14psi
using an ATP 3071R.
Alternately, this may be fixed by going EBCS too.... But I like the quick and easy setup of my MBC. :\
p057 is offline   Reply With Quote
 Old 10-30-2012, 06:10 AM   #2
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
nigga didn't I tell you how to do this?
remove clip holding actuator onto turbo. use wrench to tighten actuator arm a few turns. Replace actuator onto turbo, replace clip.
07 MS3
The original Genpoo Hater
86AmishMs3 (11-02-2012)
 Old 10-30-2012, 06:17 AM   #3
v8 convert
p057's Avatar
Groans: 220
werent you the one telling me that i needed to take it out of the car?
 Old 10-30-2012, 06:20 AM   #4
Will fuck up ur day
Chimmike's Avatar
Groans: 433
no, that was kenny and john. I think they're right, in which case, just go EWG with a bigger turbo.
07 MS3
 Old 10-30-2012, 06:23 AM   #5
v8 convert
p057's Avatar
Groans: 220
yeah, after you help me rebuild a motor.
 Old 10-30-2012, 06:24 AM   #6
Will fuck up ur day
Chimmike's Avatar
Groans: 433
when do we start?
07 MS3
 Old 10-30-2012, 06:26 AM   #7
SarcasticOne's Avatar
Posts: 1,013   (View Stats)
Groaned at 8 Times in 4 Posts
Can do it by coming from underneath
 Old 10-30-2012, 06:28 AM   #8
v8 convert
p057's Avatar
Groans: 220
and what, bend the driveshaft and transfer case out of the way?
when do we start?
after i buy a used block and new rods/pistons, etc. ughhh.
Last edited by p057; 10-30-2012 at 06:28 AM. Reason: MSF Database - Automerged Doublepost
 Old 10-30-2012, 03:28 PM   #9
oh, you have a 6.... my bad
 Old 10-30-2012, 04:26 PM   #10
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
You can do it if you have small hands.
-06 MS6
-Corn fed 07 MS3 - Sold
 Old 10-30-2012, 05:55 PM   #11
v8 convert
p057's Avatar
Groans: 220
They're pretty small, but I've tried working on the car from under and its extremely cramped, I'd rather keep cutting my hands and straining the hell out of my back.
Adjusting APP tables EmPeEs6 MazdaSpeed 3/6 - ECU Computer Tuning 8 10-11-2012 09:00 AM
pads: top spring clip or back spring plate breakfasteatre MSF KB - Mazdaspeed 3/6 - Suspension & Brakes 5 09-19-2012 01:44 PM
pads: top spring clip or back spring plate breakfasteatre MazdaSpeed 3/6 - Suspension & Brakes 4 11-05-2011 09:52 AM
Possible track spring spring setup for use with Koni yellows stretch MazdaSpeed 3/6 - Suspension & Brakes 154 04-18-2011 12:18 PM
Adjusting boost ATR? zx2man MazdaSpeed 3/6 - ECU Computer Tuning 13 08-04-2010 02:29 PM
Page generated in 0.31267 seconds with 23 queries
