Like Tree103Likes
 Old 09-06-2012, 05:52 PM   #1
RayRay's Avatar
Posts: 3,120   (View Stats)
RayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the world
Groaned at 9 Times in 5 Posts
I have definitely had similar issues with my gtx. First time I had a metal burr left on the inside of my housing. This supposedly caused excessive heat. This caused the seals to go bad. From there I sent the turbo in and they rebuilt it.sent it back and I am having the same issues. My oil return line from them had a mountain range inside of it. They sent me a new one, 1 in shorter. (I let them know the one in their kit was too long). I am still having issues. Everything is pointing to the seals again. I am actually pulling the gtx this weekend and putting the stock k04 in. ATP had told me I will have first priority when I.. send it back to get looked at. We will see what they say but I have very little faith right now. I am hoping they will take care of it!
jracer likes this.
2009 MazdaSpeed 3
Spy Hunter Smoke Screen Mod
Cobb AP (Custom Tune), ATP GTX3076 28PSi, CP Forged Pistons .020 Over, Pauter Forged Rods, Bore and Hone Block .020 Over, CP-E DISI Injector Seals, ARP Head Studs, MZR Cometic Head Gasket, ACT Stage 2 Heavy Duty Clutch,Cobb SRI Intake, JBR TIG, JBR TB Gasket, JBR 88 Duro Transmission Mount, JBR EGR Delete , JBR TB Coolant Bypass, CP-E Big Turbo TIP, KMD HPFP Internals, Street Unit TurboSmart Dual Port BOV, CorkSport TMIC, CorkSport DP, CorkSport Test Pipe, CorkSport CBE, CPE Single Guage Pod, DashHawk, Prosport Boost Gauge, Devils Own Progressive Methanol Injection Kit 80/20 with D07 Nozzle, E85 Tune 50/50, JBR DogBone 88 Duro Rear Motor Mount, CorkSport Mid Chassis Brace, JBR Stage 2 Short Shift Plate, H&R Springs, 18x8 Drag DR38 +47, Eibach 5mm Spacers, 235/40 18 Brisgestone RE760.
RayRay is offline   Reply With Quote
The Following 9 Users Say Thank You to RayRay For This Useful Post:
802MS3 (09-06-2012), atvfreek (09-06-2012), Dano (09-06-2012), doubleflusher (09-07-2012), Easter Bunny (09-06-2012), PapaSmurf (09-06-2012), rfinkle2 (09-07-2012), SPEED6 KILLAH (09-06-2012), uncorked11 (09-08-2012)
 Old 09-06-2012, 05:57 PM   #2
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
yeah. I'm interested to hear what they say.
07 MS3
The original Genpoo Hater
RayRay (09-06-2012)
LakeSpeed6 GTX3076 Build Lakespeed6 MazdaSpeed 3/6 - Big Turbo Builds 60 04-12-2013 08:09 AM
Realgib3 - GTX3076 - 400whp Realgib3 MazdaSpeed 3/6 - Dyno Sheets/Discussions 63 10-13-2011 02:57 PM
Finally let my balls drop! - GTX3076 Realgib3 MazdaSpeed 3/6 - Big Turbo Builds 109 10-04-2011 01:51 PM
Page generated in 0.41939 seconds with 23 queries
