Like Tree103Likes
 Old 09-06-2012, 02:17 PM   #1
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
Default ATP/Garrett Hate - failure GTX3076
So, the bearings went out on my GTX3076R. Used the ATP kid as provided in terms of oil lines.
Send the turbo in to ATP last week. Verdict is there was a "clog" of some sort in the oil feed portion of the turbo just before the bearings preventing oil from getting in. Garrett called it a user-induced failure, won't cover it.
ATP says there really wasn't anything I could have done to prevent it, says it's a one-in-a-million failure, but says Garrett won't cover it, and they won't eat it.
So, I'm basically out $742 to get a new CHRA because of a failure I could not have prevented on a turbo Garrett is not warrantying.
Anyone care to call ATP telling them to warranty that shit for me?
I straight up asked, "So understanding that this isn't garrett's fault, but at the same time there was nothing I could do to prevent it, Garrrett won't eat this as a customer service exception?" "the best they'll do is this CHRA exchange program for $742".
07 MS3
The original Genpoo Hater
The Following 39 Users Say Thank You to Chimmike For This Useful Post:
06Speed6 (09-07-2012), 08.5MS3 (09-06-2012), ABolewski (10-25-2014), atvfreek (09-06-2012), beachshoer (09-06-2012), BlueStreak (09-06-2012), charlesfist (09-06-2012), crazyp (09-06-2012), CWP_MS3 (09-06-2012), Darth_Nuruodo (09-06-2012), Downmented (09-06-2012), Easter Bunny (09-06-2012), Etipp98 (09-06-2012), Fail_6 (09-11-2012), Fobio (09-06-2012), helmetface (09-06-2012), J'sSpeed3 (09-09-2012), jracer (09-06-2012), Micha (09-07-2012), Mizzle (09-06-2012), Monotonous ONE (09-06-2012), mroclimbr (11-11-2012), ms3blackmica (04-27-2013), NJSPEED3 (09-06-2012), Payne Racing 67 (09-07-2012), RayRay (09-06-2012), rfinkle2 (09-06-2012), robry (09-07-2012), Rokusek (09-10-2012), smoogs12 (09-06-2012), SofaKingAwesome (09-06-2012), Speed3eak (09-07-2012), Speed3queen (09-07-2012), SPEED6 KILLAH (09-06-2012), SpeedSixxx (09-07-2012), Speed_j23 (09-06-2012), Spoofmastafly (09-06-2012), tddvrrn (09-06-2012), uncorked11 (09-06-2012)
 Old 09-06-2012, 02:20 PM   #2
Etipp98's Avatar
Posts: 1,947   (View Stats)
Groaned at 7 Times in 4 Posts
Wow... Ive been running this setup for about a month or so now. I'm crossing my fingers man. Sorry about your luck.
The Following 2 Users Say Thank You to Etipp98 For This Useful Post:
Chimmike (09-06-2012), Payne Racing 67 (09-07-2012)
 Old 09-06-2012, 02:20 PM   #3
Well the right thing to do is for ATP to eat the cost. Just when i thought ATP turned the corner, they pull this.
Personally, i can no longer recommend using ATP turbos if they can't even be loyal. ATP, go learn about how Cobb does business.... Customer loyalty is essential.
If anyone knows ATPs FB page and Twiter, they need to be directed to this page.
SpeedSixxx likes this.
The Following 17 Users Say Thank You to Haltech For This Useful Post:
atvfreek (09-06-2012), BigJimMs3 (09-06-2012), BobbleHead (09-06-2012), Chimmike (09-06-2012), CWP_MS3 (09-06-2012), dp3 (10-28-2014), dton13 (09-06-2012), dturboman (09-07-2012), Easter Bunny (09-06-2012), helmetface (09-06-2012), J'sSpeed3 (09-09-2012), Micha (09-07-2012), Monotonous ONE (09-06-2012), Pointless (09-06-2012), predapio (09-06-2012), smoogs12 (09-06-2012), SpeedSixxx (09-07-2012)
 Old 09-06-2012, 02:21 PM   #4
@RayRay had a similar issue.
@cld12pk2go, @NJSPEED3, @atvfreek, @ everyone interested....
The more I read about the gtx ball bearing turbos, the more I think we need to be running an oil restrictor.
Garrett recommends it.
@chimmike, we can get enough people together in this thread to show ATP how much business they do through this forum.
TBH, we don't need them considering their "drop in" oil and water feed kits are not correctly sized anyway.
The Following 10 Users Say Thank You to rfinkle2 For This Useful Post:
atvfreek (09-06-2012), BlueStreak (09-06-2012), BobbleHead (09-06-2012), Easter Bunny (09-06-2012), p057 (09-07-2012), SLOWHATCH (09-07-2012), smoogs12 (09-06-2012), SpeedSixxx (09-07-2012), Tokay444 (09-06-2012), Zbrit00x (09-07-2012)
 Old 09-06-2012, 02:23 PM   #5
Will fuck up ur day
Chimmike's Avatar
Groans: 433
@RayRayg37 had a similar issue.
The more I read about the ball bearing turbos, the more I think we need to be running an oil restrictor.
speaking of that, this wasn't restrictor-related. I had a long talk iwth the guy about restrictors, and he claims they aren't necessary, and that if you push too much oil and get blowby at the seals, you can add a restrictor and it won't leak anymore, that the seals are metal like pistons rings and not rubber that can blow out.
This was more like "some shit in your oil clogged up the inlet, not our fault" but something I could have prevented how? And I'm within the 1 year warranty but no coverage?
@Raider
07 MS3
The Following 5 Users Say Thank You to Chimmike For This Useful Post:
atvfreek (09-06-2012), Easter Bunny (09-06-2012), rfinkle2 (09-06-2012), SLOWHATCH (09-07-2012), smoogs12 (09-06-2012)
 Old 09-06-2012, 02:25 PM   #6
@Raider
2 failures with properly maintained cars is suspect.
In any case, their kits are poop, imo..
And if poop, they should @ least stand behind them.
SLOWHATCH (09-07-2012), SpeedSixxx (09-07-2012)
 Old 09-07-2012, 11:01 AM   #7
Tabasco69's Avatar
Posts: 554   (View Stats)
Tabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the world
Technically it is not ATP's kit failing it is garrett's chra that failed, all atp does is slap their bolt on turbine housing onto it ....IDK I think it should be garret who eats the loss.
Most definitely not you.....what exactly could have caused the feed to plug?
FYI the gtx uses the same exact bearing/shaft set-up as the gt series, the billet wheel distinguishes the 2 apart, being the case every bb garret tc I have used required a restrictor, they need/use minimal oil...........but this failure doesn't sound like it has anything to do with having too much......more like not enough.
To the best of my knowledge the seals are exactly like a piston ring, they are designed to weep to relieve pressure beyond something like 40psi, but that doesn't mean they have failed, usually something like a pinched oil return line causes back pressure.
425whp/395ftlbs - GTX3071R .82a/r- 20psi- 92 octane pump fuel
Tabasco69 is offline   Reply With Quote
The Following 5 Users Say Thank You to Tabasco69 For This Useful Post:
802MS3 (09-07-2012), 86AmishMs3 (09-09-2012), Chimmike (09-07-2012), Easter Bunny (09-07-2012), rfinkle2 (09-07-2012)
 Old 09-06-2012, 02:26 PM   #8
@Raider
Ultimately Garret should cover it, however... ATP modified the turbo to make it Mazda compatible. Therefore, the responsibility lies on them.
ATP should have no issues getting Garret to cover that turbo from them with as many turbos as ATP sells for them. This shit isn't making any sense. This is why im thinking this is ATP knowing they fucked up on the oil return like or something.
The Following 3 Users Say Thank You to Haltech For This Useful Post:
atvfreek (09-06-2012), rfinkle2 (09-06-2012), SpeedSixxx (09-07-2012)
 Old 09-06-2012, 02:25 PM   #9
Etipp98's Avatar
So that threaded aluminum piece that sits inside where the oil feed line is not an oil restrictor? I might have to look into this..
atvfreek (09-06-2012), Chimmike (09-06-2012)
 Old 09-06-2012, 02:27 PM   #10
I won't shit up Chimmikes thread, but have been looking into the size needed etc. and with info from Garrett's site, am sketchy as to if these new gtx's will have issues with the stock feed line.
 Old 09-06-2012, 03:56 PM   #11
BigjohnB20's Avatar
Posts: 779   (View Stats)
Not much else to contribute here, but didn't @BlueStreak have a similar issue recently as well?
2006 BCM MS6 GT
CS SRI/TIP
Jbarone SSP/bushings
cp-e RMM, TMIC, Stiff Diff
AP
KMD V2.whatever
Ebay Catless DP
Grom Ipod
The Following 2 Users Say Thank You to BigjohnB20 For This Useful Post:
BlueStreak (09-06-2012), rfinkle2 (09-06-2012)
 Old 09-06-2012, 03:58 PM   #12
I believe Bluestreak thinks the excessively long drain line they supply with the kit is the culprit.
BigjohnB20 (09-06-2012), BlueStreak (09-06-2012), Fobio (09-06-2012), SLOWHATCH (09-07-2012)
 Old 09-06-2012, 04:21 PM   #13
BlueStreak's Avatar
Posts: 1,467   (View Stats)
Yep. My line was kinked and I'm sure it caused the oil to back up. At this point, I'm kinda nervous about my second one failing so I ordered this oil restrictor for testing. Nuts to ATP saying we don't need one.
Turbo Oil Feed Banjo Bolt Kit Garrett GT2871R GT2876R GT3071R Ball Bearing | eBay
'07 CWP MS3
Forged.
 Old 09-06-2012, 05:25 PM   #14
crazyp's Avatar
Posts: 1,093   (View Stats)
Groans: 68
I don't understand? I've been running a restrictor since I installed my GTX? The same restricor I use to run on my GT3071, was I not supposed to? I figured since they made the claim that its was drop in interchangeable that meant it needed it?
The Following User Says Thank You to crazyp For This Useful Post:
 Old 09-06-2012, 02:21 PM   #15
helmetface's Avatar
Posts: 5,685   (View Stats)
Groans: 219
For fucking real.
I can't believe they won't back you on this..
 Old 09-06-2012, 02:21 PM   #16
Shits getting deep now
 Old 09-06-2012, 02:28 PM   #17
Will fuck up ur day
Chimmike's Avatar
Groans: 433
No @Etipp98 ATP tells me with the stock feed line, and even with -4an, a restrictor is not necessary on our cars.
Anyone care to call ATP and push them for me?
@rfinkle2 : the only difference between these and regular GT's is the compressor wheel/housing. The CHRA/shaft/turbine wheel/housing is the same.
07 MS3
The Following 3 Users Say Thank You to Chimmike For This Useful Post:
 Old 09-06-2012, 02:35 PM   #18
The wheel speeds are not the same.
 Old 09-06-2012, 02:28 PM   #19
PapaSmurf's Avatar
Posts: 8,236   (View Stats)
@RayRay had been having a bunch of problems with his GTX3076.
I run a restrictor on my GT3582 but it isnt GTX.. I also have a custom oil feed setup with AN fitings and such.
860whp/677wtq
2.7 V6 Ecoboost
 Old 09-06-2012, 02:38 PM   #20
PapaSmurf's Avatar
I use this restrictor.
-4 size Oil inlet fitting for GT28/30/35R with built-in restrictor : atpturbo.com
860whp/677wtq
2.7 V6 Ecoboost
The Following 4 Users Say Thank You to PapaSmurf For This Useful Post:
BlueStreak (09-06-2012), doubleflusher (09-07-2012), Haltech (09-06-2012), rfinkle2 (09-06-2012)
 Old 09-06-2012, 02:40 PM   #21
bcmurphy87's Avatar
Posts: 1,435   (View Stats)
wow that really blows!!!! how old is this setup?
06 Speed6 GT- Sold
 Old 09-06-2012, 02:42 PM   #22
Domino81's Avatar
Posts: 5,081   (View Stats)
Sorry to hear about this.
2008 CosmicBlue Mazdaspeed3
294whp/335wtq - Stock K04
370whp/370wtq - BNR stage 3
 Old 09-06-2012, 02:45 PM   #23
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
I thing Garrett is to blame...they made the CHRA which is where the failure occurred. ATP only adds a hotside, drain line and coupler to the mix so they never touch the CHRA oil feed.
I have a GTX3071 on the way and will compare the CHRA to my GT28.
AFAIK absolutely no restrictor needed and in-fact will likely destroy the CHRA.
 Old 09-06-2012, 02:44 PM   #24
ckMS3's Avatar
Posts: 1,112   (View Stats)
ckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the world
That really sucks I believe @Downmented had a similar problem. Good luck with everything.
BNR S3 // E85 Mix // Freektune
348tq/367whp -21.5 psi
Now - 25-26 psi + JBR 3.5 Intake
ckMS3 is offline   Reply With Quote
The Following User Says Thank You to ckMS3 For This Useful Post:
 Old 09-06-2012, 02:45 PM   #25
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,811   (View Stats)
Do not use an oil restrictor.
That's how I blew the bearings on my GTX3071.
OP's problem was lack of lube oil not an abundance of it.
The GTX CHRA is both water AND oil cooled. You will starve the bearings of oil that it needs for colling if you put a restrictor in the oil inlet.
Had the same issue with ATP. Had to buy the CHRA. It hurts but what the fuck can one do. I keep hoping a reputable company will start making single wastegate twin scroll manifolds for this platform with corresponding V band DPs but don't have much hope that will ever happen.
bertrand_CX_7 and rfinkle2 like this.
The Following 10 Users Say Thank You to Tomas For This Useful Post:
atvfreek (09-06-2012), Dano (09-06-2012), Fobio (09-06-2012), helmetface (09-06-2012), Monotonous ONE (09-06-2012), MS3-a(sore)ASS-rex (09-19-2012), ms3blackmica (04-27-2013), rfinkle2 (09-06-2012), SLOWHATCH (09-07-2012), theurgy (09-06-2012)
 Old 09-06-2012, 02:47 PM   #26
MSFer87's Avatar
Posts: 1,162   (View Stats)
Groans: 83
Sorry about your luck man...........well you did the best thing you could do, and come on here and tell other people about it. Now we just need enough people bitching to get them to change their mind. For the record this makes me want to get a EFR kit more now when I decide to go BT.
 Old 11-09-2012, 08:16 PM   #27
GartzSpeed's Avatar
Posts: 155   (View Stats)
GartzSpeed is the leader of the worldGartzSpeed is the leader of the worldGartzSpeed is the leader of the worldGartzSpeed is the leader of the worldGartzSpeed is the leader of the worldGartzSpeed is the leader of the worldGartzSpeed is the leader of the worldGartzSpeed is the leader of the worldGartzSpeed is the leader of the worldGartzSpeed is the leader of the worldGartzSpeed is the leader of the world
I just changed my wishlist to the EFR from the 3582. That's just crazy they aren't eating it to make it right.
Unless of course they have, and I didn't reach that far yet...
GartzSpeed is offline   Reply With Quote
 Old 09-06-2012, 02:57 PM   #28
1) post their information, facebook, etc in post 1.
2) mods here need a vendor master list made of untrustworthy vendors, add it to the new member section as a sticky to guide people in the right direction. Obvious to us, msf vendors > non vendors by a mile.
Fuck this shit I'm pissed.
CWP_MS3 likes this.
Caligula (09-07-2012), Chimmike (09-06-2012), CWP_MS3 (09-06-2012), dp3 (10-28-2014), Rokusek (09-10-2012), smoogs12 (09-06-2012)
 Old 09-06-2012, 02:57 PM   #29
Domino81's Avatar
How did you know the bearings were fucked?
 Old 09-06-2012, 03:05 PM   #30
anavrinIV's Avatar
Posts: 4,490   (View Stats)
Groans: 63
gtx turbos spin like a mofo..the thing probably had all kind of play in it and didn't turn well
Blue Pu.
 Old 09-06-2012, 03:11 PM   #31
Domino81's Avatar
I saw the vid that showed play from side to side. But how would that react in the car?
 Old 09-06-2012, 03:16 PM   #32
uncorked11's Avatar
Posts: 1,238   (View Stats)
Groans: 165
ATP Turbo - Hayward, CA - Local Business | Facebook
This is all that comes up.
New....Camaro SS/RS
Stocked out selling parts.
2011 Black MS3
2006 Jeep Wrangler
-20 grand of Shit
 Old 09-06-2012, 03:21 PM   #33
PapaSmurf's Avatar
they are smart and dont have a facebook.
860whp/677wtq
2.7 V6 Ecoboost
 Old 09-06-2012, 03:29 PM   #34
ms3rick's Avatar
Posts: 2,959   (View Stats)
I blame ATP for not trying harder to get Garrett to cover the warranty. Seems like they just half ass customer care....
Sorry mike!
Sent from my dizzLe using RaWr powers!
Sold:
2010 MS3 siLver.
Official 60-100mph Times
Official Video battles
Official Youtube Channels
The Following User Says Thank You to ms3rick For This Useful Post:
 Old 09-06-2012, 03:33 PM   #35
Will fuck up ur day
Chimmike's Avatar
Groans: 433
Yeah, they seemed pretty un-receptive to even considering shit and said garrett already made the ruling.
07 MS3
 Old 09-06-2012, 03:35 PM   #36
Bob Ross Fanclub
Tomas's Avatar
Garret would not give 2 shits if ATP ever bought from them again.
Honeywell sells literally tens of thousands of turbos a year. Most of them bigger than the 30 and 35 frame. If ATP never bought from them again they would hardly notice it.
Best bet is to take Garrett to small claims court in your state if you have the time and patience to fight it for $750. Florida has a min claim requirement of $500 but other states are higher. They would probably not send a lawyer to represent them for that value and would settle by giving you a free CHRA. That's just a guess however.
Easter Bunny (09-06-2012), SLOWHATCH (09-07-2012), SpeedSixxx (09-07-2012)
 Old 09-06-2012, 03:40 PM   #37
Will fuck up ur day
Chimmike's Avatar
Groans: 433
But they know the majority of us don't have the time to do that.
If it wasn't a matter of changing the manifold flange and fucking with the downpipe, I'd consider switching to a different brand turbo. but that's money I don't have, either.
07 MS3
Tomas (09-06-2012)
 Old 09-06-2012, 03:44 PM   #38
Tripple OG
NJSPEED3's Avatar
Posts: 5,703   (View Stats)
Groans: 113
I have an idea how about everyone gets off this stock frame turbo craze, and buys a true garret turbo.
Problem solved. ATP kiss our ass, haha.
The Following 9 Users Say Thank You to NJSPEED3 For This Useful Post:
ArcticSpeed3 (09-08-2012), dantes5823 (09-07-2012), doubleflusher (09-07-2012), Haltech (09-06-2012), helmetface (09-06-2012), Manny (09-06-2012), ms3blackmica (04-27-2013), MS3KO (09-08-2012), Realgib3 (09-06-2012)
 Old 09-06-2012, 03:49 PM   #39
Mizzle's Avatar
Posts: 2,829   (View Stats)
Groans: 324
Wait.
Did they SHOW you the restriction / material that clogged the line?
 Old 09-06-2012, 03:55 PM   #40
Will fuck up ur day
Chimmike's Avatar
Groans: 433
Wait.
Of course not. I'm here in FL and they're in CA.
For small claims, the company can have a lawyer prepare the case but cannot send the lawyer into court (no lawyers allowed in small claims.) Most major companies will just pay the claim once they have been served. So file the claim. Have Garrett's local business agent served. Hope to collect.
It costs around $200-250 to file a small claim here in FL, IIRC. my money is better spent on other things right now.
07 MS3
Last edited by Chimmike; 09-06-2012 at 03:55 PM. Reason: MSF Database - Automerged Doublepost
Tomas (09-08-2012)
LakeSpeed6 GTX3076 Build Lakespeed6 MazdaSpeed 3/6 - Big Turbo Builds 60 04-12-2013 08:09 AM
Realgib3 - GTX3076 - 400whp Realgib3 MazdaSpeed 3/6 - Dyno Sheets/Discussions 63 10-13-2011 02:57 PM
Finally let my balls drop! - GTX3076 Realgib3 MazdaSpeed 3/6 - Big Turbo Builds 109 10-04-2011 01:51 PM
Page generated in 0.77227 seconds with 43 queries
