 Old 10-28-2012, 01:39 PM   #1
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
Default ATP turbine housing porting
So I have a gtx3071 that I am going to bolt on until i get the funds for a holset setup, I know the turbine housing needs to be ported but how much? Ive already hogged out the wg port but on my setup im afraid that it isnt going to be enough since I have a l/a ic, ported head, cams, oversize exhaust valves, and a catless 3" turbo back. Ive nearly taken that hump out that is right before the wg port inside of the turbine so its really opened up now, is there anything that I might have missed? I really need max air flow.
2006 Mazdaspeed 6
 Old 10-28-2012, 01:46 PM   #2
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
Why would you go with a holset after hearing about the massive lag and poor transient response?
Sent from my your mom's face on my junk
07 MS3
The original Genpoo Hater
 Old 10-28-2012, 03:01 PM   #3
Speeeeeed
06Speed6's Avatar
Because everyone that has used one hasnt matched it to the car, diesels have generally low egts and low exhaust flow and they spool them just fine. This isnt a hokset turbo thread though.
I have now basically completely unshouded the wg flapper and smoothed everything out. My thinking is that if you can get the exhaust through the turbine efficiently and through the wg efficiently it shouldnt be able to back up and blow the wg open and make the boost uncontrollable. The turbine itself should be good for 550-600ish but this housing is really a pile.
2006 Mazdaspeed 6
 Old 10-28-2012, 03:07 PM   #4
helmetface's Avatar
Posts: 5,685   (View Stats)
Groans: 219
IWG?
06Speed6 (10-28-2012)
 Old 10-28-2012, 04:28 PM   #5
the problem is you cant port the flutes inside the housing. thats where the flow really gets choked.
theres plenty of people making big power on the ATP hotsides.
 Old 10-28-2012, 04:37 PM   #6
helmetface's Avatar
Groans: 219
The reason I asked about IWG above is because I'm using the ATP EWG hotside and there is nothing that needs to be done.
From his wording though, I'm guessing it's either IWG or EWG on the mani
 Old 10-28-2012, 05:09 PM   #7
Speeeeeed
06Speed6's Avatar
Its IWG sorry.
I looked at the flute and it *seems* ok. I took ALOT of material out of the EM flange/iwg area. In a couple spots im kinda worried about the strength now, but there is really alot of material in some areas that can be taken out with no worries.
2006 Mazdaspeed 6
 Old 10-28-2012, 05:14 PM   #8
rabble rabble
802MS3's Avatar
Posts: 5,318   (View Stats)
Groans: 221
I posted some pretty decent pics of the porting I had done to mine. I get no creep at all.
3071r build
'08 CWP MS3 w/ T3 3071r
Last edited by 802MS3; 10-28-2012 at 05:15 PM. Reason: MSF Database - Automerged Doublepost
06Speed6 (10-29-2012)
 Old 10-29-2012, 06:14 PM   #9
Speeeeeed
06Speed6's Avatar
Yours is ported just a little more and they smoothed everything out better than mine, maybe ill hit it with a burr again and see if I can make it prettier
2006 Mazdaspeed 6
 Old 10-30-2012, 06:12 AM   #10
v8 convert
p057's Avatar
Posts: 1,782   (View Stats)
p057 has disabled reputation
Groans: 220
i never ported mine and get reverse creep... :S
p057 is offline   Reply With Quote
 Old 10-30-2012, 06:16 AM   #11
Will fuck up ur day
Chimmike's Avatar
Groans: 433
This is where extrude honing shines, my friend.
07 MS3
06Speed6 (10-30-2012)
 Old 11-06-2012, 05:50 PM   #12
Speeeeeed
06Speed6's Avatar
So I figured out that if you port the wg hole enough the flapper gets stuck on it and may not close all the way.
2006 Mazdaspeed 6
superskaterxes (11-06-2012)
 Old 11-06-2012, 07:35 PM   #13
rabble rabble
802MS3's Avatar
Groans: 221
ooooo....that sucks
luckily a nice dude on here sold me his for $100 shipped, so I'm sure you can find another one.
 Old 11-07-2012, 01:56 PM   #14
Speeeeeed
06Speed6's Avatar
I figured it out, I put a bevel on the flapper itself and it seats fine now.
2006 Mazdaspeed 6
 Old 11-07-2012, 02:50 PM   #15
Matrix311's Avatar
Posts: 2,133   (View Stats)
Here is the porting that a buddy of mine did for me. I just picked it up from him on Monday. I also have the gtx3071r.
Photos here.
http://www.mazdaspeedforum.org/forum/foru...ml#post1729258
06Speed6 (11-09-2012)
 Old 11-07-2012, 03:02 PM   #16
Voltwings's Avatar
Posts: 3,713   (View Stats)
i ported mine a lot, just stuck some magnets on there to help with the shavings and went to town, no creep on initial set up: UR catted DP - HTP 3" intake - ETS TMIC. However switching to a front mount i did see boost drop a little, as is to be expected, but when i added a 4" intake i was creeping about 2 psi (8 psi wastegate spring but seeing 10-10.5 psi). intake side effects creep just as much as exhaust side it seems.
Past:
-Sold-
-Sold-
Current:
2012 Loaded Speed3 - Stock
2001 Miata - Basically stock
 Old 11-09-2012, 11:11 PM   #17
Speeeeeed
06Speed6's Avatar
@Matrix311 that looks like a nice port job, looks like I need to take more metal out!
2006 Mazdaspeed 6
HOW TO: Port turbine housing with IWG Chimmike MazdaSpeed 3/6 - Turbo Induction 2 08-12-2011 06:50 PM
.64 or .82 turbine housing? Jarods7920 MazdaSpeed 3/6 - Turbo Induction 12 05-02-2009 09:43 AM
Page generated in 0.37416 seconds with 27 queries
