 Old 09-03-2013, 04:33 AM   #1
Motocooney's Avatar
Posts: 175   (View Stats)
Motocooney has much to be proud ofMotocooney has much to be proud ofMotocooney has much to be proud ofMotocooney has much to be proud ofMotocooney has much to be proud ofMotocooney has much to be proud ofMotocooney has much to be proud ofMotocooney has much to be proud ofMotocooney has much to be proud of
Default Benefit of stock hood air duct with FMIC?
I was thinking of removing all the plastic air duct under the hood and above the grill. How many of you kept it on with a FMIC and is there any benefit?
Motocooney is offline   Reply With Quote
 Old 09-03-2013, 07:59 AM   #2
TurboGsxr600's Avatar
Posts: 127   (View Stats)
TurboGsxr600 has a reputation beyond reputeTurboGsxr600 has a reputation beyond reputeTurboGsxr600 has a reputation beyond reputeTurboGsxr600 has a reputation beyond reputeTurboGsxr600 has a reputation beyond reputeTurboGsxr600 has a reputation beyond reputeTurboGsxr600 has a reputation beyond reputeTurboGsxr600 has a reputation beyond reputeTurboGsxr600 has a reputation beyond reputeTurboGsxr600 has a reputation beyond reputeTurboGsxr600 has a reputation beyond repute
Any air helping to cool your engine is a benefit. Not to mention it helps get cooler air to the intake as well.
08 Speed 3 - BNR Stage 3, Cobb AP, CPE TMIC, Turbo XS DP, CNT CB, Cobb SRI, Cobb Turbo Inlet, Forge BPV, Autotech Internals, EGR Delete, and other stuff im sure I forgot to mention
TurboGsxr600 is offline   Reply With Quote
 Old 09-03-2013, 08:32 AM   #3
Mortose's Avatar
Posts: 2,441   (View Stats)
Groans: 39
Good deed for the day:
If you take it off, there is a port in the radiator support that can be opened (used for the regular 3 air ducting) that will allow air to flow to a SRI.
Other than that, if you take it off, air flows around more redily then just on top of the motor, IMO.
99 miata: sold
 Old 09-05-2013, 11:01 AM   #4
Motocooney's Avatar
Have you removed yours?
 Old 09-05-2013, 11:02 AM   #5
Mortose's Avatar
Groans: 39
yep.
99 miata: sold
 Old 09-05-2013, 11:13 AM   #6
He Hate Me's Avatar
Posts: 460   (View Stats)
He Hate Me is the leader of the worldHe Hate Me is the leader of the worldHe Hate Me is the leader of the worldHe Hate Me is the leader of the worldHe Hate Me is the leader of the worldHe Hate Me is the leader of the worldHe Hate Me is the leader of the worldHe Hate Me is the leader of the worldHe Hate Me is the leader of the worldHe Hate Me is the leader of the worldHe Hate Me is the leader of the world
Removed the ducting and the "directors" behind the grill to help give some more air to the radiator (Corksport sells some "directors" that help channel more to the radiator since the intercooler takes up most the air flow) and only kept the snorkel tube for the battery box.
He Hate Me is offline   Reply With Quote
 Old 09-05-2013, 11:16 AM   #7
Motocooney's Avatar
But the battery box tube isn't connected to anything now right?
 Old 09-05-2013, 11:17 AM   #8
He Hate Me's Avatar
I think it has it's own "Christmas tree plugs" attached to it. Mines attached to the hood still, has some wiggle since it's not connected to the rest of the ducting but it's still attached.
 Old 09-05-2013, 11:19 AM   #9
Motocooney's Avatar
Sweet thx for the info. Ill be taking it off tonight
The Following User Says Thank You to Motocooney For This Useful Post:
He Hate Me (09-05-2013)
 Old 09-05-2013, 11:51 AM   #10
jambisgone696's Avatar
Posts: 93   (View Stats)
jambisgone696 has a reputation beyond reputejambisgone696 has a reputation beyond reputejambisgone696 has a reputation beyond reputejambisgone696 has a reputation beyond reputejambisgone696 has a reputation beyond reputejambisgone696 has a reputation beyond reputejambisgone696 has a reputation beyond reputejambisgone696 has a reputation beyond reputejambisgone696 has a reputation beyond reputejambisgone696 has a reputation beyond reputejambisgone696 has a reputation beyond repute
I think the best way is to drop the air flow behind/under the intercooler (Front/top).
Less air pressure behind the FMIC = more air flow thru it
remove air duct...
jambisgone696 is offline   Reply With Quote
Page generated in 0.29849 seconds with 24 queries
