Like Tree21Likes
 Old 04-12-2012, 08:44 AM   #1
Originally Posted by dturboman View Post
the engine let go last night while driving on the turnpike... no hole on block but bent a rod
It was just a matter of time at those boost and power levels.
atvfreek (04-12-2012), charlesfist (04-13-2012), Darksun280 (04-12-2012), dturboman (04-12-2012), phate (04-12-2012)
 Old 04-12-2012, 09:13 AM   #2
dturboman's Avatar
Posts: 1,174   (View Stats)
dturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the world
was not even in power when it happen, was doing 50 through a construction zone and it let go.
Looks like its going to be built now.
dturboman is offline   Reply With Quote
The Following 2 Users Say Thank You to dturboman For This Useful Post:
Boosted Beluga (04-12-2012), rfinkle2 (04-19-2012)
 Old 04-12-2012, 09:26 AM   #3
86AmishMs3's Avatar
Posts: 3,639   (View Stats)
Groans: 338
Sad to see it give....you pushed that little 3071 hard. Any thing seem off before it went.
Current: N54 135i
DCI, DP's, Exhaust, FMIC
12.3@122
2009 Mazdaspeed 3:
GT3076 - Corkey tuned
390whp/400wtq
12.8@114
Sold
The Following 2 Users Say Thank You to 86AmishMs3 For This Useful Post:
 Old 04-12-2012, 09:45 AM   #4
dturboman's Avatar
I had the AP hooked up a few minutes before it happened, and I was seeing more than usual PT knock, but it would just come and go as if the engine was maximizing fuel mileage, few minutes later it jerked hard and the clutch pedal was vibrating hard.
so it looks like there was no way to prevent it... it was just its time.
The Following 7 Users Say Thank You to dturboman For This Useful Post:
86AmishMs3 (04-12-2012), BigjohnB20 (04-13-2012), charlesfist (04-13-2012), Darksun280 (04-12-2012), phate (04-12-2012), rfinkle2 (04-19-2012), StayBroke (04-14-2012)
 Old 04-12-2012, 09:50 AM   #5
86AmishMs3's Avatar
Groans: 338
Gay..it went out like a little bitch. Wot always...have you learned nothing...Jk can't wait to see you back up again
Current: N54 135i
12.3@122
2009 Mazdaspeed 3:
390whp/400wtq
12.8@114
Sold
 Old 04-12-2012, 10:02 AM   #6
dturboman's Avatar
yeah man it sucks this could not have happened at a worse time.
the miles and the power took its toll on her, now we know 160k and high boost(28-32psi) will last just not forever.
going to do rods, pistons and new bearings, hopefully total with machine will be under 3k
The Following 4 Users Say Thank You to dturboman For This Useful Post:
86AmishMs3 (04-12-2012), charlesfist (04-13-2012), Darksun280 (04-12-2012), rfinkle2 (04-19-2012)
 Old 04-12-2012, 10:23 AM   #7
Stress over time on the rods weakens and they slowly deform. I don't want to bring back the S/N curve for metals but while there are some cars running around at 400+whp and especially high low end torque with a stock bottom end IMO even with the best tune you're on borrowed time. We've seen this time and again. That's not unreasonable given that's almost double factory rated hp and @dturboman here was running more than that.
GL with the build
charlesfist (04-13-2012), dturboman (04-12-2012), EdgeAutosport.com (04-12-2012), InFeXIoN (04-12-2012), rfinkle2 (04-19-2012)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f11/big-turbo-stock-block-thread-108396/
? View topic - getting 300WHP out of a KO4 in JHB This thread Refback 05-13-2013 09:59 AM
HOW TO GET 400WHP FROM YOUR SPEED 3 (the practical way) This thread Pingback 04-19-2012 03:02 PM
stock block big turbo dyno kmac MazdaSpeed 3/6 - Dyno Sheets/Discussions 178 06-24-2012 08:35 PM
Bad Turbo Results in New Block batman MazdaSpeed 3 - Engine, Transmission & Driveline 31 02-22-2010 08:32 AM
So...Turbo/motor limits on stock block & internals? 94jedi MazdaSpeed 3/6 - Turbo Induction 26 05-31-2008 08:01 AM
Page generated in 0.35432 seconds with 24 queries
