 Old 05-15-2015, 10:19 PM   #1
qkrthnu2's Avatar
Posts: 131   (View Stats)
qkrthnu2 has a reputation beyond reputeqkrthnu2 has a reputation beyond reputeqkrthnu2 has a reputation beyond reputeqkrthnu2 has a reputation beyond reputeqkrthnu2 has a reputation beyond reputeqkrthnu2 has a reputation beyond reputeqkrthnu2 has a reputation beyond reputeqkrthnu2 has a reputation beyond reputeqkrthnu2 has a reputation beyond reputeqkrthnu2 has a reputation beyond reputeqkrthnu2 has a reputation beyond repute
Default BNR S3 Slow Spool and Low Max Boost
I've been struggling to hit my boost targets with my BNR S3.
I'm currently targeting 20psi (3 Bar Map sensor is on the way)
Here's what I've done recently:
- Stock EBCS I was hitting 20psi until about 4500rpm then trailing off down to 15psi.
- Installed a Grimmspeed 3 port EBCS, initally in bleed mode just like stock. That held a little better, but not much.
- Installed Guardian Angel, tested and is now set at ~21psi.
- Switched Grimmspeed over to Interrupt mode
- Removed the restrictor pill I had been using
Spool is slow, e.g. I stomp it @ 3k and I don't hit 20psi unti 4200RPM.
20psi can be held until 5k, then it starts dropping off down to ~18psi above 6k
With the compressor connected directly to the wastegate it looks like spring pressure is only ~9psi. Is this adjustable?
I'm not sure if it's the wastegate, my stock CBE, or something else that is keeping me from hitting targets.
Just to show how bad it is I've attached a log where the boost source line popped off the EBCS (uncontrolled boost situation ) and I still wasn't hitting high RPM targets. You'll see where the line popped off because WGDC drops to zero with no effect.
_______________________________________________
Driver Mods - Mid Ohio Three Day Racing School
2006 Mazdaspeed 6 GT - 130k+ miles. Daily driver (Actually my Wife's car)
Shooting for a reliable 350 AWHP.
Surefire Remanufactured Engine Installed @ 135k.
Mods: BNR S3 Turbo \ Grimmspeed EBCS \ Guardian Angel \ Cobb AccessPort \ Bosch 3 Bar MAP sensor \ AWR RMM \ TurbineTech FMM \ Corksport HPFP \ cp-e Injector seals \ Autolite XP5263 plugs \ Ebay Circuit Werks DP \ Stock CBE \ HTP 3" Intake w/ DIY CAI \ cp-e TMIC \ DIY boost tubes \ Primary & Secondary EGR delete \ Bilstein Shocks \ 215/45ZR -18 Continental ExtremeContact DWS
PERM dual PVC plate and two Damond Motorsports catch cans. Full vacuum setup w/ VTA for over pressure.
PERM #1 -> DM OCC V1 -> DM PCV valve -> Check Valve -> Intake Manifold.
PERM #2 -> DM OCC V2 w/ VTA -> Check Valve -> Tee -> Valve Cover & TIP.
The others:
2009 BMW 135i - N54 - JB4 w/ backend flash \ SRI.
1998 VW GTI VR6 - 248k miles (stock clutch!) when wrecked (not my fault)
1995 Jeep XJ - 4.0 - AW4 \ Lift/Tires etc. 230k miles. Rust bucket / winter beater.
1995 Honda del sol VTEC - DIY hodge podge turbo setup \ self tuned w/ Neptune. 2550lbs ~270whp \ 150k+ miles on stock bottom end (4th clutch though) \ knock limited on 93 octane.
qkrthnu2 is offline   Reply With Quote
 Old 05-16-2015, 03:24 PM   #2
qkrthnu2's Avatar
I'm thinking it's just my Corksport SRI and stock cat-back that is limiting flow.
Does that make sense with the flow rates I'm seeing, or am I not flowing enough for that to be the problem?
The others:
The Following User Says NO Thank You to qkrthnu2 For This Un-useful Post:
Kor3y101 (05-16-2015)
 Old 05-16-2015, 04:06 PM   #3
aaronc7's Avatar
Posts: 8,057   (View Stats)
Groans: 370
SRI or catback shouldnt limit your boost by any meaningful amount. I suspect wastegate/boost control here but don't have any specific advice for you since I have been out of the Mazda game for awhile. I bet if you remove the vacuum line completely to the wastegate she will make plenty of boost...... gotta be a boost control solenoid/wastegate/tuning issue.
The Following 2 Users Say Thank You to aaronc7 For This Useful Post:
JgamB (05-22-2015), qkrthnu2 (05-16-2015)
 Old 05-16-2015, 04:21 PM   #4
How long have you been running the BNR?
When my BNR took its time to boost, my primary cat was gone and clogged. But even then, once in boost, it would hold 21 psi until redline so you have an extra issue to solve.
Easter Bunny (05-16-2015)
 Old 05-16-2015, 04:22 PM   #5
Kor3y101's Avatar
Posts: 193   (View Stats)
Kor3y101 has a reputation beyond reputeKor3y101 has a reputation beyond reputeKor3y101 has a reputation beyond reputeKor3y101 has a reputation beyond reputeKor3y101 has a reputation beyond reputeKor3y101 has a reputation beyond reputeKor3y101 has a reputation beyond reputeKor3y101 has a reputation beyond reputeKor3y101 has a reputation beyond reputeKor3y101 has a reputation beyond reputeKor3y101 has a reputation beyond repute
Here's a link to someone who had a similar issue ; My experience installing and tuning BNR stage 3
They adjusted the preload (wastegate actuator) and changed the restricter pill (which granted, isn't relevant to you with a 3 port) But have you tried changing the preload?
'12 Black Speed 3
CS RMM -~- CS SSP & Gearbox Bushings -~- CS OCC -~- CS LED light kit -~- CS Front and Rear Sway Bar -~- UnPlugged EGR Delete -~- CS Hood Struts -~- DVC30 WMI -~- JBR 3" Widepath -~- CS HPFP -~- GrimmSpeed 3 Port -~- HKS SSQV -~- CS TMIC -~- 500W Memphis Sub/Custom Wheel Well Box -~- 3" Xforce TBE -~- RayD Tuned
Kor3y101 is offline   Reply With Quote
The Following User Says Thank You to Kor3y101 For This Useful Post:
 Old 05-16-2015, 04:46 PM   #6
Some people have also had air leaks at the turbo housing.
Check for boost leaks.
Last edited by Easter Bunny; 05-16-2015 at 04:46 PM. Reason: MSF Database - Automerged Doublepost
cyclist20 (05-23-2015), qkrthnu2 (05-16-2015)
 Old 05-16-2015, 04:46 PM   #7
MD1032's Avatar
Posts: 2,624   (View Stats)
Groans: 143
It's gotta be something with the WGA not closing fully, or opening too easily for some reason (failure), right? Gotta remove the top of the downpipe and make sure the flapper is closed and the WG is working properly.
2007 Mazdaspeed3 GT
 Old 05-16-2015, 04:59 PM   #8
qkrthnu2's Avatar
Which 2871 compressor map (Google images search) matches the BNR S3 the closest? The various 2871 maps are vastly different. I figure I could rule out a boost leak by comparing MAF g/s to what the turbo should be moving.
No vacuum leaks for sure.
I'll definitely try adjusting the preload on the WGA, anyone have experience doing that? i.e. Two turns tighter would have how much of an expected effect? It's a fair bit of work to do a lot of trial an error, so I'd like to get it close to correct the first time.
The others:
 Old 05-16-2015, 05:11 PM   #9
CFI2008's Avatar
Posts: 259   (View Stats)
CFI2008 is the leader of the worldCFI2008 is the leader of the worldCFI2008 is the leader of the worldCFI2008 is the leader of the worldCFI2008 is the leader of the worldCFI2008 is the leader of the worldCFI2008 is the leader of the worldCFI2008 is the leader of the worldCFI2008 is the leader of the worldCFI2008 is the leader of the worldCFI2008 is the leader of the world
Check your fuel trims for boost leaks. There was a thread on here about adjusting he bnr preload with a how to. If I recall 1 full turn is 1 psi adjustment.
CFI2008 is offline   Reply With Quote
The Following User Says Thank You to CFI2008 For This Useful Post:
 Old 05-16-2015, 05:20 PM   #10
qkrthnu2's Avatar
What's the typical range of adjustability?
My trims are all pretty close to rock solid < 2
The others:
 Old 05-16-2015, 05:24 PM   #11
CFI2008's Avatar
BNR Stage 3 WGA adjustment
The Following 2 Users Say Thank You to CFI2008 For This Useful Post:
MD1032 (05-16-2015), qkrthnu2 (05-16-2015)
 Old 05-16-2015, 05:38 PM   #12
qkrthnu2's Avatar
Thanks CFI2008! That's an awesome thread, just what I needed.
The others:
 Old 05-16-2015, 06:23 PM   #13
qkrthnu2's Avatar
Just checked my turbo. Hard to see with the heat shields in the way, but it looked like there was quite a bit of room for more preload. Went back to the pics from the install and....
The others:
Last edited by qkrthnu2; 04-30-2016 at 02:39 PM. Reason: Defunct copy.com image links migrated to Google Drive
 Old 05-16-2015, 06:30 PM   #14
qkrthnu2's Avatar
Since I'm only seeing 9psi for spring pressure and I have the Guardian Angel in place, I think I'll pull the WGA and tighten it 4 turns.
This looks like it'll take more time than I want to spend this weekend, and I may as well wait for my 3 Bar MAP sensor to get here, so I probably won't get to this until next weekend.
The others:
 Old 05-22-2015, 04:41 PM   #15
qkrthnu2's Avatar
Wish me luck.
The others:
Last edited by qkrthnu2; 04-30-2016 at 02:40 PM. Reason: Defunct copy.com image links migrated to Google Drive
 Old 05-22-2015, 05:05 PM   #16
Mike@Stratified's Avatar
Posts: 1,119   (View Stats)
Before you go making pre-load adjustments, 3rd gear, in those temps from the first log, with your small intake, the turbo is going to struggle to spool up. I would try a 4th gear log starting at 3k and post that up. If you give too much pre-load you are going to fight boost spikes.
The Following 2 Users Say Thank You to Mike@Stratified For This Useful Post:
dale_gribble (05-29-2015), Rich990 (05-25-2015)
 Old 05-22-2015, 05:14 PM   #17
qkrthnu2's Avatar
Everything is apart, so it's getting adjusted LOL. I have a bunch of 4th gear logs, same results. I'm planning on moving to a 3" intake before too long, or should I go 3.5"? I'm thinking 3" will be fine since that would be significantly larger than the BNR inlet already.
The others:
 Old 05-22-2015, 05:26 PM   #18
3" should be plenty.
Easter Bunny (05-22-2015), qkrthnu2 (05-22-2015)
 Old 05-22-2015, 08:30 PM   #19
aaronc7's Avatar
Groans: 370
That's what she said
The Following 3 Users Say Thank You to aaronc7 For This Useful Post:
Cujo (05-29-2015), MazdaBoy2.3 (05-29-2015), MD1032 (05-22-2015)
 Old 05-22-2015, 08:34 PM   #20
She was being nice to you.
aaronc7 (05-22-2015), Rich990 (05-25-2015), SofaKingAwesome (07-15-2015)
 Old 05-22-2015, 08:38 PM   #21
JgamB's Avatar
Posts: 2,566   (View Stats)
Who is tuning the car? These WGDC values / responses don't look like anything I've ever seen, plummeting from 80% to zero in 1 second and then trying to recover to 100% just as quickly. That CHRA is probably just losing too much inertia to do what is being asked of it. These timing values look incredibly low, 4° from 3.9K all the way to 5.5K without knock.
Something is fucky.
The Following 3 Users Say Thank You to JgamB For This Useful Post:
Easter Bunny (05-23-2015), ItsNox (05-24-2015), ms6mil (05-22-2015)
 Old 05-22-2015, 09:26 PM   #22
qkrthnu2's Avatar
Something is fucky.
I'm tuning it. The EBCS boost source hose blew off in that log, and I was slightly over target so the computer was trying to bring it down but there's nothing it could do with the hose popped off.
My boost error ramp is higher than the OTS maps so that's how it moved so quickly.
The others:
 Old 05-22-2015, 10:12 PM   #23
JgamB's Avatar
How about a clean log - and I've never seen a base map with spark advance dialed back that far at 5.5K. I'm a bit concerned you might be really heating up the exhaust valves and it might've contributed to your knock.
Easter Bunny (05-23-2015), Rich990 (05-25-2015)
 Old 05-22-2015, 10:21 PM   #24
ms6mil's Avatar
Posts: 4,972   (View Stats)
Groans: 307
Or post the map.
"Here am I. Send me!"
GT3076 - 393/380 3/9 e85
PTE5862 - TBD
The Following User Says Thank You to ms6mil For This Useful Post:
JgamB (05-22-2015)
 Old 05-22-2015, 10:54 PM   #25
qkrthnu2's Avatar
Since I've been dealing with boost issues I haven't begun to tune timing, so yeah it is really low right now.
Got the car all back together, didn't lose the clip!
Installed a 3 Bar MAP sensor and swapped out brake rotors today too.
And I just ordered a HTP 3" intake from @EdgeAutosport.com!
Zero'd out my base WGDC table, made the MAP scalar adjustments and took it for a spin. My Boost error ramp hit its max at 20, so it wasn't quite zero'd out, but still looks like a good result from the preload adjustment. 4 turns tighter and spring pressure is now 13-14ish.
Short log attached. I'll get the boost dialed in tomorrow so that I can finally start tuning timing.
The others:
The Following 3 Users Say Thank You to qkrthnu2 For This Useful Post:
Easter Bunny (05-23-2015), JgamB (05-22-2015), ms6mil (05-22-2015)
 Old 05-22-2015, 11:04 PM   #26
JgamB's Avatar
Looks a whole lot more logical now. That 2.1 KR lift throttle knock might be a good idea to look for loose shit on your RMM / FMM.
Easter Bunny (05-23-2015), qkrthnu2 (05-22-2015)
 Old 05-22-2015, 11:06 PM   #27
ms6mil's Avatar
Groans: 307
Still interested in the map.
PTE5862 - TBD
The Following 3 Users Say Thank You to ms6mil For This Useful Post:
cshunter (05-23-2015), Easter Bunny (05-23-2015), JgamB (05-22-2015)
 Old 05-23-2015, 03:01 AM   #28
cshunter's Avatar
Posts: 1,312   (View Stats)
^ This brownie......
Post your shit up, he is helpful regardless of color.
2013 CWP That's slow
Previous: MILTUNED E85 K04
The Following 4 Users Say Thank You to cshunter For This Useful Post:
Easter Bunny (05-23-2015), ItsNox (05-24-2015), JgamB (05-23-2015), ms6mil (05-23-2015)
 Old 05-23-2015, 11:27 AM   #29
qkrthnu2's Avatar
I wasn't ignoring him, some of my best friends are brownies, I swear.
Not sure why y'all want to see my fugly azz map, it needs A LOT of work still. Timing is flat up top while sorting out boost. WGDC is flat since I'm basically starting over after adjusting WG preload, so basically not much to see. Here it is, laugh away.
I showed mine now show me yours.
The others:
 Old 05-23-2015, 01:41 PM   #30
qkrthnu2's Avatar
Well, it's holding boost above 5k now , but it's still taking more WGDC than I was hoping for, and spool hasn't really improved much.
I'm hoping the 3" intake will help.
The others:
 Old 05-23-2015, 04:15 PM   #31
JgamB's Avatar
No one wanted to laugh at your map - we just want to make sure you don't blow up your car. I'll take a look after the UFC fights tonight.
And I've seen a BNR S3 tuned on a 68mm intake, that isn't your primary issue.
The Following 6 Users Say Thank You to JgamB For This Useful Post:
cshunter (05-24-2015), Easter Bunny (05-23-2015), ItsNox (05-24-2015), MD1032 (05-23-2015), ms6mil (05-23-2015), qkrthnu2 (05-23-2015)
 Old 05-24-2015, 12:47 PM   #32
qkrthnu2's Avatar
I apologize for getting defensive. I just know my current map is going to get heavily criticized, and rightly so, it's no where near finished or close to anything someone would want to run. I definitely appreciate any help!
Here's a good example of the intermittent KR I'm seeing, which is why I initially reduced timing to 4 degrees up top while tuning boost, although it doesn't seem to have helped, so I guess I should just go back to something closer to OTS values.
These are back to back logs (and the map I was running at the time).
The first is an uphill on-ramp 3rd gear, nasty KR. Next is a downhill on-ramp a few minutes later, 3rd gear as well as some 4th, nothing but a few 0.35 KR counts.
Notice that downhill my WGDC went up to amost 100 to hold 20psi up top. Is that in part because of the low timing values? I would think if anything that would build more boost...
The others:
 Old 05-24-2015, 06:56 PM   #33
You have something mechanically wrong fucking your couch.
The Following 6 Users Say Thank You to Easter Bunny For This Useful Post:
ItsNox (05-26-2015), JgamB (05-24-2015), MazdaBoy2.3 (05-29-2015), ms6mil (05-24-2015), NCspecV81 (05-25-2015), Rich990 (05-25-2015)
 Old 05-24-2015, 08:01 PM   #34
JgamB's Avatar
I'm not familiar with Surefire remanufactured motors. (Google suggests sourced via Autozone?) Was the BNR installed along with the new motor, or had it already been running strong with a K04? I'd like to see how it behaves with stock timing and 0 WGDC since you've adjusted the WGA preload.
In other words roll it back to a base map.
And contrary to popular belief, we're usually here to help. It's not like you're asking about oil or front lips.
 Old 05-24-2015, 10:03 PM   #35
qkrthnu2's Avatar
Yeah AutoZone, there are only a few major sources for remanufactured engines. I installed the BNR on the original motor after the K04 was smoking for a while. The original engine (135k) let go while I was still running spring pressure on the BNR.
I can certainly load a stage zero OTS map. What are you expecting to see?
The others:
 Old 05-24-2015, 10:24 PM   #36
ms6mil's Avatar
Groans: 307
Just to go along with the PM I sent and what J is sayin, I too recommend starting with a fresh OTS map. As far as what to expect.... It's just to eliminate any possible factors that are and most likely going on with whatever hardware issues you may have.
Your WG, boost tables need a lot of work. You can see the behavior of your WG here...
Go back to a OTS map (with the obvious sensor edits) and zero out the WGDC, the ramp limiter (High) and the under side of the BEC table. Leave everything else OTS. Take some logs then post em.
PTE5862 - TBD
JgamB (05-24-2015)
 Old 05-24-2015, 11:04 PM   #37
qkrthnu2's Avatar
Ok I can do that. Just to be clear, stage zero OTS (load based) or a stage 1 (boost based)?
The others:
 Old 05-24-2015, 11:10 PM   #38
ms6mil's Avatar
Groans: 307
1,2 or 3 doesn't matter as you will be neutering the WG/comp tables. As long as you have the supporting mods, ie hpfp and IC.
Focus on one thing at a time. Start with the OTS, boost based, zeroed out map. confirm proper functionality of spring pressure. Post logs. Then we'll go from there.
PTE5862 - TBD
ItsNox (05-26-2015)
 Old 05-24-2015, 11:10 PM   #39
JgamB's Avatar
I want to see if the timing on your reman is off and what kind of spring pressure boost your WGA preload adjustment created, and it should give some indication of whether or not the motor is healthy. Minimal boost + mild spark advance shouldn't yield any knock.
 Old 05-25-2015, 01:49 PM   #40
qkrthnu2's Avatar
Ask and ye shall receive, fresh map and logs attached.
I Started with COBB Stage1+SF+DP 93 v234, zero'd out all of the boost target, comp and WGDC tables. Added in the 3 Bar MAP settings and my MAF cals.
The two logs attached were taken on the same stretch of road as the previous two runs I posted. First log is the 3rd gear uphill run, second is slight downhill 3rd and 4th.
Fuel is Costo (Top-Tier) 93 octane E10. Mods in signature are accurate.
File Type: ptm Stage1+SF+DP 93 v234 - Zeroed WGDC and boost tables - My 3Bar and MAF cal.ptm (18.4 KB, 2 views)
The others:
The Following User Says Thank You to qkrthnu2 For This Useful Post:
JgamB (05-25-2015)
Boost spike during spool with DP/EM; Dial down WG or up error compensation? dale_gribble MazdaSpeed 3/6 - ECU Computer Tuning 49 04-01-2014 03:01 PM
BNR S1 Slow Spool + Boost Spike thricestrat MazdaSpeed 3/6 - Turbo Induction 13 06-25-2013 08:07 AM
Boost spike after spool up and shifting VertigoM 2010 MS3 - ECU Computer Tuning 27 05-16-2012 08:08 AM
Initial turbo spool "spoolup" boost spikes fortressofcomfort 2010 MS3 - ECU Computer Tuning 8 04-18-2012 09:06 PM
Trouble shooting big turbo slow spool time Ckmazdaspeed3 2010 MS3 - Troubleshoot/Diagnostics 87 06-18-2011 10:58 AM
Page generated in 0.61219 seconds with 31 queries
