 Old 12-03-2013, 04:59 PM   #1
maddocx240's Avatar
Posts: 823   (View Stats)
Default bnr s3 smoking
So after having my bnr installed fir about 5 months now im getting smoking at idle. At first it wasn't too apparent, but now its happening more. It doesn't bother me to much, but I'm thinking its gonna get worse. Just trying to see if anyone else has experienced this. Maybe the turbo seals didn't seat properly or something. I'm going to do a compression test to make sure there's no issue there. I really don't feel like taking this turbo off again, but looks like I might have to.
 Old 12-03-2013, 05:01 PM   #2
obijack's Avatar
Posts: 1,830   (View Stats)
Do you use a turbo timer? Do you use Rotella T6? Did you try raising your idle?
2014 Honda Grom-Red
2014 Yamaha Grizzly 350- Blue
 Old 12-03-2013, 05:07 PM   #3
mxlplx71's Avatar
Posts: 3,269   (View Stats)
Groans: 128
how many miles on the engine? maybe pcv or valve seals.
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
 Old 12-03-2013, 05:10 PM   #4
KevMS6's Avatar
Posts: 316   (View Stats)
One of the uk guys had a problem when installed his bnr3, started smoking very soon after installation.
Low failure rate but these things happen
Tuned with by
 Old 12-03-2013, 05:10 PM   #5
kby
kby's Avatar
Posts: 653   (View Stats)
kby is the leader of the worldkby is the leader of the worldkby is the leader of the worldkby is the leader of the worldkby is the leader of the worldkby is the leader of the worldkby is the leader of the worldkby is the leader of the worldkby is the leader of the worldkby is the leader of the worldkby is the leader of the world
You have no luck
kby is offline   Reply With Quote
 Old 12-03-2013, 05:24 PM   #6
maddocx240's Avatar
No need for a turbo timer on a water cooled turbo. I use rosella t6.' I didn't try raising my idle they.
 Old 12-03-2013, 05:34 PM   #7
maddocx240's Avatar
Engine has 70,000 miles on it. It was fine when i first got my s3, then I had the issue with an extension messing up the turbine wheel, sent it back to bnr and turbo was rebuilt, smoking issues started soon after. It wasn't much at first, but now it's a bit more noticeable. Valve seals or PVC could be a the issue but the turbo hasn't been that long and there was no issue with that before.
Did he get it taken care of under warranty?
Originally Posted by kby View Post
You have no luck
Yeah I've had some bad luck lately, but smokey turbo ain't the end of the world lol..
Last edited by maddocx240; 12-03-2013 at 05:34 PM. Reason: MSF Database - Automerged Doublepost
The Following 2 Users Say Thank You to maddocx240 For This Useful Post:
kby (12-03-2013), mxlplx71 (12-03-2013)
 Old 12-04-2013, 12:15 PM   #8
KevMS6's Avatar
The guy in uk paid to get it refurbished in uk, too much bother sending it back so he just cut his losses. Zero smoking problems since getting it done so must of just been a bad turbo I guess...
Good luck with yours
Tuned with by
 Old 12-04-2013, 12:17 PM   #9
Since it's journal bearing you could get the turbo rebuilt relatively cheaply.
 Old 12-04-2013, 07:25 PM   #10
Mazdazilla6's Avatar
Posts: 3,657   (View Stats)
I would get your PVC checked out first. The valve is very cheap to replace. No point in having it get rebuilt if it's going to happen again. The BNR turbos are obviously better but that doesn't mean they fix our crap PVC.
VersaTuner = Versatune
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Autotech = HPFP Internals
Grimmspeed = EBCS
 Old 12-05-2013, 07:13 AM   #11
maddocx240's Avatar
Yea I'm gonna check the pvc first. I'm gonna check a few things over the weekend. And to rebuild a s3 isn't much money at all. But turbo is still under warranty, so um good there.
 Old 12-05-2013, 08:02 AM   #12
LatinKraze's Avatar
Posts: 804   (View Stats)
My BNR is fine. Been running it fine for 10 months and 110k on my motor.
Do you have oil in the IC or TIP? Catch can fills quickly? How's your oil consumption? Do a leak down after compression test too.
2016 CX-5 GT AWD
Smoking MS3 DV8 MazdaSpeed 3/6 - Turbo Induction 10 02-25-2010 04:29 PM
Maybe smoking? watdog MazdaSpeed 6 - Engine, Transmission & Driveline 17 03-15-2009 04:28 PM
Page generated in 0.31611 seconds with 27 queries
