![]() Join Date: Apr 2016 Location: Long Island
Rep Power: 0 ![]() ![]() ![]() Thanks: 138
Groaned at 8 Times in 4 Posts
(Thread Starter) | Not Ranked : 0 score My 2007 Speed3 is completely stock other than the cat on the downpipe replaced with straight pipe done by the previous owner. Today I was going WOT and noticed that around 5800 RMPS the boost drops from 14 to like 10 within a fraction of a second. I understand after doing some reading that with a stock car, its normal, but I got a video of it just in case because the drop in boost does seem a little dramatic. Sent from my SM-G900T3 using Tapatalk Last edited by MS3Shadow; 04-30-2016 at 03:46 PM. | |||
![]() Join Date: Apr 2009 Location: Wooster, OH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 210
| Not Ranked : 0 score you need hpfp internals with catless downpipe! watch your fuel pressure, don't go WOT until you get them. do some more reading
__________________ 07 SPEED 6 W/ GEN PU MOTOR SWAP/BNR S3/ K27 OIL FEED LINE/CUSTOM OIL DRAIN LINE/COBB INJECTOR SEALS/COBB XLE/CX RACING FMIC/CORKSPORT POWER SERIES 3" EXHAUST (CATLESS)/M2 3" DOWNPIPE (CATLESS)/COBB AP V3/GRIMMSPEED EBCS/JBR 3.5" WIDE PATH INTAKE/XS POWER V3 TURBO MANIFOLD/PNP INTAKE MANIFOLD/AUTOTECH INTERNALS/3 BAR MAP SENSOR/VTCS DELETE/KOZMIC MOTORSPORTS EGR DELETE/JBR BSD & BAFFLE TRAY/JBR OCC/NGK PLUGS/SURE TORQUE R6 RMM/AWR TRANSMISSION & PASSENGER MOUNTS/SURE JUGGERNAUGHT REAR DIFF MOUNT/CORKSPORT REAR DIFF MOUNT/FIDANZA FLYWHEEL W/ LUK CLUTCH/TWM SHORT SHIFTER/SURE COUNTER SHIFT/SURE SHORTCUT/H&R LOWERING SPRINGS/KONI YELLOWS/ WHITELINE RSB/ AWR END LINKS FRONT&REAR/ CORKSPORT FRONT & REAR STRUT BARS/SPC FRONT CAMBER BALL JOINTS/BRAIDED STEEL BRAKE & CLUTCH LINES/FIBER IMAGES VENTED HOOD/CORKSPORT FRONT PLATE RELOCATE/PC VALVE COVER/TRUNK MOUNTED RED TOP/INTERIOR MODS K04 93 FREEKTUNED 271 AWHP/296TQ K04 E85 FREEKTUNED 309 AWHP/360TQ BNR S3 93 FREEKTUNED 336 AWHP/360TQ BNR S3 E85 FREEKTUNED 375 AWHP/376TQ |
(Thread Starter) | Not Ranked : 0 score Oh, I thought that was only if I got an aftermarket catless downpipe. Not if the cat was just deleted, thanks Sent from my SM-G900T3 using Tapatalk Would that be the cause of the boost cut? Sent from my SM-G900T3 using Tapatalk Last edited by Speed3Pedro; 04-30-2016 at 11:15 AM. Reason: MSF Database - Automerged Doublepost |
| Not Ranked : 0 score i'm not certain if that pertains to just having a deleted cat or not, but the only way to really tell is to monitor your fuel pressure. if you dont have an access port, get the torque app and and obd 2 plug in. hpfp internals should be done regardless if you plan on doing anything down the road.
| You will need fuel pump internals even with a deleted cat. sent from my Nexus 6P
![]() Join Date: Jun 2009
| Not Ranked : 0 score Get pump internals - now. Any upstream increased exhaust flow (downpipe or race pipe deleted or gutted cat) will overtax the high pressure fuel pump. Stay out of boost until you get that done. Also, have you changed plugs recently? If so, what brand and what gap? They should be iridium fine wire plugs with a gap of no more than .028" -- many aftermarket plugs come with an insanely wide gap. Boost increase that comes along with removing that cat (presumably in the race pipe or secondary cat section), can cause "spark blow out" if the plugs are gapped too wide. This happens even on stock tune. That will induce boost cut followed by recovery when under maximum load. Check your plugs if not certain they are gapped correctly. This is no substitute for hpfp internal upgrade, however. That is mandatory with your mod.
| The Following User Says Thank You to MSMS3 For This Useful Post: | Speed3Pedro (05-03-2016) |
(Thread Starter) | Not Ranked : 0 score @msms3 Already ordered my autotechs. I properly gapped my NGK plugs about a month ago Sent from my SM-G900T3 using Tapatalk |
| The Following User Says Thank You to Speed3Pedro For This Useful Post: | MSMS3 (05-04-2016) |
| Normal Boost Readings on Stock MS3 | projectr13b | MazdaSpeed 3/6 - Turbo Induction | 4 | 12-07-2013 01:50 PM |
| cp-e TIH normal?! | Vinnie | 2010 MS3 - Turbo Induction | 6 | 04-03-2012 04:37 PM |
| Is this normal? | atenza_freak | MazdaSpeed 3/6 - ECU Computer Tuning | 40 | 01-26-2010 09:54 PM |
