 Old 03-17-2013, 07:22 PM   #1
sriser66's Avatar
Posts: 380   (View Stats)
sriser66 is the leader of the worldsriser66 is the leader of the worldsriser66 is the leader of the worldsriser66 is the leader of the worldsriser66 is the leader of the worldsriser66 is the leader of the worldsriser66 is the leader of the worldsriser66 is the leader of the worldsriser66 is the leader of the worldsriser66 is the leader of the worldsriser66 is the leader of the world
Default Boost issue
Ok, here is the back story.
I bought a GTX3071R from 06speed6 about a month ago and installed it. Was a huge pain in the ass! I have the stock downpipe for now and the the stock intercooler. Had to get a new turbo because the old one smoked some much it was embarrassing. Intercooler and downpipe are next. I have an AP, catch can, 3 inch TIP, intake, egr delete, and my fuel pump holds great pressure till 1700. 06speed6 has already ported the exhast housing on the turbo, and I checked to make sure it sealed properly.
Now the problem.
I am only getting 10 psi of boost, no matter what tune I have used. I hooked the wastegate vacuum line up to the boost tube right above the turbo and ran a T in that to the ebcs. I bought a new grimmspeed ebcs and am running it in 2 port mode for right now till i figure out the issue. I have done a boost leak check and it came back fine, and I have used all new vacuum lines to eliminate that problem.
The car runs great up till 10 psi, but after then it just stays at 10, as where before I was boosting to 20 and tapering to 17.5 consistently.
I am out of ideas and I have searched the forums to find any answer and tried what I can. I do have an AP and can do logs if anyone thinks it would be helpful.
Thanks for any help, and if I have missed anything, I will not take offense to me being an idiot.
sriser66 is offline   Reply With Quote
 Old 03-18-2013, 10:44 PM   #2
mach69's Avatar
Posts: 79   (View Stats)
mach69 has a reputation beyond reputemach69 has a reputation beyond reputemach69 has a reputation beyond reputemach69 has a reputation beyond reputemach69 has a reputation beyond reputemach69 has a reputation beyond reputemach69 has a reputation beyond reputemach69 has a reputation beyond reputemach69 has a reputation beyond reputemach69 has a reputation beyond reputemach69 has a reputation beyond repute
You seem to have the exact same problems mentioned in the thread linked below. In that thread its a BNR S3 which is similar to your turbo. You will need to restrict the flow to your EBC (if you are using that). The grimmspeed in 2 port mode (I've read) works the same as the stock EBC. You should run the grimmspeed in 3 port mode and you wouldn't need to restrict the flow with welding tips. Thats what I plan to do when I go S3.
Boost Problems.
Off Topic Laugh: Theres seriously a Gainesville, GA? Isn't the Gainesville in FL enough?
2008 Mazdaspeed 3 - True Red
Engine: CPE Nano, CPE TIP, CPE TMIC, CPE HPFP, CS BeCuse Injector Seals, SU Boost Tubes, Forge BPV V1, ITV-22, AQ Motorsports DP, Dashhawk, Spin-on Oil filter conversion, Saikou Michi OCC, Cobb AP Self-tuned, VTCS Delete, EGR Delete, TB Coolant Bypass, DFDD VVT, 3 bar map
Drivetrain: Southbend Clutch Stage 3 DD, JBR Short Shift Plate, SU Shifter Bushings, CPE Stage 2 RMM, CPE TMM
Suspension: Koni Yellows, Eibach Springs, Cobb RSB, MOOG Swaybar Endlinks, Energy Suspension FSB Bushings
mach69 is offline   Reply With Quote
The Following User Says Thank You to mach69 For This Useful Post:
sriser66 (03-19-2013)
 Old 03-19-2013, 06:31 AM   #3
sriser66's Avatar
Yeah, there is a Gainesville, Ga, it is about 40 miles north of Atlanta. Your not missing much, but I will take anything over any town that has the FL Gators. lol.
Thanks for the tip, I will try it today, I am eventually going to run the Grimmspeed in 3 port mode once I get this issue resolved, I just want to make sure it is not the WGA.
 Old 03-19-2013, 02:18 PM   #4
sriser66's Avatar
It worked!! I bought the 8mm that you mentioned in your thread and I am boosting up to 15 now. I just need to tweak the AP now to hit the targets I would like. Thanks!!
 Old 03-19-2013, 10:40 PM   #5
mach69's Avatar
You are welcome. I think you meant 0.8mm.
Good luck with your tuning. 3 port ftw.
Prosport Boost Gauge Issue Jkspeed MazdaSpeed 3/6 - Car Audio & Electronics 7 09-15-2014 02:37 PM
Issue with hpfp/boost?!?! please help maf07003 Mazdaspeed3/6 General Discussion 15 02-25-2013 09:18 PM
Partial boost surging issue Zbrit00x Gen2 MS3 General Discussion 10 10-10-2012 04:19 PM
part throttle boost issue dooderek MazdaSpeed 3/6 - Turbo Induction 4 11-07-2011 02:32 PM
Hypertech Boost issue? ANMSPD3 MazdaSpeed 3/6 - ECU Computer Tuning 26 05-04-2010 08:48 AM
Page generated in 0.26561 seconds with 21 queries
