Like Tree34Likes
 Old 08-07-2012, 06:53 AM   #201
rob ms6gt's Avatar
Posts: 416   (View Stats)
Originally Posted by Mistersix View Post
Never thought of removing the headlight.
How well does the bumper fit now? Did you run into issues with the foglight shrouds?
How well does it fit now? Well it fits fucking perfect! Had to cut bumper behind foglight shrouds and a bunch of the airdam section. Before that it didn't fit at all.
I'll get you guys some more pics when I swap out the core.
ROB MS6GT
2006 Liquid Platinum Metallic Mazdaspeed 6
Stratified Tune, Stratified GA V2, Cobb AP V2, GTX3071R, HTP 4" Intake, Synchronic Diverter Valve, 3 bar MAP, Stratified Boost Dial, Corksport Injector Seals, Autotech Internals, Ebay DP, Custom TR8 FMIC, DevilsOwn Meth, Damond Catch Can, JBR 70 Duro Trilogy, TT front diff mount, Penis Eater top diff mount, Cut OEM Springs, Koni Yellows
rob ms6gt is offline   Reply With Quote
 Old 08-07-2012, 07:06 AM   #202
rob ms6gt's Avatar
Originally Posted by ESB Jiu JItsu View Post
@rob ms6gt looks great what size ebay IC are you running now and what were are bats/am temps/coolant temps with that IC ? Thank you I know myself and others would love to start being able to see some bat comparisons on ebay ICs since so many of us are running them.
Im running the core the OP used. I'll post up some logs when I get home tonight.
ESB Jiu JItsu likes this.
ROB MS6GT
The Following User Says Thank You to rob ms6gt For This Useful Post:
ESB Jiu JItsu (08-07-2012)
 Old 08-07-2012, 06:40 PM   #203
rob ms6gt's Avatar
I took a couple logs. I wasn't sure what you guys needed. I took one big log right from my house, on a short ride to the highway, to a 1234 gear pull, then a another short ride so you could see how long it took to cool. Then the other log is a 3rd gear pull.
However Im overboosting and getting fuel cut. Plus I'm not hitting fuel targets. So there wiil be no more WOT or logs till I get straightened out.
ROB MS6GT
 Old 08-16-2012, 08:07 PM   #204
rob ms6gt's Avatar
Ok I got the tr-8 in today and took before and after logs. The tune isn't even close to right because I haven't had any time to dick with it, but it's the same tune on both logs. The only difference being the cores. The first is the CX Racing at 86 deg ambient, follwed by the Treadstone at 89 deg.
The calculated load says the CX makes more power, no? Please discuss.
ROB MS6GT
ESB Jiu JItsu (08-17-2012)
 Old 08-17-2012, 06:13 AM   #205
ESB Jiu JItsu's Avatar
Posts: 492   (View Stats)
ESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the world
this is interesting.....
2006 Mazdaspeed6 GT Liquid Platinum Metallic
"because racecar!" " I love this $%&*ing car"
-Gram Lights 57C 18"x7.5/Cooper SR3-A 2254018/H&R Springs/SURE RMM/Diff Straps
-2.75 Blow Through MAF/Custom CXracing FMIC&BOV/Fujita SRI/AEM dryflow/PG TIP/SLS TP/Exhaust Delete/NGK LTR7IX11 plugs/ TB Coolant BP/Bat->Trunk Relocation/JBR egr delete
-TWM Stage 2 Short Shifter/JBR Weighted Shift Knob/TWM 4in Shifter Extender
-Emil Drilled/Slotted rotors/Hawk HP Pads/Clutch Pedal Mod/Shift Counter Weight Mod
-Custom Vented Hood/Custom Front Bumper/Emblem delete/Prosport Mech. boost gauge
ESB Jiu JItsu is offline   Reply With Quote
The Following User Says Thank You to ESB Jiu JItsu For This Useful Post:
rob ms6gt (08-20-2012)
 Old 08-18-2012, 08:30 AM   #206
rob ms6gt's Avatar
Here a few comparison and bumper clearancing pics. Sorry about the blurry ones. I would have gotten more but the camera batt died. Use the endtank to detemine which is which in the pics. The CX has polished while the Treadstone are "as cast". The Treadstone clearly has more dense fin structure both inside and out. The TR8 fins are staggered as well while the CX are not.
Also It looks like I would have had to do little to no cutting on the airdam for the TR8 to fit.
ROB MS6GT
The Following 2 Users Say Thank You to rob ms6gt For This Useful Post:
ESB Jiu JItsu (08-19-2012), TiGraySpeed6 (08-18-2012)
 Old 08-19-2012, 07:17 AM   #207
maybe the Cx racing is technically higher flow because of the lack of fins and at a certain point that maybe is more important over the additional cooling fins? Im sure there is a trade off depending on the power your making, but very interesting data.
The Following 2 Users Say Thank You to ESB Jiu JItsu For This Useful Post:
J'sSpeed3 (09-01-2012), rob ms6gt (08-20-2012)
 Old 09-02-2012, 08:35 PM   #208
Voltwings's Avatar
Posts: 3,713   (View Stats)
Hey, where are you guys getting the flanges from, im having a hard time finding a weld on flange for my application (stock flange Turbosmart 50/50)? Nothing on Ebay has any sizes listed, and Googling "Turbosmart 50/50 flange" is next to hopeless haha. Thanks.
Past:
-Sold-
-Sold-
Current:
2012 Loaded Speed3 - Stock
2001 Miata - Basically stock
 Old 09-02-2012, 08:37 PM   #209
Don06speed6's Avatar
Posts: 2,492   (View Stats)
Don06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the world
Groans: 62
Read back, I posted a link to threadstone who sells pipe with a rotating Mazda flange on it.
Edit, post 181
Cobb AP(FREEK TUNED)/CS TBE/SURE AEROS/CPE TIH/ ITV 22/SU RMM/KMD INTERNALS/SURE DREADNAUGHT/JUGGERNAUGHT/WHITELINE RSB/SURE ANCHORS/SURE COUNTERWEIGHT/SURE SHORTCUT/JBR HEAVY KNOB/JBR EGR DELETE/SPC BALL JOINTS/CENTRIC BLANKS/HPS PADS/BNOON BOLT/ALTERED CUSTOMS FMIC/TURBO XS RFL
Don06speed6 is offline   Reply With Quote
The Following User Says Thank You to Don06speed6 For This Useful Post:
Voltwings (09-02-2012)
 Old 09-07-2012, 11:02 AM   #210
Carlo1170's Avatar
Posts: 232   (View Stats)
Carlo1170 is the leader of the worldCarlo1170 is the leader of the worldCarlo1170 is the leader of the worldCarlo1170 is the leader of the worldCarlo1170 is the leader of the worldCarlo1170 is the leader of the worldCarlo1170 is the leader of the worldCarlo1170 is the leader of the worldCarlo1170 is the leader of the worldCarlo1170 is the leader of the worldCarlo1170 is the leader of the world
Edit, post 181
I followed your link and I see nothing of the sort. Which one is it?
2007 True Red Speed3
--Cobb TIP--Cobb SRI--Sure Shifter Bushings--Prosport Premium Boost Gauge--Block8head Gauge Pod--
2002 Honda RVT1000R RC51
Carlo1170 is offline   Reply With Quote
 Old 09-08-2012, 03:51 PM   #211
Mistersix's Avatar
Posts: 2,585   (View Stats)
I used and adapter flange from SU on the BPV pipe that came with the CX racing pipe kit. Its basically a greddy to mazdaspeed flange.
The Following User Says Thank You to Mistersix For This Useful Post:
TiGraySpeed6 (09-08-2012)
 Old 09-10-2012, 09:02 AM   #212
same here CXracing BOV flange pipe FTW!
 Old 03-21-2013, 03:49 PM   #213
Rainmens's Avatar
Posts: 129   (View Stats)
Rainmens is the leader of the worldRainmens is the leader of the worldRainmens is the leader of the worldRainmens is the leader of the worldRainmens is the leader of the worldRainmens is the leader of the worldRainmens is the leader of the worldRainmens is the leader of the worldRainmens is the leader of the worldRainmens is the leader of the worldRainmens is the leader of the world
Wanted to thank h.h.sk1nny and everyone else for this thread (as well as Tigrayspeed6 for tons of help), i chose this core and went with the 2.25" piping kit from cxracing.. grand total was $246 shipped. I still have to get a cpl more reducer elbows and the adapter flange from SU. So when its all said and done, should be at approx $295.
Here's to lower temps in hot as balls Phoenix!!
304whp/360tq Vdyno 1.01 CF
Cobb AP, Sure 3" Full3 Aeros Intake, Autotech Internals, M2 DP, 3" CP-E Single Exit (w/resonator), 3.25" ETS, PnP'ed IM w/VTCS removed, 1/16"Sure TIG spacer Synapse BPV, AWR 70 Duro RMM, JBR 70 Duro TMM, Denso 1-Step Colder Plugs, TWM Shifter Bushings, SM OCC, Custom Shift Knob, Custom Shifter Weight, SURE Shorcut, H&R Springs, Tenzo DC-6 Wheels
Rainmens is offline   Reply With Quote
The Following 2 Users Say Thank You to Rainmens For This Useful Post:
h.h.sk1nny (02-16-2014), TiGraySpeed6 (03-21-2013)
 Old 03-21-2013, 06:55 PM   #214
Mistersix's Avatar
Cool. Going FMIC was a lot of work but totally worth it. Be sure to post up some pics to further the thread.
 Old 03-21-2013, 06:57 PM   #215
Roddiy's Avatar
Posts: 5,388   (View Stats)
Groans: 279
Does anyone have a link to the Piping kit for $100? Or something similar?
I can't find it anywhere :/
2010 LSM Speed3
#BakeryTuned
 Old 03-21-2013, 08:30 PM   #216
Rainmens's Avatar
search 2.5" if you didnt want 2.25"
2.25 Universal ALUM Intercooler Piping Kit Supra MR2 items in cxracing store on eBay!
 Old 03-22-2013, 05:21 AM   #217
Mistersix's Avatar
ebay is where i pretty much got everything. I started with a 2.25'' inch kit but ended up going 2.5" because it was harder to find the reducers and it was a bit more $$ because You need reducers for the turbo, throttle body and intercooler since its more than likely 2.5" inlet/outlet.
And there was limited selection with the 2.25" kits. There were a ton of 2.5" kits out there. Why is it you wanna go with 2.25"?
 Old 03-22-2013, 06:19 AM   #218
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
Using 2.25" and limited or no 90* bends does wonderful things to eliminate lag especially with the smaller turbos like the K04 or BNR.
If you have or are targeting something in the GT/GTX range you may prefer 2.5"
I used the 2.25 and was/still am impressed by the very minor change in feel from the top mount- TiGray goes FMIC
The original research and supporting math that convinced me to go with 2.25 is here- MS6 CXRacing 2.25 FMIC DIY Setup
340hp / 371tq
The Following 6 Users Say Thank You to TiGraySpeed6 For This Useful Post:
Axel907 (05-20-2013), dot584 (03-22-2013), magicka (03-25-2013), Mistersix (03-22-2013), Rainmens (03-22-2013), Sobe (08-03-2013)
 Old 02-09-2014, 09:35 PM   #219
UT-06-MS6's Avatar
Posts: 4   (View Stats)
UT-06-MS6 is an unknown quantity at this point
I have a cx racing kit and it fits ok, had to a lil extending on the intake side.. Now having to redo the hot pipe because its bend and leaking!! They use 90 bend alum to the ko4!! After many pulls sand take offs and put ons the not cutting…I ordered a silicon 90 2.5-2.0 to see if that helps. I i have to do is chop my bend hot 90 and use a silicon 90…Its that a bad idea? I throw on a gtx 3071/ewg so
i am tryin to figure this out before i put more power down!!
UT-06-MS6 is offline   Reply With Quote
 Old 02-16-2014, 09:11 AM   #220
Mistersix's Avatar
I used a 45* reducer with a 45* pipe coming off the turbo. The 90* coupler with a straight pipe hit the valve cover. Two 45* angles gave just enough clearance.
 Old 03-10-2014, 08:25 PM   #221
afronese1's Avatar
Posts: 73   (View Stats)
afronese1 has a brilliant futureafronese1 has a brilliant futureafronese1 has a brilliant futureafronese1 has a brilliant futureafronese1 has a brilliant futureafronese1 has a brilliant futureafronese1 has a brilliant futureafronese1 has a brilliant futureafronese1 has a brilliant futureafronese1 has a brilliant futureafronese1 has a brilliant future
It looks like everyone's going with the treadstone TR8. I want to go with the TR6 because I don't want to cut the crash bar and plan on sticking with the KO4 for a long time. Is anyone using the TR6?
MS6/SP63 Stage 1 build/APv3/BNR S4 v2/hpfp internals/JBR full 3" intake/ATP catted dp/Magnaflow cbe/GFB bov/Damond OCC/Damond egr delete/Treadstone TR1035 FMIC kit/CPE rear diff mount/CPE safe seals/Damond rmm/H&R co/18x9 conti dws 235-40/Stoptech bbk/morimoto xb led fogs/Osram Xenarc d2s 6000K bulb/osram led parking light/Led Tails/Purple Drank Tuned
afronese1 is offline   Reply With Quote
 Old 03-11-2014, 06:35 PM   #222
Mistersix's Avatar
My initial plans included using a TR6. But after measuring there didn't seem to be a way to fit it without cutting the crash bar or the tray, or both. Even at 6 inches tall, something has to go to make room. Maybe it would be easier to make it work once you had the actual item and test fitted it. But the measuring tape said other wise.
afronese1 (03-18-2014)
 Old 03-18-2014, 07:31 AM   #223
afronese1's Avatar
I might give it a shot and see how it goes with the TR6 when it gets warmer here in MD and stops snowing.
The Following User Says Thank You to afronese1 For This Useful Post:
Mistersix (03-18-2014)
 Old 05-26-2014, 09:48 PM   #224
afronese1's Avatar
Finally had the time and courage to try this fmic install. I did not want to move the washer, cut the crash bar, cut as little as possible off the front bumper, and wanted the treadstone tr6 intercooler. I have no plans to go bt so tr6 is perfect. I used the Nissan Sentra SE-R Spec-V Intercooler Brackets from Treadstone performance.
My setup uses the cxracing ms6 fmic pipes and clamps only, which worked out perfectly for me because I did not have to cut, bead, or weld anything and they're all beaded pipes. I did have to buy a u-pipe and cut it into a very short sort of 90 degree going into intercooler front turbo side (it is the only short black pipe you'll see in the photo).
There are still adjustments I need to make. As you can see, the intercooler isn't sitting horizontally straight, but you don't really notice it once the bumper is on. I only had to cut off the bottom panel off the front bumper to clear the intercooler and bumper fits, but barely lol.
Overall, this was a pain in the ass lol, but i did it!
The Following 3 Users Say Thank You to afronese1 For This Useful Post:
jack_hammer (05-27-2014), SamiChicago (12-22-2015), thehead (05-27-2014)
 Old 05-27-2014, 04:50 PM   #225
aviator79's Avatar
Posts: 3,934   (View Stats)
I was hesitant about routing right infront of the PS tank cause worried the engine could rock and crack it. Looks good, but hope you dont run into issue. I do not recall how the engine moves I just remember seeing it move more than I expected when I was at dyno.
 Old 05-27-2014, 09:01 PM   #226
thehead's Avatar
Posts: 1,141   (View Stats)
thehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the world
Groans: 143
I've had no issues with mine, I've been running it like that for 30k+ miles.
2016 BMW M235i
[Dead] 2006 MS6 #367 Liquid Platinum 73,000 miles
Engine - Killah built -L19 Headstuds - Steedspeed T3 Twin Scroll top mount goodness - Twin Scroll .83 A/R hotside GTX3071R - JMF V1 IM - Perm 6th Port - CP-E FMIC - SURE 3.25 MAF housing - customized EBay DP - Magnaflow CBE - Autotech HPFP internals
Electrical - GS EBC - Cobb AP Richtune in progress
Drive train - Techna-fit Stainless Steel clutch and brake lines - stoptech rotors - CorkSport RMM - Corksport Trans inserts - SURE Juggernaught & Dreadnaught - E4 heavy knob & Jbarone's Short Shift plate - Tenzo DC-5 Bronze +45 wrapped in ExtremeContact DWS 235/40-18's
Fluids Transmission - Motorcraft synthetic. PTO and Rear diff - Conklin Gold Guard Plus synthetic 75W-90. Engine Oil - Rotella T6 5W-40.
thehead is offline   Reply With Quote
The Following User Says Thank You to thehead For This Useful Post:
afronese1 (05-28-2014)
 Old 05-28-2014, 10:29 AM   #227
afronese1's Avatar
Did you upgrade your mounts?
 Old 05-28-2014, 03:44 PM   #228
aviator79's Avatar
Just RMM and FMM.
The engine I saw move if anything had only a RMM. I just used a spearco top to bottom core and stuck with routing on drivers side as main thing was to keep WW tank. Glad to see others go this route to prove it is safe.
 Old 12-22-2015, 09:30 AM   #229
SamiChicago's Avatar
Posts: 289   (View Stats)
SamiChicago is the leader of the worldSamiChicago is the leader of the worldSamiChicago is the leader of the worldSamiChicago is the leader of the worldSamiChicago is the leader of the worldSamiChicago is the leader of the worldSamiChicago is the leader of the worldSamiChicago is the leader of the worldSamiChicago is the leader of the worldSamiChicago is the leader of the worldSamiChicago is the leader of the world
Holy shit! I wish I would've seen this before I installed my FMIC.
Anyone with CX RACING FMIC went with TR8? I'm searching which brackets is recommended to use since my CX Racing intercooler will be sufficient enough for BNR S4.
'07 MS6: HTP 3 Inch Intake.Cobb AP.CorkSport CBE.ATP DP.FMIC.AutoTech Internals.Bosch 3 Bar map sensor.GRIMMSPEED 3 PORT EBCS. BNR S4.WISECO 9:5 pistons. Manley H-Beam rods. Keyed Crank by APEX. SouthBend Stage 3 clutch kit. Bilstein shocks. H&R Springs.
SamiChicago is offline   Reply With Quote
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f11/build-your-custom-front-mount-intercooler-276-a-99869/
Interests for intercooler kit for 200sx??? This thread Pingback 05-31-2014 04:05 AM
Bon setup non forger. This thread Refback 04-12-2013 05:30 PM
Whats New/General Speed 6 Discussion - Page 89 This thread Refback 05-14-2012 04:42 PM
Altered customs vs Corksport vs cxracing - Page 2 This thread Refback 03-08-2012 03:54 PM
Custom FMIC MSP6COP MazdaSpeed 3/6 - Turbo Induction 30 07-07-2012 04:18 AM
Custom fmic done jozi-111 MazdaSpeed 3/6 - Turbo Induction 31 01-17-2011 03:28 AM
Page generated in 0.54429 seconds with 34 queries
