 Old 02-05-2018, 11:00 AM   #1
Levi's Avatar
Posts: 18   (View Stats)
Levi will become famous soon enoughLevi will become famous soon enough
Default Buying used forge bpv v1, what do
Hey guys, so i might be picking up a used forge bpv v1 and had a few questions.
Is buying a used bpv a bad idea?
what would i have to do to the bpv before i install it(making sure it will work fine)
and what do i have to do post install ( do i need a dyno tune or is there a cobb map?)
i am currently running stage 1+sf but havnt been hitting anywhere near target boost (17psi), im at around 12-14psi. Have checked for leaks and cant seem to find anything so wanted to try switching out the bpv to see.
il toss a 3rd pull up in case anyone can figure out what else could be wrong.
Thanks!
Levi is offline   Reply With Quote
 Old 02-06-2018, 06:53 AM   #2
Posts: 2,826   (View Stats)
Why? If you are on stock K04 a test published years ago by Grassroots Motorsports Magazine demonstrated that the stock bpv holds boost better that the Forge bpv. You are taking a step backward unless you know for sure the stocker is leaking.
Have you tested the stock bpv? There are threads here on how to do that.
 Old 02-06-2018, 09:38 AM   #3
Thor Hammer's Avatar
Posts: 1,847   (View Stats)
Groans: 211
Like he ^ said. Unless its leaking don't bother. Spend your money on parts that increase performance. Not ricer sounds.
 Old 02-06-2018, 09:57 AM   #4
Levi's Avatar
Im no ricer, but i guess i had questionable information so will do. il get on checking it then looking for other explanations for my boost problem. Thanks guys!
The Following User Says Thank You to Levi For This Useful Post:
Thor Hammer (02-06-2018)
 Old 02-06-2018, 11:01 AM   #5
Groans: 211
Check the lines on your EBCS. Make sure the plastic nipple on the EBCS isn't cracked. Check the wastegate actuator arm as well. And of course a proper boost leak test.
New car buying guide: Buying an Audi like an adult Haltech Automotive News 0 06-14-2016 11:30 AM
Looking for Help - Buying MS3! G-Hart14 Mazdaspeed3/6 General Discussion 6 04-04-2015 09:33 PM
Buying a used AP.. vrspeed10 2010 MS3 - ECU Computer Tuning 6 11-03-2011 04:58 PM
Page generated in 0.26595 seconds with 23 queries
