 Old 11-29-2009, 06:17 PM   #1
socks's Avatar
Posts: 3,250   (View Stats)
Groans: 125
Default Byebye ATP Fail
So, i'm getting rid of the ATP housing on my turbo. swapped it out today with this:
T3 Flange
3" Vband Exit
.82 A/R
Will be using this with a RaceRoots T3 exhaust manifold, RaceRoots 3" Vband Downpipe, and Tial 44mm Wastegate
The old housing:
The Following 20 Users Say Thank You to socks For This Useful Post:
06Speed6 (11-30-2009), 802MS3 (11-29-2009), aaronc7 (11-29-2009), AmillieMS6 (11-30-2009), bioevolve (11-30-2009), boosted3 (11-30-2009), D-Rick21 (12-02-2009), danesti (11-30-2009), djuosnteisn (11-29-2009), doubleflusher (11-30-2009), Fobio (11-30-2009), FreeFlyFreak (12-02-2009), jayspeed3 (11-29-2009), KeysMS3 (12-07-2009), madvillain (11-30-2009), mexicant (11-29-2009), Murse (12-04-2009), Realgib3 (12-08-2009), SpeedSixxx (12-01-2009), taf0422 (11-29-2009)
 Old 11-29-2009, 06:21 PM   #2
Tripple OG
NJSPEED3's Avatar
Posts: 5,703   (View Stats)
Groans: 113
nice! should give much better air flow
 Old 11-29-2009, 08:42 PM   #3
jayspeed3's Avatar
Posts: 356   (View Stats)
jayspeed3 has a reputation beyond reputejayspeed3 has a reputation beyond reputejayspeed3 has a reputation beyond reputejayspeed3 has a reputation beyond reputejayspeed3 has a reputation beyond reputejayspeed3 has a reputation beyond reputejayspeed3 has a reputation beyond reputejayspeed3 has a reputation beyond reputejayspeed3 has a reputation beyond reputejayspeed3 has a reputation beyond reputejayspeed3 has a reputation beyond repute
Groans: 60
Need pics of install and post-install!
Performance Mods: Cobb AP, e48 Tune (22psi), Cobb SF w/ Amsoil Filter, RPMC TIP, Synapse Synchronic BOV, Custom FMIC w/ Godspeed Type C, CP-e DP, Custom CBE, KMD v2 CDFP Internals, Denso ITV-22, MattD OCC, Castrol Edge 5w30, XT-M5-QS Gear Oil, SU RMM, Cobb STS, Cobb Stage2 Suspension Kit, Bilstein HD, RX-8 Wheels, Toyo Proxes 4 Plus (235/40/18)
jayspeed3 is offline   Reply With Quote
 Old 11-29-2009, 09:12 PM   #4
taf0422's Avatar
Posts: 4,689   (View Stats)
Groans: 192
nasty....enough said
[SIZE="1"]07 MS3 GT..
GTX3076r --- 479/412
S4-460/400
Highest HP BNR S3
BNR-S3 424/397
 Old 11-29-2009, 09:26 PM   #5
martyxattack's Avatar
Posts: 924   (View Stats)
martyxattack is the leader of the worldmartyxattack is the leader of the worldmartyxattack is the leader of the worldmartyxattack is the leader of the worldmartyxattack is the leader of the worldmartyxattack is the leader of the worldmartyxattack is the leader of the worldmartyxattack is the leader of the worldmartyxattack is the leader of the worldmartyxattack is the leader of the worldmartyxattack is the leader of the world
Groaned at 37 Times in 27 Posts
your reign is supreme sir
know your roll
martyxattack is offline   Reply With Quote
The Following 3 Users Say Thank You to martyxattack For This Useful Post:
danesti (11-30-2009), KeysMS3 (12-07-2009), MarkyMark (11-30-2009)
 Old 11-30-2009, 01:23 AM   #6
madvillain's Avatar
Posts: 4,160   (View Stats)
Groans: 78
very nice man, good to see you got rid of that thing. and it's even better to see you're going to be throwing some RR parts on the car! how do you plan to route the FMIC piping? or do you plan on getting their fmic kit as well?
 Old 11-30-2009, 05:33 AM   #7
socks's Avatar
Groans: 125
I'm going to adapt my cobb fmic. It shouldnt sit so much lower that i cant come up with something.
The Following 2 Users Say Thank You to socks For This Useful Post:
madvillain (11-30-2009), SpeedSixxx (12-01-2009)
 Old 11-30-2009, 06:09 AM   #8
how much was just the housing? and how big of a difference is this really gona net someone whos EWG anyway?
 Old 11-30-2009, 06:38 AM   #9
socks's Avatar
Groans: 125
The difference is the size of the housing, not just switching from IWG to EWG. The ATP 3071r has a .50a/r turbine housing, which is TINY. Its no wonder the torque falls off even on the BT cars.
Also, now there wont be a "chamber" behind the turbine causing turbulance.
Theoretically, this will spool a tad later, but hold power harder/longer.
Realistically, I dont know how much difference it will actually make. But having a Vband downpipe will make my life so much easier.
Here is a picture of my super sweet custom compressor housing bracket, sans IWG:
The Following User Says Thank You to socks For This Useful Post:
xcoldricex (12-17-2009)
 Old 11-30-2009, 07:29 AM   #10
if you weld the ATP iwg shit and port the fuck out of it (kind of like PTP did on the new SST's) will u be able to see a lil more increase?
 Old 11-30-2009, 07:59 AM   #11
socks's Avatar
Groans: 125
you'll still have a small A/R....
it comes down to the gangster factor. You want to be proper, or make it work?
I "made it work" for so long, and now i want to make it Proper.
do it twice or do it right? I did it twice. my advice is to do it right.
The Following 7 Users Say Thank You to socks For This Useful Post:
802MS3 (11-30-2009), BudUMfan (12-02-2009), bykeryder4life (12-01-2009), djuosnteisn (11-30-2009), madvillain (11-30-2009), SpeedSixxx (12-02-2009), xcoldricex (12-17-2009)
 Old 11-30-2009, 12:04 PM   #12
madvillain's Avatar
Groans: 78
damn, you should see some good numbers with this! can't wait to see some 400whp+ without n02!
 Old 11-30-2009, 12:23 PM   #13
socks's Avatar
Groans: 125
I've heard whispers of there being multiple 400whp cars floating around now...
I think you'll see it sooner than my car will be put back together.
djuosnteisn (11-30-2009), SpeedSixxx (12-02-2009)
 Old 11-30-2009, 12:26 PM   #14
madvillain's Avatar
Groans: 78
i've got a lot of things in the works myself, so hopefully mine will be one of them!
 Old 11-30-2009, 04:50 PM   #15
boosted3's Avatar
Posts: 855   (View Stats)
boosted3 is the leader of the worldboosted3 is the leader of the worldboosted3 is the leader of the worldboosted3 is the leader of the worldboosted3 is the leader of the worldboosted3 is the leader of the worldboosted3 is the leader of the worldboosted3 is the leader of the worldboosted3 is the leader of the worldboosted3 is the leader of the worldboosted3 is the leader of the world
I just gave up lol,
boosted3 is offline   Reply With Quote
The Following User Says Thank You to boosted3 For This Useful Post:
superskaterxes (11-30-2009)
 Old 11-30-2009, 05:07 PM   #16
das macht kein sinn
mizboo102's Avatar
Posts: 1,202   (View Stats)
mizboo102 is the leader of the worldmizboo102 is the leader of the worldmizboo102 is the leader of the worldmizboo102 is the leader of the worldmizboo102 is the leader of the worldmizboo102 is the leader of the worldmizboo102 is the leader of the worldmizboo102 is the leader of the worldmizboo102 is the leader of the worldmizboo102 is the leader of the worldmizboo102 is the leader of the world
Hold power harder and longer? Now that's what I like to hear
NATOR East Coast
1999 Miata http://www.mazdaspeedforum.org/forum/forum/f25/time-121773/
& 2014 WRX SWP premium - DD
"Making your mark on the world is hard. If it were easy, everybody would do it. But it's not. It takes patience, it takes commitment, and it comes with plenty of failure along the way. The real test is not whether you avoid this failure, because you won't, it's whether you let it harden or shame you into inaction, or whether you learn from it; whether you choose to persevere."
mizboo102 is offline   Reply With Quote
The Following User Says Thank You to mizboo102 For This Useful Post:
Murse (12-04-2009)
 Old 11-30-2009, 05:29 PM   #17
socks's Avatar
Groans: 125
yes, you have to run a bigger housing so you can hold power harder and longer.
 Old 12-01-2009, 11:24 PM   #18
BoostedBlack6's Avatar
Posts: 261   (View Stats)
BoostedBlack6 has a reputation beyond reputeBoostedBlack6 has a reputation beyond reputeBoostedBlack6 has a reputation beyond reputeBoostedBlack6 has a reputation beyond reputeBoostedBlack6 has a reputation beyond reputeBoostedBlack6 has a reputation beyond reputeBoostedBlack6 has a reputation beyond reputeBoostedBlack6 has a reputation beyond reputeBoostedBlack6 has a reputation beyond reputeBoostedBlack6 has a reputation beyond reputeBoostedBlack6 has a reputation beyond repute
Hey you two, i believe you need to keep your harder and longer concepts to yourself.
2006 Black Mica MS6: Cobb AP, Stage 2 v105 93, MSD Dashhawk, Speedie6 TIP, CPe Nano SRI, HKS SSQV, Custom FMIC, Custom 3" Single Exhaust w/ Dynomax Race Muffler, H&R Sport Springs, SPC Adjustable Balljoints, TWM Stage 2 Short Shifter w/ SU bushings, 18" Drag DR-34s
BoostedBlack6 is offline   Reply With Quote
 Old 12-01-2009, 11:44 PM   #19
IshiKage's Avatar
Posts: 6,231   (View Stats)
Groans: 278
i hope mizboo is a chic and sexy
2015 Mazda 6
 Old 12-01-2009, 11:50 PM   #20
Nope 5'9" 320lb hispanic guy.....thats just how Socks rolls
The Following 3 Users Say Thank You to BoostedBlack6 For This Useful Post:
IshiKage (12-02-2009), MarkyMark (12-02-2009), Murse (12-04-2009)
 Old 12-02-2009, 12:04 AM   #21
SpeedSixxx's Avatar
Posts: 4,184   (View Stats)
SpeedSixxx is the leader of the worldSpeedSixxx is the leader of the worldSpeedSixxx is the leader of the worldSpeedSixxx is the leader of the worldSpeedSixxx is the leader of the worldSpeedSixxx is the leader of the worldSpeedSixxx is the leader of the worldSpeedSixxx is the leader of the worldSpeedSixxx is the leader of the worldSpeedSixxx is the leader of the worldSpeedSixxx is the leader of the world
Groans: 778
where you get the turbine?....i have the same ATP gt3071 as u just with the anti surge compressor inlet.....not installed yet...
maybe I should go your route before my install...already getting your IM. +) Ty
i assume our ATP housing and turbine is worth shit so if I go your route I would be left with a nice dirty paper weight.
how much is the RR v band DP?.....fuck there goes more money!
2003 SilverStone Grey Honduh S2000
SpeedSixxx is offline   Reply With Quote
 Old 12-02-2009, 12:19 AM   #22
madvillain's Avatar
Groans: 78
don't even bother with the ATP setup man, if you're going to do it do it right the first time. it will cost you much more to scrap the old and start over
The Following User Says Thank You to madvillain For This Useful Post:
 Old 12-02-2009, 12:31 AM   #23
SpeedSixxx's Avatar
Groans: 778
yeah! thanx! LOL
if you read I already got the atp 3071...LOL...
 Old 12-02-2009, 01:06 AM   #24
madvillain's Avatar
Groans: 78
haha i know, im just saying.. if you install it it will depreciate even more, so dont throw it on there just yet!
 Old 12-02-2009, 01:15 AM   #25
SpeedSixxx's Avatar
Groans: 778
what to do...what to do
 Old 12-02-2009, 06:53 AM   #26
socks's Avatar
Groans: 125
Yea, a "proper" 3071r costs less than the "bolt-on" version anyways.
I think it retails on the ATP site for $1400 or so, and the "bolt-on" version is $1900
you forgot that he's 65 years old.
Last edited by socks; 12-02-2009 at 06:53 AM. Reason: MSF Database - Automerged Doublepost
 Old 12-02-2009, 07:14 AM   #27
KoukiS14's Avatar
Posts: 146   (View Stats)
KoukiS14 has a reputation beyond reputeKoukiS14 has a reputation beyond reputeKoukiS14 has a reputation beyond reputeKoukiS14 has a reputation beyond reputeKoukiS14 has a reputation beyond reputeKoukiS14 has a reputation beyond reputeKoukiS14 has a reputation beyond reputeKoukiS14 has a reputation beyond reputeKoukiS14 has a reputation beyond reputeKoukiS14 has a reputation beyond reputeKoukiS14 has a reputation beyond repute
Look at that nice crack on the ATP housing spreading from the turbine outlet towards the wastegate.
KoukiS14 is offline   Reply With Quote
The Following User Says Thank You to KoukiS14 For This Useful Post:
Darksun280 (12-02-2009)
 Old 12-02-2009, 07:22 AM   #28
socks's Avatar
Groans: 125
ill check that when i get home and get better pics of it. I didnt even notice. Honestly I didnt care enough once that thing was off to even look at it.
 Old 12-02-2009, 07:37 AM   #29
Fux Wit It
Darksun280's Avatar
Posts: 9,214   (View Stats)
Groans: 175
Lol I saw that fail too. I'm used to looking for that on SST turbos not fucking GT30's. Fail Fail fail....
Carry on citizens....
10.7 @ 133 auto 1G DSM
 Old 12-02-2009, 04:54 PM   #30
socks's Avatar
Groans: 125
Makin room for RaceRoots:
And yes, ill be cleaning up that mess while its open.
Not to mention, that crack in the old housing was BAD. from the wastegate opening, all the way into the turbine area.
Last edited by socks; 12-02-2009 at 05:07 PM. Reason: MSF Database - Automerged Doublepost
The Following 3 Users Say Thank You to socks For This Useful Post:
Dash08 (12-02-2009), madvillain (12-02-2009), SpeedSixxx (12-03-2009)
 Old 12-02-2009, 06:24 PM   #31
hey would anyone with an ATP 3076 willing to trade turbine housings with the T3 version like on socks car? its brand new and i dont care if yours is shitty as long as its not cracked.
 Old 12-02-2009, 06:32 PM   #32
socks's Avatar
Groans: 125
you can HAVE mine, but as you can see, its cracked. lol..
 Old 12-02-2009, 10:33 PM   #33
turd burglar's Avatar
Posts: 1,895   (View Stats)
Groans: 39
Wait socks weren't u gonna sell ur speed like 2 weeks ago lol i musta missed somethin
 Old 12-02-2009, 10:39 PM   #34
lol scratch that last one. ill have the same exact turbine housing socks is using in this thread brand new for sale if anyone wants early dibs on it. just PM me
 Old 12-02-2009, 10:44 PM   #35
flyrevs2's Avatar
Posts: 1,235   (View Stats)
flyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the world
this will prolly void your warantee, make sure you don't have any blowups
2013 Mazdaspeed3 Gen2
Mods: Cobb SRI, Tip, Turbosmart BPV, Cobb AP, Cp-e DP, CPE HPFP, CPE RMM, PTP Kicker Mount
flyrevs2 is offline   Reply With Quote
 Old 12-02-2009, 10:51 PM   #36
lol was this directed towards me? haha if so have u seen my sig? ironically my dealer is so chill they just did suspension work under warranty because they know i rate them so high on their mazda warranty service survey. haha
 Old 12-02-2009, 11:06 PM   #37
madvillain's Avatar
Groans: 78
wtf? i think socks kissed his warranty goodbye a looooong time ago haha
 Old 12-03-2009, 08:29 AM   #38
socks's Avatar
Groans: 125
i think my ms3 was the only one in the world that didnt come with a warranty from the factory....
 Old 12-03-2009, 08:49 AM   #39
Fuck sushi rolls
rodrigo's Avatar
Posts: 18,719   (View Stats)
Groans: 356
some day all this will hopefully see a 1320 ft track and a timeslip.....
 Old 12-03-2009, 08:51 AM   #40
socks's Avatar
Groans: 125
Im thinking the 18th.
look for 11's. 420ish whp is my guess.
big things in the works
The Following 6 Users Say Thank You to socks For This Useful Post:
djuosnteisn (12-03-2009), gsrtype1 (12-07-2009), madvillain (12-03-2009), Realgib3 (12-08-2009), SpeedSixxx (12-03-2009), superskaterxes (12-03-2009)
FAIL! TURBINETECH L/A IC FAIL! bioevolve MazdaSpeed 3/6 - Turbo Induction 50 07-21-2009 04:25 PM
Page generated in 0.55647 seconds with 37 queries
