 Old 09-27-2018, 06:54 AM   #1
jtimms6's Avatar
Posts: 22   (View Stats)
jtimms6 is on a distinguished road
Default CEL p2009 and low boost
I’ve been getting a CEL for code p2009 which is the IMRC and it says the part could be bad or have a bad connection or a bad vacuum line on the part. Has anyone else had this problem or know where and what to look at first? Also I’ve been having low boost getting around 13-13.5 however on the highway if I drop to 5th to pass someone and sometimes even coming out an exit in 4th the car will peak at about 14-14.38 psi. I don’t think I have a boost leak because I can build boost haven’t had the chance to do a boost leak test but I also don’t understand why I’m higher gears I can build more boost? Is the car under more of a load in a higher gear? And does anyone know or think the two issues could be related to each other? Thanks guys let me know what you think.
DC sports cai
Test pipe w stock catback
Stage 1+ 93 octane tune
Cobb AP
jtimms6 is offline   Reply With Quote
 Old 09-27-2018, 07:45 AM   #2
Posts: 2,233   (View Stats)
You IM is separated in 2 set of runner and it move on and off with a vaccuum actuator. It could be a bad solenoid, a vac live, a tear in the actuator diaphragm or just rust/dirt in the moving parts...
You car get more load in higher gears and get more time to build boost than in lower gears...
P2009 Code IzzysAuto 2010 MS3 - Troubleshoot/Diagnostics 5 11-13-2016 05:05 PM
CEL P2009 no idea what it is Highestrich4 MazdaSpeed 6 - Engine, Transmission & Driveline 7 06-12-2016 09:46 PM
P2004 P2009 codes angiehbrown MazdaSpeed 3/6 - Troubleshoot/Diagnostics 4 01-31-2016 08:27 PM
DTC P2004, P2009 f-castrillo 2010 MS3 - Troubleshoot/Diagnostics 24 07-14-2015 07:27 PM
P2004 P2009 codes Sphinx1983 Mazdaspeed3/6 General Discussion 1 05-20-2015 08:44 AM
Page generated in 0.23028 seconds with 21 queries
