![]() | | #41 | ![]() |
![]() Join Date: Nov 2009 Location: South Portland, Maine
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,579
| Not Ranked : 0 score
~AJ | |
| The Following User Says Thank You to AJ713 For This Useful Post: | Ckmazdaspeed3 (01-07-2011) |
![]() | | #42 | ![]() |
![]() Join Date: Nov 2010 Location: St. Louis missouri
Rep Power: 1310 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,310
Groans: 134
| Not Ranked : 0 score |
![]() | | #43 | ![]() |
![]() Join Date: Nov 2008 Location: Sanford/Orlando/Daytona Beach FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,682
Groans: 278
| Not Ranked : 0 score i think. ERZ performance posted a link to a gb thread. go look at ERZ's thread.
__________________ 2015 Mazda 6 Pioneer Z2 DVD/Nav :|: Hifonics 800/4 & 1100/1 :|: Kicker Solo Classic 15" |
![]() | | #44 | ![]() |
![]() Join Date: Feb 2010
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,452
Groans: 82
| Not Ranked : 0 score Well, seeing as gutted ('natored') stock downpipes come up in the f/s sale section, I'd say you'd be able to. I still wouldn't though. Even with an aftermarket turbo, you can still run into boost spike (remember, this happened to 9900 when he went with a iwg 3076 I think, and older members here said it was a common problem), which a cat will help prevent. I mean, if you plan on going BT, you can go with one of the bolt-on turbos (ATP 2871, 3071, 3076, BNR, etc.), but those are expensive. You can save some money by keeping your stock DP for the time being, so when you go big turbo, you're not limited by the downpipe you have. On a whim, I shot off an e-mail to bullseye, and they make a smaller hotside for a holset hx-35 (70 trim IIRC) that bolts up to a v-band downpipe and a t3 manifold. What that means is that you can pair that hotside with an hx-35 compressor side and have a great turbo for a lot less than any of the ATP bolt-on turbos. I'm still doing research into this, so the only difficulty would be getting a v-band DP either fabbed up or buying a cheap one on ebay and do some cutting and welding to get it to fit to either A.) a test pipe, or B.) A catback exhaust A t3 manifold shouldn't be that hard to find used if you have some time to wait for one to pop up, and worse comes to worse, you just send steedspeed $675 and get their t3 manifold w/ 38mm EWG. I still need to look into it more, but that's what my ideal BT setup would be - t3 holset hx-35 w/ smaller hotside, v-band flange, steedspeed manifold, and single exit exhaust. If you take your time working on it, you can put it together for less than an arm and a leg. |
| The Following User Says Thank You to Speed3eak For This Useful Post: | Ckmazdaspeed3 (01-07-2011) |
![]() | | #45 | ![]() |
| Approved MSF Vendor ![]() Join Date: Jan 2010
Rep Power: 197 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
Groaned at 18 Times in 18 Posts
(Thread Starter) | Not Ranked : 0 score Group buy is over but we are having a intro promotion price for the next two weeks.
__________________ ERZ Performance 1680 west winton ave 3 Hayward CA 94545 800-363-8599 Best regards Thomas http://www.erzperformance.com http://www.cntracing.com Become our facebook fan |
| The Following User Says Thank You to ERZperformance For This Useful Post: | AJ713 (01-08-2011) |
![]() | | #46 | ![]() |
Groans: 278
| Not Ranked : 0 score ERZ. you should update your product descriptions for the DPs, adding 2010+ here and on your site
| The Following User Says Thank You to IshiKage For This Useful Post: | AJ713 (01-08-2011) |
![]() | | #47 | ![]() |
Groans: 134
| Not Ranked : 0 score Do we know if the catted will throw a cel on a gen2? |
![]() | | #48 | ![]() |
(Thread Starter) | Not Ranked : 0 score Not sure, but we do sell a L shape 02 cel fix for 35 dollars if you have this problem.
![]() | | #49 | ![]() |
Groans: 134
| Not Ranked : 0 score Works most of the time? |
![]() | | #50 | ![]() |
| The Following User Says Thank You to ERZperformance For This Useful Post: | Ckmazdaspeed3 (01-10-2011) |
![]() | | #51 | ![]() |
![]() Join Date: Jun 2010 Location: Wichita, KS
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 40,628
Groans: 386
| Not Ranked : 0 score From what I've gathered, catted dp on genpu does not cause any CELs... I will be ordering one either this week or next, but I won't be putting it on til the AP comes out and I can datalog... |
| The Following 2 Users Say Thank You to wolly6973 For This Useful Post: | AJ713 (01-14-2011), Ckmazdaspeed3 (01-10-2011) |
![]() | | #52 | ![]() |
| Ur moms boyfriend ![]() Join Date: Jul 2010 Location: Chicago, ILL
Rep Power: 1272 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 923
Groans: 70
| Not Ranked : 0 score yo for real they CNT needs to make a CBE for the 2nd gen quick |
![]() | | #53 | ![]() |
(Thread Starter) | Not Ranked : 0 score OBX makes a lower price exhaust for the 2010 Mazdaspeed 3
![]() | | #54 | ![]() |
Groans: 278
| Neutral : +1 score when are yall going to have one made, theres plenty people who will buy. and OBX sucks
| The Following User Says Thank You to IshiKage For This Useful Post: | AJ713 (01-14-2011) |
![]() | | #55 | ![]() |
Groans: 70
| Not Ranked : 0 score dont see it on their website |
![]() | | #56 | ![]() |
(Thread Starter) | Not Ranked : 0 score OBX is not that bad anymore they been in business since 1986 the first 20 years they were buying exhaust from factory in oversea and these factory would under cut anyone so the pass three years OBX have their own factory oversea so they can control the quality now. I have seen a lot of their header and exhaust in person and I have to say they are much better then most other company exhaust or header in the market today.
![]() | | #57 | ![]() |
![]() Join Date: Jul 2009 Location: Keene, NH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 53
| Not Ranked : 0 score Does this DP mate up with the stock catback flange?
__________________ 08.5 Mazdaspeed 3 - Cobb AP w/ Boost Targetting at 17psi, CP-E Nano SRI, ETS 3.25" TMIC, SU Test Pipe, CP-E RMM, Bilstein Sports, Cobb Springs, Progress RSB, Short Shift Plate, SU Solid Shifter Bushings, Dashhawk, Gold 18x8.5 Rota G-Force's, 235/40/18 Hankook Ventus V12's 253WHP/274WTQ on a Mustang Dyno before tune, 282WHP/318WTQ in VD after tune 97 Suzuki TL1000S Naked - LeoVince Slip-Ons, K&N Filter, PCII, fully custom naked setup 89 Kawasaki 650SX Stand-Up Jetski |
![]() | | #58 | ![]() |
(Thread Starter) | Not Ranked : 0 score yes, don't use the gasket we provide and only use OEM O gasket (it's not 100 perfect)
![]() | | #59 | ![]() |
| Banned ![]() Join Date: Nov 2010 Location: Abingdon maryland
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 194
| Not Ranked : 0 score i feel really dumb for asking this but i will just call myself a noob and get it over with if i order the cnt catted downpipe a testpipe and a cnt catback i wont throw a cel |
![]() | | #60 | ![]() |
![]() Join Date: Jun 2008 Location: lancaster, ca
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,297
Groans: 91
| Not Ranked : 0 score cnt dp catted or non catted is a complete one piece that replaces the factory test pipe and dp. so if you get cnt or cobb or aq or cp-e they are all one piece that replaces BOTH the TEST and the DOWN PIPE.
__________________ "Go find your own enterprise, and get the fuck off my bridge!" 2008 Speed 3 GT- Cobb SRI, Cobb TIP, AQ Motorsports DP (Turboxs Adapter Plate), TurboXS FMIC, GReddy CBE, GReddy BPV, 3P Flange, GReddy TT, GReddy Boost Gauge, Vent Pod, GReddy Shift Knob, SU Shifter Bushings, AWR RMM, Cobb RSB, Cobb AP, Cobb Shifter Weight, Autotech FP Internals, Corksport Exhaust Hangers. "parked hard" 1996 200sx SE-R- Injen CAI, GReddy SP CBE, Tein Basic Coilovers, Progress FSB, Clutch Masters Flywheel, Progress RSB, Cusco FSTB, Progress LCAB, Prothane MM, JWT POP Program, JWT S4 Cams, Mishimoto Radiator, GoodRidge SS Brake Lines, Powerslot Rotors, Nismo CF Shift Knob. "back in action" |
![]() | | #61 | ![]() |
| Not Ranked : 0 score reall wow ok my bad i need to brush up on my reading skills thank you for the confomation |
| The Following User Says Thank You to Speeed3 For This Useful Post: | skeeter149 (01-13-2011) |
![]() | | #62 | ![]() |
(Thread Starter) | Not Ranked : 0 score You don't need a test pipe if you purchase a CNT Racing Downpipe.
| The Following User Says Thank You to ERZperformance For This Useful Post: | Speeed3 (01-13-2011) |
![]() | | #63 | ![]() |
![]() Join Date: Mar 2010
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6
| Not Ranked : 0 score I dont see why people are bitching about throwing a cel. 1. You cant smog it anyway even if you had no cel. 2. Your waranty is done anyway. |
![]() | | #64 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 755
| Not Ranked : 0 score Why do you think the car wouldn't be somgable with a catted dp? |
![]() | | #65 | ![]() |
Groans: 278
| Not Ranked : 0 score not true
| The Following User Says Thank You to IshiKage For This Useful Post: | Ckmazdaspeed3 (01-14-2011) |
![]() | | #66 | ![]() |
Groans: 134
Do you mean I could end up w an exhaust leak, or, will I need to mod something, or can fitment just be a pita? I've got one day of work to put this on... I can get help, but it is my DD for work. | |
![]() | | #67 | ![]() |
![]() Join Date: May 2010 Location: West Palm Beach, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,842
Groans: 819
| Not Ranked : 0 score im highly considering jumping in on this too
__________________ |
![]() | | #68 | ![]() |
![]() Join Date: Jun 2010 Location: West Jordan, UT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 91
Groans: 32
Groaned at 27 Times in 12 Posts
| Not Ranked : 0 score i had turbo xs cbe and turbo xs catless dp and rp. that shit is annoyingly loud. i would never go catless again. even on my BT i got a catted test pipe.
__________________ CP-E INTAKE W/ AMSOIL FILTER, CP-E INLET, TURBOSMART BOV, DENSO ITV22, AWR RMM, STREET-UNIT TMM & PMM, STEEDSPEED MANI CERAMIC COATED, T3 GT3076, TIAL EWG, CUSTOM V-BAND DOWNPIPE, UR CATTED TESTPIPE, TURBO XS CATBACK EXHAUST, COBB FMIC, CP-E FUEL PUMP, DASHHAWK+CP-E MOUNT, JBARONE SSP, COBB ACCESSPORT STAGE 2 SF 91 FMIC. SELF TUNED WITH 400HP/375TQ @ 21 PSI ON 100 OCTANE. |
![]() | | #69 | ![]() |
Groans: 278
| Not Ranked : 0 score txs and cpe are super loud and they sound like shit
| The Following User Says NO Thank You to IshiKage For This Un-useful Post: | pearl_ms3 (01-14-2011) |
![]() | | #70 | ![]() |
the CNT downpipe will fit perfect with all HKS . CNT exhaust or any exhaust with a large flat surface flange.
__________________ ERZ Performance 1680 west winton ave 3 Hayward CA 94545 800-363-8599 Best regards Thomas http://www.erzperformance.com http://www.cntracing.com Become our facebook fan | |
![]() | | #71 | ![]() |
Groans: 32
| Not Ranked : 0 score ill agree with you on the cpe. but the turbo xs sounds the best of any on the market for the speed. i have heard the hks/greddy/cobb/cpe in person, and those dont have shit on the turbo xs.
![]() | | #72 | ![]() |
Groans: 278
| Not Ranked : 0 score eww. disagree. corksport takes the cake for that, it shits on txs. txs makes the car sounds more like a SRT4 all the others dont sound good to me either. txs, glh, hks and cpe all sound terrible, cpe and txs being the worst IMO
![]() | | #73 | ![]() |
Groans: 32
| Not Ranked : 0 score id rather my car sound like an srt than a honda like the greddy does imo.
![]() | | #74 | ![]() |
Groans: 134
Anyway, can I simply get underneath the car and take a picture of the flange, or do I need to take the exhaust off to get the photo you are looking for? If it helps, I have a gen2 w stock exhaust. Will this ship right away? I just installed a FMIC, and even w a tune, I think my shit is slower because of the pressure drop. It is my understanding that this should help me regain the boost. | |
![]() | | #75 | ![]() |
Groans: 278
corksport sounds the best, hands down
__________________ 2015 Mazda 6 Pioneer Z2 DVD/Nav :|: Hifonics 800/4 & 1100/1 :|: Kicker Solo Classic 15" | |
![]() | | #76 | ![]() |
Groans: 32
| Not Ranked : 0 score the txs tbe sounds bad. but txs cbe with cobb dp sounds much better.
![]() | | #77 | ![]() |
Groans: 278
| Not Ranked : 0 score heard a cs turbo back in person. i bet you will agree its the best sounding. nothing else comes close damn we are chopping up erz's thread haha my bad, erz. back on topic
![]() | | #78 | ![]() |
![]() Join Date: Dec 2009
| Not Ranked : 0 score I haven't got my DP yet ( supposed to show on Monday) but in order for it to fit the stock CBE, I think we need an adapter. If I am remembering correctly, the flange on the CNT DP is flat. CNT has an adapter on their website in the Subaru section, and this would also probably work. Subimods.com 3" Down Pipe To Stock Catback Adapter Flange - Cat Back Systems - Subaru Aftermarket Parts Same idea as CNT's adapter, but it has a nice taper that fits in the DP to reduce the flow gradually when it hits the stock CBE. ideas?
__________________ 2008 Black Mica MS3 Sport |
![]() | | #79 | ![]() |
![]() Join Date: Jan 2011 Location: sanford, fl
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1
| Not Ranked : 0 score im feeling left out with my ms6 hope u guys make some stuff for us but looks good |
![]() | | #80 | ![]() |
| Not Ranked : 0 score Hands down the Exhaust sounds GREAT! Like Best sounding I've heard so far. Deep subie sound. No drone at all on the freeway at 65mph. Is quite at normal driving, and does get pretty loud at WOT. The install is a PAIN!!!!! You guys where not joking lol. Took about 5 hours. My buddy has a lift in his garage so it made things so much easier. Everything Bolt on just fine! BUT beware that bottem right turbo stud is a BITCH!!!!! Sorry no pics. I had no cam. I'll hit up my buddy later for sound clips. I dod throw a cel. its saying something about my 02 senser. maybe I fucked it up who knows? I'm tired as shit right now, so My details are not here right now. Nap time! |
| The Following 2 Users Say Thank You to b00b00 For This Useful Post: | mdl3v8 (01-15-2011), Monotonous ONE (01-15-2011) |
| In stock now CNT Racing Mazdaspeed 3 catted and non Catted downpipe | ERZperformance | ERZPerformance | 325 | 08-04-2013 05:13 PM |
| Convert your catless downpipe to catted | E4Performance | Mazdaspeed3/6 General Discussion | 23 | 01-14-2010 04:48 PM |
| catted or catless | jlocurto | MazdaSpeed 3 - Engine, Transmission & Driveline | 10 | 06-04-2009 07:15 PM |
| catless or catted cpe dp? | asiandude74 | MazdaSpeed 3/6 - Turbo Induction | 16 | 01-02-2009 11:58 AM |
