 Old 06-14-2016, 08:31 PM   #1
BuddySpeed3's Avatar
Posts: 479   (View Stats)
Groaned at 7 Times in 4 Posts
Default CorkSport 3.5 inch intake
I saw this recently and am wondering how it compares to the HTP and JBR 3.5 intakes.
Gotta start looking into which intake to buy when I get the BNR S4.
My goal is about 350 whp. I'm on stock block and don't want to max out the fueling system.
I know that either of these intakes will be more than suitable for that goal.
Ideally I want the loudest one because I gotta hear that turbo spoooolll!!!
But I also want it to fit perfectly. I've done a bit of reading but haven't found any reviews on the Corksport.
My Injen CAI was much louder than my current JBR SRI due to the long aluminum plumbing.
I really miss that intake but had to part it out due to water being sucked into it. (hydro shield helped, but still had issues).
On to bigger and better things!
The Following 2 Users Say NO Thank You to BuddySpeed3 For This Un-useful Post:
faeker (06-16-2016), Thepedigree13 (06-14-2016)
 Old 06-15-2016, 12:05 AM   #2
mxlplx71's Avatar
Posts: 3,269   (View Stats)
Groans: 128
the metal ones are louder. as for better size v.s. size 3.5=3.5 .
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
 Old 06-16-2016, 06:27 PM   #3
The HTP maf housing has an inner diameter of 3.37 inches. The Corksport and JBR have an ID of 3.5 inches. Either way, I won't be maxing them out on the stock fuel system I don't think. The JBR 3.5 is not metal, while the other two are, so I'd imagine the JBR is a bit quieter.
Originally Posted by c_bye View Post
I have the CS 3.5" Intake. It's a really great peice, and fits perfectly. I had the Cobb TIP and Short Ram with the air box before, but after upgraded turbo (also CS), I switched to the bigger tube. I like the fact it is all one metal piece from the turbo up into the bay, and has a nice gloss black finish. Sounds great, you can definitely hear the difference. The MAF housing also has a built in air straightener, which I've heard is not necessary but I've also heard people having problems without one.
If you go with a 3.5" intake you need a smaller battery box/relocated ECU (CS makes a box as does JBR), and because of the larger MAF housing you need a tune, but if you're getting a bigger turbo anyway that is going to happen regardless.
Yes I may end up just moving the ECU on top of the fuse box and securing it somehow. I want to keep the stock battery box in place, because it's where I have my relay and boost switch for my WMI kit stashed away nice and clean.
Last edited by BuddySpeed3; 06-16-2016 at 06:29 PM. Reason: MSF Database - Automerged Doublepost
 Old 06-16-2016, 07:27 PM   #4
Actually JBR has both aluminium and the silicone 3.5in intakes.
sent from my Nexus 6P
BuddySpeed3 (06-19-2016)
 Old 06-15-2016, 07:27 AM   #5
JakeMS3's Avatar
Posts: 1,164   (View Stats)
Groaned at 7 Times in 5 Posts
As long as its an aluminum intake you'll hear the turbo spool, and like he mentioned ^^ a 3.5" intake is a 3.5" intake. I run the Cp-e TIP along with their 3.5" MAF+intake and it sounds just as loud as other aluminum intakes I've heard. Its silicone, that's why I was surprised its so loud.
2013 LSM w/tech
Cobb AP V3, CBE
CS Turbo tuned by PD
JBR FMIC Pipe Kit w/TR8
CP-E TIP/3.5" Intake
DM OCC/TMM
Forge V2 BPV
Bilstein B8 w/Swift springs
Wilwood 6 pot BBK
EBC RedStuff rear pads
Konig Hypergram 18x8.5"
 Old 06-15-2016, 07:40 AM   #6
c_bye's Avatar
Posts: 67   (View Stats)
c_bye is a splendid one to beholdc_bye is a splendid one to beholdc_bye is a splendid one to beholdc_bye is a splendid one to beholdc_bye is a splendid one to beholdc_bye is a splendid one to beholdc_bye is a splendid one to behold
2008 Cosmic Blue MS3 GT // CS TD05-18G Turbo // Freektuned //Denso ITV22 // CS DP // CS 3.5" Full Intake // CS 3.5 Bar Map // CNT Catback // CS HPFP // JBR FMIC Piping // Treadstone TR8 FMIC // CS OCC // CS Heat Sheilds // CS boost hoses // CS ECU relocation // Cobb AP3 // Cobb RMM // HKS SSQV 4 // CS Short Shifter // CS Short Shift plate // Fifteen52 18x9 Tarmacs // Hankook RS3 235/40 // Koni Yellows // GC Coilovers // CS F&R Sway Bars // CS front Endlinks // Whiteline rear Endlinks // GC bump stops // CS mid chassis brace // Megan front H brace // CS rear strut tower bar // Stoptech rotors/pads/ss lines // DG carbon spoiler // DG carbon bumper cover // V2 Side Skirts // STi Lip // CS Antenna // CS Lisence plate relocator // CS LED Fogs // PIAA yellow high beams // Pioneer NEX-7100 // Prosport Premium gauges (Boost/OP/OT) // CP-E Gauge Pod // TWM Shift Knob // Sparco Pedals // Royal Purple 5w/30
c_bye is offline   Reply With Quote
 Old 06-16-2016, 09:19 PM   #7
dale_gribble's Avatar
Posts: 4,720   (View Stats)
I've found silicone intakes to be louder than aluminum ones as others suggested.
MINI H1 6.0 - CAR LED TAILS
 Old 06-16-2016, 09:37 PM   #8
sharksinspace's Avatar
Posts: 766   (View Stats)
Groans: 126
This has been my experience, as well. I recently posted the same thing in another thread, but my CS SRI is definitely louder to my ear than the Mazdaspeed/AEM CAI that it replaced.
 Old 06-17-2016, 02:37 PM   #9
mxlplx71's Avatar
Groans: 128
i guess the consensus has changed on the intakes.
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
 Old 06-19-2016, 05:55 PM   #10
In terms of the Sound difference between aluminum and silicone?
The Following User Says Thank You to BuddySpeed3 For This Useful Post:
mxlplx71 (06-19-2016)
 Old 06-19-2016, 06:25 PM   #11
mxlplx71's Avatar
Groans: 128
Yes
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
 Old 06-19-2016, 08:35 PM   #12
rocknrolla47's Avatar
Posts: 77   (View Stats)
rocknrolla47 is just really nicerocknrolla47 is just really nicerocknrolla47 is just really nicerocknrolla47 is just really nice
Groaned at 14 Times in 6 Posts
I got the jbr 3.5 3.5 in tru wide path full aluminum intake and it is really great intake. It's great quality and it's powdercoated. Makes the turbo spool and bypass valve sound 2times louder.
I really recommend this piece or anything from jbr.
Also the way I fit mine in was to relocate the ecu. Right now I'm using the stock battery box. I trimmed the edge of the box a little for ecu cables at the bottom of the box and removed the from sliding battery cover. Fits perfect. But for a much cleaner look , I will be getting a smaller battery and the 51r battery tray and ecu bracket.
This jbr intake with the forge v1 bypass valve sounds awesome.
Corksport hpfp- Corksport long catted downpipe-Ultimate racing catback- tr6 front mount intercooler w/ cx racing piping- Jbr 3.5 tru wide path aluminum intake- Jbr 3port bcs- Jbr rear and passenger mount-Bosch 3 BAR MAP sensor- Jbr shifter bushings- Matt Damond shift plate-
Last edited by rocknrolla47; 06-19-2016 at 08:40 PM. Reason: MSF Database - Automerged Doublepost
rocknrolla47 is offline   Reply With Quote
 Old 06-19-2016, 08:54 PM   #13
You don't need the battery tray and ecu bracket. The ECU will fit inside the stock battery box with a 51R battery.
BuddySpeed3 (06-23-2016)
 Old 06-19-2016, 08:58 PM   #14
I know but like I said above I want a cleaner look. Tho the corksport battery box looks real good but too much for a box.
Last edited by rocknrolla47; 06-19-2016 at 08:58 PM. Reason: MSF Database - Automerged Doublepost
The Following User Says NO Thank You to rocknrolla47 For This Un-useful Post:
Omega (06-19-2016)
 Old 06-19-2016, 09:05 PM   #15
Doing the stock battery box is bit cleaner and your battery and ECU would be covered unlike the open battery tray design. And yeah, the CS box is pricey but looks nice.
rangerd93 (10-10-2016)
 Old 06-19-2016, 09:06 PM   #16
Send pics if you have this set up I wanna see lol. I couldn't fit the box cover for some reason.
Last edited by rocknrolla47; 06-19-2016 at 09:07 PM. Reason: MSF Database - Automerged Doublepost
 Old 06-19-2016, 09:22 PM   #17
I posted these in another thread.
Covered
[IMG]i.imgur.com/7vnHWsi.jpg[/IMG]
Took off the battery cover
[IMG]i.imgur.com/2Jy0m1G.jpg[/IMG]
 Old 06-19-2016, 09:36 PM   #18
Covered
Hmm for some reason I can't see them
 Old 06-19-2016, 09:49 PM   #19
That's weird.
Try this link
http://www.imgur.com/a/ikX8B
 Old 06-19-2016, 09:52 PM   #20
That's weird.
Try this link
Http://imgur.com/a/ikX8B
Still no good , says page can't be found on imgur. Pretty weird maybe I can't see it on my iPhone.
That's weird.
Try this link
Nvm it worked. Hmm you must show me how You put the ecu in the box lol
Last edited by rocknrolla47; 06-19-2016 at 09:52 PM. Reason: MSF Database - Automerged Doublepost
 Old 06-20-2016, 05:16 PM   #21
That's weird.
Try this link
Imgur: The most awesome images on the Internet
Wow that's clean! I'll probably go this route.
CS FMIC with SURE 3 inch Aeros intake deekspeed 2010 MS3 - Turbo Induction 11 02-05-2014 09:44 AM
Anyone running a JBR 3 inch intake with airbox shaneski 2010 MS3 - Turbo Induction 1 05-30-2013 01:08 PM
Page generated in 0.43299 seconds with 27 queries
