 Old 04-10-2017, 10:16 PM   #1
desertbound1024's Avatar
Posts: 36   (View Stats)
desertbound1024 is an unknown quantity at this point
Default corksport turbo in CA
Ive searched and havent come up with any solid information. Does anyone run a corksport or similar turbo (BNR) in california? If so have you had any problems getting it smogged? I have a 07 MS3 with 161k and it is in dire need of a turbo. It s burning about .5 quart per tank of fuel. If im going to be getting a turbo id like to not have to buy another POS ko4. Im not looking to make a ton of power, will most likely just do internals, access port and good tune with whatever turbo i purchase. Any information would be awesome. Thanks guys!
desertbound1024 is offline   Reply With Quote
 Old 04-11-2017, 02:26 PM   #2
Thor Hammer's Avatar
Posts: 1,847   (View Stats)
Groans: 211
If you can fit it under the stock heat shield I wouldn't worry about it passing visual. Even then most techs wont know the difference I bet. Though I may be wrong.
Is it smoking at idle or just burning oil? I need to replace my K04 as its puking oil into my intercooler and smokes at startup sometimes. Yet my oil level stays constant between changes. My leak is minor evidently.
 Old 04-11-2017, 03:45 PM   #3
tegxsi's Avatar
Posts: 1,281   (View Stats)
Groans: 87
I don't have to smog my car yet but I should be able to pass visual...If I install the factory TMIC+shroud my engine bay would pretty much look stock.
My DP is stock with all the heat shields intact, EGR is functional, intake is CARB legal and no disabled CEL. I do have a test pipe but that's well hidden but I may swap it back just to be safe.
2018 Audi RS3
2007 Acura TSX 6MT
macdiesel (04-11-2017)
 Old 04-11-2017, 04:45 PM   #4
Smokes a little bit. Not too much, hoping it is in fact just the turbo
 Old 04-11-2017, 05:51 PM   #5
Are you running a cs turbo?
So, about the new Corksport turbo... dale_gribble CorkSport 1859 08-01-2017 01:32 AM
Corksport Turbo EWG Jester2552 CorkSport 60 12-03-2015 06:53 PM
Corksport Turbo Xxblinddzxx Mazdaspeed3/6 General Discussion 9 08-25-2015 08:06 PM
Corksport Turbo Set Up 406Speed6 CorkSport 7 07-15-2015 11:29 AM
Page generated in 0.25464 seconds with 22 queries
