 Old 01-13-2009, 10:00 AM   #1
DaleNixon's Avatar
Posts: 2,079   (View Stats)
DaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the world
Groans: 91
With my Cobb SRI/Forge combo I get +7.6 at cruise and +14.2 under heavy acceleration/WOT. I've already sent logs to Cobb and await their answer as to what could be going on.
My AFR's are fine. Also, no backfires and the knock warning isn't too frequent.
Gay car #1: 2001 Miata (Gay White)
Gay car #2: 2011 Mazda 2 (Gay Blue)
DaleNixon is offline   Reply With Quote
 Old 01-13-2009, 11:26 AM   #2
pewpew
Sacrilicious's Avatar
Posts: 2,452   (View Stats)
Groaned at 9 Times in 9 Posts
if you're not running rich, then the LTFTs are just where they need to be to account for the way the air flows in the SRI. if you want them adjusted closer to 0, christian can very easily take care of that for you with just a few changes. i had this same problem, and it took christian just one try to drop them from ~14% to <5%. keep in mind, that this is different from the BPV problem, because it simply means that your baseline LTFTs are rather high (which is nothing to panic about)...the BPV problem i'm referring to happens when your BPV artificially takes whatever baseline LTFT you should have been running at and then adds like 5-10% to it...causing you to run pig rich at WOT and bang bang out the tailpipe...=/
Originally Posted by Deadman View Post
im runing hks in vta, currently with like 35 miles on the reflash my ltfts are at:
idle - +16.4%
cruising - -.8%_-2.3%
WOT - -.8%
Whats the good/bad in this?! :|
well, simply looking at the LTFTs doesn't necessarily tell us if you are having a problem. do you run richer than you expect at WOT? does your car backfire on shifts? if not, then i wouldn't worry about it, but i suspect that you DO backfire on shifts because you're venting to air (makes you run really freakin rich on shifts).
Originally Posted by Phantom View Post
I am running a Turbosmart Compact BOV. I will check the AFR's this week and see what I can find out.
ya, if you're running hybrid mode on the turbosmart, you're almost guaranteed to run too rich on shifts (pops and backfires). VTA is guaranteed to run richer than BPV, because you're dumping metered air to the atmosphere...less air, same amount for fuel = rich as a pig. you can either leave it like this and make sure the spring tension is adjusted so that you at least run normally at WOT and deal with the fact that you will pop and backfire on shifts, or you can go conservative and put the valve in full recirc so that it runs as smoothly as stock (clean AFRs and no pops/backfires on shifts...not moreso than stock, anyways).
The Following User Says Thank You to Sacrilicious For This Useful Post:
knarfies (04-10-2012)
 Old 01-15-2009, 01:56 PM   #3
Phantom's Avatar
Posts: 313   (View Stats)
Phantom has much to be proud ofPhantom has much to be proud ofPhantom has much to be proud ofPhantom has much to be proud ofPhantom has much to be proud ofPhantom has much to be proud ofPhantom has much to be proud ofPhantom has much to be proud ofPhantom has much to be proud ofPhantom has much to be proud of
I am currently running my Turbo Smart in full recirc. The popping I was getting I think is from a spring being too tight. Seems bit better now. Still need to work on the spring tension
Phantom is offline   Reply With Quote
 Old 01-15-2009, 03:01 PM   #4
pewpew
awesome... ya, you just need the spring to be a little bit tighter than it absolutely needs to be in order to hold boost. you don't want to go much farther than that, because you will run into trouble from its being too tight.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f11/discussion-how-bypass-valves-can-affect-ltfts-18962/
Forge BPV and boost leak question - Page 2 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 02-27-2014 04:51 AM
Turbosmart dual port bov? - 2010 Mazda 3/Mazdaspeed 3 Forums This thread Refback 06-28-2012 05:28 AM
Bypass valve small points (+ a boom theory!) - Page 2 This thread Refback 11-30-2011 06:29 AM
Bypass valve small points (+ a boom theory!) This thread Pingback 08-30-2011 04:02 AM
From out of no where SURGE! - Page 3 - MN Mazda Forums This thread Refback 06-17-2009 10:18 AM
Super lean at idle, AFR super high. - Mazda6 / Atenza This thread Refback 01-13-2009 02:21 PM
Factory alarm bypass xcoldricex MazdaSpeed 3/6 - Car Audio & Electronics 1 01-12-2009 07:53 PM
The 2nd O2 sensor does affect AFR after-all. LBV MazdaSpeed 3/6 - ECU Computer Tuning 53 01-09-2009 04:25 PM
LTFTs and Winter MidwestSpeed3 MazdaSpeed 3/6 - ECU Computer Tuning 6 11-12-2008 09:34 AM
Feds investigate valves in Ford tires Haltech Automotive News 0 10-21-2008 12:20 PM
Page generated in 0.32962 seconds with 24 queries
