 Old 10-23-2014, 06:11 PM   #1
AshFromCan's Avatar
Posts: 295   (View Stats)
AshFromCan is the leader of the worldAshFromCan is the leader of the worldAshFromCan is the leader of the worldAshFromCan is the leader of the worldAshFromCan is the leader of the worldAshFromCan is the leader of the worldAshFromCan is the leader of the worldAshFromCan is the leader of the worldAshFromCan is the leader of the worldAshFromCan is the leader of the worldAshFromCan is the leader of the world
Originally Posted by jerihaly View Post
I did the down pipe and fudged the threads in the turbo up, took the turbo off and just cleaned the threads with a tap. I put everything back together and while driving, heard a whiney noise under boost, quite positive its the manifold to turbo gasket. I picked one up for $20 and put it on, still making the noise. Should I have sanded the surfaces first? Or could it be something else?
You should watch out or you will get banned doing this. Putting the same post in multiple threads even dead ones that are years old. Then you'll be out a great source of information. Sorry I can't answer your question though.
2013 White MS3
Power |Cobb V3 AccessPort| |Ultimate Racing TBE w/ V2 DP| |Cobb FMIC| |Cobb SRI/TIP| |Autotech HPFP Internals|
Supporting |Cobb RMM| |Cobb Shift Weight|
AshFromCan is offline   Reply With Quote
bpv gasket boosthead MazdaSpeed 3/6 - Turbo Induction 3 08-01-2010 05:19 PM
help with exhaust gasket johnnybochamp MazdaSpeed 3 - Engine, Transmission & Driveline 2 07-06-2010 05:08 PM
BPV gasket? Zeya MazdaSpeed 3/6 - Turbo Induction 18 05-13-2008 06:18 PM
Page generated in 0.23508 seconds with 21 queries
