 Old 02-04-2015, 02:28 PM   #41
smoogs12's Avatar
Posts: 7,731   (View Stats)
Groans: 423
"Blue spring 2 shims"
-Nancy Pelosi
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
The Following 3 Users Say Thank You to smoogs12 For This Useful Post:
ASHMS3 (03-04-2015), Easter Bunny (02-04-2015), WAMBUSHHHH! (02-04-2015)
 Old 03-04-2015, 08:48 AM   #42
itzjustme407's Avatar
Posts: 110   (View Stats)
itzjustme407 is infamous around these partsitzjustme407 is infamous around these partsitzjustme407 is infamous around these partsitzjustme407 is infamous around these partsitzjustme407 is infamous around these parts
Since someone already revived this thread I have a question. Currently running blue two shims but installing my gtx3071 Saturday. Should I be changing to a different spring or should I ask my tuner? Hate to bother him with questions not pertaining to my tuning (install stuff).
2011 Speed3 Tech-
GTX3071 EWG Ceramic Coated hotside - ATP DUMP - TIAL 38MM External Wastegate - HTP 3.5" Full intake - COBB DownPipe - 3 Bar Map w/ FastBits Adapter - Grimmspeed EBCS - Forge V2 - JBR Battery Tray - 51r Battery - Matt Damond VTA OCC - Matt Damond Full EGR Delete - Denso Step Colder Plugs - Treadstone TR6 - CX Piping Modded for gen2 - JBR SSP/Solid Bushings/Heavy Knob - JBR RMM - SURE TMM - SURE PMM - AutoTech Internals - AP v2 Tuned BY NISHAN - Sonic Tuning S3 Coilovers - SPC Camber Arms - TSW Intelagos Rotary Forged - Conti Extreme DW - StopTech Pads - SouthBend Stg 2 Endurance -
FUTURE MODS
Built Bottom End - 5th Port - Meth - Exhaust Manifold - CatBack Exhaust - Slicks
itzjustme407 is offline   Reply With Quote
 Old 07-18-2015, 11:49 PM   #43
Hossanngeorge's Avatar
Posts: 38   (View Stats)
Hossanngeorge has a spectacular aura aboutHossanngeorge has a spectacular aura about
So I have also just got my forge v2 bpv. I'm seeing a lot of blue spring talk for the speed 3 and since they're the same engine I'm wondering if I need to use that as well. Blue spring one shim? Is that the consensus on completely stock besides accessport? I'm running like 17 psi.
I am not hearing any whoosh noise at all. Used green and yellow springs.
Hossanngeorge is offline   Reply With Quote
 Old 07-19-2015, 07:41 AM   #44
Blue two shims as posted many times.
 Old 07-19-2015, 09:32 AM   #45
btstarcher's Avatar
Posts: 4,852   (View Stats)
I used red spring. But I was at 24 psi. Blue spring, 2 shims is the general consensus.
SnailTune in progress
 Old 09-11-2015, 05:47 PM   #46
Chris1208's Avatar
Posts: 1   (View Stats)
Chris1208 can only hope to improve
Neutral  :  -1 score
Ok so I know everyone posts about blue 2 shim and all that but now with accessports with tuning and all all if your a little of stock boost like 16.5 and a little up should blue and one shim be best or just no shims or start using yellow spring. I know I read all the comments but I just want to know lol sorry
Chris1208 is offline   Reply With Quote
The Following User Says NO Thank You to Chris1208 For This Un-useful Post:
Addikted To Boost (09-11-2015)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f11/forge-boost-bypass-valve-spring-shim-11573/
Êóçíèöà ÁÏ è ïîâûñèòü ãåðìåòè÷íîñòü âîïðîñ - Ñòðàíèöà 2 - Ôîðóìû Mazda 6 Mazda 6: Ôîðóì / Ôîðóì Mazda Atenza This thread Refback 06-01-2015 09:44 AM
Forge BPV and boost leak question - Page 2 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 02-27-2014 07:10 AM
Forge BPV V2 maintenance. This thread Refback 03-29-2012 01:39 PM
FORGE WGA TRU-BOOST MazdaSpeed 3/6 - Turbo Induction 119 06-20-2011 11:29 AM
Possible track spring spring setup for use with Koni yellows stretch MazdaSpeed 3/6 - Suspension & Brakes 154 04-18-2011 12:18 PM
Forge VTA TurboMazda1313 MazdaSpeed 3/6 - Turbo Induction 9 06-27-2008 04:00 PM
Page generated in 0.28812 seconds with 25 queries
