 Old 06-09-2014, 07:59 PM   #1
Danielism's Avatar
Posts: 64   (View Stats)
Danielism has a brilliant futureDanielism has a brilliant futureDanielism has a brilliant futureDanielism has a brilliant futureDanielism has a brilliant futureDanielism has a brilliant futureDanielism has a brilliant futureDanielism has a brilliant futureDanielism has a brilliant futureDanielism has a brilliant futureDanielism has a brilliant future
Default Forge V2 Loud Squeak
Hey guys, just installed a Forge V2 on my MS6, I was getting a loud squeak noise coming from the stock BPV so I decided I needed to upgrade or replace, now its even louder. It blows off perfectly fine at high RPMs but when I decide to shift lower, it makes a loud squeak instead of the normal sound. I am running it with the blue spring and 2 shims, paired with JBR TIP and SRI. I just serviced the BPV with synthetic grease. Any suggestion what is causing this obnoxious noise? Can't find anything on Google or Youtube to compare the noise too, but it's like a dog yelping or if you were to wipe your finger across a wet sink/window/bathtub.
http://www.therpmstore.com/
Danielism is offline   Reply With Quote
 Old 06-09-2014, 08:15 PM   #2
pzr2874's Avatar
Posts: 6,778   (View Stats)
Groans: 146
Take both shims out or try it with just one. See if it subsides.
 Old 06-09-2014, 08:17 PM   #3
Danielism's Avatar
Ok, will I be safe to drive it to work tomorrow? Or is it something I need to do before I move the car anymore? Ill also update when I change them out.
 Old 06-09-2014, 08:19 PM   #4
faeker's Avatar
Posts: 5,091   (View Stats)
Groans: 731
clean it, lube it, see if it does it again. i know you said you did before but do it again. try and remove all of the old shit on it.
Mods: stock
 Old 06-11-2014, 04:01 PM   #5
Danielism's Avatar
Re lubed it and removed a shim and it is still making the same noise
 Old 06-11-2014, 04:57 PM   #6
quad4svtspeed6's Avatar
Posts: 82   (View Stats)
quad4svtspeed6 has a reputation beyond reputequad4svtspeed6 has a reputation beyond reputequad4svtspeed6 has a reputation beyond reputequad4svtspeed6 has a reputation beyond reputequad4svtspeed6 has a reputation beyond reputequad4svtspeed6 has a reputation beyond reputequad4svtspeed6 has a reputation beyond reputequad4svtspeed6 has a reputation beyond reputequad4svtspeed6 has a reputation beyond reputequad4svtspeed6 has a reputation beyond reputequad4svtspeed6 has a reputation beyond repute
Could possible be the O-ring between the BPV and Flange or the flange and cold pipe, for the bpv-flange, take off bpv you'll see two notches at the bottom, use needle nose pliers and try tightening it, my forge was loose when new.
Current Mods>>>>>CPE-Nano..CPE TMIC...TIP....Ebay Test Pipe...Forge V1 BPV...ITV22 Plugs....HyPeRtEcH TuNe
quad4svtspeed6 is offline   Reply With Quote
 Old 06-11-2014, 05:32 PM   #7
Danielism's Avatar
I'll try that now, if it doesn't work i managed to get a sound clip of the sound that i can upload.
 Old 06-11-2014, 07:10 PM   #8
Danielism's Avatar
Ok tightened the flange, re lubed, removed both shims one at a time and still the noise. Squeaks at 2.5k and 3.5k rpm when I let off. Could something be wrong with my intake? I have a JBR TIP & SRI.
 Old 06-11-2014, 07:12 PM   #9
pzr2874's Avatar
Groans: 146
Do a boost leak test.
 Old 06-11-2014, 07:56 PM   #10
Danielism's Avatar
https://www.youtube.com/watch?v=E0Ma...ature=youtu.be
Video of the sound for ya, Ill try and see if my work can do one for me or ill have to do that $15 DIY one.
 Old 06-11-2014, 08:13 PM   #11
pzr2874's Avatar
Groans: 146
Are you hitting targeted boost?
 Old 06-11-2014, 08:20 PM   #12
Danielism's Avatar
Don't have an AP or boost gage so I have no idea..
 Old 06-11-2014, 08:32 PM   #13
faeker's Avatar
Groans: 731
my v1 made that noise at times. no clue wtf it was. i cleaned it, used some lithium, and it either stayed or went away. wish I could help you more man. other than the o rings being the culprit or a leak in the bpv area i couldn't suggest much more. good luck finding the issue.
Mods: stock
 Old 06-12-2014, 04:13 PM   #14
Danielism's Avatar
No one can identify the noise? it made the same noise with the stock bpv just quieter, so it might not even be the bpv.
 Old 06-12-2014, 04:23 PM   #15
faeker's Avatar
Groans: 731
See if the gasket is torn or smashed down weird.
now with three times the hate
Mods: stock
 Old 06-12-2014, 08:59 PM   #16
volcomcinematic's Avatar
Posts: 274   (View Stats)
check your TIP to turbo clamp. i'm serious..
Pd tuned.
09' true red GT
Forge bpv v1 loud squeky noise volcomcinematic MazdaSpeed 3/6 - Troubleshoot/Diagnostics 18 12-29-2013 05:07 PM
squeak squeak squeak bradkn 2010 MS3 - Engine, Transmission & Driveline 2 02-24-2013 07:59 PM
Squeak at certain RPM Keko Gen2 MS3 General Discussion 9 10-30-2012 11:09 AM
Loud Squel from Forge BPV bbrownderville 2010 MS3 - Turbo Induction 13 08-28-2012 06:28 AM
squeak squeak pvms3g MazdaSpeed 3 - Engine, Transmission & Driveline 8 05-14-2009 02:20 PM
Page generated in 0.33942 seconds with 24 queries
