 Old 09-09-2013, 10:34 AM   #1
Motocooney's Avatar
Posts: 175   (View Stats)
Motocooney has much to be proud ofMotocooney has much to be proud ofMotocooney has much to be proud ofMotocooney has much to be proud ofMotocooney has much to be proud ofMotocooney has much to be proud ofMotocooney has much to be proud ofMotocooney has much to be proud ofMotocooney has much to be proud of
Default Gt3071r with stock BCS?
Can this be done?
I'm currently running an AEM Truboost(which sucks)
Can I run this turbo with the stock BCS until I get a Grimspeed 3 port?
What are the disadvantages to doing this?
Do I need to do anything different? Any restrictor pill?
Thanks
Motocooney is offline   Reply With Quote
 Old 09-09-2013, 10:39 AM   #2
maisonvi's Avatar
Posts: 3,490   (View Stats)
Groans: 75
I think its fine. Someone like @Lex; could say for sure.
I made my own 3 port for pretty cheap. Hit me with a PM since you are local and I might be able to help save you some cash.
 Old 09-09-2013, 10:39 AM   #3
thricestrat's Avatar
Posts: 232   (View Stats)
thricestrat is the leader of the worldthricestrat is the leader of the worldthricestrat is the leader of the worldthricestrat is the leader of the worldthricestrat is the leader of the worldthricestrat is the leader of the worldthricestrat is the leader of the worldthricestrat is the leader of the worldthricestrat is the leader of the worldthricestrat is the leader of the worldthricestrat is the leader of the world
Just ran into a similiar issue, why not run Wastegate spring pressure only? Run a line from boost source to wastegate top nipple (check this to make sure).
How to route your BCS lines 2 and 3 port, iwg and ewg
^^ should get you on your way
edit: this is temporary until you get your 3 port; and you should feel out your boost first to make sure you aren't overboosting if your wastegate is F'd
Koni Yellows / Eibach Pro Springs / CX & Treadstone FMIC / HTP 3.5" / PowerSlot Rotors / Moog Rear Endlinks / ProSport Boost Gauge / CP-E Defrost Vent Pod / Autotech HPFP / Cobb AP V3 / BNR S1->S3->Modded S3 / CP-E Stage 2 RMM / JBR Boost Tubes / JBR Recirc Tube / JBR EGR Block Off /
thricestrat is offline   Reply With Quote
 Old 09-09-2013, 11:06 AM   #4
The most effective way to run with the stock ebcs is to add the Stratified boost dial.
Otherwise you won't be able to increase boost pressure much over spring.
 Old 09-09-2013, 11:19 AM   #5
Motocooney's Avatar
Hmmmm upon further inspection, could I use the AEM solenoid?
It's a MAC. It looks decent. How would I wire it to the stock harness.
I'm at work so I'm gonna look into it tonight.
 Old 09-09-2013, 11:25 AM   #6
DSIT995's Avatar
Posts: 1,768   (View Stats)
You can buy the oem connector and not have to splice your wires.. that's what I run with a MAC valve. I found the connector on balinger motorsports
Search for diy 3 port ebcs
tapping.... tap tap
Here is the thread
OEM ECBS Pigtail (CONN-85730)
tapping.... tap tap
tapping.... tap tap
99 Miata NB - Stock for now
Last edited by DSIT995; 09-09-2013 at 11:25 AM. Reason: MSF Database - Automerged Doublepost
 Old 09-09-2013, 01:56 PM   #7
Motocooney's Avatar
Can't I just use my stock bcs harness clip? Somehow?
 Old 09-09-2013, 02:11 PM   #8
The AEM solenoid should work fine. You just need to either source a connector or splice into the OEM harness. The OEM BCS doesn't have a removable connector.
 Old 09-09-2013, 04:48 PM   #9
Motocooney's Avatar
Dremel with a cutoff and its removable lol
Ill post pics in a few. It actually turned out nice
I think I'm all set. Just ordered a new boost gauge cause the truboost gauge is useless without the bcs. So as soon as that arrives, I'll be able to start tuning this thing.
It's running a map from Ptuning and boy does it suck.
I can feel that it's being held back. The timing is just so low. I can't wait to get some power out of this thing.
BT opinions, ATP GT3071r, relatively stock MS3 Dark MazdaSpeed 3/6 - Big Turbo Builds 24 11-15-2010 10:42 AM
Page generated in 0.31116 seconds with 24 queries
