 Old 10-04-2014, 08:37 PM   #1
WilbanksUSMC's Avatar
Posts: 11   (View Stats)
WilbanksUSMC will become famous soon enoughWilbanksUSMC will become famous soon enough
Default Having loss of power at 50%< throttle
I am currently having issues with the car cutting power while under full throttle. I do not have any idling smoke, and when accelerating <50%, the car will hit red line, but it feels like it is struggling to get there. I have replaced the MAF and fuel lines, as well as my purge valve solenoid. My mods are just a HKS 3" intake and BOV w/ recirc. This is very urgent, I NGK's that i need to gap, going in the car this week. AP should be on the way soon too. But for now, does anyone have any idea what this might be? I thought maybe a really bad boost leak, but i don't see anything on the piping, nor i do i hear any whistling or whining while under boost.
Thanks
WilbanksUSMC is offline   Reply With Quote
The Following User Says NO Thank You to WilbanksUSMC For This Un-useful Post:
Vansquish (10-04-2014)
 Old 10-04-2014, 10:10 PM   #2
Colepidd55's Avatar
Posts: 211   (View Stats)
Colepidd55 has a reputation beyond reputeColepidd55 has a reputation beyond reputeColepidd55 has a reputation beyond reputeColepidd55 has a reputation beyond reputeColepidd55 has a reputation beyond reputeColepidd55 has a reputation beyond reputeColepidd55 has a reputation beyond reputeColepidd55 has a reputation beyond reputeColepidd55 has a reputation beyond reputeColepidd55 has a reputation beyond reputeColepidd55 has a reputation beyond repute
No internals? As soon as that ap gets to you I'd look at that fuel pressure. And you need a MAF cal for that 3 inch too I believe. I'd do more reading if I were you.
SOLD
2009 CWP Speed3
Cobb Ap/AT Internals/Cobb Downpipe/Cobb SRI,TIP/TS BPV/sure shortcut/JBR 88a RMM/JBR TMM/JBR solid shifter bushings/Freektune OTS+
Colepidd55 is offline   Reply With Quote
The Following 2 Users Say Thank You to Colepidd55 For This Useful Post:
Vansquish (10-05-2014), WilbanksUSMC (10-05-2014)
 Old 10-04-2014, 10:38 PM   #3
Police - Grammarhead
Vansquish's Avatar
Put the OEM BPV back on, and put the stock intake back on. You're running dangerously lean with a larger-bore MAF housing.
Get an AP as quickly as you can, and tune for the mods you intend to put on. These are finicky motors, and you're risking serious damage right now.
The Following 3 Users Say Thank You to Vansquish For This Useful Post:
Colepidd55 (10-04-2014), CrawlingMS3 (10-05-2014), WilbanksUSMC (10-05-2014)
 Old 10-05-2014, 10:22 PM   #4
Thanks guys, just trying to fix problems from the stealership. Bought it with the intake and bov kit -_-
 Old 10-05-2014, 10:36 PM   #5
Hargarbl's Avatar
Posts: 642   (View Stats)
Groans: 51
Do you have a speed 3 or 6?
 Old 10-11-2014, 07:32 AM   #6
its a 6.
 Old 10-06-2014, 04:10 AM   #7
pzr2874's Avatar
Posts: 6,778   (View Stats)
Groans: 146
Here:
http://www.mazdaspeedforum.org/forum/foru...-valve-178269/
The Following User Says Thank You to pzr2874 For This Useful Post:
WilbanksUSMC (10-11-2014)
 Old 10-06-2014, 06:29 AM   #8
Billcraft78's Avatar
Posts: 230   (View Stats)
Billcraft78 is the leader of the worldBillcraft78 is the leader of the worldBillcraft78 is the leader of the worldBillcraft78 is the leader of the worldBillcraft78 is the leader of the worldBillcraft78 is the leader of the worldBillcraft78 is the leader of the worldBillcraft78 is the leader of the worldBillcraft78 is the leader of the worldBillcraft78 is the leader of the worldBillcraft78 is the leader of the world
Man buying a speed like that is dangerous!!! Think you should do a leak down test to make sure there's no motor problems. Hope all is well, good luck brother!
Corksport Sri, Tip, Rmm, springs, CPE tmic, CPE cbe, UR test pipe, JBR PMM, stage 2 oil catch can in vta, shift knob, boost tubes, ssp, AP V3, autotech internals (Freektuned ots+ tune) Forge BPV, alcohol injection systems-progressive meth kit
Billcraft78 is offline   Reply With Quote
The Following User Says Thank You to Billcraft78 For This Useful Post:
Power cut at part throttle tommyboy 2010 MS3 - ECU Computer Tuning 0 09-02-2014 07:33 PM
part throttle power loss feldm4n MazdaSpeed 3/6 - Troubleshoot/Diagnostics 8 04-06-2013 05:15 PM
Boost loss at 1/2-3/4 throttle Cell Block 54 2010 MS3 - ECU Computer Tuning 17 03-25-2012 06:31 PM
WTF power loss and mpg loss ztnedman1 Gen2 MS3 General Discussion 10 11-07-2011 07:26 PM
stepping power at medium throttle? event MazdaSpeed 6 - Engine, Transmission & Driveline 3 06-27-2010 09:42 AM
Page generated in 0.29442 seconds with 25 queries
