 Old 09-30-2014, 02:56 PM   #1
Ozynigma's Avatar
Posts: 743   (View Stats)
The key is getting one with a check valve.
Thanks for your input. The Matt Damond one has a check valve standard. The JBR has it as an added cost option. The MD is under $200.
I told you...to make it work with a tire inflation pump, you need ''da pink pyjamas''
AS for the catch can, the best ones have media to help catch oil (non-media CC have about a 30% efficiency)
The cheap one on eBay is the older model Corksport. But at $120AU for the can only I don't think it is cheap enough.
Both MD and JBR do hose kits the right length for the CX7 with their catch cans. I almost ordered the MD OCC yesterday but ordered an Aussie made check valve from an OzMPS forum member instead. This should help me solve the immediate check valve problem this week as I will be waiting about 3 weeks for shipping after I order the catch can.
I think I have figured out my BPV problem. I don't think the Cobb has a problem. I used a scale to test it and it is taking about 8psi pressure differential to move the piston and 18psi to open it fully.
So the fact that I was generating the 8psi pressure differential at around 12psi boost pressure indicates I might have a leak from the vacuum/boost hose connection from the manifold to the BPV.
So the plan is to get the improved check valve tomorrow hopefully and pull the intake manifold and replace the check valve and check the BPV hose connection.
The Following 3 Users Say Thank You to Ozynigma For This Useful Post:
ALPINEST4RS (09-30-2014), jdmage_mx5 (09-30-2014), SarcasticOne (09-30-2014)
Not hitting boost targets, not boost leak ADHDAdditiv MazdaSpeed 3/6 - Troubleshoot/Diagnostics 28 07-18-2014 02:18 PM
Not hitting Stage 2 boost targets (boost leak?) Bubba Ho-Tep 2010 MS3 - ECU Computer Tuning 15 04-26-2012 08:25 PM
Help a Dummy (finding boost leak) helmetface MazdaSpeed 3/6 - Turbo Induction 12 05-24-2011 04:57 PM
Vacuum leak, but no boost leak? vbt101 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 23 04-18-2010 01:06 PM
Finding Source of Oil Leak, Are Octane Ratings Real?, Bearing Problem on Honda Civic, HCCI Engine, Another Bogus 'Gas Sa Haltech Automotive News 1 07-11-2008 06:13 PM
Page generated in 0.22741 seconds with 22 queries
