Like Tree5Likes
  • 1 Post By TRSpeed
  • 1 Post By TRSpeed
  • 1 Post By Crazyspeed3
  • 1 Post By rfinkle2
  • 1 Post By drg0708
 Old 10-04-2011, 11:23 AM   #1
TRSpeed's Avatar
Posts: 1,537   (View Stats)
TRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the world
Default Help-OEM Boost Control Solenoid
Hey guys,
So to make this story short, I broke the INNER nipple on my BCS that connects to the WG. And NOT the one that goes to the TIP that usually breaks.
I ordered the OEM BCS ($52) and I was looking at the BCS and and it has little metal prongs that you squeeze to pull out( if that makes any sense) but I was wondering when I am putting it back in, how to I open the prongs back up since they are tiny and made of metal.
The Dealer wants $90 bucks just to install the Fucking part held in by ONE damn bolt in the bottom plus the metal prongs.
So I am wondering if anyone has done this before and can help me out in removing the BCS and replacing it with the new one.
Thanks
TRSpeed
2008.05 True Red Mazdaspeed3
Lex Tuned
GTX3071r | 38mm Tial WG | Hallman MBC
Cobb AP E85 30% |CPE Big MAF | CPE Big TIP | CPE FMIC | SS Ex Mani | CPE Catted DP | CNT CBE | CPE Triple Gauge Pod |
Autotech HPFP Internals | Denso ITV22 | TS BPV | TWM ShortShifter | JBR Shifter Bushings | JBR 88 RMM |
Razo Heavy Shift Knob | 20% Tint | DDM 55W HID | Hankook Ventus V12 | H&R Springs
TRSpeed is offline   Reply With Quote
 Old 10-04-2011, 12:09 PM   #2
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
They are clamps, and will spring back as soon as you release pressure.
rfinkle2 (10-04-2011)
 Old 10-04-2011, 02:34 PM   #3
Jake5713's Avatar
Posts: 1,775   (View Stats)
ummmmm
FUCKING FAIL
just take the hoses off and take off the bolt as mentioned above release the clamps they will spring back
now go bang your head against a wall for a while
Jake5713 is offline   Reply With Quote
The Following 2 Users Say NO Thank You to Jake5713 For This Un-useful Post:
SSinstaller (10-04-2011), TRSpeed (10-04-2011)
 Old 10-04-2011, 09:44 PM   #4
TRSpeed's Avatar
OK Guys so I just replaced the BCS. I made this post because when I ordered the part I did NOT now that the BCS was a whole piece and it was NOT incased in the Metal casing.
When I received the part I noticed it was ONE piece so it was just a simple bolt at the bottom like I thought.
So For anyone that needs to replace there BCS the part number is
1. BCS P/N L3K918741
2. Remove Battery Box
3. Remove SRI
4. Remove TIP
5. un screw the 10 mm bolt uner the Boost Control Solenoid.
6. Put everything back
Tada!!
PS. Dont forget the 4mm Hoses!! and be carefull with the nipples.
TRSpeed
Lex Tuned
The Following 5 Users Say Thank You to TRSpeed For This Useful Post:
MSFer87 (03-26-2013), Poohster (03-29-2013), rfinkle2 (01-18-2012), SJP0tato (01-18-2012), tddvrrn (11-18-2012)
 Old 10-05-2011, 04:47 AM   #5
Jake5713's Avatar
You really don't need to take anything off
Maybe the intercooler cover
 Old 10-05-2011, 06:55 AM   #6
TRSpeed's Avatar
Well mostly just to make this Alot easier lol
But Thanks
Sent from my DROID2 GLOBAL using Tapatalk
Lex Tuned
The Following User Says Thank You to TRSpeed For This Useful Post:
 Old 01-18-2012, 11:12 AM   #7
Crazyspeed3's Avatar
Posts: 167   (View Stats)
Crazyspeed3 has a reputation beyond reputeCrazyspeed3 has a reputation beyond reputeCrazyspeed3 has a reputation beyond reputeCrazyspeed3 has a reputation beyond reputeCrazyspeed3 has a reputation beyond reputeCrazyspeed3 has a reputation beyond reputeCrazyspeed3 has a reputation beyond reputeCrazyspeed3 has a reputation beyond reputeCrazyspeed3 has a reputation beyond reputeCrazyspeed3 has a reputation beyond reputeCrazyspeed3 has a reputation beyond repute
But Thanks
wen ur BCS broke did it make any clicking sounds???
Crazyspeed3 is offline   Reply With Quote
 Old 01-18-2012, 12:12 PM   #8
Bob-o's Avatar
Posts: 1,312   (View Stats)
But Thanks
Agreed. I just recently replaced my BCS, and taking off the intake/inlet made things much easier! Ghood writeup lol
 Old 01-18-2012, 12:58 PM   #9
TRSpeed's Avatar
Not that I can think of, the sound is from the BCS.
Thanks man! ,
and ya if you dont take those 2 things of it just make a 2 min job a 45 min job.
Glad it helped
Lex Tuned
 Old 01-18-2012, 03:08 PM   #10
sucks for me i only have an cobb sf and cobb AP stage1+ sf 93 for some reason im hitting 22 psi of boost with 0 WG i think my boost control is f up or the acuator it self
 Old 01-18-2012, 07:00 PM   #11
TRSpeed's Avatar
Ok I had this same exact problem.
Its either Your WG Actuator. OR
For me it was a broken BCS nipple specifically the nipple from BCS to WG .
I have a thread somewhere about it. Look in my threads.
Edit: Found it. http://www.mazdaspeedforum.org/forum/foru...-21-psi-93139/
My WG was also at 0 and 22psi
@Crazyspeed3
Lex Tuned
atvfreek (01-19-2012)
 Old 01-18-2012, 08:44 PM   #12
Bob-o's Avatar
And if you break the other nipple, you get the complete opposite! Or at least i did...
WGDC at 100% and 12psi
The Following 2 Users Say Thank You to Bob-o For This Useful Post:
atvfreek (01-19-2012), rfinkle2 (05-21-2012)
 Old 01-19-2012, 03:04 PM   #13
@Crazyspeed3
cool man im ganna replace my bcs and my WG but its funny cuz i only get boost cut on a tune map at 18psi but wen i reflash to the cobb OTS map witch is stage 1+ SF 93 the boost cuts STOPS lol so its hard to say if i really have a bad bcs/WGA but thanks for the info bro
The Following User Says Thank You to Crazyspeed3 For This Useful Post:
 Old 05-21-2012, 11:22 AM   #14
rolanblack's Avatar
Posts: 2,110   (View Stats)
Did anyone have a problem with removing the 4mm hose? Its just completely rock solid.
 Old 05-21-2012, 05:08 PM   #15
Ingle's Avatar
Posts: 421   (View Stats)
Grab hold with a pliers near where it goes over the nipple and move twist/jiggle it back and forth and up at the same time(seriously). This will break the hose free since it's more or less fused there. Just be careful not to move it sideways that would cause it to snap with enough force.
Ingle is offline   Reply With Quote
 Old 05-21-2012, 05:21 PM   #16
@Crazyspeed3
Somehow, we need to have a way for guys (to warn them / alert them) to keep from busting their oem solenoid. It happens way too often, and is potentially dangerous for the engine.
I would definitely slice the factory vacuum line off and either use some line supplied with the TIP (if supplied), or have some handy before any tip install etc.
Glad to hear that you got things sorted guys.
SLOWHATCH likes this.
Bucker (05-21-2012), Silverspec06 (11-18-2012), SLOWHATCH (11-18-2012), trf5000 (06-20-2012)
 Old 05-23-2012, 03:27 PM   #17
rolanblack's Avatar
Talked to a dude who works at Mazda and he told me that those nipples are easy to break nomatter what. Save it from happening, cut the hose from bottom to top then just out the aftermarket hose on. SAVES THE PLASTIC
The Following 2 Users Say Thank You to rolanblack For This Useful Post:
rfinkle2 (05-23-2012), trf5000 (06-20-2012)
 Old 06-20-2012, 02:42 PM   #18
drg0708's Avatar
Posts: 3   (View Stats)
drg0708 will become famous soon enough
+1 on this. I broke this stupid thing installing my TIP, thought I had it fixed with a little sealant and just sticking the vacuum line on the end (so one hose up, one straight out from the BCS.) I know, I know...I just needed to get the thing running again. Everything looked fine, the dash boost meter was reading full pressure, but the butt dyno was a little underwhelmed at my new sri and tip. I got an AP and saw that my boost was actually peaking at ~15 and tapering to 12.5-13....with targets of 16.... and 100% WGDC. Thought it was boost leak for a bit, but swapped out my shade-tree mechanic fix for a new BCS and it feels like I'm driving a new car.
The lesson? Don't take short-cuts when fixing crap.
drg0708 is offline   Reply With Quote
The Following User Says Thank You to drg0708 For This Useful Post:
rfinkle2 (06-21-2012)
 Old 11-18-2012, 12:57 PM   #19
Silverspec06's Avatar
Posts: 244   (View Stats)
Silverspec06 has much to be proud ofSilverspec06 has much to be proud ofSilverspec06 has much to be proud ofSilverspec06 has much to be proud ofSilverspec06 has much to be proud ofSilverspec06 has much to be proud ofSilverspec06 has much to be proud ofSilverspec06 has much to be proud ofSilverspec06 has much to be proud ofSilverspec06 has much to be proud of
I second this, I was just trying to do my interals trying to move the tip a little it came off trying to get it back on the hose broke... such a shit show
Silverspec06 is offline   Reply With Quote
 Old 03-26-2013, 02:25 PM   #20
twincitySPEED6's Avatar
Posts: 276   (View Stats)
I'm bringing this thread up again. I broke the outer nipple. I attempted the superglue way then I decided to just sand the whole thing down and attach a larger hose. No boost gauge so I can't see if I'm hitting full boost.
I feel laggy sometimes and other times I don't. My question is should there be some type of vacuum from the outer nipple? I pulled it one time when I was idle and felt nothing from it
SOLD - 2007 Mazdaspeed3 210k
Current - 2007 Mazdaspeed6
The Following User Says Thank You to twincitySPEED6 For This Useful Post:
m8357510 (02-16-2020)
 Old 03-28-2013, 03:01 PM   #21
Posts: 2,827   (View Stats)
Get a boost gauge -- you need one anyway!
Superglue is probably not working. Even if it does, it probably won't last long.
To avoid the same thing happening again, consider the Grimmspeed electronic boost control solenoid, run it regular two port mode. It is a "drop in" replacement for the stock part.
You would just leave your broken stock piece where it is. You mount the Grimmspeed solenoid to your battery box and connect the supplied hoses to your wastegate actuator and TIP. The electrical connection is a direct plug-in for your stock wiring -- no cutting or splicing. The great thing about the Grimmspeed is that the nipples are metal, not plastic, and you'll never have to worry about breaking them again.
And, if you every decide to get a Cobb AP you can use its three port mode.
GrimmSpeed
It will cost you about twice the cost of the OEM Mazda product, but the peace of mind coming from very sturdy metal nipples, quality construction, and easy access at the battery box make it more than worth it.
The Following 2 Users Say Thank You to MSMS3 For This Useful Post:
kolosok17 (12-25-2013), twincitySPEED6 (04-02-2013)
 Old 02-15-2016, 12:16 PM   #22
Richys10's Avatar
Posts: 61   (View Stats)
Richys10 is a jewel in the roughRichys10 is a jewel in the roughRichys10 is a jewel in the rough
Groaned at 12 Times in 3 Posts
Default Oem EBCS part Number?
Like most guys I broke my EBCS nipple as well and I was looking to replace it. I temporarily fixed it but I'm looking to purchase a oem one but I was wondering if anyone knew the part number?
Richys10 is offline   Reply With Quote
The Following 2 Users Say NO Thank You to Richys10 For This Un-useful Post:
MSMS3 (02-16-2016), Vansquish (02-15-2016)
 Old 02-15-2016, 01:06 PM   #23
gdawg25's Avatar
Posts: 248   (View Stats)
gdawg25 is the leader of the worldgdawg25 is the leader of the worldgdawg25 is the leader of the worldgdawg25 is the leader of the worldgdawg25 is the leader of the worldgdawg25 is the leader of the worldgdawg25 is the leader of the worldgdawg25 is the leader of the worldgdawg25 is the leader of the worldgdawg25 is the leader of the worldgdawg25 is the leader of the world
Post #4 . Read it.
'08 MS3 // Corksport Turbo // JBR 3.5" WP // CNT Racing Turbo-Back // CX Racing FMIC // COBB AP // SURE Ventus // SURE Return // Damond Motorsports PMM & TMM // SURE Torq R3 // Stratified Guardian Angel // Autotech HPFP Internals // JBR EBCS // Corksport 3.5bar MAP // JBR S2 OCC // JBR EGR Delete // JBR TIG's // CP-e Safe Seals // SURE Shortcut // Corksport Swaybars // Bilstein Sports // H&R Springs // Tenzo R Type M 18"x8" // Michelin PSS
gdawg25 is offline   Reply With Quote
The Following User Says Thank You to gdawg25 For This Useful Post:
 Old 02-16-2016, 07:09 AM   #24
Get the Grimmspeed part instead. It is inexpensive and has metal nipples. You'll never break it.
It comes with new hoses and is easy to install. You leave them factory POS where it is and install the Grimmspeed unit to the side of your battery box. No reason to replace a plastic nipple with another one you will just break again, sooner or later.
Richys10 (02-19-2016)
GrimmSpeed 3 Port Boost Control Solenoid ? ms6ms6 MazdaSpeed 3/6 - ECU Computer Tuning 42 04-14-2012 09:04 AM
Anyone using the stock boost control solenoid with an MBC? madvillain MazdaSpeed 3/6 - Turbo Induction 0 07-28-2010 08:26 PM
Boost Control Solenoid Part #??? ITALIA3 2010 MS3 - Troubleshoot/Diagnostics 4 06-29-2010 03:34 PM
Page generated in 0.46231 seconds with 33 queries
