 Old 02-23-2014, 05:25 PM   #1
torquemaniac's Avatar
Posts: 733   (View Stats)
The 582 (CX-7) as smaller exhaust A/R and compressor wheel than both the 881 and 882
I once took apart a 582 (CX-7) and 881 (MS6) side by side, and two difference I saw is the journal bearing design and the oil inlet banjo (the CX-7 banjo as a smaller oil passage)
Maybe Mazda made some change to the turbo at some point to prevent the smoking issue (by restricting the oil intake and altering the journal bearing design for the lessen oil pressure)
881 may be the old version, and 882 the new version?
Anyhow, before I put the MS6 turbo in my CX-7, I rebuilt it with the original journal bearing (the two version are included in the rebuilt kit), and put the turbo on the car with a MS6 banjo bolt (bigger oil inlet hole)... a while after, I begin to have smoking issue
The minute I put the CX-7 banjo bolt back, the smoking issue was gone (the CX-7 banjo as a small opening like the Bnoon bolt)
Maybe you just need a rebuilt (with the new journal bearing design) and Bnoon bolt?
2011 CX-7 AWD 2.3 turbo
Gen 1 vs Gen 2 piston and rod differences Lex MazdaSpeed 3 - Engine, Transmission & Driveline 42 08-14-2019 02:43 PM
K04 Differences: K0422-582 vs. K0422-881 / K0422-882 BAT-man 2010 MS3 - Turbo Induction 92 12-07-2016 09:02 PM
any differences between K04's? btstarcher MazdaSpeed 3/6 - Turbo Induction 5 04-09-2013 04:52 PM
Going from 93 to 91...what kind of differences will I see Stangcobra MazdaSpeed 3/6 - ECU Computer Tuning 16 09-13-2012 07:29 PM
Gen 1 - Gen 2 differences? steedspeed 2010 MS3 - Turbo Induction 15 11-05-2010 08:44 AM
Page generated in 0.23011 seconds with 21 queries
