Like Tree15Likes
 Old 09-17-2011, 09:12 AM   #81
G26
G26's Avatar
Posts: 2,988   (View Stats)
G26 is the leader of the worldG26 is the leader of the worldG26 is the leader of the worldG26 is the leader of the worldG26 is the leader of the worldG26 is the leader of the worldG26 is the leader of the worldG26 is the leader of the worldG26 is the leader of the worldG26 is the leader of the worldG26 is the leader of the world
Groans: 39
So, like I said, is this something you would recommend doing with the stock pull through setup, on a sri?
Btw, I found this site that seems to offer custom Honeycomb sizes cheap.
http://www.saxonpc.com/100mm-cells-for-100.html
2011 MS3 / Fully Bolted / 290whp - 320wtrq ~ Sold
2010 Accord Coupe EX-L V6 ~ Current ~ K&N SRI / 4300k HIDs
G26 is offline   Reply With Quote
 Old 09-17-2011, 09:18 AM   #82
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
Honeycomb for MAF
If you are not running a larger than OEM maf housing there is no reason to add the straightener.
The Following 3 Users Say Thank You to SSinstaller For This Useful Post:
G26 (09-17-2011), wolly6973 (09-17-2011), Ziggo (09-17-2011)
 Old 09-17-2011, 12:37 PM   #83
MZR165's Avatar
Posts: 273   (View Stats)
MZR165 is the leader of the worldMZR165 is the leader of the worldMZR165 is the leader of the worldMZR165 is the leader of the worldMZR165 is the leader of the worldMZR165 is the leader of the worldMZR165 is the leader of the worldMZR165 is the leader of the worldMZR165 is the leader of the worldMZR165 is the leader of the worldMZR165 is the leader of the world
So, there wouldn't be any benefit at all if you have an OEM MAF housing or just very negligible.
MZR165 is offline   Reply With Quote
 Old 09-17-2011, 12:38 PM   #84
Groans: 60
Unless you have a very shitty intake there will be no benefit..
The Following 2 Users Say Thank You to SSinstaller For This Useful Post:
Dano (09-19-2011), MZR165 (09-17-2011)
 Old 09-17-2011, 01:19 PM   #85
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
Just read this whole thread and I have to say my head exploded a couple of times..LOL
now that I have it back together and on the subject of OE maf size and the need or no need for honeycomb.
since the air coming through the filter is very turbulent, will the honeycomb still not have a positive effect on flow. Typical SRI filters are only a few inches away from the MAF itself and I have to believe the airflow is all outta whack...[engineering term there]
1) would it improve idle stability
2) would it improve WOT operation
edit: I guess SS already answered both while I was posting...
 Old 09-19-2011, 12:42 PM   #86
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
Originally Posted by SSinstaller View Post
I'm still running the small filter CP-E sends with the big maf housing, I think that coupled with the maf straightener is creating significant vacuum in the compressor at WOT lowering efficiency as the vacuum rises... I will rectify this problem when I go blow through...will be running a full 4" intake with this filter.
I haven't finished the map revisions yet, but it looks like it will be closer to 20~30g/s...so even on my current setup it's not that big of a restriction..
Why not just put the filter on the turbo?
Now you got me thinking between 4" intake vs blow through and filter on turbo.
I think i'll have to do the blow through now hahahaha.
Tokay444 likes this.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
jmhinkle (09-19-2011)
 Old 09-19-2011, 12:44 PM   #87
bcmurphy87's Avatar
Posts: 1,435   (View Stats)
im doing blow through...i just need to get the car running to tune it. i havnt ordered an air striaghtner yet.
06 Speed6 GT- Sold
The Following User Says Thank You to bcmurphy87 For This Useful Post:
djuosnteisn (09-19-2011)
 Old 09-19-2011, 12:45 PM   #88
BlueStreak's Avatar
Posts: 1,467   (View Stats)
I imagine IATs would be significantly hotter with just a filter on the turbo, no?
'07 CWP MS3
Forged.
The Following User Says Thank You to BlueStreak For This Useful Post:
 Old 09-19-2011, 12:48 PM   #89
Captain
trade offs between pressure ratios and temp inefficiencies.
I kinda want to try my hand at tuning a 4" intake with a maf for giggles, and then fab a blow through as well.
www.permtuning.com
BlueStreak (09-19-2011), BobtailedSnail (11-29-2011)
 Old 09-19-2011, 01:19 PM   #90
Honeycomb for MAF
does anyone read the OP these days? lol
The Following 3 Users Say Thank You to superskaterxes For This Useful Post:
BobtailedSnail (11-29-2011), Dano (09-19-2011), jmhinkle (09-19-2011)
 Old 09-19-2011, 01:31 PM   #91
G26
G26's Avatar
Groans: 39
nah, lol.
 Old 09-19-2011, 01:59 PM   #92
Groans: 60
It would hit the brake fluid reservoir.. It's not going to be much of an intake really, just a 45deg coupler a few inches of 4" pipe and 14" of filter...
 Old 09-19-2011, 02:45 PM   #93
Trail of Fail
Dano's Avatar
IMO blow through is waaaaay easier and probably provides more stable AF control.
BlueStreak (09-19-2011), BobtailedSnail (11-29-2011), djuosnteisn (09-19-2011)
 Old 09-19-2011, 02:47 PM   #94
Captain
Lol, blow thru is far from easy to tune for.... at least the one time i've tried.
Long tubes are a blessing, and this air straightener is probably the key to success. I'll do both tho, because race fabricator.
www.permtuning.com
The Following 7 Users Say Thank You to djuosnteisn For This Useful Post:
BlueStreak (09-19-2011), Dano (09-19-2011), JacksonMS30 (09-20-2011), jmhinkle (09-19-2011), kgb (09-20-2011), Tokay444 (09-19-2011), wolly6973 (09-19-2011)
 Old 09-19-2011, 02:52 PM   #95
Trail of Fail
Dano's Avatar
ok then...I just gathered from this thread and from guys that had big mafs and then went back to OE that it was a PITA to run a big maf.
blowthru wouldn't' require any scaling right?
I could see the need to either negate the IAT tables or split the harness and put another IAT sensor in the intake pre turbo.
BlueStreak (09-19-2011), djuosnteisn (09-19-2011)
 Old 09-19-2011, 03:01 PM   #96
Captain
I dunno, i've honestly never had a horrible time calibrating larger intakes. That's the main reason i want to try a 4", just cause i know it should be a pita lol. I want to try nonetheless.
For the temp sensor on the maf, i think you want to keep it with the maf sensor. So that the ecu can account for the density of the air stream blowing across the hot wire. And i think scaling would be necessary if the pipe diameter changes. If / when i do blow through, i'll probably use a 3.25" I.D. pipe like before. Or at least a 3". You can just as easily max the maf in blow thru as draw thru from what i understand. I mean, it's not like the mass of air is changing just cause it's under pressure, right?
Check out these blow through options for wrx (which will fit our maf sensor exactly btw):
MegaMAF Blow-Thru MAF Housing (with couplers)
Notice how they offer different diameters for increased power goals?
www.permtuning.com
Last edited by djuosnteisn; 09-19-2011 at 03:01 PM. Reason: MSF Database - Automerged Doublepost
Dano (09-19-2011), Navy_Mech2 (11-16-2011), PapaSmurf (09-19-2011), rfinkle2 (07-13-2012), wolly6973 (09-19-2011)
 Old 09-19-2011, 03:46 PM   #97
Ziggo's Avatar
Posts: 3,843   (View Stats)
DJ gets +1 internets.
If a 3" draw-thru is getting maxed, a 3" blow-thru would be maxed as well. The MAF measures mass flow, not velocity.
Zigatapatalka
Ask Me About My:
The Following 3 Users Say Thank You to Ziggo For This Useful Post:
chaser27 (11-20-2014), djuosnteisn (09-19-2011), jmhinkle (09-19-2011)
 Old 09-19-2011, 04:36 PM   #98
Captain
Lol @ how my car will look with a 3.25" cold pipe.
www.permtuning.com
BobtailedSnail (11-29-2011), jmhinkle (09-19-2011)
 Old 11-07-2011, 01:21 PM   #99
Jackis's Avatar
Posts: 428   (View Stats)
Jackis is the leader of the worldJackis is the leader of the worldJackis is the leader of the worldJackis is the leader of the worldJackis is the leader of the worldJackis is the leader of the worldJackis is the leader of the worldJackis is the leader of the worldJackis is the leader of the worldJackis is the leader of the worldJackis is the leader of the world
Nice thread... subbed.
Feel myself like dumb actually... Graduated 4yrs ago, didn't have fluid or hydrodynamics course (applied math department), but realized I totally forgot almost all this stuff behind rotors, divergences, Navier-Stocks ODEs....
Does your MS3 start when it's -30C (-22F)?
Forged, bolted, tuned, gtx30/tial/ewg. Thanks.
Jackis is offline   Reply With Quote
 Old 11-09-2011, 03:33 PM   #100
Navy_Mech2's Avatar
Posts: 484   (View Stats)
Navy_Mech2 is the leader of the worldNavy_Mech2 is the leader of the worldNavy_Mech2 is the leader of the worldNavy_Mech2 is the leader of the worldNavy_Mech2 is the leader of the worldNavy_Mech2 is the leader of the worldNavy_Mech2 is the leader of the worldNavy_Mech2 is the leader of the worldNavy_Mech2 is the leader of the worldNavy_Mech2 is the leader of the worldNavy_Mech2 is the leader of the world
good find. bigger and wayyyyyyyyyyyy cheaper than cpe's 3.25" housing
06 MS6 |SP Built motor - Weisco Pistons .020" over, Manley H-Beam Rods, Ported Head, Ported Intake, VTCS Delete, BS Delete, VVT Actuator, Keyed Crank, 6th Port Fuel Injection | ACT 6 Puck w/ Streetlite Flywheel | Bullseye S259 .70 A/R Single Scroll | 3.5" Intake/MAF Housing | Steedspeed Twin Scroll T3 Top Mount Manifold | Tubosmart 40mm EWG | Custom DP | Custom TBE | Custom LTA Intercooler | HKS Type IV TT | Dashhawk | COBB AP | AWR RMM | PTP HPFP Guts |
KILLAH BUILT
Navy_Mech2 is offline   Reply With Quote
 Old 11-26-2011, 02:50 PM   #101
G26
G26's Avatar
Groans: 39
Eh i just ordered one for the hell of it. If it doesn't work out, im out $5. Only thing I am concerned about is the running rich at wot with it.
 Old 11-27-2011, 11:36 AM   #102
MarkyMark's Avatar
Posts: 1,624   (View Stats)
MarkyMark has disabled reputation
Groans: 62
Groaned at 156 Times in 148 Posts
We have BIg Power Aeros MAF housings finishing next month. 3" ID for big dogs and 3.25" ID for even bigger dogs.
MarkyMark is offline   Reply With Quote
The Following 6 Users Say Thank You to MarkyMark For This Useful Post:
86AmishMs3 (11-27-2011), BobtailedSnail (11-29-2011), djuosnteisn (11-29-2011), Easter Bunny (11-27-2011), rfinkle2 (07-13-2012), SSinstaller (11-27-2011)
 Old 11-27-2011, 11:53 AM   #103
Groans: 60
You might as well skip the 3".
3.25" and 3.75", would be better...
djuosnteisn (11-29-2011), jmhinkle (11-27-2011), superskaterxes (11-27-2011)
 Old 11-27-2011, 07:51 PM   #104
86AmishMs3's Avatar
Posts: 3,639   (View Stats)
Groans: 338
Nothing should be wrong with 3" for those staying under 450wheel. Also consider sumark said ID
Current: N54 135i
DCI, DP's, Exhaust, FMIC
12.3@122
2009 Mazdaspeed 3:
GT3076 - Corkey tuned
390whp/400wtq
12.8@114
Sold
 Old 11-27-2011, 08:50 PM   #105
J-Liss's Avatar
Posts: 1,949   (View Stats)
J-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the world
Groans: 81
Groaned at 30 Times in 25 Posts
awesome work skates! cant wait to see the outcome, then copy your ass.
2004 mazda 3-Daily
2008 mazda 6-Wife
2008.5 Mazdaspeed 3 totaled
1983- FB Rx-7 Soon to be boosted Carb epicness
Exedy Clutch/Tokico shocks/racing beat Springs/2.5 Custom exhaust/Short shifter/Solid Motor Mounts/custom 3 point harness bar/Full MSD ignition/T2 Oil cooler
J-Liss is offline   Reply With Quote
The Following User Says Thank You to J-Liss For This Useful Post:
 Old 11-29-2011, 08:59 AM   #106
Captain
If you need help with calibrations, just lemme know. It would be cool if you published maf values for each intake IMHO.
Oh, and i just read my quote from a while back about trying a 4" intake... cause it should "theoretically" be difficult. I calibrated my 4" intake in one try... hahaha. Definitely wasn't an issue whatsoever.
www.permtuning.com
BobtailedSnail (11-29-2011), Jackis (11-29-2011), jracer (11-29-2011), wolly6973 (11-29-2011)
 Old 11-29-2011, 11:53 AM   #107
bcmurphy87's Avatar
Well i feel safe to safe that im running a blow thru set up perfectly now with just a 4in filter on the turbo. I did not work right until i added the honeycomb in the OP post and put about 8.5in of straight pipe in front of the maf.
06 Speed6 GT- Sold
The Following 5 Users Say Thank You to bcmurphy87 For This Useful Post:
Boosted Beluga (11-29-2011), djuosnteisn (11-29-2011), ESB Jiu JItsu (08-08-2012), Jackis (11-29-2011), wolly6973 (11-29-2011)
 Old 11-29-2011, 11:56 AM   #108
Captain
IIRC, we tried a honeycomb originally on the shorter section... and while "better", it still wasn't enough, right? The real saving grace was the extra length IMO.
I might be remembering wrong though lol.
www.permtuning.com
bcmurphy87 (11-29-2011), wolly6973 (11-29-2011)
 Old 11-29-2011, 12:19 PM   #109
bcmurphy87's Avatar
You are VERY VERY correct! Length is everything. Do not think adding the straightener will compensate for being to short. I think we were having issues at 6 inches. The saving grace was the 8 inches or better.
06 Speed6 GT- Sold
The Following 2 Users Say Thank You to bcmurphy87 For This Useful Post:
djuosnteisn (11-29-2011), wolly6973 (11-29-2011)
 Old 11-29-2011, 12:20 PM   #110
MarkyMark's Avatar
Groans: 62
We weren't even going to go that far. We were just going to make available a larger housing with airflow straightener for you guys to calibrate with ATR once you got it.
The Following User Says Thank You to MarkyMark For This Useful Post:
 Old 11-29-2011, 01:10 PM   #111
wolly6973's Avatar
Posts: 2,364   (View Stats)
Groans: 386
You are VERY VERY correct! Length is everything. I think we were having issues at 6 inches. The saving grace was the 8 inches or better.
That's what she said...
The Following 7 Users Say Thank You to wolly6973 For This Useful Post:
bcmurphy87 (11-29-2011), chaser27 (11-20-2014), djuosnteisn (11-29-2011), J-Liss (11-29-2011), Jackis (12-01-2011), jmhinkle (12-27-2011), Pointless (01-02-2013)
 Old 11-29-2011, 02:10 PM   #112
Captain
Beat me to it. Just don't beat me with it.
Well if you want, i'd be happy to dial in a few, and publish the maf values in the perm tuning section. Wouldn't hurt for people to have a starting point. Just lemme know if you want.
www.permtuning.com
 Old 11-29-2011, 02:29 PM   #113
BobtailedSnail's Avatar
Posts: 1,375   (View Stats)
So do have pull through or blow thru?
I'm buying a new block to build and am going topmount BT with this new ground you guys are covering with the Intake manifolds and now this straightener business it brings a lil more hope for a high HP DISI. i think ima bite the bullet and go HTA3794R w/T4 twinscroll 1.00A/R hotside and i believe it does have a 4in. compressor inlet and i think a 2.5 outlet. My concern is that with all the pipe size changes what would be an optimal IC inlet/outlet size and if it could come into play with air uniformity/turbulance.
This peaked my intrest with DJ talking about the 4in intake. Also has anyone ever concidered a different MAF like the Mustang ones that are 3.5in+ and have the components centered in the housing or is this no longer a problem?
sorry my head has been hurting from reading this thread even tho ima Mechanical Engineer major just haven't had these classes yet lol.
Skreets be calling...
The Following User Says Thank You to BobtailedSnail For This Useful Post:
 Old 11-29-2011, 02:58 PM   #114
Captain
My intake is pull through, like normal... just much much larger.
That's a big fucking turbo your talking about lol. Fuel should be your #1 concern IMO. The rest will be easy, hahaha.
2.5" IC piping will be fine, and there are lots of intercoolers to choose from with that size. If your going blow through, copy what bcmurphy has done, it seems to be working great so far.
www.permtuning.com
 Old 11-29-2011, 03:13 PM   #115
yeah it is very huge and with prolly be set up for drag alone and with the custom Intake manifold that SilverDemon is heading up it was discussed about a possible additional port injection incorporated into the IM.
EDIT: not trying to hack this into a IM/fueling thread lol
 Old 12-26-2011, 09:05 PM   #116
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,811   (View Stats)
Had a lot of fun today putting together a 4" intake with MAF screen.
Stock location. Braille light weight battery with DIY mount. Shit is tighter than taliban pussy but it fits.
Vehicle would not start after install of course. This is me not thinking things through as usual . So after pondering whether to put back the old Cobb SRI and getting a reasonable MAF table or doing something to jig it I decided to just use some masking tape to restrict the flow till I could get the car to idle. Fucking LULZ! It worked. After I got home from the shop I had to increase my MAF table 4 times 25% before I could completely remove all of the tape. I kept widening the opening after every revision till I was able to get the car to idle with STFT and LTFTs within +/- 10. hahaha. Fun times.
My maf curve goes to 925 gs now. hehe.
Not sure how the maf screen will work. I'll start calibrating some time this week,
The Following 5 Users Say Thank You to Tomas For This Useful Post:
86AmishMs3 (12-26-2011), crazyp (12-26-2011), Dano (12-26-2011), helmetface (09-12-2012), rfinkle2 (07-13-2012)
 Old 12-26-2011, 09:18 PM   #117
crazyp's Avatar
Posts: 1,093   (View Stats)
Groans: 68
some sick shit right there lol, nice
 Old 12-26-2011, 09:19 PM   #118
Trail of Fail
Dano's Avatar
Lol
Nice tape job.
Tappin
 Old 12-26-2011, 09:30 PM   #119
86AmishMs3's Avatar
Groans: 338
haha did you fail geometry in highschool? Should have made a scaled maf cal first based on the squared ratio of ID's
Current: N54 135i
12.3@122
2009 Mazdaspeed 3:
390whp/400wtq
12.8@114
Sold
The Following User Says Thank You to 86AmishMs3 For This Useful Post:
 Old 12-26-2011, 09:34 PM   #120
Bob Ross Fanclub
Tomas's Avatar
Highschool? I barely passed kindergarten. And that was only cuz I let my priest teacher fondle my wee wee.
86AmishMs3 (12-26-2011), Dano (12-27-2011), Easter Bunny (12-27-2011), jmhinkle (12-27-2011), rfinkle2 (07-13-2012)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f11/maf-airflow-straightener-testing-88520/
Untitled document This thread Refback 12-24-2015 02:29 AM
Here's how VW is fixing its emissions-cheating engines - Business Insider This thread Refback 12-02-2015 05:26 PM
Oh, the wicked web you weave... - Page 9 - Motoring Alliance :: MINI Cooper Forums This thread Pingback 12-02-2015 11:51 AM
Here's how VW is fixing its emissions-cheating engines - Business Insider This thread Refback 12-02-2015 10:04 AM
How The Volkswagen 'Flow Straightener' Really Works This thread Refback 12-02-2015 09:01 AM
V8 Brothers - ???????? 447 - 1UZ\3UZ - Altezza & Lexus IS Club - ???????? 447 This thread Refback 11-19-2015 04:05 AM
V8 Brothers - ???????? 447 - 1UZ\3UZ - Altezza & Lexus IS Club - ???????? 447 This thread Refback 11-19-2015 02:07 AM
V8 Brothers - ???????? 447 - 1UZ\3UZ - Altezza & Lexus IS Club - ???????? 447 This thread Refback 11-18-2015 10:40 AM
5VZ-FE Turbo Build Help Thread - Page 20 - Toyota Tacoma Forum This thread Pingback 03-21-2015 08:52 PM
Paper honeycomb in throttle body - FordFusionClub.com : The #1 Ford Fusion Forum This thread Refback 10-20-2014 09:32 PM
Throttle Body Screen Removal - Page 2 This thread Refback 10-10-2014 10:15 PM
What are your (modified) long term fuel trims? - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 09-08-2014 07:34 PM
SRT Intake w/ Air Straightener w/ PIX - my.IS - Lexus IS Forum This thread Pingback 06-21-2014 02:44 AM
Piggy back for turbo is - my.IS - Lexus IS Forum This thread Refback 06-10-2014 09:03 AM
what did you do to your micra today ? | Page 292 | Micra Sports Club This thread Refback 01-03-2014 03:25 PM
TourerV.ru ? ???????? ???? - ??? ????? ????.?????? ?? JZX110/JZS17x? ???????? MAF This thread Refback 07-15-2013 12:24 PM
Cone air filter with a stock look. ? Mazda MPS Owners Club This thread Refback 04-23-2013 12:41 PM
HoneyComb MAF Mass Air Meter Airflow Straightener - Page 2 - NewCelica.org Forum This thread Refback 03-31-2013 03:26 PM
Air Flow Straightners ? Mazda MPS Owners Club This thread Refback 03-10-2013 08:28 PM
intake idea? - Power and Drivetrain - Nissan GT-R Heritage This thread Refback 02-09-2013 12:53 PM
MAF mod completed!! Success!! :) - Page 2 This thread Pingback 08-01-2012 04:52 PM
Check engin - Civic 2012 et plus - Club Civic Quebec :: Forum This thread Refback 07-16-2012 09:55 AM
CAI or modified Intake cure..? This thread Pingback 07-15-2012 06:44 PM
Check Emission System after 60 miles with Injen CAI. Bummer. - Page 2 This thread Pingback 07-15-2012 05:46 PM
Mazda MPS Owners Club • View topic - Air Flow Straightners This thread Refback 05-10-2012 06:24 AM
HELP! ?????????? ????? ? ????????????? ?????? This thread Refback 11-07-2011 12:41 PM
Mazda MPS Owners Club • View topic - Cone air filter with a stock look. This thread Refback 11-02-2011 11:51 AM
Report: Citroen to follow Fiat's lead with DS3 Airflow convertible [w/poll] Haltech Automotive News 0 05-15-2011 09:40 AM
Got airflow? Hectik1 MazdaSpeed 3/6 - Appearance 3 04-21-2011 04:31 PM
Air Straightener? bewsted 2010 MS3 - Turbo Induction 7 12-25-2010 11:51 AM
Engine Load and Airflow vs TQ and HP bova
Cobb Access Port/Maps
9 02-25-2009 07:25 AM
v103 MS CAI maps... will they REQUIRE the airflow straightener? bast525
6 09-15-2008 01:15 PM
Page generated in 0.63405 seconds with 37 queries
