![]() Join Date: May 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2
(Thread Starter) | Not Ranked : 0 score Anybody run the MS CAI as a SRI? Not sure if it is even possible. |
![]() Join Date: Feb 2009 Location: Coronado ca.
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 101
| Not Ranked : 0 score I've done this... I have a MS CAI and when (though not often) we have heavy rains I make the CAI into a SRI, I cut the tube in the appropriate place and slid cone on..works great. The when the rain goes away I put a silicone coupler with 2 clamps on where I cut the tube and its back to a CAI. Works good either way. But I have seen on the dashhawk that when its a CAI the intake air temp is about 20 to 25 cooler. Hope that helps somewhat.
__________________ 2007 mazdaspeed6 & 2007 mazda 6 wagon gt 3.0 |
![]() Join Date: Mar 2008 Location: Central Florida
Rep Power: 0 ![]() ![]() Thanks: 8
| Not Ranked : 0 score i also have done it to mine. twice. first i cut it because i was tired of it getting wet when it rained. the second time i had to cut it shorter for my custom front mount. |
![]() Join Date: Mar 2008 Location: Boone, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 241
| Not Ranked : 0 score I had mine in SRI mode for a long time when I had a FMIC and then even after I took the FMIC off. Just remove the lower tube and put the filter on the top pipe. You may or may not have to twist it from the inlet to get it to fit correctly. Make sure you put that relay box thing back on the side down there since it's attached to the CAI
__________________ -Derek No longer in the Mazdaspeed Family |
![]() Join Date: Mar 2008 Location: Victoria TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 405
Groans: 70
| Not Ranked : 0 score Running it right now.
__________________ Black 2003 Evo VIII-3in TBE,HKS 280's,ETS Intake,Halman pro MBC,Forge BOV,Precision 6262,4" Intercooler,AEM Meth injection,Manely S&R's.4G63 FTW! |
(Thread Starter) | Not Ranked : 0 score Are you running the air straightener as well? Also does your filter cover the Mazdaspeed logo? I did this today and have the filter and air straightener on, but it was a tight fit. |
![]() Join Date: Dec 2008 Location: Philly, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14
Groaned at 5 Times in 1 Post
| Not Ranked : 0 score Can you twist the upper pipe to give more clearance? |
Groans: 70
yea you can turn it a little.
__________________ Black 2003 Evo VIII-3in TBE,HKS 280's,ETS Intake,Halman pro MBC,Forge BOV,Precision 6262,4" Intercooler,AEM Meth injection,Manely S&R's.4G63 FTW! | |
(Thread Starter) | Not Ranked : 0 score Yeah I fiddled with it some more and covered a little more of the D as suggested, and it gave me a little more clearance. It still rests along the side 'frame' so to speak. |
![]() Join Date: Aug 2008 Location: jersey
Rep Power: 609 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 388
| Not Ranked : 0 score any negative performance to going from cai to sri? i have a dent in my lower pipe on my cai and im thinking about switching it to a sri |
![]() Join Date: Feb 2009 Location: All Over
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 284
Groans: 32
Groaned at 31 Times in 18 Posts
| Not Ranked : 0 score Hey MS6PC, how were you getting the CAI wet? Did you not have a hydroshield that comes with the mazdaspeed CAI? I'm just curious, because I ordered my mazdaspeed CAI this past week and if there's a problem with it getting wet, I'm worried. I've heard it does not get wet unless I truck through like 12 inches or more of water. |
