 Old 10-08-2008, 05:26 PM   #1
socks's Avatar
Posts: 3,250   (View Stats)
Groans: 125
Default -+- My custom cobb SF intake (gt3071r) -+-
So when i first installed my gt3071r, i was using an RPMC inlet pipe.
This required a 4" to 2.5" reducer at the turbo. yikes. I wasnt happy with its orientation, the reducer was crushed just to fit, and it was a huge reduction in size that i was not happy with.
I started by relocating the battery to the trunk to relieve some of the "kink" in the reducer at the turbo. It helped, but was still kinked, and a 1.5" reduction right at the turbo.
So now with all that extra room in the engine bay, i decided to make a custom 3" inlet. I used a 4" to 3" reducer, with a 45* bend in it, right at the turbo. from that, i used a 3" aluminum pipe, with another 45" bend. this pointed the intake directly towards the front of the car.
then i used a 3" coupler to connect the inlet pipe directly to the cobb maf housing, and retained the cobb filter.
The problems with this are that between the inlet pipe, and the cobb silicon piece, there are 2 connections that i had to account for. one is the crankcase vent on the valve cover. For now, all i did was put a small breather filter on it. I will have a piece welded on so i can use a hose to connect this back to the inlet pipe.
Also, the HKS valve i have was recirculating to the RPMC inlet. For now i am just venting this to atmosphere. no problems yet, but i still plan to have another piece welded to the inlet to recirculate.
I am not even concerned with the wastegate solenoid dump.
Overall this cost a little over $225, with the battery relocation kit ($110), the aluminum was $60, and the silicon connections and Tbolts were about $45. the breather filter was another $10
I am very happy to have the kink out right before the turbo, as well as a much larger inlet pipe. I still have to clean up the wiring for the battery, and make a bracket for the ecu, and possibly the intake.
Pics are below
Next... Porting the ATP exhaust housing wastegate opening.
The Following 2 Users Say Thank You to socks For This Useful Post:
gsrtype1 (10-09-2008), kingpin748 (10-08-2008)
 Old 10-08-2008, 05:40 PM   #2
ILL3ST
xcoldricex's Avatar
Posts: 2,777   (View Stats)
Groans: 105
what is this battery relocation kit?
 Old 10-08-2008, 06:02 PM   #3
socks's Avatar
Groans: 125
i got mine from summit racing. Its a sealed battery box. Includes a drain, and enough 2 gauge wiring for a power and ground. it also comes with clips and such to run the wire securely.
its the premium battery relocation kit on summitracing.com
 Old 10-08-2008, 06:21 PM   #4
crazyitalian041's Avatar
Posts: 611   (View Stats)
crazyitalian041 is the leader of the worldcrazyitalian041 is the leader of the worldcrazyitalian041 is the leader of the worldcrazyitalian041 is the leader of the worldcrazyitalian041 is the leader of the worldcrazyitalian041 is the leader of the worldcrazyitalian041 is the leader of the worldcrazyitalian041 is the leader of the worldcrazyitalian041 is the leader of the worldcrazyitalian041 is the leader of the worldcrazyitalian041 is the leader of the world
I did the same as well for my gt3071r.
crazyitalian041 is offline   Reply With Quote
 Old 10-08-2008, 08:15 PM   #5
NEC
subparpunk03's Avatar
Posts: 1,267   (View Stats)
Whats the deal with the ECU? How did you mount it?
Looks awesome sean!!!
Also, can I get my inlet back now please
2006 Lotus Elise: Toy car
2007 Mazdaspeed 3: *sold*
2005 Corolla XRS: *sold*
 Old 10-08-2008, 08:54 PM   #6
socks's Avatar
Groans: 125
yes, you can have it back.
I definately notice a good difference. although, the roads are still wet.
im pumped. i cant wait to color match it to the FMIC pipes, and have it finalized.
 Old 10-08-2008, 08:56 PM   #7
socks's Avatar
Groans: 125
PS, im gonna plug siliconintakes.com for the silicon pieces i got from them. I got both pieces from this time, and the old reducer from them. although i was not happy with the application of a 4" to 2.5" reducer, they were the only place i could find it, and got it to me fast.
 Old 10-08-2008, 09:03 PM   #8
phailerider's Avatar
Posts: 4,639   (View Stats)
what the hell tune are you running on that thing.
 Old 10-08-2008, 09:20 PM   #9
socks's Avatar
Groans: 125
a beta tune from christian@cobb, hes been getting me revisions every time i send him logs, unfortunately, i havent been able to log too too much...
 Old 10-08-2008, 09:27 PM   #10
wow...ok. what boost are you running? and youre still on stock internals right?
we need to keep an eye on you man.
 Old 10-08-2008, 09:30 PM   #11
socks's Avatar
Groans: 125
still on stock internals, 16psi other than creep, i dont let it go over 18psi.
once i port the wastegate or solve my creep somehow, whether it be porting or EWG, im gonna work on the motor...then after that its 21-22psi, and water/meth or possibly nitrous...
when you get your car back you gonna go with more than 18psi?
 Old 10-08-2008, 10:05 PM   #12
my car is basically done, i drove it(babied) on sun/mon.... maybe a week or two i'll be back up in DC to pick it up. FCF, standback street tune at 23-24psi.... then back to NC and dyno at the home dyno for baseline. im hoping for 400-425 or so..... it might be less cause of fuel and maf size... which will be worked out next. anything less than 400 i'll be disappointed.
at that point, after a little enjoyment and the baseline dyno.... back up to cpe for some whoosh goodies, maf, and meth.... i want 450 on the gt3071. i dont know what i'll do after that. maybe stop for a while.
still thinking its possible i'll chase 500 in the spring if better fuel options come along. im tempted to be the first with a secondary rail too... but even if i make 500, then so much other stuff will start breaking.... and the cost will start getting ludicrous. the first two parts are a given though.
The Following User Says Thank You to phailerider For This Useful Post:
 Old 10-09-2008, 07:30 AM   #13
ElBartoRex's Avatar
Posts: 1,186   (View Stats)
ElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the world
That is awesome I am really glad those parts are working out for you.
I have considered relocating my battery many times with one of those universal kits-- where did you end up putting it? got any pics?
ElBartoRex is offline   Reply With Quote
 Old 10-09-2008, 08:00 AM   #14
fuck this, go whoosh style and do an EWG......
 Old 10-09-2008, 08:11 AM   #15
gsrtype1's Avatar
Posts: 7,514   (View Stats)
Groans: 102
nice! sub
 Old 10-09-2008, 08:57 AM   #16
LBV
LBV's Avatar
Posts: 700   (View Stats)
LBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond repute
Intercooler Pipe Fabrication - Silicone Intake Systems Auto Parts << that website has a couple of interesting items I noticed: 1 - an intake pressure tester to catch boost leaks and 2 - intakes with splash shields around them for uou guys running cai's - these are priced at $14.99 ???
2007 White MazdaSpeed 6 for sale ... new wheels = G8 GXP manual.
LBV is offline   Reply With Quote
 Old 10-09-2008, 09:24 AM   #17
ms3guy22's Avatar
Posts: 530   (View Stats)
ms3guy22 has a reputation beyond reputems3guy22 has a reputation beyond reputems3guy22 has a reputation beyond reputems3guy22 has a reputation beyond reputems3guy22 has a reputation beyond reputems3guy22 has a reputation beyond reputems3guy22 has a reputation beyond reputems3guy22 has a reputation beyond reputems3guy22 has a reputation beyond reputems3guy22 has a reputation beyond reputems3guy22 has a reputation beyond repute
where did you run the wires to? more specificially the route into the car.
I hate my mazdaspeed3 more than anything else in this world!
ms3guy22 is offline   Reply With Quote
 Old 10-09-2008, 02:50 PM   #18
NEC
He ran them along the floor on the passengers side, then up underneath the glove box through the firewall and behind the heat shield in the engine bay. Its all pretty well hidden, I ran my wires / tubes for the water injection in the same location and you can't even tell its there unless you look in the trunk.
The battery box is screwed into that big flat trunk "floor" piece on the passengers side.
 Old 10-09-2008, 04:09 PM   #19
socks's Avatar
Groans: 125
more pics:
battery box:
 Old 10-09-2008, 04:26 PM   #20
what box is that? where did u get it?
 Old 10-09-2008, 04:40 PM   #21
Eazy's Avatar
Posts: 1,539   (View Stats)
Eazy is the leader of the worldEazy is the leader of the worldEazy is the leader of the worldEazy is the leader of the worldEazy is the leader of the worldEazy is the leader of the worldEazy is the leader of the worldEazy is the leader of the worldEazy is the leader of the worldEazy is the leader of the worldEazy is the leader of the world
Groaned at 32 Times in 14 Posts
Really? did you even read the freaking thread?!?!
Eazy is offline   Reply With Quote
 Old 10-09-2008, 05:27 PM   #22
woops. i didnt connect 2 and 2.
 Old 10-12-2008, 04:25 PM   #23
socks's Avatar
Groans: 125
Im still working on making a bracket for the ecu, and cleaning up the battery wiring.
It does feel alot stronger now that i can drive it on dry roads. could also be since i washed my car. anyone else get that feeling that it is faster after a carwash? :-P
 Old 10-13-2008, 07:56 AM   #24
NEC
It IS faster after a carwash... less friction, and uhm.... less dirt weighing you down.
Also, good lord that thing is FAST. We'll have to see how it compares to mine once I put on an IC and downpipe.
 Old 10-13-2008, 08:38 AM   #25
socks's Avatar
Groans: 125
mmmm... just wait til i dont have to pedal it to keep the boost down... cuz then i may actually be able to get some logs for christian, and he can make me t0000n..
im thinking 18psi will be safe as long as it doesnt creep...
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f11/my-custom-cobb-sf-intake-gt3071r-12919/
Relocate Battery to the back - Page 2 - TorontoMazda3 This thread Refback 03-12-2009 12:24 PM
Relocate Battery to the back - Page 2 - TorontoMazda3 This thread Refback 10-14-2008 09:54 AM
Relocate Battery to the back - Page 2 - TorontoMazda3 This thread Refback 10-09-2008 10:06 PM
Relocate Battery to the back - Page 2 - TorontoMazda3 This thread Refback 10-09-2008 05:04 PM
Relocate Battery to the back - Page 2 - TorontoMazda3 This thread Refback 10-09-2008 09:51 AM
Relocate Battery to the back - Page 2 - TorontoMazda3 This thread Refback 10-09-2008 09:46 AM
Relocate Battery to the back - Page 2 - TorontoMazda3 This thread Refback 10-09-2008 09:32 AM
CP-E intake with COBB intercooler? will it fit? ChrisK Mazdaspeed3/6 General Discussion 11 08-25-2008 11:04 AM
Page generated in 0.42120 seconds with 30 queries
