![]() Join Date: Jan 2016 Location: Minnesota
Rep Power: 0 ![]() Thanks: 1
(Thread Starter) | Not Ranked : 0 score Mod list consists of: -91 octane tune, -bnr s3, -ffs 5k, -Grimmspeed ebcs, -88mm Wiseco pistons, -k1 rods, -3.5" HTP intake, -3" catless dp cbe, -Autotech HPFP internals, -Cx-racing fmic, -Damond TB spacer, -jbr Im spacer, -Kozmic egr delete, -Go fast Bitz blows off valve recirculated, -occ set to vta under boost, -c-pe safe seals, -light weight fidanza flywheel, banjo bolt, -sure short shift plate, streetunit rmm, -ngk 6510 spark plugs, -3 bar map sensor, -IM flap runner delete, -jbr bsd oil baffle. -Making 350+whp on 91; and 400+whp on e33 |
| Not Ranked : 0 score If I had to guess, I'm guessing you just bought this car didn't you?
__________________ 2006 MS6 WWP Sport - 340whp/350wtq JBR 3"- BNRS3V2 - GS EBCS - CUSTOM FMIC - CS IM - LTR7IX - CMGS WMI & D07 GA - TURBOXS HEADER - FIDANZA FW - CP-E CATTED DP - 3" CATBACK BILSTEIN - H&R SPRINGS - 18x8.5 +48 ROTA SVN - 265/35R18 HTR ZIII MINI H1 6.0 - CAR LED TAILS SEE MORE USING !SHOUTTAG.COM - ENTER: !6SPEED6 |
Rep Power: 3746 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,744
| What exact tune?
| Approved MSF Vendor ![]() Join Date: Jan 2012 Location: Maryland, USA
Rep Power: 884 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,286
| Not Ranked : 0 score Log? Weather?
__________________ --- 2011 Black Mica MS3 Tech --- ![]() www.stratifiedauto.com COBB AP and VersaTuner Custom Tuning. Guardian Angel Protection and Boost Control. |
| The Following User Says Thank You to Mike@Stratified For This Useful Post: | Vansquish (02-08-2016) |
| Not Ranked : 0 score There's a huge disconnect between what mods are explained and the lack of knowledge of tune. If I look at the Mod List, it looks cut/pasted from a CL ad.
| The Following User Says Thank You to dale_gribble For This Useful Post: | Vansquish (02-08-2016) |
| LMAO, I think I finally teased out the problem here. The OP sounds like he's got all that shit in his car, but is still running an OTS tune. No fucking shit, it's going to overboost!!
| The Following 2 Users Say Thank You to Vansquish For This Useful Post: | dale_gribble (02-08-2016), MS3Shadow (02-08-2016) |
| He thinks the OTS tune can make adjustments on it own relating to his mods. sent from my Nexus 6P
| The Following User Says Thank You to MS3Shadow For This Useful Post: | Vansquish (02-08-2016) |
| Oy, @G3nwonMazdaratti;, where you at? You must use a tune customized for your mods, you cannot use an OTS map and have the car run safely with an aftermarket map sensor, intake, or downpipe, much less your turbo.
__________________ 2013 Crystal White Pearl Mazdaspeed 3 w/ Tech Package BNR S4, XSPower v3 Exhaust Manifold w/ Tial 44mm EWG Cobb accessport V3, Dizzy Tune in progress CP-e stage2 rmm, tmic, hpfp JBR boost tubes, Tru-3.5in Intake inside a Corksport Cold Air Box, Catless Downpipe & Racepipe, bypass hose, hood scoop, BPV, hood struts, stubby antenna, Aluminum Skid Plate, EBCS, 3.5BAR MAP Sensor, Magnaflow Catback Exhaust DM Full EGR Delete, Passenger Motor Mount, Transmission Motor Mount., Coolant Bypass, VTCS Delete, NGK ILTR6A-7G ,G-LOC R6 Brake pads and Centric High Carbon brake rotors Looks: 25% tint front, 5% back, Heat-blocking front windshield film Escort Passport Max360, RGBW Halos/Demon Eyes 20'' LED Light bar Use my Updated Custom Google Search to search this forum since the advanced search here is broken | |
| I should groan you for that. :-P
| Haha, I went off the IP, apparently the ISP is Qwest. sent from my Nexus 6P
![]() Join Date: Mar 2011 Location: Dallas, Texas
| Not Ranked : 0 score Did you guys scare him off?
__________________ Max Bolted and Built Stock K04 |
| I was just asking to see if he was avoiding his own thread.
| Not Ranked : 0 score Troll maybe?
Groans: 438
| Not Ranked : 0 score Included "ffs 5k" as a mod. 400+ on e33 with a cxracing FMIC. Troll.
__________________ All good things must come to an end... |
| The Following User Says Thank You to g00s3y For This Useful Post: | Vansquish (02-08-2016) |
![]() Join Date: Aug 2015 Location: Towson, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17
| Not Ranked : 0 score I'm just commenting to laugh at this fuckery.
__________________ 2008.5 GT, it's slow. COBB AP // 80MM TEST PIPE // AUTOTECH HPFP INTERALS // CPE RMM // SHITTY CBE // GFB BOV // BILSTEIN |
I listed everything that my accessport said was on my tune. I'm just trying to get as much help as possible. Just so it's clear. IT'S FREEK TUNED ON 91, making 350+ CURRENTLY!!!! I have another e33 tune that makes 400+ for the summer. I'm not troll, i listed everything that my Accessport said was on the tune. I'm from Minnesota. I purchased the car at the beginning of november from someone in the south metro. He has been helping me diagnose my problem. My data was logged and sent To Justin at freek tune. Currently waiting a response from him. Thanks to anyone that is trying to help. Last edited by G3nwonMazdaratti; 02-09-2016 at 05:21 AM. Reason: MSF Database - Automerged Doublepost | ||
2. Post datalogs. Without them, we have literally nothing to go on.
__________________ Having trouble finding something on MSF? Use MS3Shadow's search tool:SEARCH MSF HERE! | |
-v3 accessport show that as soon as i hit WOT the wastegate opens to 48-50 and then will slowly close and completely shut to 0 around 6,000. and thats when it will properly boost. | |
(Thread Starter) | Not Ranked : 0 score datalogs |
| Your understanding of the WGDC sounds very flawed. The wastegate duty cycle should increase with boost pressure and RPM, not drop to zero. 100% should be when the wastegate is closed, and 0% is when it should be open. Take pictures of your EBCS routing too. Your map shows the exact behavior I would expect, except that the car was clearly tuned for a warmer climate, and as a result, the tune may need to be neutered a bit for cold weather and shittier gas.
A proper WOT datalog should be done in 3rd or 4th gear and be a single consistent pull from just under 3000rpm all the way to well above 6000rpm.
__________________ Having trouble finding something on MSF? Use MS3Shadow's search tool:SEARCH MSF HERE! Last edited by Vansquish; 02-09-2016 at 07:14 AM. | |
![]() | | #24 | ![]() |
| Not Ranked : 0 score That's got to be one of the weirdest logs I've seen. Especially for a Freek tune. Definitely looks like it needs some work. I'd start by looking at your MAF cal. Seems your AFRs are all over the place and your LTFT and STFTs almost hit 10 in the small region we can see. For an BNRS3, you don't seem to have the response you should. WGDG should go high trying to get your targeted boost (unless you have a load tune, and it's set very low). I'd try things like wastegate pre-load, etc. Don't understand your first comment about all the boost goes out the wastegate? It's a closed system, wastegate is in the exhaust..... I also don't understand why you call it an overboost problem. It's definitely not overboosting
![]() | | #25 | ![]() |
![]() Join Date: Nov 2010
| Not Ranked : 0 score Piggybacking because I have a similar issue with fewer/no mods. Been running on Cobb SRI + Cobb 91 Stage 1 for about 2 years with no problems. This spring started having fuel cut due to P0123 overboost (No CEL). LOGS: datazap.me | absurdity | 4th gear pull 5/17 Noticed the MAF voltage was stuck, cleaned it, same problem a little less pronounced. Got CEL and MAF voltage too high errors. Replaced MAF. Issue persists. Changed to Cobb 91 Safe Mode, issue persists. Returned everything to Stock, uninstalled Accessport. Issue persists. Sorry that I'm a total noob, I live at altitude in a colder climate so no doubt I'll need a better tune, but I'm confused as to why things would be stable for years only to shit the bed now. Any advice including a reputable shop in the Denver area is greatly appreciated! |
![]() | | #26 | ![]() |
Groans: 438
Overboost, you just need to lower your WGDC in the Cobb OTS map some, or be a little more aggressive with the boost compensation. Didn't look at the log, but i'm pretty sure that's why you were getting the overboost code.
__________________ All good things must come to an end... | |
![]() | | #27 | ![]() |
Groans: 111
__________________ 2008 Cosmic Blue Mazda 3MPS Bilstein B12 + CS Camber plates + Eibach camber arms, SSR Type-F, Michelin PS4 225/40/R18, Cobb RMM, StopTech Street Pads + Stoptech Slotted disks, SouthBend Enduro Stage3 clutch, genpu TMM + CS Insert, TheSpeedLine 2X Rear Cross Floor and Rear Middle Lower Strut bars, Tanabe 4 Point Under Brace, Whiteline Bumpsteeer corection kit JBR Tru-3" + CS CAI Box, CP-e TMIC, Cobb XLE, NGK LTR7IX, UR v3 catted DP and res&catted TP, Cobb CatBack, GS EBCS, Autotech internals, GTX3071r gen2, CS 3.5BAR, Guardian Angel, CoolingMist WMI, VCTS Delete, stock ported IM, CorkSport cam shafts Mahle 88mm 4032 9.6:1 pistons, Manley rods, CA625+ head studs, King rod&main bearings, CS seals, DCR VVT, Koyorad radiator. StratiVersaTuned FTW to 28PSI, self-tuned to 32PSI 2008 Icy Blue Mazda CX7 6 Speed Manual SU TMIC, Autotech HPFP internals, Cobb XLE, Cobb EBCS, CorkSport 3.5BAR MAP GTX2867R gen2, stock spark plugs, stock cats and stock exhaust FTW, JBR Tru-3" Silicone intake TheSpeedLine Top and Lower Strut bars self-Versatuned to 22PSI | |
![]() | | #28 | ![]() |
That said, if you're getting an overboost code, then that suggests your ECU map is also not properly designed.
| The Following User Says Thank You to Vansquish For This Useful Post: | g00s3y (09-02-2016) |
![]() | | #29 | ![]() |
Groans: 111
| Not Ranked : 0 score If the tune is targeting load then it's pretty far off, so the WGDC adjustments will be pretty aggressive initially to up the load. It's hard to tell how the tune is with such a big defect like the MAF.
| The Following User Says Thank You to mituc For This Useful Post: | Vansquish (09-02-2016) |
![]() | | #30 | ![]() |
I replaced the wiring with longer wires and didn't clip it to the battery box this time (wish I never had) and am getting good voltage on the MAF, 1V at idle, 3.6-4V under load. Got the same issue pulling in 3rd though, don't have space to do another log yet. I checked the codes again and I might be crazy - Getting a "PCM" error and P0234 (not P0123) overboost. Not sure if that's different or if I just brainfarted and got them mixed up... Found P0234 in another thread here: P0234 and Stuff - Page 2 - Mazda3 Forums : The #1 Mazda 3 Forum Wondering if it could be fuel cut? Would the turbo still boost over target with a lack of fuel, with the ECM assuming fuel is flowing and the limiting factor is intake? The first CEL I ever got was for "system too lean" in the winter. Ran some injector cleaner and it went away, happened twice now. Could that be signs of a fuel system issue? Another suspicious point is that I hadn't touched anything with the tune/intake/etc. for about two years, then suddenly engine overboost. Perhaps the combination of restricted fuel and bad MAF wiring is causing this but won't know for sure until I get the fuel system checked. Hoping it's not the solenoid or ECM itself, but that seems less likely. Thanks for any advice! | |
![]() | | #31 | ![]() |
| Post a datalog. It's likely to be the only way that we'll be able to figure out exactly what's going on.
![]() | | #32 | ![]() |
Disregard the first comment, i wasn't fully knowledgeable on the proper function of the wastegate. I uploaded a 2nd gear wot log. Still haven't resolved issue... But then again, i haven't tried anything tune related.. i said overboost because my car threw a cell for engine overboost condition (p0234). it happened as if i was boosting, got too much boost, and then loss of all power and hasnt been the same. | |
![]() | | #33 | ![]() |
(Thread Starter) | Not Ranked : 0 score 2nd gear wot, should be 25#'s. only hits 14#'s.. |
![]() | | #34 | ![]() |
| Check your EBCS lines. It would appear that you're running spring-pressure only.
![]() | | #35 | ![]() |
| Not Ranked : 0 score I agree, but there is a discussion in another thread about whether EBCS vented to atm will actually hurt a tune.... If not the EBCS, it looks like a leak of some sort. AFRs are all over the place (maybe partly due to low load being still in CL), but off WOT, LT and STFT are high as well Earlier I said to look at your MAF cal assuming you had changed something going to the S3, if not, leaks are probably the best bet
![]() | | #36 | ![]() |
Groans: 111
| Not Ranked : 0 score Only 15psi and 300+ g/s of air... Even with all those flow mods I'd say the MAF is out of town taking a blow job somewhere on a side of the road. The actual AFRs look good though but depending on the tune you may get the air difference fully compensated.
![]() | | #37 | ![]() |
I want to replace my wastegate actuator rod. I haven't done that yet and I think It might make a difference. Because if it's correct that 100% is all the way closed, mine only goes to 52. And if 0% is open, then at idle I'm always at 0. Is that correct..? But it seems to boost better when the waste gate is at 0% or under 52%. Like at half throttle it makes more boost then wot. So could my tune be fucked up..? Last edited by G3nwonMazdaratti; 09-25-2016 at 01:28 AM. Reason: MSF Database - Automerged Doublepost | |
![]() | | #38 | ![]() |
| What do you mean, "it"? There are three EBCS lines on a 3-port EBCS.
Moreover, I think you need to spend a bit more time reading your logs and making sure you understand what is in them. In the last log you posted, your car doesn't get into positive boost pressure until you're at about 2000rpm and your WGDC is around 50 at that point. Your car does NOT appear to be building boost better at 0% WGDC except for the fact that because it is running spring pressure it seems to be having a lot of trouble building boost until close to red line. You should talk to @atvfreek; about this, especially if he was the one who tuned your car.
__________________ Having trouble finding something on MSF? Use MS3Shadow's search tool:SEARCH MSF HERE! Last edited by Vansquish; 09-25-2016 at 02:18 AM. | |||
![]() | | #39 | ![]() |
| Not Ranked : 0 score Well sorry if it doesn't help but looks like I had both a broken MAF sensor wire AND a leak between the turbo and WG solenoid. Dry rot cracked hose. Couldn't reach it myself, but a shop replaced it for a couple bucks and I'm back n business, holding target boost at WOT up to redline. Good luck to others with your woes. |
![]() | | #40 | ![]() |
![]() Join Date: Apr 2012 Location: port orchard, w.a
Rep Power: 501 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 655
That is kinda common. Always leads to overboosting. Glad u found it.
__________________ COBB ACCESSPORT//TURBOXS CATLESS DP+RACEPIPE//3 BAR MAP//3.5" HTP INTAKE//NGK 1 STEP COLDER PLUGS//HKS CATBACK//AUTOTECH INTERNALS//COBB FMIC V2.0//HKS BOV BLACK EDITION IN VTA//RPF1 17x9//pilot super sport 245/45/17//ACT 6 PUCK//M.D OCC VTA//TOKAY SEALS//BNR S4//Hypnotic tuned | |
| Overboost maybe? | snypeZ | MazdaSpeed 3/6 - ECU Computer Tuning | 10 | 04-12-2013 10:48 AM |
| just cleaned valves, p0222, p0123 HELP PLEASE | meicalnissyen | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 10 | 06-17-2012 03:19 PM |
| MS6 Throwing Codes P0123 P0222 and P2009 | Speedn253 | MazdaSpeed 6 - Engine, Transmission & Driveline | 4 | 01-19-2012 11:17 AM |
| Overboost!! | oh_yeams6 | MazdaSpeed 6 - Engine, Transmission & Driveline | 4 | 10-03-2011 01:59 PM |
