 Old 02-17-2010, 11:07 PM   #1
-cj-'s Avatar
Posts: 649   (View Stats)
-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world
Default PTP SST?
I'm trying to find out more information about this turbo. Is anyone on here running one? Wondering how it'll do on a stock motor. Can it be safely tuned with an accessport? What kind of numbers are people seeing from this turbo?
Tried searching and nothing comes up....
Mod List: ATP 3071R @ 22 psi, Grimspeed in 3-port mode, Steedspeed Manifold, Snow Performance Stage 2 Meth Kit, Cobb AP, CP-E 3" Nano SRI, CP-E Big Inlet TIP, Cobb "Stage 2" Suspension Kit, CP-E FMIC, CP-E DP, CP-E HPFP, CP-E MM, TWM STS, Custom Tuned by Fobio.
-cj- is offline   Reply With Quote
 Old 02-18-2010, 01:18 PM   #2
-cj-'s Avatar
Here's some technical specs on the turbo if no one knows about it:
PT-Performance.com
"Super Stock Turbo". Anyone running one?
 Old 02-18-2010, 01:24 PM   #3
KR....i haz it
Blackspeed's Avatar
Posts: 2,845   (View Stats)
Blackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the world
Groans: 166
Groaned at 56 Times in 41 Posts
the search button is your friend
Cobb SRI | Cobb Turbo Inlet | Cobb AP |ETS TMIC 3.25" | CS Inserts |
CS Test Pipe | NGK IV22 | Blitz TT | MSD DH | TWM full replacement | PTP cdfp
While the other forum is GREAT for technical/mechanical information and how to, that place is filled with single-minded (if you aren't driving fast, you're doing it wrong), arrogant, and professional douchebags.
Blackspeed is offline   Reply With Quote
The Following 2 Users Say Thank You to Blackspeed For This Useful Post:
06Speed6 (02-18-2010), phantom3 (02-19-2010)
 Old 02-18-2010, 01:26 PM   #4
-cj-'s Avatar
Holy shit, what did you search for? I tried "PTP SST", "SST" and got nada.
 Old 02-18-2010, 01:28 PM   #5
KR....i haz it
Blackspeed's Avatar
Groans: 166
"sst turbo" in quotation marks. It comes up with a bunch of crap if you dont use the quotes.
The Following User Says Thank You to Blackspeed For This Useful Post:
-cj- (02-18-2010)
 Old 02-18-2010, 01:33 PM   #6
-cj-'s Avatar
#$%#$%... Thanks dude.
 Old 02-18-2010, 01:42 PM   #7
18psiWhiteMS3
Lurkers
18psiWhiteMS3's Avatar
Posts: n/a
i had one and spent money tuning it with the ap. i can tell u anythign u want to know. as a matter of fact i have a bran new one for sale i have not posted yet. ill sell for 600. Its the PTP sst
this was my dyno...... My DynoJet DYNO 10/6/09
Last edited by 18psiWhiteMS3; 02-18-2010 at 01:42 PM. Reason: MSF Database - Automerged Doublepost
 Old 02-18-2010, 01:44 PM   #8
meeker13's Avatar
Posts: 282   (View Stats)
meeker13 is the leader of the worldmeeker13 is the leader of the worldmeeker13 is the leader of the worldmeeker13 is the leader of the worldmeeker13 is the leader of the worldmeeker13 is the leader of the worldmeeker13 is the leader of the worldmeeker13 is the leader of the worldmeeker13 is the leader of the worldmeeker13 is the leader of the worldmeeker13 is the leader of the world
I wouldn't do anything with a K04...pg or ptp! IMO Get a GT series
GT28_COBB AP_COBB SFI_ETS IC_DNP MANI_TIAL 44MM EWG_CP-E INLET_CP-E DP_CP-E 3'' CB_TURBOSMART EBOOST2 EBC_OEM BPV_SURE DREDNAUGHT_KONIG ZERO'S_EIBACH SL SPRINGS
meeker13 is offline   Reply With Quote
 Old 02-18-2010, 02:26 PM   #9
-cj-'s Avatar
^^^ Well, I'm not built and I'm not planning on building the motor (Unless it blows and I have to). My seal is leaking and I hate replacing when I can upgrade.... Just looking for a slightly better turbo.
 Old 02-18-2010, 02:38 PM   #10
DSIT995's Avatar
Posts: 1,768   (View Stats)
U got a brand new one? %!?#% I just bought a stocker k04 to have modified. Well that sux.
BTW that 40 to 150 is fukn sweet!
99 Miata NB - Stock for now
 Old 02-18-2010, 02:44 PM   #11
johnsin55's Avatar
Posts: 59   (View Stats)
johnsin55 has much to be proud ofjohnsin55 has much to be proud ofjohnsin55 has much to be proud ofjohnsin55 has much to be proud ofjohnsin55 has much to be proud ofjohnsin55 has much to be proud ofjohnsin55 has much to be proud ofjohnsin55 has much to be proud ofjohnsin55 has much to be proud ofjohnsin55 has much to be proud of
GT2871r... more expensive but a much better designed turbo than a reworked stocker... if you buy an ss it will just have the same problem again after a period of time, I havent heard of any GT's running around with leaking seals to date, mine included
johnsin55 is offline   Reply With Quote
The Following User Says Thank You to johnsin55 For This Useful Post:
-cj- (02-18-2010)
 Old 02-18-2010, 03:10 PM   #12
tbot's Avatar
Posts: 2,821   (View Stats)
Groans: 40
I've seen those PTP turbo's grenade on a speed6 before. The compressor wheel spun down the DP and the compressor side disappeared to nothingness. That was at 20lbs. I really don't think the exhaust flange for the k04 on our car is really worth much.
The same turbo on an audi can push 24 psi efficiently, ours are about 19. I'm just throwing that out there. If you go with a BT that doesn't mean u have to push the same psi, if you look at the volume of air instead of the psi you'll see that something like a gt28 running 14lbs is gunna be similar in volume of air to our cheesy ko4 running 18lbs.
I'll leave it at that, but I've seen nothing but positive running a BT setup at lower psi levels and making the same if not more power.
The Following 2 Users Say Thank You to tbot For This Useful Post:
-cj- (02-18-2010), flyrevs2 (02-19-2010)
 Old 02-18-2010, 03:13 PM   #13
18psiWhiteMS3
Lurkers
Posts: n/a
BT are the way to go if u have time and money but if u really are just looking for a direct swap then the sst is the way to go. The sst is also efficiant up to 26 psi and i had a 24 psi tune with mine.
The Following User Says Thank You to For This Useful Post:
-cj- (02-18-2010)
 Old 02-18-2010, 06:31 PM   #14
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
Where did you see that at? Ive been around a long time and I havent seen that before.
2006 Mazdaspeed 6
 Old 02-18-2010, 07:10 PM   #15
KoukiS14's Avatar
Posts: 146   (View Stats)
KoukiS14 has a reputation beyond reputeKoukiS14 has a reputation beyond reputeKoukiS14 has a reputation beyond reputeKoukiS14 has a reputation beyond reputeKoukiS14 has a reputation beyond reputeKoukiS14 has a reputation beyond reputeKoukiS14 has a reputation beyond reputeKoukiS14 has a reputation beyond reputeKoukiS14 has a reputation beyond reputeKoukiS14 has a reputation beyond reputeKoukiS14 has a reputation beyond repute
I do remember seeing pics of a reworked K04 killing itself. I think it was on 6 club. The turbine wheel came off the shaft, shed its blades and went for a ride in the downpipe.
I also remember that he got it replaced under warranty.
KoukiS14 is offline   Reply With Quote
 Old 02-19-2010, 10:57 AM   #16
tbot's Avatar
Groans: 40
My buddies speed6. I'll see if I can get pictures from him and post em up.
 Old 02-19-2010, 10:59 AM   #17
meeker13's Avatar
Im not built but im not gona go nutz with either! As long as ur not pushing more than 20psi...
Thsi pic says it all for me!
K04 < 2871r
I don't know much about the ptp one but my buddy had a pg one and it blew up and sent 3 quarts thru the exhaust...2871 is well worth the extra $$$
 Old 02-19-2010, 11:12 AM   #18
KR....i haz it
Blackspeed's Avatar
Groans: 166
the turbo itself is more expensive, but that leads to a lot of other expenses to consider also.
manifold
DP
inlet
wastegate
how much more is all that?
Last edited by Blackspeed; 02-19-2010 at 11:12 AM. Reason: MSF Database - Automerged Doublepost
 Old 02-19-2010, 11:24 AM   #19
DSIT995's Avatar
manifold
DP
inlet
wastegate
I agree, The additional expenses get a little silly. W/ the 28 u have to run a EWG, right? If u dont u get crazy boost creep
Then u've got to have alot of custom work done to make a safe setup.
Right now for me It make more sense to go w/ and SST(Or similiar) and make 330-340whp for a fraction of the cost of making 350-380whp with GT28.
And since I already have a Mani(No EWG) and DP, this is the route I will be going
Dont get me wrong If I had access to unlimited funds and time I would go bigger, and all out, but I dont, And I dont have the skillz to do work like that myself. I go back and fourth on my goals for this car and think my mind is set........ I think
 Old 02-19-2010, 11:28 AM   #20
Alpha's Avatar
Posts: 3,711   (View Stats)
Or you can have the best of both worlds with BNR's Stage III rebuild. 2871 CHRA and upgraded turbo inlet housing that utilizes all stock mounting points and flanges. You also get to keep your IWG and not go EWG like the GTs force you to do.
Superstretch18 (02-19-2010)
 Old 02-19-2010, 11:37 AM   #21
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
GT's will get leaky seals if you don't use restrictors in them.....
I bet if u do the bnoon restrictor bolt on a new stock turbo it won't leak from the seals....
07 MS3
The original Genpoo Hater
 Old 02-19-2010, 11:41 AM   #22
KR....i haz it
Blackspeed's Avatar
Groans: 166
Don't the ATP's get boost creep? I havent to many good thinga about that turbo.Not to mention going BT is useless unless you get cp-e wall flash, which means getting a SB if you dont have one.
 Old 02-19-2010, 11:53 AM   #23
Alpha's Avatar
That's why I'm doing what I'm doing. See above (BNR)
The ATP IWG is garbage and creeps terribly.
 Old 02-19-2010, 12:12 PM   #24
KR....i haz it
Blackspeed's Avatar
Groans: 166
Am i missing somehting? I went to BNR's website and they list an ATP. Do they modify the ATP?
 Old 02-19-2010, 12:29 PM   #25
Alpha's Avatar
No, it's a modified KO4 that utilizes a 2871 CHRA and upgraded inlet housing.
Basically a hybrid between the stock K04 and a GT2871 turbo using the best from each. The site hasn't been updated yet, but I already put a deposit on my Stage III and should get it in the next month or two. I can't wait!
 Old 02-19-2010, 12:40 PM   #26
KR....i haz it
Blackspeed's Avatar
Groans: 166
Is it $1600?
 Old 02-19-2010, 12:43 PM   #27
Fagwagon's Avatar
Posts: 2,090   (View Stats)
Groans: 75
JUST GET A HOLSET--BEST OF BOTH WORLDS!
 Old 02-19-2010, 12:45 PM   #28
manelscout4life's Avatar
Posts: 1,781   (View Stats)
Groans: 661
what is a holset?
manelscout4life is offline   Reply With Quote
 Old 02-19-2010, 12:48 PM   #29
Fagwagon's Avatar
Groans: 75
click
 Old 02-19-2010, 01:17 PM   #30
Alpha's Avatar
Is it $1600?
$1,200 plus core for a Stage II (2860 CHRA) or $1,300 for a Stage III (2871 CHRA)
That's a headache and it requires A LOT of fab work with poor reliability IMHO.
Last edited by Alpha; 02-19-2010 at 01:17 PM. Reason: MSF Database - Automerged Doublepost
The Following User Says NO Thank You to Alpha For This Un-useful Post:
 Old 02-19-2010, 01:25 PM   #31
Fagwagon's Avatar
Groans: 75
POOR RELIABILITY??? Considering there are cummins guys that run these at 30+ psi for 100s of thousands of miles with only rebuilds (which are easy as pie) i think you may be throwing that statement out there without much knowlege of the turbo itself...and btw ive spent ohhh around 1200 or less on the setup so far and ive got everything but a wastegate ready to go...this includes dp mani intake etc..
The Following User Says Thank You to Fagwagon For This Useful Post:
Alpha (02-19-2010)
 Old 02-19-2010, 01:35 PM   #32
Alpha's Avatar
Interesting, although the Hs aren't built to withstand the kind of heat we build on gasoline engines. I wish you the best man, but there's a reason why the rebuilds are so cheap.
 Old 02-19-2010, 01:44 PM   #33
phantom3's Avatar
Posts: 1,223   (View Stats)
Groans: 190
we got my buddies holset HY35 for $250. Rebuilt it for $60. and it good to 550hp on his 2.8L
Again a satment without research.
DSM have been beating the crap out of these things for a while now, and the turbo keeps coming back for more.
EDIT: search around and you'll find them on Nissans, hondas, and skylines.
My mission is to go fast.
Currently Designing:
The golden girdle of the gods
The CF "fuck your face" IM
Last edited by phantom3; 02-19-2010 at 01:46 PM. Reason: MSF Database - Automerged Doublepost
The Following User Says Thank You to phantom3 For This Useful Post:
Alpha (02-19-2010)
 Old 02-19-2010, 01:47 PM   #34
Fagwagon's Avatar
Groans: 75
you sir need to look at dsm forums.
 Old 02-19-2010, 01:52 PM   #35
phantom3's Avatar
Groans: 190
Or even the Datsun forums.hybridZ
 Old 02-19-2010, 01:55 PM   #36
Alpha's Avatar
I stand corrected guys... I still don't like the "Custom" route, but if it works for you guys then rock n roll.
 Old 02-19-2010, 02:01 PM   #37
[MSF STIG]
FORZDA 1's Avatar
Posts: 1,206   (View Stats)
I would go here Turbo Repair and get one of Bryans hybrid turbos. I have a stage 3 on the way to me. I'm going to try it before the 3071 Garrette ATP version. Bryan guarantess bolt-on and uses the CHRA from the famous "disco potoato" which is a bullet-proof plain bearing housing with a larger shaft. Nothing but good results so far. There is a thread over on 6club for more details.
Mazdaspeed 3/6 K04 Hybrid turbocharger 330WHP!!! - Mazda6 / Atenza
FORZDA 1 is offline   Reply With Quote
 Old 02-19-2010, 02:03 PM   #38
DSIT995's Avatar
Are u doing all the work urself ? cuz if u are u have more experince than I do. I know just enough to get me trouble.........
1200 is an awesome # for the setup that u've got for sure, but how long have u been working on it. This car isnt my Project car its my DD, and while I do have another car to drive when working on bigger projects( 2-3 Days), I dont want my car out of commission for a long time
FW, I cnat wait to see ur setup when ur done
 Old 02-19-2010, 02:04 PM   #39
Fagwagon's Avatar
Groans: 75
It will be done...and when i have a 380 whp ms3 for under 2000 in aftermarket i shall laugh...LOL
 Old 02-19-2010, 02:09 PM   #40
DSIT995's Avatar
Ive been talking Bryan via email and he said that he could only do a stg 2 w/ a GT2860 not the 2871. Stg3 is not available yet. I would like to see the results from urs aswell. Since I just picked up a stocker and havnt decided what to do w/ it yet
Last edited by DSIT995; 02-19-2010 at 02:11 PM. Reason: MSF Database - Automerged Doublepost
daren83 (05-12-2011)
Page generated in 0.60066 seconds with 33 queries
