Like Tree6Likes
 Old 05-03-2011, 02:36 PM   #1
08.5MS3's Avatar
Posts: 3,840   (View Stats)
Groans: 89
Hopefully Brad can chime in on this. With the restrictor bolt in place, how much less oil is the turbo seeing? And are there any detrimental effects because it may be seeing less oil?
 Old 05-03-2011, 06:57 PM   #2
bnoon's Avatar
Posts: 1,770   (View Stats)
That's the balancing act right there. If you restrict too much, you're keeping oil from the turbo. But... if the oil is pushing past the seal into the exhaust or intake, what good is that oil doing for lubrication? None.
Another point is that we're not starving the oil in the turbo housing. The volume remains the same because even with a restrictor in place, the oil feed side can easily supply MUCH more oil than will actually flow through the turbo center section itself. The same volume of oil is just under less pressure due to the restrictor. Now, important note here, that oil does sit in the center section longer before it cycles through the center section due to the pressure drop and this was one of my main concerns in researching my restrictor options. If the pressure were too low, the oil would stay in the center section too long and "cook". All you have to do to see if this is happening is send in your oil for an UOA, or Used Oil Analysis. I've sent in several and never once had any thermal breakdown on any of the many many oils I've tried.
If you believe that the oil has any issues with cooking, let it idle a full minute or more after hard runs before shutting the car off. This will do more for your oil than the difference in oil supply will.
I've run maybe 15+ thousand miles with the bolt in and 31,000+ miles total and never have an issue boosting to 19-20 psi. That extra psi cooks the oil more than my bolt will and I still have good UOA's.
blazonemore likes this.
2008.5 MS3 GT - Sold!
2013 Ford Focus SE - Sold!
2002 BMW M3 - Sold!
The Following 2 Users Say Thank You to bnoon For This Useful Post:
08.5MS3 (05-04-2011), labikesrcool (05-21-2011)
 Old 08-02-2011, 11:43 PM   #3
kkostec's Avatar
Posts: 8   (View Stats)
kkostec will become famous soon enough
Default So excited
After spending hours fighting with my stock downpipe and race pipe to pop in my Turbo XS stealthback exhaust (which is hardly stealthy but amazing nonetheless), I initiated the dreaded cloud of smoke. I just ordered a Cobb Turbo inlet pipe and restrictor bolt. Hopefully these two will resolve my issue.
kkostec is offline   Reply With Quote
 Old 09-19-2011, 03:09 PM   #4
G Sp33dy's Avatar
Posts: 337   (View Stats)
G Sp33dy is the leader of the worldG Sp33dy is the leader of the worldG Sp33dy is the leader of the worldG Sp33dy is the leader of the worldG Sp33dy is the leader of the worldG Sp33dy is the leader of the worldG Sp33dy is the leader of the worldG Sp33dy is the leader of the worldG Sp33dy is the leader of the worldG Sp33dy is the leader of the worldG Sp33dy is the leader of the world
Groaned at 7 Times in 3 Posts
how did this work out for you ^^^?
G Sp33dy is offline   Reply With Quote
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f11/smoke-idle-fixes-my-thoughts-notes-76005/
Mazda 3 MPS - Smokey exhaust - Page 1 - Jap Chat - Pistonheads This thread Refback 11-01-2015 04:17 AM
Mazda 3 MPS - Smokey exhaust -  Gassing Station - PistonHeads This thread Refback 09-08-2015 12:22 AM
HSV & Monaro Forum This thread Refback 02-16-2015 06:27 AM
Stage 3, Blown Turbo Seal, now what?? - Page 4 Post #31 Pingback 11-10-2014 06:08 PM
Central Ohio Chat Thread - Page 18 Post #31 Pingback 06-11-2014 08:25 AM
?????????? - ??????? (??????????, ???????, ??????) This thread Refback 03-28-2014 09:42 PM
Mazda 3 MPS - Smokey Auspuff - Pistonheads This thread Refback 01-14-2013 10:20 AM
Mazda 3 MPS - Smokey exhaust - PistonHeads - PistonHeads mobile This thread Refback 12-20-2012 09:58 AM
MPS 6 / tyhjäkäynnin kierrosten nosto (versatuner tms?) This thread Refback 12-20-2012 06:13 AM
Mazda 3 MPS - Smokey exhaust - PistonHeads This thread Refback 12-16-2012 12:20 PM
Mazda 3 MPS - Smokey exhaust - PistonHeads This thread Refback 11-12-2012 12:05 PM
Mazda 3 MPS - Smokey exhaust This thread Refback 07-16-2012 02:10 AM
Mazda 3 MPS - Smokey exhaust This thread Refback 04-06-2012 09:46 AM
Mazda 3 MPS - Smokey exhaust - PistonHeads mobile This thread Refback 04-02-2012 01:21 PM
Mazda 3 MPS - Smokey exhaust This thread Refback 04-01-2012 01:09 PM
smoke on idle? kraz3y MazdaSpeed 3/6 - Turbo Induction 20 01-09-2013 03:26 AM
Thoughts on venting the oil return line, another possible smoke fix? bnoon MazdaSpeed 3 - Engine, Transmission & Driveline 6 12-10-2010 09:36 AM
idle smoke getting serious Chriscote MazdaSpeed 6 - Engine, Transmission & Driveline 16 11-03-2010 01:43 PM
Smoke at idle sleeper329 MazdaSpeed 3 - Engine, Transmission & Driveline 8 06-13-2010 01:56 PM
smoke at idle ms3-87 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 12 05-31-2008 01:15 PM
Page generated in 0.28979 seconds with 24 queries
