 Old 01-02-2009, 07:09 PM   #81
personally i like to see all this progress. its fun to see pictures and work out details along the way. what if sean comes across a problem and needs some advice? technically we are all testing this manifold as we are giving our opinions to further improve it. carry on!!
 Old 01-03-2009, 10:58 AM   #82
socks's Avatar
Posts: 3,250   (View Stats)
Groans: 125
Its on.
Man, i dont know how you guys like the sound of an open wastegate dump. sounds like shit.
i have some tuning issues to work out. And a few more pics... you can see how much i had to cut off the studs on the head. the size to get those studs out is an e8. same socket as to get the fuel pump off.
The Following 3 Users Say Thank You to socks For This Useful Post:
802MS3 (01-03-2009), mdogg (01-04-2009), y2kc0wb0y (01-15-2009)
 Old 01-03-2009, 11:13 AM   #83
Eth/Meth Junkie
cld12pk2go's Avatar
Posts: 2,998   (View Stats)
Steed
I would recommend modifying the design to allow more room to get at the nuts.
It appears Speed3shon was forced to use the open end of the wrench due to insufficient room to get the closed end in on some of the nuts, and they are partially rounded off as a result.
Just my 0.02.
 Old 01-03-2009, 11:18 AM   #84
rabble rabble
802MS3's Avatar
Posts: 5,318   (View Stats)
Groans: 221
are you going to have a new downpipe worked out, or just leave it dumping?
'08 CWP MS3 w/ T3 3071r
 Old 01-03-2009, 11:31 AM   #85
steedspeed's Avatar
Posts: 582   (View Stats)
Steed
Just my 0.02.
I think the factory nuts and studs will need to be changed for something less bulky in those 2 locations. I'll source ARP studs and nuts etc and include them with the manifolds. How far are they threaded into the head? 10mm fine or coarse thread?
Thanks for the great work Sean and keep the pics coming + let us know on the wastegate pipe arrangement.
 Old 01-03-2009, 11:35 AM   #86
Eth/Meth Junkie
cld12pk2go's Avatar
That would be an excellent upgrade. I unfortunately do not know the answers to your questions.
Keep up the great work. Some of us have been through the prototyping path before and understand that you are doing an excellent job. Please keep sharing.
If I didn't already have a PG manifold, I would certainly be in line to get yours.
 Old 01-03-2009, 12:49 PM   #87
socks's Avatar
Groans: 125
having this thing dumping is not an acceptable noise level. Since i will be getting a production manifold, i will be holding off on a recirc tube until i get that.
I will just have to lay off the boost until that happens, which should be easy enough, my motor build parts will be here soon.
-Sean
 Old 01-03-2009, 12:58 PM   #88
MS6_Auburn_Fan's Avatar
Posts: 481   (View Stats)
MS6_Auburn_Fan is the leader of the worldMS6_Auburn_Fan is the leader of the worldMS6_Auburn_Fan is the leader of the worldMS6_Auburn_Fan is the leader of the worldMS6_Auburn_Fan is the leader of the worldMS6_Auburn_Fan is the leader of the worldMS6_Auburn_Fan is the leader of the worldMS6_Auburn_Fan is the leader of the worldMS6_Auburn_Fan is the leader of the worldMS6_Auburn_Fan is the leader of the worldMS6_Auburn_Fan is the leader of the world
Do you have a dump pipe connected to the waste gate? A dump pipe though still loud will probably make it a little more bearable as it would be under the car.
MS6_Auburn_Fan is offline   Reply With Quote
 Old 01-03-2009, 01:18 PM   #89
steedspeed's Avatar
I agree. Its loud right now because the wastegate is dumping inside the engine bay. My Civic had a pipe routed out the side through a hole in the fender and it wasn't bad at all as the noise goes away from the car.
 Old 01-03-2009, 03:50 PM   #90
phantom3's Avatar
Posts: 1,223   (View Stats)
Groans: 190
Originally Posted by Speed3shon View Post
no worries. i know to expect things like this. but you also know to hear it from me.
LBV,
this is not a QC problem. The holes on the wastegate flange are not tapped through because they must have been tapped after being welded to the flange, and you need a special tap to tap the hole through, as the clearance on the back side doesnt allow for a normal tap to tap through. This is a prototype afterall.
As I said, this adapter is choice otherwise. I have no problem with having to make small adjustments as the test fitter. The production manifolds im assuming will have a relocated EWG flange rather than use an EWG relocating adapter. So there should be no worries on your end.
-Shon
FYI: It's not really a "special" Tap... It's just a bottoming tap. Most cheep tap & die kits only come with the tapered taps. http://www.stuartmodels.com/images/a...50-72061lg.jpg (notice that the thread is not fully formed until roughly half way up the tap). Not a problem if you have room to run the tap all the way through.
Bottoming taps are for holes that are "blind" (not through the work piece) or holes that have little back clearance such as the EWG flange. http://www.armacoil.com.sg/Enlarged%...oming-Plug.jpg (Notice the threads are fully formed after roughly 2 threads).
Chances are the machinist grabbed the wrong style tap by accident (I have done it before). It's by no means even remotely a tiny problem as it only takes 30sec (IF that) to run a bottoming tap through the hole to form the last couple threads. Minor error easily fixed.
Note: A taper tap should be use before a bottoming tap when hand taping, as a bottoming tap requires more torque and is more likely to break when running full hole. A taper tap is also easier to square up to hole hole, as the is more play in it.
-David
 Old 01-03-2009, 06:34 PM   #91
bf360's Avatar
Posts: 2,069   (View Stats)
can you take a vid? ive never heard a wastegate too loud lol
bf360 is offline   Reply With Quote
 Old 01-03-2009, 06:37 PM   #92
socks's Avatar
Groans: 125
No thank you, Id rather people not know how shitty my car sounds right now :-P
 Old 01-03-2009, 06:38 PM   #93
socks's Avatar
Groans: 125
-David
Thanks for the info, i know this, but was just too lazy to type it all out. But as you said, most sets come with tapered taps.
The Following User Says Thank You to socks For This Useful Post:
phantom3 (01-21-2009)
 Old 01-03-2009, 06:46 PM   #94
whoosh@Realtune's Avatar
Posts: 1,459   (View Stats)
whoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the world
Groaned at 39 Times in 23 Posts
your car probably doesn't sound very good because you don't have your dump pipe on yet
dumping right out of the EWG in the engine compartment will sound crappy
once you have the dump redirected back into the D/P or at least 12-14" screamer pipe pointing toward the ground, the sound will be sweet
2006 Mazdaspeed 6 / 386awhp/376awtq (Aug 2008)
2008 Caliber SRT4 / 11.8 @ 120
whoosh@Realtune is offline   Reply With Quote
The Following User Says Thank You to whoosh@Realtune For This Useful Post:
Darksun280 (01-03-2009)
 Old 01-14-2009, 09:46 PM   #95
Miembro
nighthawk358's Avatar
Posts: 725   (View Stats)
nighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the world
Groans: 27
i love the vented sound
2008.5 MS3 Metro Gray...slow
nighthawk358 is offline   Reply With Quote
 Old 01-15-2009, 11:18 AM   #96
aamguy's Avatar
Posts: 63   (View Stats)
aamguy has a brilliant futureaamguy has a brilliant futureaamguy has a brilliant futureaamguy has a brilliant futureaamguy has a brilliant futureaamguy has a brilliant futureaamguy has a brilliant futureaamguy has a brilliant futureaamguy has a brilliant futureaamguy has a brilliant futureaamguy has a brilliant future
if the sound is really that bad you could dump it back into the downpipe.
aamguy is offline   Reply With Quote
 Old 01-15-2009, 12:31 PM   #97
yoichi's Avatar
Posts: 557   (View Stats)
yoichi is the leader of the worldyoichi is the leader of the worldyoichi is the leader of the worldyoichi is the leader of the worldyoichi is the leader of the worldyoichi is the leader of the worldyoichi is the leader of the worldyoichi is the leader of the worldyoichi is the leader of the worldyoichi is the leader of the worldyoichi is the leader of the world
I suggest you dump it back like myself. Even w/ the screamer pipe, you will like it for the first couple of month but......It will eventually get to you.
With it recirculated, you will slightly hear it. You will also hear the sweet whine of your turbo more.
2003 E39 ///M5
yoichi is offline   Reply With Quote
 Old 01-15-2009, 01:11 PM   #98
socks's Avatar
Groans: 125
how much did your WG work cost? im getting slightly high quotes around here
 Old 01-15-2009, 05:33 PM   #99
Fux Wit It
Darksun280's Avatar
Posts: 9,214   (View Stats)
Groans: 175
if you couldn't hear your turbo over your WG means it wasn't big enough.
GT42r's can correct this sound quality issue for you.
Carry on citizens....
10.7 @ 133 auto 1G DSM
The Following 4 Users Say Thank You to Darksun280 For This Useful Post:
aaronc7 (01-15-2009), mdogg (01-15-2009), phantom3 (01-21-2009), Smoker6 (01-15-2009)
 Old 01-15-2009, 06:27 PM   #100
socks's Avatar
Groans: 125
I was going to have the re-route tube made today or tomorrow, but the shop didnt have the flanges available, so i had to pick them up from atp. I ordered 3 flanges. One will go very close to the downpipe, so that the reroute tube is removable to make the dp easier to remove.
I will have the work done when i get back from costa rica in february.
 Old 01-15-2009, 07:26 PM   #101
bombdotcom's Avatar
Posts: 816   (View Stats)
bombdotcom is the leader of the worldbombdotcom is the leader of the worldbombdotcom is the leader of the worldbombdotcom is the leader of the worldbombdotcom is the leader of the worldbombdotcom is the leader of the worldbombdotcom is the leader of the worldbombdotcom is the leader of the worldbombdotcom is the leader of the worldbombdotcom is the leader of the worldbombdotcom is the leader of the world
Groaned at 40 Times in 20 Posts
when are we expecting this to be available leen?
(RIP) 08' MS3---MODS:COBB AP- COBB SRI AND TIP- COBB RSB- COBB KNOB- CP-E TMIC- LIMITED EDITION HKS BOV- CORKSPORT DP AND TP- TRZ REARMOUNT- MD OCC- PTP IM COOLER KIT- COSWORTH BSD- EIBACH PROKIT- TWM SHIFTER BUSHINGS- JBR SHORT SHIFT KIT-
13' CWP MS3
bombdotcom is offline   Reply With Quote
 Old 01-15-2009, 07:43 PM   #102
ATE BALLER's Avatar
Posts: 3,227   (View Stats)
can i has 1 yet?
Originally Posted by StreetUnitMark View Post
I don't think I could go one day without some sort of meat in my mouth.
ATE BALLER is offline   Reply With Quote
 Old 01-15-2009, 08:17 PM   #103
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
Please post some pics of it before you install, I'm sure you will regardless. Gonna have such a nice setup mang.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
 Old 01-16-2009, 08:28 AM   #104
socks's Avatar
Groans: 125
the manifold? its already installed. or you mean the reroute tube? someone is making it for me, so i'd have to take it off to have pics of it uninstalled.
 Old 01-16-2009, 11:02 AM   #105
steedspeed's Avatar
If someone can get me a DP and a stock turbo (blown is fine) I can make up some downpipes with the wastegate routed into the DP.
 Old 01-16-2009, 11:13 AM   #106
ATE BALLER's Avatar
If it's too loud for you, use a motorcycle muffler and dump it out the bottom.
 Old 01-16-2009, 11:14 AM   #107
kingpin748's Avatar
Posts: 2,611   (View Stats)
kingpin748 is the leader of the worldkingpin748 is the leader of the worldkingpin748 is the leader of the worldkingpin748 is the leader of the worldkingpin748 is the leader of the worldkingpin748 is the leader of the worldkingpin748 is the leader of the worldkingpin748 is the leader of the worldkingpin748 is the leader of the worldkingpin748 is the leader of the worldkingpin748 is the leader of the world
Groans: 78
Groaned at 48 Times in 31 Posts
I got a stock DP here in Calgary. Are you going to ruin it?
In reality I love lenny
kingpin748 is offline   Reply With Quote
 Old 01-16-2009, 11:58 AM   #108
steedspeed's Avatar
Not at all. I just need to set up a jig to locate the manifold, turbo, downpipe and wastegate so I can establish the relative positions and create a custom pipe that follows the same path and will meet the stock exhaust system.
 Old 01-16-2009, 12:21 PM   #109
bombdotcom's Avatar
i have a stock dp u can have leen, whatever makes this thing come out faster!
13' CWP MS3
 Old 01-16-2009, 02:13 PM   #110
ATE BALLER's Avatar
I can send you my stock MS6 dp. Would you be willing to trade it for a T3 mani and the right sized studs?
 Old 01-16-2009, 02:59 PM   #111
Fux Wit It
Darksun280's Avatar
Groans: 175
ms6 guys have it easy ATP already makes a DP with a vband on it. I woulda been done with my project weeks ago if i had an Ms6
 Old 01-17-2009, 05:14 AM   #112
steedspeed's Avatar
Looks like I have the DP sorted with Kingpin being a short drive from me. All I need now is a stock turbo to mock the rest of it up. A blown turbo would be perfect. If you are thinking about getting my manifold and can help with this you get the prototype downpipe $0.
 Old 01-19-2009, 07:43 PM   #113
Rich's Avatar
Posts: 10   (View Stats)
Rich is an unknown quantity at this point
In response to your made-to-order policy, are T25 inlet / C5 outlet flanges for non-ATP GT28s going to be an option? A C5 flanged DP w/ EWG dump pipe would be great.
Too many for the much-too-short signature size.
Rich is offline   Reply With Quote
 Old 01-20-2009, 04:56 PM   #114
steedspeed's Avatar
With the latest design changes I can send you a manifold with a separate turbo flange which can be switched at any time for another flange of your choice.
 Old 01-20-2009, 05:57 PM   #115
ugh recir'd EWG FTL..........
Darksun280 (01-20-2009)
 Old 01-21-2009, 08:20 AM   #116
rabble rabble
802MS3's Avatar
Groans: 221
why not like?
 Old 01-21-2009, 12:44 PM   #117
Rich's Avatar
That's good news! Not sure on the DP yet?
 Old 01-21-2009, 12:52 PM   #118
bf360's Avatar
nice i can get it for stock turbo now, and if i upgrade i can use the same manifold with any turbo
 Old 01-22-2009, 09:50 AM   #119
steedspeed's Avatar
I can make them no problem but I need a stock turbo and downpipe to work with.
 Old 01-22-2009, 11:32 AM   #120
ATE BALLER's Avatar
I passed my emissions test last night (no cats either, lol), so I can send you my stock dp whenever. I'd want the new one set up for a BW S366 turbo though. I don't remember if those are 4-bolt or v-band. PM me your address when you get a moment.
-Andy
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f11/steed-has-arrived-17617/
Mazda6 / Atenza > Steedspeed Exhaust Mani. This thread Refback 01-20-2009 04:21 PM
Steedspeed Exhaust Mani. - Mazda6 / Atenza This thread Refback 01-19-2009 09:13 AM
new toy just arrived cbspeed3 MazdaSpeed 3 - Engine, Transmission & Driveline 13 12-14-2008 07:55 PM
Stickers Arrived! Haltech Automotive News 0 11-06-2008 06:43 PM
They've arrived! Alex Roy, Damon and crew about to cross Bay Bridge Haltech Automotive News 0 08-14-2008 11:10 AM
Cobb STS Has Arrived! Haltech MazdaSpeed 3 - Engine, Transmission & Driveline 30 07-13-2008 08:39 PM
Page generated in 0.57628 seconds with 38 queries
