![]() Join Date: May 2009 Location: Georgia
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 24
(Thread Starter) | Not Ranked : 0 score Can a reworked turbo handle more? What is the stock boost pressure of the stock turbo? How much hp/torque gain is there 1,2,3 psi gain in boost pressure?
__________________ 2006 Mazdaspeed6 Sport - Black Cherry Mica Sure Aeros Short Ram Intake | Stage 1 SF +93 AP Map | 3.25 TMIC | Cobb Tuning Turbo Inlet Pipe | Turbosmart Hybrid BOV | Magnaflow catback Exhaust | ATP High Flow Catted Downpipe | Steedspeed Exhaust Manifold Ceramic Coated | ACT Clutch and Flywheel | Black JDM LED Tailights | CPE Rear Engine Motor Mount | SU Solid Shifter Spacers | Denso 2 Step Colder Spark Plugs | SU Boost Tubes |
![]() Join Date: Jan 2009 Location: PHX/SV AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 772
Groans: 94
Groaned at 43 Times in 33 Posts
A reworked turbo can handle more boost more efficently. Stock boost is 15.6 PSI it depends on the mods you have, there is no set PSI gain.
__________________ 321 HP/348TQ-- 13.940 @ 106 /3kft ASL | |
![]() Join Date: Apr 2008 Location: NoVA
Rep Power: 998 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 167
Groaned at 86 Times in 65 Posts
| Not Ranked : 0 score The stock turbo is pretty limited. You can turn it up a bit but it is already getting hotter and hotter as you go. Everyone seems to run about 18psi. The turbo is too small for this motor.
__________________ -JEWBERT |
![]() Join Date: Mar 2008 Location: Oceanside, CA
Rep Power: 2852 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 676
Groans: 106
| Not Ranked : 0 score ask darksun how high you can go......lol
__________________ 13.2@111 CP-E Nano, CP-E Inlet, CP-E catless DP, CP-E Standback V2, CPE FullThrottle/No Cut Flash, CP-E FMIC, CP-E CDFP, CP-E HKS BPV, TRZ Poly MM, E4P Shifter, Denso Iridium ITV22 plugs, CP-E Towplate, PG V3 Manifold w/EGT bung, Saikou Michi OCC, EGR delete, BSD w/oil baffle, BC Coilovers w/front camber adjustment, SPC rear arms, 17x8 Anthracite O.Z. Alleggerita's wrapped in Nitto NT01's
http://jpnutritionandfitness.blogspot.com/ Sponsored By: CP-E | |
| The Following User Says Thank You to SgtP For This Useful Post: | phillyb (07-15-2009) |
![]() Join Date: May 2009 Location: Weston, FL
Rep Power: 0 ![]() ![]() Thanks: 9
| Not Ranked : 0 score Reworked or upgraded turbo? What is better? |
![]() Join Date: Mar 2008 Location: Pittsburgh, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17,174
Groans: 45
| Not Ranked : 0 score so i shouldn't have mine set for 30psi? |
![]() Join Date: Jan 2009 Location: Columbus Ohio
Rep Power: 1087 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,958
Groans: 27
| Not Ranked : 0 score it's also a factor of just how reworked you go - there are some folks out there now doing completely different guts to the k04 housings (for a price in between what you pay for pg's and a whole new garrett gt series) - with a total rebuild like that you may actually enter the situation where you can make more hp with less amounts of boost because the air is being moved and shaped in a whole new way
__________________ 08 CB MS3 Sport Sold 01 MX-5 (Project) 03 P5 (DD) |
| The Following User Says Thank You to cpolly69 For This Useful Post: | SpeedSixxx (07-16-2009) |
Probably greater than 30psi, provided that there is enough restriction. Probably greater than 40psi, provided that there is enough restriction. 15psi For what size pipe diameter, air temp, humidity, intercooler efficiency, a/f ratio, compression ratio, intercooler pressure drop, exhaust manifold to dp pressure differential, and rpm? Actually the answer is not much hp is gained for the wear and tear added. The engine produces around 120hp n/a at a absolute pressure of 14.7psi, 120/14.7= ~8 * 3psi = 24 crank hp * .8 correction factor for drivetrain loss = ~20whp for 3psi. Assuming all the above factors stay the same, which they dont.
__________________ 2006 Mazdaspeed 6 P&P, flow benched, head with welded EGR and +1mm inconel exhaust valves (260/200cfm @ .500"), Web Cams, Custom crankcase breather with integrated air/oil seperator, Custom 3/4" ID pan vac system, Blow through maf, Port matched IM, CNC AN-12 ORB block oil adapter, CP-e 88mm Stage 2 pistons, Pauter 22.5mm rods, ARP main, head, and crank studs, CP-e injector seals, Injector stud kit, Cometec 88mm 5 layer HG, Deatschworks flow tested matched injectors, DCR VVT, PTP 2250psi RV, Corksport front sway, Whiteline rear sway, AWR front/rear sway links, TT FMM, AWR 70d DMM, JBR 80D PMM, SU RMM, TT FRDM, CP-e RRDM, Autotech CDFP, DW65c ITFP, Custom L/A IC with a dual pass 20x25x1.5 heat exchanger, Dual Cobra I/C pumps, 2.5" ID 700hp I/A intercooler, Custom DP, Corksport catback, Corksport exhaust hangers, chrome plated genpu valve cover, chrome plated timing cover, Spin on oil filter, Fluidyne dual pass AN-12 oil cooler, Hayden oil cooler fan controller, Dual 4.7" SPAL oil cooler fans, Canton Racing 22-480 oil tstat, Custom BMRS AN-12 oil lines, SPC ball joints, 55w/35w headlights and independently switched fogs on custom waterproof harnesses, PIAA Super Plasma driving and interior lights, rear diff cutout switch, 3M clear front cover, Volk 17x7.5 wheels, Custom tcase bearing cap upgrade, GS EBC 3 port, Redline SS hood lift, Versatune, Defi gauges, Innovate MTX-L WB gauge, triple center gauge pod, Block8head dual vent pod, Redline shift boot & ebrake cover & arm rest cover, Mazdaspeed CF ebrake handle, SBC Full Face Feramic Clutch Disc, Dashawk, ACL rod bearings, King main bearings, Cosworth BSD, Custom windage tray, Holset HX35w, Creative Performance T3 EWG manifold, HKS VTA BOV, A1 H11 head studs, Hylomar HG sealant, SSP EGR delete plate, JBR EGR IM plug, JGS 40mm Race EWG | |
Groans: 60
| Not Ranked : 0 score Seven The answer to all of your questions is Seven.
| The Following 2 Users Say Thank You to SSinstaller For This Useful Post: | meicalnissyen (04-04-2017), SharkDiver (07-14-2009) |
Groans: 27
| Not Ranked : 0 score and a half
| Not Ranked : 0 score I am looking into gutting in my stock K04. Does anyone know any place that does this? |
![]() Join Date: Jul 2009
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 11
| Not Ranked : 0 score Try this link, PT-Performance.com they claim efficiency to 24psi. i have a reworked PG turbo I run at 20-21psi with no problems for 17k miles. Never dynoed it but seat on the pants says 20 pulls harder than 18psi. |
| Not Ranked : 0 score My bad ,efficiency to 25.5psi for the PT- performace turbo as stated on their website. |
Groans: 27
![]() Join Date: Dec 2008 Location: Harrisburg, pa
Groaned at 7 Times in 5 Posts
| Not Ranked : 0 score wow this thread feels like 24/7............. |
| The Following User Says Thank You to sleeperstang1994 For This Useful Post: | phillyb (07-15-2009) |
![]() Join Date: Sep 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 145
| Not Ranked : 0 score All of the reworked stockers are of the same idea. Efficient to 25.x psi, larger wheel, stock housing, P&P, 270* bearing instead of a 90*.
__________________ All wagon, No traction |
![]() Join Date: Jun 2008 Location: NW Indiana
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 361
__________________ Pauter rods,Cp pistons 9.5:1 @ .020 over,ARP head & main studs,DNP ceramic coated exhaust mani.,TXS Dp,TXS Tp with high flow cat,PG reworked turbo,Cobb sri,Cobb fmic,Cobb Ap,Cobb inlet,HPFP,BSD,ACT street disk with light flywheel,TWM shifter bushing,rear MM,Oil CC and 1 step colder plugs and more http://videos.streetfire.net/profile/SharkDiver.htm http://www.youtube.com/user/sharkdiverjohn | |
Groans: 27
| Not Ranked : 0 score actually i talked to bryan at bnr that is building these - it will remain a journal bearing and not a ball bearing if that's what you mean but he will be using a totally different type of seal then what the stock setup or pg uses - so even if someone didn't get the pcv fix that's coming (which is the real source of the oil leaking problem) they could still use this turbo and hopefully not leak - all the other internal parts will be upgraded - not just the compressor wheel - as this price point is really in between pg's rework and a gt2871 (don't forget your inlet doesn't fit a gt2817) you are really getting what you are paying for - i am looking forward to the results of the first few folks who get one of these as he plans to do even bigger power later on - vw's use and build the k series turbos with great results - the big reason a lot of folks bailed on them in the mazda community is b/c of the leaking oil seal issue
| The Following User Says Thank You to cpolly69 For This Useful Post: | SharkDiver (07-17-2009) |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 20
Groaned at 299 Times in 34 Posts
| Not Ranked : 0 score |
| The Following 4 Users Say NO Thank You to zamdam For This Un-useful Post: |
![]() Join Date: Feb 2009 Location: Tampa, Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 503
| Not Ranked : 0 score wrong its 42 the answer to life, the universe, and, well, everything
__________________ A democracy, in its purest form, is well represented by a group consisting of 2 wolves and 1 rabbit. Voting on what to have for lunch |
![]() Join Date: Oct 2014 Location: Crofton, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3
Sent from my Nexus 5X using Tapatalk
__________________ 2007 True Red MS3 GT - AP V3 - BNR S4 - eBay DP - JBR Tru 3.0 - TR8 FMIC - TS BPV - Autotechs - JBR EBCS - 3 BAR - JBR PMM - CS RMM - CS Shift Plate - DM OCC - Koni Yellows - Eibach Pro-Kit - Enkei Evo Xs - Freektuned | |
![]() Join Date: Aug 2013 Location: Ft Myers, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 34
At least he quoted a decent movie/ book. Still... shame. Sent while probably pooping
__________________ CS TIP/SRI CS RMM CS Sexy Steering Wheel CS Springs & Struts CS Shirt Throw Shifter CS Shifter Bushings CS TBE CS Boost Tubes CP-e TMIC HKS BOV in resirc DM Vented OCC DM TMM DM PMM DM SSP Autotech Internals Custom E33 Freaktune | |
![]() Join Date: Mar 2011 Location: Dallas, Texas
| Not Ranked : 0 score I've only been able to get 41
__________________ Max Bolted and Built Stock K04 |
![]() | | #24 | ![]() |
![]() Join Date: Nov 2015 Location: Raleigh, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 29
| Not Ranked : 0 score Highly underrated movie.
__________________ AP v3 -- Autotech -- HTP 3.5" Intake -- CS BPV -- JBR SSP -- COBB Shift Knob -- H&R RSB -- Custom E-cutout -- CP-e TMIC -- JBR IC Piping -- JBR Coolant Bypass -- DM TIGs -- CP-e DP -- JBR EGR Delete -- AEM 30-3000 WMI -- Akebono Ceramics -- Centric High Carbon Rotors -- s204 Lip "The mind is like a parachute, it only works when open" |
![]() | | #25 | ![]() |
![]() Join Date: Oct 2012 Location: Colorado Springs, CO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 757
__________________ mods: \\// AT HPFP // AccessPort // CS S2 TIP, SRI and TMIC // CPe S2 RMM // Synapse BPV // Mazda gutted secondary cat // S-OTS+ 91S2 // HKS TP DLi II // Wilwood DP6 13” brakes // TCE 2 piece rear rotors // Maxwell SuperCap/LiFePO4 cell \\// waiting for install: \\// CPE Catted DP // CS Battery Box // Devils Own Meth kit // H&R Coilovers \\// |
![]() | | #26 | ![]() |
| Not Ranked : 0 score I wonder if Alans last words were, so long, and thanks for all the fish
![]() | | #27 | ![]() |
![]() Join Date: Aug 2009 Location: Bryan/College Station, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 137
__________________ 2009 Mazdaspeed with 134,000 miles, Corksport Turbo, AT internals, CNT Turbo Back, AP, fully mounted, 3 bar, Freaktuned E25. |
| Turbo Mani & Boost | badams118 | MazdaSpeed 3/6 - Turbo Induction | 7 | 04-13-2009 12:23 PM |
| how much boost can your stock turbo hold? | johnac08 | MazdaSpeed 3/6 - Turbo Induction | 16 | 03-18-2009 01:12 PM |
| Big Turbo, Stock Boost Control | Laloosh | MazdaSpeed 3/6 - ECU Computer Tuning | 30 | 12-30-2008 04:57 AM |
| Should've bought a Garmin? Testing the iPhone 3G's GPS capabilities | Haltech | Automotive News | 0 | 07-14-2008 10:50 AM |
